[PATCH 2/5] rtems-bsps-tiers.ini: Update comment to use tier 2 definitiion in docs
Fri Jan 21 15:26:51 UTC 2022
See rtems-docs/user/hardware/tiers.rst. Tier 2 is test results on
simulator not hardware and simulator.
 config/rtems-bsps-tiers.ini | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/config/rtems-bsps-tiers.ini b/config/rtems-bsps-tiers.ini
index a48b8ef..c3e62b2 100644
--- a/config/rtems-bsps-tiers.ini
+++ b/config/rtems-bsps-tiers.ini
@@ -28,8 +28,7 @@ bsps_powerpc = qoriq_e500
 bsps_aarch64 = xilinx_zynqmp_lp64_zu3eg, xilinx_zynqmp_ilp32_zu3eg
-# Tier 2: no build errors and no unexpected tests failures on hardware and
-#         simulators.
+# Tier 2: no build errors and no unexpected tests failures on simulators.
 [tier-2]
 archs = mips, powerpc, sparc
2.24.4
