New validation test suites
Mon Jan 17 09:51:08 UTC 2022
On 17/01/2022 09:47, Chris Johns wrote:
> On 17/1/22 7:04 pm, Sebastian Huber wrote:
>> On 17/01/2022 08:52, Chris Johns wrote:
>>> My understanding of the status of these patches is the remaining topic is the
>>> release dependencies. I have not had time to give this any consideration however
>>> I have a feeling it will not be easy or simple because of the inter-dependency
>>> of the repos and sub-module relationship. I hope I am wrong about this.
>> In order to work with the generated test programs you have to use the
>> specification items which are in rtems-central.  Most of the validation tests
>> are defined through transitions from pre-conditions to post-conditions. Working
>> directly with the generated sources is too complicated. I don't know what
>> complicates a release here, the rtems-central is just another repository which
>> needs a release branch. In the release branch, the submodules track the
>> corresponding release branch of the referenced repository.
> A release has tarballs of sources and not git repos so I am not sure how
> branches help? How does the submodules in rtems-central get captured? The
> current release scripts expand sub-modules which means they need to reconcile or
> we will have different copies of the code in the release.
> At the point of release how does the release manager know the rtems-central
> scripts match the generated sources in the down stream repos that are released?
The rtems-central contains nothing relevant to an user of RTEMS. There
is no need to provide a release archive. The purpose of the branch is
the maintenance of an RTEMS release branch.
>> Please note, that the RTEMS sources used by rtems-central are currently not
>> one-to-one a commit of the RTEMS master branch. There are about 90 additional
>> patches. The patch set with the new validation sets is a part of it.
> Which is a concern and why a release needs to check and make sure everything is
> in sync.
> Ideally the rtems-central submodule hashes match the release tarball sources for
> each repo. This is the task as I see it.
> I am sure this can be resolved and I prefer it happens before being pushed so it
> is not left as a task for the release manager.
The only way to reduce the gap between the RTEMS version referenced by
rtems-central and the RTEMS master is to integrate patch sets step by
step. Some patch sets are specific to the sparc/leon3 BSPs and the build
system. I am not sure if this should delay the RTEMS 6 release.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
