[PATCH v2 2/4] arm: Rework per-CPU control in interrupt handling
Sebastian Huber
Fri Jan 14 13:17:34 UTC 2022
Use volatile register r0 for the per-CPU control of the current
processor instead of the non-volatile register r7. This enables the use
of r7 in a follow up patch. Do the interrupt handling in ARM mode.
Update #4579.
cpukit/score/cpu/arm/arm_exc_interrupt.S | 97 +++++++++++-------------
1 file changed, 46 insertions(+), 51 deletions(-)
diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
index 2775558bd9..77e57ff5e7 100644
--- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
+++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
@@ -42,10 +42,9 @@
#define EXCHANGE_LIST {EXCHANGE_LR, EXCHANGE_SPSR, EXCHANGE_CPSR, EXCHANGE_INT_SP}
#define EXCHANGE_SIZE 16
-#define SELF_CPU_CONTROL r7
#define NON_VOLATILE_SCRATCH r9
-#define CONTEXT_LIST {r0, r1, r2, r3, EXCHANGE_LR, EXCHANGE_SPSR, SELF_CPU_CONTROL, r12}
+#define CONTEXT_LIST {r0, r1, r2, r3, EXCHANGE_LR, EXCHANGE_SPSR, r7, r12}
#define CONTEXT_SIZE 32
.arm
@@ -75,19 +74,19 @@ _ARMV4_Exception_interrupt:
push CONTEXT_LIST
push {NON_VOLATILE_SCRATCH, lr}
+ /* Get per-CPU control of current processor */
+ GET_SELF_CPU_CONTROL r0
#ifdef ARM_MULTILIB_VFP
/* Save VFP context */
- vmrs r0, FPSCR
+ vmrs r2, FPSCR
vpush {d0-d7}
#ifdef ARM_MULTILIB_VFP_D32
vpush {d16-d31}
#endif
- push {r0, r1}
+ push {r2, r3}
#endif /* ARM_MULTILIB_VFP */
- /* Get per-CPU control of current processor */
- GET_SELF_CPU_CONTROL SELF_CPU_CONTROL
/* Remember INT stack pointer */
mov r1, EXCHANGE_INT_SP
@@ -95,46 +94,46 @@ _ARMV4_Exception_interrupt:
ldmia r1, EXCHANGE_LIST
/* Get interrupt nest level */
- ldr r2, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+ ldr r2, [r0, #PER_CPU_ISR_NEST_LEVEL]
/* Switch stack if necessary and save original stack pointer */
mov NON_VOLATILE_SCRATCH, sp
cmp r2, #0
moveq sp, r1
- /* Switch to Thumb-2 instructions if necessary */
- SWITCH_FROM_ARM_TO_THUMB_2 r1
/* Increment interrupt nest and thread dispatch disable level */
- ldr r3, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
- add r2, #1
- add r3, #1
- str r2, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
- str r3, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+ ldr r3, [r0, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+ add r2, r2, #1
+ add r3, r3, #1
+ str r2, [r0, #PER_CPU_ISR_NEST_LEVEL]
+ str r3, [r0, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
/* Call BSP dependent interrupt dispatcher */
#ifdef RTEMS_PROFILING
cmp r2, #1
bne .Lskip_profiling
BLX_TO_THUMB_1 _CPU_Counter_read
- mov SELF_CPU_CONTROL, r0
+ push {r0, r1}
BLX_TO_THUMB_1 bsp_interrupt_dispatch
+ pop {r1, r3}
mov r2, r0
- mov r1, SELF_CPU_CONTROL
BLX_TO_THUMB_1 _Profiling_Outer_most_interrupt_entry_and_exit
.Lprofiling_done:
#else
#endif
/* Load some per-CPU variables */
- ldr r0, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
