[PATCH] Remove obsolete rtems_gxx_*() implementation
Sebastian Huber
Wed Jan 26 10:05:17 UTC 2022
GCC versions prior to 6.1 used a RTEMS thread model based on
rtems_gxx_*() functions. GCC version 6.1 or later uses the
self-contained synchronization objects of Newlib <sys/lock.h> for the
RTEMS thread model.
Remove the obsolete implementation.
Close #3143.
cpukit/include/rtems/gxx_wrappers.h | 80 ------
cpukit/include/rtems/score/interr.h | 4 +-
cpukit/libcsupport/src/gxx_wrappers.c | 261 --------------------
spec/build/testsuites/libtests/grp.yml | 2 -
spec/build/testsuites/libtests/gxx01.yml | 19 --
spec/build/testsuites/sptests/grp.yml | 4 -
spec/build/testsuites/sptests/spfatal24.yml | 19 --
spec/build/testsuites/sptests/spfatal25.yml | 19 --
testsuites/libtests/gxx01/gxx01.doc | 33 ---
testsuites/libtests/gxx01/gxx01.scn | 35 ---
testsuites/libtests/gxx01/init.c | 228 -----------------
testsuites/sptests/spfatal24/init.c | 31 ---
testsuites/sptests/spfatal24/spfatal24.doc | 19 --
testsuites/sptests/spfatal24/spfatal24.scn | 3 -
testsuites/sptests/spfatal25/init.c | 33 ---
testsuites/sptests/spfatal25/spfatal25.doc | 19 --
testsuites/sptests/spfatal25/spfatal25.scn | 3 -
17 files changed, 2 insertions(+), 810 deletions(-)
delete mode 100644 cpukit/include/rtems/gxx_wrappers.h
delete mode 100644 cpukit/libcsupport/src/gxx_wrappers.c
delete mode 100644 spec/build/testsuites/libtests/gxx01.yml
delete mode 100644 spec/build/testsuites/sptests/spfatal24.yml
delete mode 100644 spec/build/testsuites/sptests/spfatal25.yml
delete mode 100644 testsuites/libtests/gxx01/gxx01.doc
delete mode 100644 testsuites/libtests/gxx01/gxx01.scn
delete mode 100644 testsuites/libtests/gxx01/init.c
delete mode 100644 testsuites/sptests/spfatal24/init.c
delete mode 100644 testsuites/sptests/spfatal24/spfatal24.doc
delete mode 100644 testsuites/sptests/spfatal24/spfatal24.scn
delete mode 100644 testsuites/sptests/spfatal25/init.c
delete mode 100644 testsuites/sptests/spfatal25/spfatal25.doc
delete mode 100644 testsuites/sptests/spfatal25/spfatal25.scn
diff --git a/cpukit/include/rtems/gxx_wrappers.h b/cpukit/include/rtems/gxx_wrappers.h
deleted file mode 100644
index e462d27d66..0000000000
--- a/cpukit/include/rtems/gxx_wrappers.h
+++ /dev/null
@@ -1,80 +0,0 @@
- * @file
- * RTEMS threads compatibility routines for libgcc2.
- * by: Rosimildo da Silva (rdasilva at connecttel.com)
- * Used ideas from:
- * W. Eric Norum
- * Canadian Light Source
- * University of Saskatchewan
- * Saskatoon, Saskatchewan, CANADA
- * eric at cls.usask.ca
- * Eric sent some e-mail in the rtems-list as a start point for this
- * module implementation.
-#ifndef __GCC_WRAPPERS_h
-#define __GCC_WRAPPERS_h
-#ifdef __cplusplus
-extern "C" {
-#endif /* __cplusplus */
- * @defgroup GxxWrappersSupport Gxx Wrappers Support
- * @ingroup libcsupport
- * @brief RTEMS Threads Compatibility Routines for Libgcc2
- * These typedefs should match with the ones defined in the file
- * gcc/gthr-rtems.h in the gcc distribution.
