[PATCH v2] cpukit: Prevent error with disabled stack checker
Kinsey Moore kinsey.moore at oarcorp.com
Thu Jan 27 15:37:09 UTC 2022
When the stack checker is not enabled, the stack checker reporting
function can still be called. This prevents that call from performing a
null memory access in trying to find the high water mark if the stack
checker was never initialized.
This also introduces a test to ensure this call does not cause a crash.
Closes #4588
 cpukit/libmisc/stackchk/check.c               |  6 ++
 spec/build/testsuites/libtests/grp.yml        |  2 +
 spec/build/testsuites/libtests/stackchk02.yml | 19 ++++++
 testsuites/libtests/stackchk02/init.c         | 67 +++++++++++++++++++
 testsuites/libtests/stackchk02/stackchk02.doc | 16 +++++
 testsuites/libtests/stackchk02/stackchk02.scn |  8 +++
 6 files changed, 118 insertions(+)
 create mode 100644 spec/build/testsuites/libtests/stackchk02.yml
 create mode 100644 testsuites/libtests/stackchk02/init.c
 create mode 100644 testsuites/libtests/stackchk02/stackchk02.doc
 create mode 100644 testsuites/libtests/stackchk02/stackchk02.scn
diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
index a2b63345d9..386cb0d97d 100644
--- a/cpukit/libmisc/stackchk/check.c
+++ b/cpukit/libmisc/stackchk/check.c
@@ -410,6 +410,12 @@ static bool Stack_check_Dump_stack_usage(
   void     *low;
   void     *high_water_mark;
+  /* This is likely to occur if the stack checker is not actually enabled */
+  if ( stack->area == NULL ) {
+    rtems_printf(printer, "Stack usage information not available\n");
+    return false;
   low  = Stack_check_Usable_stack_start(stack);
   size = Stack_check_Usable_stack_size(stack);
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index cd5cc210e2..4717081312 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -249,6 +249,8 @@ links:
   uid: stackchk
 - role: build-dependency
   uid: stackchk01
+- role: build-dependency
+  uid: stackchk02
   uid: stat
diff --git a/spec/build/testsuites/libtests/stackchk02.yml b/spec/build/testsuites/libtests/stackchk02.yml
new file mode 100644
index 0000000000..4a4cbf9660
--- /dev/null
+++ b/spec/build/testsuites/libtests/stackchk02.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/stackchk02/init.c
+stlib: []
+target: testsuites/libtests/stackchk02.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/libtests/stackchk02/init.c b/testsuites/libtests/stackchk02/init.c
index 0000000000..0904e37c68
--- /dev/null
+++ b/testsuites/libtests/stackchk02/init.c
@@ -0,0 +1,67 @@
+ * @file
+ * @ingroup libtests
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include <tmacros.h>
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define TASK_STACK_SIZE (RTEMS_MINIMUM_STACK_SIZE*3)
+#define CONFIGURE_MAXIMUM_TASKS               1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
+#include <rtems/stackchk.h>
+const char rtems_test_name[] = "STACKCHK02";
+rtems_task Init(
+  rtems_task_argument argument
+  TEST_BEGIN();
+  rtems_stack_checker_report_usage();
+  TEST_END();
+  rtems_test_exit( 0 );
diff --git a/testsuites/libtests/stackchk02/stackchk02.doc b/testsuites/libtests/stackchk02/stackchk02.doc
index 0000000000..7907f216a8
--- /dev/null
+++ b/testsuites/libtests/stackchk02/stackchk02.doc
@@ -0,0 +1,16 @@
+#  COPYRIGHT (c) 2022.
+#  On-Line Applications Research Corporation (OAR).
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.org/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name: stackchk02
+directives:
+  + rtems_stack_checker_report_usage
+concepts:
+  + This task verifies that the stack checker will not perform bad
+    accesses when not properly enabled.
diff --git a/testsuites/libtests/stackchk02/stackchk02.scn b/testsuites/libtests/stackchk02/stackchk02.scn
index 0000000000..c0285a110c
--- /dev/null
+++ b/testsuites/libtests/stackchk02/stackchk02.scn
@@ -0,0 +1,8 @@
+*** TEST STACKCHK02 ***
+                             STACK USAGE BY THREAD
+ID         NAME                  LOW        HIGH       CURRENT     AVAIL   USED
+0x09010001 IDLE                  0x10104940 0x1010713f 0x10107140  10224 N/A
+0x0a010001 UI1                   0x10109950 0x1010c14f 0x1010c150  10224 N/A
+Stack usage information not available
+*** END OF TEST STACKCHK02 ***
2.30.2
