New validation test suites
Sebastian Huber
Tue Jan 11 16:09:44 UTC 2022
Hello,
I implemented the new Interrupt Manager directives for the powerpc/qemu
BSPs. The new validation tests pass now on real hardware (MVME2500).
Passed: 662
Failed: 3
User Input: 5
Expected Fail: 1
Indeterminate: 0
Benchmark: 3
Timeout: 0
Test too long: 0
Invalid: 0
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Wrong Header: 0
Total: 674
Failures:
libfdt01.exe.img
spintrcritical21.exe.img
minimum.exe.img
User Input:
top.exe.img
fileio.exe.img
capture.exe.img
monitor.exe.img
termios.exe.img
Expected Fail:
psxfenv01.exe.img
Benchmark:
whetstone.exe.img
linpack.exe.img
dhrystone.exe.img
Average test time: 0:00:13.517023
Testing time : 2:31:50.473792
I fixed the setjmp() and longjmp() for some powerpc multilibs so that
the new validation tests pass on the powerpc/psim simulator except the
test for the Interrupt Manager (ts-validation-intr.exe). The
powerpc/psim BSP uses a legacy interrupt controller support and I don't
have time to convert this. I simply marked the test as "expected-fail".
A test run for i386/pc686 was not really great using the pc-qemu
rtems-test configuration:
rtems-test --rtems-bsp=pc-qemu build/i386/pc686/testsuites/validation
Passed: 12
Failed: 1
User Input: 0
Expected Fail: 0
Indeterminate: 0
Benchmark: 0
Timeout: 5
Test too long: 0
Invalid: 2
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Wrong Header: 0
Total: 20
Failures:
ts-validation-one-cpu-0.exe
Timeouts:
ts-performance-no-clock-0.exe
ts-validation-io-kernel.exe
ts-validation-timecounter-1.exe
ts-validation-no-clock-0.exe
Invalid:
ts-fatal-init-task-construct-failed.exe
ts-fatal-too-large-tls-size.exe
Some failed tests print "raw_idt_notify has been called" before they
time out or fail. There is probably an issue with the tm27 support which
is used to call handlers in interrupt context. I don't have time to fix
this. I marked all failed, timed out, and invalid tests as "expected-fail":
Passed: 12
Failed: 0
User Input: 0
Expected Fail: 5
Indeterminate: 0
Benchmark: 0
Timeout: 1
Test too long: 0
Invalid: 2
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Wrong Header: 0
Total: 20
Expected Fail:
Timeouts:
Invalid:
Average test time: 0:00:02.357636
Testing time : 0:00:47.152718
Since the test state reporting is done by the test, this doesn't always
work. Maybe we should add the test state and some other information as
ELF annotations. Since rtems-test doesn't use ELF files currently, some
work would be necessary to use this information.
I will do a test run on a arm/imx7 board tomorrow. The new validation
tests already passed some time ago on this board.
From my point of view the new validation tests are ready to get integrated.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
