[PATCH rtems-tools] tiers: Add AArch64 to tier 1
Tue Jan 18 21:59:52 UTC 2022
Ok to push.
Thank you
On 19/1/22 3:19 am, Kinsey Moore wrote:
> Hardware test results have recently been posted for AArch64.
> Closes #4581
>  config/rtems-bsps-tiers.ini | 3 ++-
>  1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/config/rtems-bsps-tiers.ini b/config/rtems-bsps-tiers.ini
> index 875c5df..ba9e6b5 100644
> --- a/config/rtems-bsps-tiers.ini
> +++ b/config/rtems-bsps-tiers.ini
> @@ -21,10 +21,11 @@
>  # Tier 1: no build errors and no unexpected tests failures on hardware.
>  [tier-1]
> -archs = arm, i386, powerpc
> +archs = arm, i386, powerpc, aarch64
>  bsps_arm = beagleboneblack, imx7, xilinx_zynq_zedboard
>  bsps_i386 = pc686
>  bsps_powerpc = qoriq_e500
> +bsps_aarch64 = xilinx_zynqmp_lp64_zu3eg, xilinx_zynqmp_ilp32_zu3eg
>  # Tier 2: no build errors and no unexpected tests failures on hardware and
