[RSB 5 PATCH v2] tools/rtems-tools-5-1: Bump hash
Ryan Long
ryan.long at oarcorp.com
Wed Jan 5 22:41:33 UTC 2022
Bump up the hash so that the recent mailer changes can be used.
rtems/config/tools/rtems-tools-5-1.cfg | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-5-1.cfg b/rtems/config/tools/rtems-tools-5-1.cfg
index 5fb3346..3be7a29 100644
--- a/rtems/config/tools/rtems-tools-5-1.cfg
+++ b/rtems/config/tools/rtems-tools-5-1.cfg
@@ -10,14 +10,14 @@
%define rtems_tools_source rtems-tools-%{rtems_tools_version}
%define rtems_tools_ext xz
%else
- %define rtems_tools_version 0a5d2057749066e7d184836e92c7ce5334fccc90
+ %define rtems_tools_version e6a4bc55959d884e9889a76d360b6bfc3de138a1
%define rtems_tools_ext bz2
%endif
%source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
%hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
- QsjquFu8FJOKDKpa6jXRuJ3HE8/h9YGAenvddcTCAGmHB57VGd54jFXUaxhwRbohlS1rrrL610ulbhf2IzOxYw==
+ sDjV6Gz4Yn6HodB9D2anthZ9HMDm35iWw40zs2OFzZKlaTxFOP7Bz01PriCejrnABxar/t3AnwKrdvzzj97ywA==
# Optionally enable/disable building the RTEMS Tools via the command line.
1.8.3.1
