[PATCH] arm: Optimize interrupt handling
Sebastian Huber
Thu Jan 13 14:27:22 UTC 2022
Use the SRS (Store Return State) instruction if available. This
considerably simplifies the context save and restore.
cpukit/score/cpu/arm/arm_exc_interrupt.S | 45 +++++++++++++++++--
.../score/cpu/arm/include/rtems/score/arm.h | 1 +
.../cpu/arm/include/rtems/score/cpuimpl.h | 13 ++++++
3 files changed, 56 insertions(+), 3 deletions(-)
diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
index 43568747b1..1dc8c6eab4 100644
--- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
+++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
@@ -34,6 +34,11 @@
#ifdef ARM_MULTILIB_ARCH_V4
+#define SELF_CPU_CONTROL r7
+#define NON_VOLATILE_SCRATCH r9
+#ifndef ARM_MULTILIB_HAS_STORE_RETURN_STATE
#define EXCHANGE_LR r4
#define EXCHANGE_SPSR r5
#define EXCHANGE_CPSR r6
@@ -42,16 +47,31 @@
#define EXCHANGE_LIST {EXCHANGE_LR, EXCHANGE_SPSR, EXCHANGE_CPSR, EXCHANGE_INT_SP}
#define EXCHANGE_SIZE 16
-#define SELF_CPU_CONTROL r7
-#define NON_VOLATILE_SCRATCH r9
#define CONTEXT_LIST {r0, r1, r2, r3, EXCHANGE_LR, EXCHANGE_SPSR, SELF_CPU_CONTROL, r12}
#define CONTEXT_SIZE 32
+#endif /* ARM_MULTILIB_HAS_STORE_RETURN_STATE */
.arm
.globl _ARMV4_Exception_interrupt
_ARMV4_Exception_interrupt:
+#ifdef ARM_MULTILIB_HAS_STORE_RETURN_STATE
+ /* Prepare return from interrupt */
+ sub lr, lr, #4
+ /* Save LR_irq and SPSR_irq to the SVC stack */
+ srsfd sp!, #ARM_PSR_M_SVC
+ /* Switch to SVC mode */
+ cps #ARM_PSR_M_SVC
+ * Save the volatile registers, two non-volatile registers used for
+ * interrupt processing, and the link register.
+ push {r0-r3, SELF_CPU_CONTROL, NON_VOLATILE_SCRATCH, r12, lr}
+#else /* ARM_MULTILIB_HAS_STORE_RETURN_STATE */
/* Save exchange registers to exchange area */
stmdb sp, EXCHANGE_LIST
@@ -73,6 +93,7 @@ _ARMV4_Exception_interrupt:
stmdb sp!, CONTEXT_LIST
stmdb sp!, {NON_VOLATILE_SCRATCH, lr}
#ifdef ARM_MULTILIB_VFP
/* Save VFP context */
@@ -87,11 +108,13 @@ _ARMV4_Exception_interrupt:
/* Get per-CPU control of current processor */
GET_SELF_CPU_CONTROL SELF_CPU_CONTROL
/* Remember INT stack pointer */
mov r1, EXCHANGE_INT_SP
/* Restore exchange registers from exchange area */
ldmia r1, EXCHANGE_LIST
/* Get interrupt nest level */
ldr r2, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
@@ -99,7 +122,11 @@ _ARMV4_Exception_interrupt:
/* Switch stack if necessary and save original stack pointer */
mov NON_VOLATILE_SCRATCH, sp
cmp r2, #0
+ ldreq sp, [SELF_CPU_CONTROL, #PER_CPU_INTERRUPT_STACK_HIGH]
+#else
moveq sp, r1
+#endif
/* Increment interrupt nest and thread dispatch disable level */
ldr r3, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
@@ -208,6 +235,13 @@ _ARMV4_Exception_interrupt:
vmsr FPSCR, r0
#endif /* ARM_MULTILIB_VFP */
+ * Restore the volatile registers, two non-volatile registers used for
+ pop {r0-r3, SELF_CPU_CONTROL, NON_VOLATILE_SCRATCH, r12, lr}
/* Restore NON_VOLATILE_SCRATCH register and link register */
ldmia sp!, {NON_VOLATILE_SCRATCH, lr}
@@ -238,6 +272,7 @@ _ARMV4_Exception_interrupt:
/* Restore EXCHANGE_LR and EXCHANGE_SPSR registers from exchange area */
ldmia sp!, {EXCHANGE_LR, EXCHANGE_SPSR}
#ifdef ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE
@@ -267,7 +302,11 @@ _ARMV4_Exception_interrupt:
#endif
/* Return from interrupt */
+ rfefd sp!
+#else
subs pc, lr, #4
+#endif
#ifdef RTEMS_PROFILING
#ifdef __thumb2__
diff --git a/cpukit/score/cpu/arm/include/rtems/score/arm.h b/cpukit/score/cpu/arm/include/rtems/score/arm.h
index b1e4b07a37..7eaa69d889 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/arm.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/arm.h
@@ -47,6 +47,7 @@ extern "C" {
#define ARM_MULTILIB_HAS_WFI
#define ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE
#define ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
+ #define ARM_MULTILIB_HAS_STORE_RETURN_STATE
#endif
#ifndef ARM_DISABLE_THREAD_ID_REGISTER_USE
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
index 0f86710966..a6fe74e9ad 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
@@ -79,6 +79,18 @@ typedef struct {
double d6;
double d7;
+ uint32_t r0;
+ uint32_t r1;
+ uint32_t r2;
+ uint32_t r3;
+ uint32_t r7;
+ uint32_t r9;
+ uint32_t r12;
+ uint32_t lr;
+ uint32_t return_pc;
+ uint32_t return_cpsr;
uint32_t r9;
uint32_t lr;
uint32_t r0;
@@ -89,6 +101,7 @@ typedef struct {
uint32_t r7;
uint32_t r12;
} CPU_Interrupt_frame;
#ifdef RTEMS_SMP
2.31.1
