[PATCH] sptests: Avoid a dependency on errno
Thu Jan 27 13:21:19 UTC 2022
Avoid a dependency on errno which might be a thread-local object.  The tests
sp01, spstkalloc02, and sptls03 assume that no thread-local storage object is
present.
Update #4560.
 testsuites/sptests/sp01/system.h       | 7 ++++++-
 testsuites/sptests/spstkalloc02/init.c | 7 ++++++-
 testsuites/sptests/sptls03/init.c      | 7 ++++++-
 3 files changed, 18 insertions(+), 3 deletions(-)
diff --git a/testsuites/sptests/sp01/system.h b/testsuites/sptests/sp01/system.h
index d7990aeca8..82354b801e 100644
--- a/testsuites/sptests/sp01/system.h
+++ b/testsuites/sptests/sp01/system.h
@@ -21,9 +21,14 @@ rtems_task Task_1_through_3(
 /* configuration information */
-#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+ * Avoid a dependency on errno which might be a thread-local object.  This test
+ * assumes that no thread-local storage object is present.
+#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/sptests/spstkalloc02/init.c b/testsuites/sptests/spstkalloc02/init.c
index a2805d1164..6115b06413 100644
--- a/testsuites/sptests/spstkalloc02/init.c
+++ b/testsuites/sptests/spstkalloc02/init.c
@@ -117,9 +117,14 @@ static rtems_task Init(rtems_task_argument argument)
   rtems_test_exit(0);
 #define CONFIGURE_MAXIMUM_TASKS TASK_COUNT
 #define CONFIGURE_TASK_STACK_ALLOCATOR_INIT task_stack_init
diff --git a/testsuites/sptests/sptls03/init.c b/testsuites/sptests/sptls03/init.c
index ac46f068eb..d0aa60758d 100644
--- a/testsuites/sptests/sptls03/init.c
+++ b/testsuites/sptests/sptls03/init.c
@@ -48,7 +48,12 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS 1
2.26.2