-typedef void *__gthread_key_t;
-typedef int __gthread_once_t;
-typedef void *__gthread_mutex_t;
-typedef void *__gthread_recursive_mutex_t;
-int rtems_gxx_once(__gthread_once_t *once, void (*func) (void));
-int rtems_gxx_key_create (__gthread_key_t *key, void (*dtor) (void *));
-int rtems_gxx_key_delete (__gthread_key_t key);
-void *rtems_gxx_getspecific(__gthread_key_t key);
-int rtems_gxx_setspecific(__gthread_key_t key, const void *ptr);
- * MUTEX support
-void rtems_gxx_mutex_init (__gthread_mutex_t *mutex);
-int rtems_gxx_mutex_lock (__gthread_mutex_t *mutex);
-int rtems_gxx_mutex_destroy (__gthread_mutex_t *mutex);
-int rtems_gxx_mutex_trylock (__gthread_mutex_t *mutex);
-int rtems_gxx_mutex_unlock (__gthread_mutex_t *mutex);
-void rtems_gxx_recursive_mutex_init(__gthread_recursive_mutex_t *mutex);
-int rtems_gxx_recursive_mutex_lock(__gthread_recursive_mutex_t *mutex);
-int rtems_gxx_recursive_mutex_trylock(__gthread_recursive_mutex_t *mutex);
-int rtems_gxx_recursive_mutex_unlock(__gthread_recursive_mutex_t *mutex);
-#ifdef __cplusplus
-#endif /* __GCC_WRAPPERS_h */
diff --git a/cpukit/include/rtems/score/interr.h b/cpukit/include/rtems/score/interr.h
index 65cac29500..4054e21253 100644
--- a/cpukit/include/rtems/score/interr.h
+++ b/cpukit/include/rtems/score/interr.h
@@ -188,8 +188,8 @@ typedef enum {
/* INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_FROM_BAD_STATE = 18, */
/* INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0 = 19, */
/* INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP = 20, */
- INTERNAL_ERROR_GXX_KEY_ADD_FAILED = 21,
- INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED = 22,
+ /* INTERNAL_ERROR_GXX_KEY_ADD_FAILED = 21, */
+ /* INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED = 22, */
INTERNAL_ERROR_NO_MEMORY_FOR_HEAP = 23,
INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR = 24,
INTERNAL_ERROR_RESOURCE_IN_USE = 25,
diff --git a/cpukit/libcsupport/src/gxx_wrappers.c b/cpukit/libcsupport/src/gxx_wrappers.c
index b81d82d454..0000000000
--- a/cpukit/libcsupport/src/gxx_wrappers.c
+++ /dev/null
@@ -1,261 +0,0 @@
- * @file
- * @ingroup GxxWrappersSupport
- * W. Eric Norum
- * This file is only used if using gcc
-#if defined(__GNUC__)
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/gxx_wrappers.h>
-#include <rtems/score/onceimpl.h>
-#include <errno.h>
-#include <stdlib.h>
-#include <pthread.h>
-#include <rtems.h>
-/* uncomment this if you need to debug this interface */
-/*#define DEBUG_GXX_WRAPPERS 1*/
- #ifdef DEBUG_GXX_WRAPPERS
- printk( "gxx_wrappers: once=%x, func=%x\n", *once, func );
- #endif
- return _Once( (unsigned char *) once, func );
- int eno;
- pthread_key_t *pkey;
- pkey = malloc( sizeof( *pkey ) );
- *key = pkey;
- if ( pkey == NULL )
- return ENOMEM;
- printk(
- "gxx_wrappers: create key=%x, dtor=%x, pkey=%x\n", key, dtor, pkey
- #endif
- eno = pthread_key_create(pkey, dtor);
- if ( eno != 0 ) {
- free( pkey );
- *key = NULL;
- return eno;
- int eno = 0;
- pthread_key_t *pkey = key;
- printk( "gxx_wrappers: delete key=%x\n", pkey );
- #endif
- if ( pkey == NULL ) {
- return EINVAL;
- eno = pthread_key_delete(*pkey);
- if ( eno == 0 ) {
- free( pkey );
- return eno;
- void *p = NULL;
- if ( pkey != NULL ) {
- p = pthread_getspecific( *pkey );
- printk(
- "gxx_wrappers: getspecific key=%x, ptr=%x, id=%x\n",
- pkey,
- p,
- rtems_task_self()
- #endif
- return p;
- int eno;
- return EINVAL;
- eno = pthread_setspecific( *pkey, ptr );
- printk(
- "gxx_wrappers: setspecific key=%x, ptr=%x, id=%x\n",
- pkey,
- ptr,
- rtems_task_self()
- #endif
