[PATCH 0/2] microblaze: libbsd support
Alex White
alex.white at oarcorp.com
Tue Jan 4 18:10:54 UTC 2022
This patch set adds support for libbsd to the MicroBlaze BSPs and contains fixes
for issues found while debugging the rtems-libbsd telnetd01 test in QEMU and on
the Xilinx KCU105 board.
Alex White (1):
microblaze: Add support for libbsd networking
Jennifer Averett (1):
microblaze: Add support for libbsd.
.../microblaze_fpga/dts/microblaze-dtb.c | 963 ++++++++++++++++++
.../microblaze/microblaze_fpga/dts/system.dts | 452 ++++++++
bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c | 22 +
bsps/microblaze/microblaze_fpga/include/bsp.h | 9 +
bsps/microblaze/microblaze_fpga/irq/irq.c | 2 +-
.../microblaze_fpga/start/bspstart.c | 6 +
.../start/microblaze_enable_dcache.S | 20 +
.../start/microblaze_enable_icache.S | 20 +
.../start/microblaze_invalidate_dcache.S | 29 +
.../start/microblaze_invalidate_icache.S | 28 +
cpukit/score/cpu/microblaze/cpu.c | 1 -
cpukit/score/cpu/microblaze/cpu_asm.S | 4 +-
.../bsps/microblaze/microblaze_fpga/grp.yml | 12 +
.../bsps/microblaze/microblaze_fpga/obj.yml | 6 +
.../microblaze_fpga/optdcachebaseaddress.yml | 18 +
.../microblaze_fpga/optdcachelinelen.yml | 17 +
.../microblaze_fpga/optdcachesize.yml | 17 +
.../microblaze_fpga/opticachebaseaddress.yml | 18 +
.../microblaze_fpga/opticachelinelen.yml | 17 +
.../microblaze_fpga/opticachesize.yml | 17 +
20 files changed, 1673 insertions(+), 5 deletions(-)
create mode 100644 bsps/microblaze/microblaze_fpga/dts/microblaze-dtb.c
create mode 100644 bsps/microblaze/microblaze_fpga/dts/system.dts
create mode 100644 bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_enable_dcache.S
create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_enable_icache.S
create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache.S
create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optdcachebaseaddress.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optdcachelinelen.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optdcachesize.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opticachebaseaddress.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opticachelinelen.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/opticachesize.yml
2.27.0