- ldrb r1, [SELF_CPU_CONTROL, #PER_CPU_DISPATCH_NEEDED]
- ldr r2, [SELF_CPU_CONTROL, #PER_CPU_ISR_DISPATCH_DISABLE]
- ldr r3, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+ ldr r12, [r0, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+ ldrb r1, [r0, #PER_CPU_DISPATCH_NEEDED]
+ ldr r2, [r0, #PER_CPU_ISR_DISPATCH_DISABLE]
+ ldr r3, [r0, #PER_CPU_ISR_NEST_LEVEL]
/* Restore stack pointer */
mov sp, NON_VOLATILE_SCRATCH
@@ -143,15 +142,15 @@ _ARMV4_Exception_interrupt:
mrs NON_VOLATILE_SCRATCH, CPSR
/* Decrement levels and determine thread dispatch state */
- eor r1, r0
- sub r0, #1
- orr r1, r0
- orr r1, r2
- sub r3, #1
+ eor r1, r1, r12
+ sub r12, r12, #1
+ orr r1, r1, r12
+ orr r1, r1, r2
+ sub r3, r3, #1
/* Store thread dispatch disable and ISR nest levels */
- str r0, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
- str r3, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+ str r12, [r0, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+ str r3, [r0, #PER_CPU_ISR_NEST_LEVEL]
* Check thread dispatch necessary, ISR dispatch disable and thread
@@ -166,46 +165,42 @@ _ARMV4_Exception_interrupt:
.Ldo_thread_dispatch:
/* Set ISR dispatch disable and thread dispatch disable level to one */
- mov r0, #1
- str r0, [SELF_CPU_CONTROL, #PER_CPU_ISR_DISPATCH_DISABLE]
+ mov r12, #1
+ str r12, [r0, #PER_CPU_ISR_DISPATCH_DISABLE]
/* Call _Thread_Do_dispatch(), this function will enable interrupts */
- mov r0, SELF_CPU_CONTROL
- mov r1, NON_VOLATILE_SCRATCH
- mov r2, #0x80
- bic r1, r2
+ bic r1, NON_VOLATILE_SCRATCH, #0x80
BLX_TO_THUMB_1 _Thread_Do_dispatch
/* Disable interrupts */
msr CPSR, NON_VOLATILE_SCRATCH
-#ifdef RTEMS_SMP
-#endif
+ * Get per-CPU control of current processor. In SMP configurations, we
+ * may run on another processor after the _Thread_Do_dispatch() call.
/* Check if we have to do the thread dispatch again */
- ldrb r0, [SELF_CPU_CONTROL, #PER_CPU_DISPATCH_NEEDED]
- cmp r0, #0
+ ldrb r12, [r0, #PER_CPU_DISPATCH_NEEDED]
+ cmp r12, #0
bne .Ldo_thread_dispatch
/* We are done with thread dispatching */
- mov r0, #0
+ mov r12, #0
.Lthread_dispatch_done:
- /* Switch to ARM instructions if necessary */
- SWITCH_FROM_THUMB_2_TO_ARM
/* Restore VFP context */
- pop {r0, r1}
+ pop {r2, r3}
vpop {d16-d31}
#endif
vpop {d0-d7}
- vmsr FPSCR, r0
+ vmsr FPSCR, r2
/* Restore NON_VOLATILE_SCRATCH register and link register */
@@ -216,7 +211,7 @@ _ARMV4_Exception_interrupt:
* still in use. So the stack is now in an inconsistent state. The
* FIQ handler implementation must not use this area.
- mov r0, sp
+ mov r12, sp
add sp, #CONTEXT_SIZE
/* Get INT mode program status register */
@@ -230,7 +225,7 @@ _ARMV4_Exception_interrupt:
push {EXCHANGE_LR, EXCHANGE_SPSR}
/* Restore context */
- ldmia r0, CONTEXT_LIST
+ ldmia r12, CONTEXT_LIST
/* Set return address and program status */
mov lr, EXCHANGE_LR
2.31.1