- if ( eno != 0 ) {
- _Internal_error( INTERNAL_ERROR_GXX_KEY_ADD_FAILED );
- return 0;
- * MUTEX support
- rtems_status_code status;
- printk( "gxx_wrappers: mutex init =%X\n", *mutex );
- #endif
- status = rtems_semaphore_create(
- rtems_build_name ('G', 'C', 'C', '2'),
- 1,
- RTEMS_PRIORITY|RTEMS_BINARY_SEMAPHORE|
- RTEMS_INHERIT_PRIORITY|RTEMS_NO_PRIORITY_CEILING|RTEMS_LOCAL,
- 0,
- (rtems_id *)mutex
- if ( status != RTEMS_SUCCESSFUL ) {
- printk(
- "gxx_wrappers: mutex init failed %s (%d)\n",
- rtems_status_text(status),
- status
- #endif
- _Internal_error( INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED );
- printk( "gxx_wrappers: mutex init complete =%X\n", *mutex );
- #endif
- printk( "gxx_wrappers: lock mutex=%X\n", *mutex );
- #endif
- status = rtems_semaphore_obtain(
- *(rtems_id *)mutex,
- RTEMS_WAIT,
- RTEMS_NO_TIMEOUT
- if ( status == RTEMS_SUCCESSFUL )
- return 0;
- return -1;
- printk( "gxx_wrappers: destroy mutex=%X\n", *mutex );
- #endif
- status = rtems_semaphore_delete(*(rtems_id *)mutex);
- return 0;
- return -1;
- printk( "gxx_wrappers: trylock mutex=%X\n", *mutex );
- #endif
- status = rtems_semaphore_obtain (*(rtems_id *)mutex, RTEMS_NO_WAIT, 0);
- return 0;
- return -1;
- printk( "gxx_wrappers: unlock mutex=%X\n", *mutex );
- #endif
- status = rtems_semaphore_release( *(rtems_id *)mutex );
- return 0;
- return -1;
- rtems_gxx_mutex_init(mutex);
- return rtems_gxx_mutex_lock(mutex);
- return rtems_gxx_mutex_trylock(mutex);
- return rtems_gxx_mutex_unlock(mutex);
-#endif /* __GNUC__ */
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index cd5cc210e2..fdb9e4fede 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -141,8 +141,6 @@ links:
uid: gettimeofday
- role: build-dependency
uid: getuid
-- role: build-dependency
- uid: gxx01
uid: heapwalk
diff --git a/spec/build/testsuites/libtests/gxx01.yml b/spec/build/testsuites/libtests/gxx01.yml
index 1027db9b9a..0000000000
--- a/spec/build/testsuites/libtests/gxx01.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-build-type: test-program
-cflags: []
-copyrights:
-- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-cppflags: []
-cxxflags: []
-enabled-by: true
-features: c cprogram
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/libtests/gxx01/init.c
-stlib: []
-target: testsuites/libtests/gxx01.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index b2278a60fe..740684a0e4 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -237,10 +237,6 @@ links:
uid: spfatal14
uid: spfatal15
- uid: spfatal24
- uid: spfatal25
uid: spfatal26
diff --git a/spec/build/testsuites/sptests/spfatal24.yml b/spec/build/testsuites/sptests/spfatal24.yml
index 22eefa9de5..0000000000
--- a/spec/build/testsuites/sptests/spfatal24.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spfatal24/init.c
-stlib: []
-target: testsuites/sptests/spfatal24.exe
-type: build
-use-after: []
-use-before: []
diff --git a/spec/build/testsuites/sptests/spfatal25.yml b/spec/build/testsuites/sptests/spfatal25.yml
index f80f26abfa..0000000000
--- a/spec/build/testsuites/sptests/spfatal25.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-cflags: []
-copyrights:
-cppflags: []
-cxxflags: []
-enabled-by: true
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spfatal25/init.c
-stlib: []
-target: testsuites/sptests/spfatal25.exe
-type: build
-use-after: []
-use-before: []
diff --git a/testsuites/libtests/gxx01/gxx01.doc b/testsuites/libtests/gxx01/gxx01.doc
index 568e26f49a..0000000000
--- a/testsuites/libtests/gxx01/gxx01.doc
+++ /dev/null
@@ -1,33 +0,0 @@
-# COPYRIGHT (c) 1989-2010.
