[PATCH rtems-libbsd 2/2] microblaze: Finish AXI Ethernet support
Sebastian Huber
Mon Jan 24 18:45:54 UTC 2022
On 24/01/2022 17:04, Alex White wrote:
> On Thu, Jan 20, 2022 at 12:12 AM Sebastian Huber<sebastian.huber at embedded-brains.de> wrote:
>> On 20/01/2022 04:54, Alex White wrote:
>>> diff --git a/freebsd/sys/netinet/tcp_input.c b/freebsd/sys/netinet/tcp_input.c
>>> index fc111d9c..60f9123a 100644
>>> --- a/freebsd/sys/netinet/tcp_input.c
>>> +++ b/freebsd/sys/netinet/tcp_input.c
>>> @@ -721,6 +721,15 @@ tcp_input(struct mbuf **mp, int *offp, int proto)
>>> #endif /* INET */
>>> +#ifdef __rtems__
>>> +#ifdef __MICROBLAZE__
>>> + /* Ensure that the TCP header is properly aligned in memory. */
>>> + struct tcphdr aligned_hdr;
>>> + memcpy(&aligned_hdr, th, sizeof(struct tcphdr));
>>> + th = &aligned_hdr;
>>> +#endif
>>> +#endif
>>> * Check that TCP offset makes sense,
>>> * pull out TCP options and adjust length. XXX
>> Changes like this should not be hidden in a driver-specific patch. The
>> alignment changes are hacks. Why don't you fix the Ethernet frame
>> alignment in the network interface driver?
> I have made the realization while testing fixes for this that if I
> change the definition of struct tcphdr in netinet/tcp.h to include
> __attribute__((packed)), GCC generates code that avoids the unaligned
> memory access. This removes the need for any code to handle memory
> alignment of the network headers.
> I then noticed that you had some notes on what I think is this same
> phenomenon at freebsd/contrib/libpcap/extract.h line 40.
> Since, for example, the ip struct in netinet/ip.h is defined as packed,
> shouldn't the tcphdr struct be packed, too?
> In addition, struct tcphdr is being used to represent raw bytes on the
> wire so it makes sense to declare it as packed so no padding is
> included.
> The initial solution I came up with was to change
> newlib/libc/sys/rtems/include/netinet/tcp.h in newlib to add
> __attribute__((packed)) to struct tcphdr . This could be added inside
> an #ifdef __microblaze__ to minimize impact elsewhere. This would, of
> course, diverge from FreeBSD's netinet/tcp.h.
> Does that sound like a reasonable solution?
No, I would try to fix this in the network interface driver. See for
example (freebsd/sys/dev/dwc/if_dwc.c):
static int
dwc_setup_rxbuf(struct dwc_softc *sc, int idx, struct mbuf *m)
bus_dma_segment_t seg;
#ifndef __rtems__
int error, nsegs;
#endif /* __rtems__ */
m_adj(m, ETHER_ALIGN);
Several other drivers use the same approach.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
