[PATCH rtems-libbsd 2/2] microblaze: Finish AXI Ethernet support
Sebastian Huber
Thu Jan 20 06:12:10 UTC 2022
On 20/01/2022 04:54, Alex White wrote:
> diff --git a/freebsd/sys/netinet/tcp_input.c b/freebsd/sys/netinet/tcp_input.c
> index fc111d9c..60f9123a 100644
> --- a/freebsd/sys/netinet/tcp_input.c
> +++ b/freebsd/sys/netinet/tcp_input.c
> @@ -721,6 +721,15 @@ tcp_input(struct mbuf **mp, int *offp, int proto)
> #endif /* INET */
> +#ifdef __rtems__
> +#ifdef __MICROBLAZE__
> + /* Ensure that the TCP header is properly aligned in memory. */
> + struct tcphdr aligned_hdr;
> + memcpy(&aligned_hdr, th, sizeof(struct tcphdr));
> + th = &aligned_hdr;
> +#endif
> +#endif
> * Check that TCP offset makes sense,
> * pull out TCP options and adjust length. XXX
Changes like this should not be hidden in a driver-specific patch. The
alignment changes are hacks. Why don't you fix the Ethernet frame
alignment in the network interface driver?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