-# On-Line Applications Research Corporation (OAR).
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
-This file describes the directives and concepts tested by this test set.
-test set name: gxx01
-directives:
- rtems_gxx_once
- rtems_gxx_key_create
- rtems_gxx_key_delete
- rtems_gxx_getspecific
- rtems_gxx_setspecific
- rtems_gxx_mutex_lock
- rtems_gxx_mutex_destroy
- rtems_gxx_mutex_trylock
- rtems_gxx_mutex_unlock
- rtems_gxx_recursive_mutex_init
- rtems_gxx_recursive_mutex_lock
- rtems_gxx_recursive_mutex_trylock
- rtems_gxx_recursive_mutex_unlock
-concepts:
-+ Fully exercise wrappers provided by RTEMS for GCC's C++ library's
- mutual exclusion implementation.
diff --git a/testsuites/libtests/gxx01/gxx01.scn b/testsuites/libtests/gxx01/gxx01.scn
index f831881fa3..0000000000
--- a/testsuites/libtests/gxx01/gxx01.scn
+++ /dev/null
@@ -1,35 +0,0 @@
-*** TEST GXX 01 ***
-rtems_gxx_mutex_init() - OK
-rtems_gxx_mutex_trylock() - OK
-rtems_gxx_mutex_unlock() - OK
-rtems_gxx_mutex_lock() - OK
-rtems_gxx_recursive_mutex_init() - OK
-rtems_gxx_recursive_mutex_trylock() - OK
-rtems_gxx_recursive_mutex_trylock() - Nest
-rtems_gxx_recursive_mutex_unlock() - Unnest
-rtems_gxx_recursive_mutex_unlock() - OK
-rtems_gxx_recursive_mutex_lock() - OK
-rtems_gxx_mutex_destroy(mutex) - OK
-rtems_gxx_mutex_destroy(mutex) - NOT OK
-Call once method the first time
-Running once method
-Call once method the second time
-rtems_gxx_key_create(&key, NULL) - OK
-rtems_gxx_key_delete(key) - OK
-rtems_gxx_key_create(&key, key_dtor) - OK
-rtems_gxx_getspecific(key) not set - OK
-rtems_gxx_setspecific(key, 0x1234) - OK
-rtems_gxx_getspecific(key) already existing - OK
-rtems_gxx_getspecific(key) non-existent - OK
-rtems_gxx_key_delete(key) - NOT OK
-rtems_gxx_setspecific(NULL, 0x1234) - NOT OK
-rtems_gxx_getspecific(NULL) - OK
-rtems_gxx_key_delete(NULL) - NOT OK
-*** END OF TEST GXX 01 ***
diff --git a/testsuites/libtests/gxx01/init.c b/testsuites/libtests/gxx01/init.c
index 306e4f1f0b..0000000000
--- a/testsuites/libtests/gxx01/init.c
+++ /dev/null
@@ -1,228 +0,0 @@
- * COPYRIGHT (c) 1989-2012.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#endif
-#include <errno.h>
-#include <tmacros.h>
-#include "test_support.h"
-const char rtems_test_name[] = "GXX 1";
-/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument argument);
-void test_recursive_mutex(void);
-void test_mutex(void);
-void once_function(void);
-void test_once(void);
-void key_dtor(void *ptr);
-void test_key(void);
- int sc;
- __gthread_mutex_t mutex;
- mutex = 0;
- puts( "rtems_gxx_recursive_mutex_init() - OK" );
- rtems_gxx_recursive_mutex_init(&mutex);
- rtems_test_assert( mutex != 0 );
- puts( "rtems_gxx_recursive_mutex_trylock() - OK" );
- sc = rtems_gxx_recursive_mutex_trylock(&mutex);
- rtems_test_assert( sc == 0 );
- puts( "rtems_gxx_recursive_mutex_trylock() - Nest" );
- puts( "rtems_gxx_recursive_mutex_unlock() - Unnest" );
- sc = rtems_gxx_recursive_mutex_unlock(&mutex);
- puts( "rtems_gxx_recursive_mutex_unlock() - OK" );
