[PATCH 4/5] rtems-bsps.ini: Add missing architectures and BSPs
Joel Sherrill
joel at rtems.org
Fri Jan 21 15:26:53 UTC 2022
The aarch64, microblaze, nios2, and x86_64 needed to be added.
config/rtems-bsps.ini | 20 ++++++++++++++++----
1 file changed, 16 insertions(+), 4 deletions(-)
diff --git a/config/rtems-bsps.ini b/config/rtems-bsps.ini
index 5be9cba..659e31f 100644
--- a/config/rtems-bsps.ini
+++ b/config/rtems-bsps.ini
@@ -60,27 +60,34 @@ include = rtems-bsps-tiers.ini
# All the architectures and BSPs.
[everything]
-archs = arm,
+archs = aarch64,
+ arm,
bfin,
i386,
lm32,
m68k,
+ microblaze,
mips,
moxie,
+ nios2,
or1k,
powerpc,
riscv,
sh,
sparc,
sparc64,
- v850
+ v850,
+ x86_64
+bsps_aarch64 = ${arch64:bsps}
bsps_arm = ${arm:bsps}
bsps_bfin = ${bfin:bsps}
bsps_i386 = ${i386:bsps}
bsps_lm32 = ${lm32:bsps}
bsps_m68k = ${m68k:bsps}
+bsps_microblaze = ${microblaze:bsps}
bsps_mips = ${mips:bsps}
bsps_moxie = ${moxie:bsps}
+bsps_nios2 = ${nios2:bsps}
bsps_or1k = ${or1k:bsps}
bsps_powerpc = ${powerpc:bsps}
bsps_riscv = ${riscv:bsps}
@@ -88,25 +95,30 @@ bsps_sh = ${sh:bsps}
bsps_sparc = ${sparc:bsps}
bsps_sparc64 = ${sparc64:bsps}
bsps_v850 = ${v850:bsps}
+bsps_x86_64 = ${x86_64:bsps}
# Architectures
[architectures]
-include = rtems-bsps-arm.ini,
+include = rtems-bsps-aarch64.ini,
+ rtems-bsps-arm.ini,
rtems-bsps-bfin.ini,
rtems-bsps-i386.ini,
rtems-bsps-lm32.ini,
rtems-bsps-m68k.ini,
+ rtems-bsps-microblaze.ini,
rtems-bsps-mips.ini,
rtems-bsps-moxie.ini,
+ rtems-bsps-nios2.ini,
rtems-bsps-or1k.ini,
rtems-bsps-powerpc.ini,
rtems-bsps-riscv.ini,
rtems-bsps-sh.ini,
rtems-bsps-sparc.ini,
rtems-bsps-sparc64.ini,
- rtems-bsps-v850.ini
+ rtems-bsps-v850.ini,
+ rtems-bsps-x86_64.ini
# The Build Options define how each combination is to be build.
2.24.4
