[PATCH 0/5] Update rtems-bsp-builder to match RTEMS master
Wed Jan 19 18:04:06 UTC 2022
The set of ini files for rtems-bsp-builder was out of sync
with the set of architectures and BSPs currently in RTEMS.
This patch set adds three architectures and a handful of BSPs.
Build results with these patches are at:
https://lists.rtems.org/pipermail/build/2022-January/031032.html
--joel
Joel Sherrill (5):
  rtems-bsps-arm.ini: Add missing BSPs
  rtems-bsps-riscv.ini: Add missing BSPs
  rtems-bsps-aarch64.ini: New file
  rtems-bsps-microblaze.ini: New file
  rtems-bsps-x86_64.ini: New file
 config/rtems-bsps-aarch64.ini    | 31 +++++++++++++++++++++++++++++++
 config/rtems-bsps-arm.ini        | 16 +++++++++++++---
 config/rtems-bsps-microblaze.ini | 25 +++++++++++++++++++++++++
 config/rtems-bsps-riscv.ini      |  4 +++-
 config/rtems-bsps-x86_64.ini     | 25 +++++++++++++++++++++++++
 5 files changed, 97 insertions(+), 4 deletions(-)
 create mode 100644 config/rtems-bsps-aarch64.ini
 create mode 100644 config/rtems-bsps-microblaze.ini
 create mode 100644 config/rtems-bsps-x86_64.ini
2.24.4