- puts( "rtems_gxx_recursive_mutex_lock() - OK" );
- sc = rtems_gxx_recursive_mutex_lock(&mutex);
- puts( "rtems_gxx_mutex_destroy(mutex) - OK" );
- sc = rtems_gxx_mutex_destroy(&mutex);
- puts( "rtems_gxx_mutex_destroy(mutex) - NOT OK" );
- rtems_test_assert( sc == -1 );
- int sc;
- mutex = 0;
- puts( "rtems_gxx_mutex_init() - OK" );
- rtems_gxx_mutex_init(&mutex);
- puts( "rtems_gxx_mutex_trylock() - OK" );
- sc = rtems_gxx_mutex_trylock(&mutex);
- puts( "rtems_gxx_mutex_unlock() - OK" );
- sc = rtems_gxx_mutex_unlock(&mutex);
- puts( "rtems_gxx_mutex_lock() - OK" );
- sc = rtems_gxx_mutex_lock(&mutex);
- puts( "Running once method" );
- __gthread_once_t once;
- int sc;
- once = 0;
- puts( "Call once method the first time" );
- sc = rtems_gxx_once(&once, once_function);
- puts( "Call once method the second time" );
-volatile bool key_dtor_ran;
- key_dtor_ran = true;
- int sc;
- __gthread_key_t key;
- void *p;
- puts( "rtems_gxx_key_create(&key, NULL) - OK" );
- sc = rtems_gxx_key_create(&key, NULL);
- puts( "rtems_gxx_key_delete(key) - OK" );
- sc = rtems_gxx_key_delete(key);
- puts( "rtems_gxx_key_create(&key, key_dtor) - OK" );
- sc = rtems_gxx_key_create(&key, key_dtor);
- puts( "rtems_gxx_getspecific(key) not set - OK" );
- p = rtems_gxx_getspecific(key);
- rtems_test_assert( p == NULL );
- puts( "rtems_gxx_setspecific(key, 0x1234) - OK" );
- sc = rtems_gxx_setspecific(key, (void *)0x1234);
- puts( "rtems_gxx_getspecific(key) already existing - OK" );
- rtems_test_assert( p == (void *)0x1234 );
- /* pthread_key man-page: the dtor should _not_ be called */
- rtems_test_assert( key_dtor_ran != true );
- key = calloc( 1, sizeof( *key ) );
- rtems_test_assert( key != NULL );
- puts( "rtems_gxx_getspecific(key) non-existent - OK" );
- p = rtems_gxx_getspecific( key );
- puts( "rtems_gxx_key_delete(key) - NOT OK" );
- sc = rtems_gxx_key_delete( key );
- rtems_test_assert( sc != 0 );
- puts( "rtems_gxx_setspecific(NULL, 0x1234) - NOT OK" );
- sc = rtems_gxx_setspecific( NULL, (void *)0x1234 );
- rtems_test_assert( sc == EINVAL );
- puts( "rtems_gxx_getspecific(NULL) - OK" );
- p = rtems_gxx_getspecific( NULL );
- puts( "rtems_gxx_key_delete(NULL) - NOT OK" );
- sc = rtems_gxx_key_delete( NULL );
-rtems_task Init(
- rtems_task_argument argument
- TEST_BEGIN();
- test_mutex();
- puts( "" );
- test_recursive_mutex();
- puts( "" );
- test_once();
- puts( "" );
- test_key();
- puts( "" );
- TEST_END();
- rtems_test_exit( 0 );
-/* configuration information */
-#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_MAXIMUM_POSIX_KEYS 1
-#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 1
-#define CONFIGURE_MAXIMUM_TASKS 1
-#define CONFIGURE_MAXIMUM_SEMAPHORES 2
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#include <rtems/confdefs.h>
-/* end of file */
diff --git a/testsuites/sptests/spfatal24/init.c b/testsuites/sptests/spfatal24/init.c
index 6522ef7be2..0000000000
--- a/testsuites/sptests/spfatal24/init.c
+++ /dev/null
@@ -1,31 +0,0 @@
-#endif
-#include "../spfatal_support/spfatal.h"
- * COPYRIGHT (c) 1989-2010.
