[PATCH 0/5] rtems-bsp-builder Configuration Cleanup
Sun Jan 23 22:42:27 UTC 2022
OK to push.
Thank you for taking the time to get this sorted.
On 22/1/22 2:26 am, Joel Sherrill wrote:
> As part of adding aarch64 BSPs to tier 1, it become obvious that
> these config files had not received attention lately. Multiple
> architectures and BSPs needed to be added. Some BSPs that had
> been removed needed to be removed here as well.
> With the legacy TCP/IP stack no longer in rtems.git, it made
> sense to eliminate the build variance on network. This will
> have a huge impact on the execution time of the build sweeps.
> Build results for everything, tier-1, tier-2, and tier-3 are
> posted to build at .
> Hopefully not controversial since it wasn't in the best shape
> when I started.
> --joel
> Joel Sherrill (5):
>   rtems-bsps-tiers.ini: Add missing architectures and BSPs as tier 3
>   rtems-bsps-tiers.ini: Update comment to use tier 2 definitiion in docs
>   rtems-bsps-arm.ini, config/rtems-bsps.ini: Remove build variance on
>     network
>   rtems-bsps.ini: Add missing architectures and BSPs
>   rtems-bsps-tiers.ini: Move appropriate aarch64 BSPs to Tier 1 and 2
>  config/rtems-bsps-arm.ini   |  1 -
>  config/rtems-bsps-tiers.ini | 36 ++++++++++++++++++++++++++----------
>  config/rtems-bsps.ini       | 31 +++++++++++++++++--------------
>  3 files changed, 43 insertions(+), 25 deletions(-)
