[PATCH] rtems-tools-6.cfg: Bump hash to get new INI files
Joel Sherrill
joel at rtems.org
Thu Jan 20 14:32:22 UTC 2022
This looks good to me. If no one objects, I will push it.
--joel
On Thu, Jan 20, 2022 at 8:28 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> rtems/config/tools/rtems-tools-6.cfg | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
> index cf895d6..d493955 100644
> --- a/rtems/config/tools/rtems-tools-6.cfg
> +++ b/rtems/config/tools/rtems-tools-6.cfg
> @@ -10,14 +10,14 @@
> %define rtems_tools_source rtems-tools-%{rtems_tools_version}
> %define rtems_tools_ext xz
> %else
> - %define rtems_tools_version 6b31bb03aaf98232a21813c471d0298c170dde60
> + %define rtems_tools_version 6736c738baee94a31ec4f8bc4484582eb7839556
> %define rtems_tools_ext bz2
> %endif
> %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
> %hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
> - +TKPQxx2HdnSBW7QcgfzFZCjRw7mssXHaJSxDd0v1KJ/VLeWcdus/MELH7oq0WyEMpqAyd1+1HpMVuFrMFyvcw==
> + DK6eZJJTXeO3g7PJrB+CsqUU/aYgb3/46MjUP8OqSLYTEOCStoIAm9NjHkWZCIPpJyqQIeEpX8Aerd3RfFiuYA==
> # Optionally enable/disable building the RTEMS Tools via the command line.
> 1.8.3.1
> devel mailing list
> devel at rtems.org