-#include <rtems/malloc.h>
-#define FATAL_ERROR_TEST_NAME "GXX KEY ADD FAILURE"
-#define FATAL_ERROR_DESCRIPTION "GXX KEY ADD FAILURE"
-#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_CORE
-#define FATAL_ERROR_EXPECTED_ERROR INTERNAL_ERROR_GXX_KEY_ADD_FAILED
-static void force_error(void)
- pthread_key_t key = -1;
- rtems_gxx_setspecific( &key, NULL );
-#include "../spfatal_support/spfatalimpl.h"
diff --git a/testsuites/sptests/spfatal24/spfatal24.doc b/testsuites/sptests/spfatal24/spfatal24.doc
index b697770085..0000000000
--- a/testsuites/sptests/spfatal24/spfatal24.doc
+++ /dev/null
@@ -1,19 +0,0 @@
-test set name: spfatal24
-directives:
- rtems_gxx_setspecific();
-concepts:
-+ Trigger fatal error.
diff --git a/testsuites/sptests/spfatal24/spfatal24.scn b/testsuites/sptests/spfatal24/spfatal24.scn
index 46a4f20409..0000000000
--- a/testsuites/sptests/spfatal24/spfatal24.scn
+++ /dev/null
@@ -1,3 +0,0 @@
-*** TEST FATAL GXX KEY ADD FAILURE ***
-Fatal error (GXX KEY ADD FAILURE) hit
-*** END OF TEST FATAL GXX KEY ADD FAILURE ***
diff --git a/testsuites/sptests/spfatal25/init.c b/testsuites/sptests/spfatal25/init.c
index 83042557e5..0000000000
--- a/testsuites/sptests/spfatal25/init.c
+++ /dev/null
@@ -1,33 +0,0 @@
-#endif
-#define FATAL_ERROR_TEST_NAME "GXX MUTEX INIT FAILED"
-#define FATAL_ERROR_DESCRIPTION "GXX MUTEX INIT FAILED"
-#define FATAL_ERROR_EXPECTED_ERROR INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED
- while ( true ) {
- rtems_gxx_mutex_init( &mutex );
diff --git a/testsuites/sptests/spfatal25/spfatal25.doc b/testsuites/sptests/spfatal25/spfatal25.doc
index e30241bc8b..0000000000
--- a/testsuites/sptests/spfatal25/spfatal25.doc
+++ /dev/null
@@ -1,19 +0,0 @@
-directives:
- rtems_gxx_getspecific();
-concepts:
diff --git a/testsuites/sptests/spfatal25/spfatal25.scn b/testsuites/sptests/spfatal25/spfatal25.scn
index 93a6b729b8..0000000000
--- a/testsuites/sptests/spfatal25/spfatal25.scn
+++ /dev/null
@@ -1,3 +0,0 @@
-*** TEST FATAL GXX MUTEX INIT FAILED ***
-Fatal error (GXX MUTEX INIT FAILED) hit
-*** END OF TEST FATAL GXX MUTEX INIT FAILED ***
2.31.1
