[PATCH 0/3] aarch64: boot in to EL1NS
Gedare Bloom
gedare at rtems.org
Thu Jan 6 22:22:30 UTC 2022
rtems-test results for xilinx-zynqmp_lp64_qemu with RTEMS_SMP:
Passed: 632
Failed: 5
User Input: 5
Expected Fail: 0
Indeterminate: 3
Benchmark: 3
Timeout: 1
Test too long: 1
Invalid: 0
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Wrong Header: 0
Total: 650
Failures:
spintrcritical24.exe
smpschededf01.exe
smpmrsp01.exe
spintrcritical21.exe
smpschedaffinity02.exe
On Thu, Jan 6, 2022 at 3:13 PM Gedare Bloom <gedare at rtems.org> wrote:
> This patch series resolves a lingering problem with the
> aarch64 port for the versal, which uses gicv3, that it
> is not possible to initialize the GIC distributor and
> redistributor (cpuif) while in the non-secure world.
> Previously we added a configuration option to allow
> running RTEMS in secure world as a way to overcome
> this problem, but that is not the right thing to do
> in general. Only trusted firmware is expected to run
> in secure world, and it is not supported to run an SMP
> kernel in secure world, so this problem needs a different
> fix.
> We now use the bsp_start_hook_0 to initialize the GIC from
> EL3 secure before stepping down to EL1NS.
> This hook is only called when execution begins in EL3S, which is the
> case for the versal running on qemu. GIC initialization is still
> attempted again during the generic IRQ initialization. BSPs that
> start in EL2 or EL1, or that use gicv2, behave as before, but the
> BSP-specific SMP initialization for xilinx-zynqmp moves from hook_0
> to hook_1.
> rtems-test results for xilinx-versal_lp64_qemu:
> Passed: 578
> Failed: 2
> User Input: 5
> Expected Fail: 0
> Indeterminate: 0
> Benchmark: 3
> Timeout: 1
> Test too long: 2
> Invalid: 0
> Wrong Version: 0
> Wrong Build: 0
> Wrong Tools: 0
> Wrong Header: 0
> Total: 591
> Failures:
> sp69.exe
> rtems-test results for xilinx-zynqmp_lp64_qemu:
> Passed: 577
> Failed: 1
> User Input: 5
> Expected Fail: 0
> Indeterminate: 3
> Benchmark: 3
> Timeout: 1
> Test too long: 1
> Invalid: 0
> Wrong Version: 0
> Wrong Build: 0
> Wrong Tools: 0
> Wrong Header: 0
> Total: 591
> Failures:
> Gedare Bloom (3):
> bsps/aarch64: refactor register init and hooks
> arm/gicv3: refactor DIST initialization to helper
> aarch64: always boot into EL1NS
> bsps/aarch64/shared/start/start.S | 127 ++++++++++--------
> .../xilinx-versal/start/bspstarthooks.c | 3 +-
> .../xilinx-zynqmp/start/bspstarthooks.c | 12 +-
> bsps/shared/dev/irq/arm-gicv3.c | 75 +++++------
> spec/build/bsps/aarch64/a53/grp.yml | 2 -
> spec/build/bsps/aarch64/a72/grp.yml | 2 -
> spec/build/bsps/aarch64/optisns.yml | 20 ---
> spec/build/bsps/aarch64/xilinx-versal/grp.yml | 2 -
> spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml | 2 -
> 9 files changed, 109 insertions(+), 136 deletions(-)
> delete mode 100644 spec/build/bsps/aarch64/optisns.yml
> 2.25.1
