[PATCH 08/12] gcov: Add functions to dump the gcov information
Chris Johns
chrisj at rtems.org
Fri Jul 1 00:37:49 UTC 2022
On 29/6/2022 4:30 pm, Sebastian Huber wrote:
> Update #4670.
> cpukit/include/rtems/score/io.h | 4 +
> cpukit/include/rtems/test-info.h | 6 ++
> cpukit/libtest/testgcovdumpinfo.c | 66 ++++++++++++++
> cpukit/score/src/iogcovdumpinfo.c | 101 +++++++++++++++++++++
> cpukit/score/src/iogcovdumpinfobase64.c | 111 ++++++++++++++++++++++++
> spec/build/cpukit/librtemscpu.yml | 2 +
> spec/build/cpukit/librtemstest.yml | 1 +
> testsuites/validation/tc-terminate.c | 3 +-
> 8 files changed, 293 insertions(+), 1 deletion(-)
> create mode 100644 cpukit/libtest/testgcovdumpinfo.c
> create mode 100644 cpukit/score/src/iogcovdumpinfo.c
> create mode 100644 cpukit/score/src/iogcovdumpinfobase64.c
> diff --git a/cpukit/include/rtems/score/io.h b/cpukit/include/rtems/score/io.h
> index 106418f185..097cb9bdfe 100644
> --- a/cpukit/include/rtems/score/io.h
> +++ b/cpukit/include/rtems/score/io.h
> @@ -141,6 +141,10 @@ int _IO_Base64url(
> void _IO_Relax( void );
> +void _IO_Gcov_dump_info( IO_Put_char put_char, void *arg );
> +void _IO_Gcov_dump_info_base64( IO_Put_char put_char, void *arg );
Why just a per char interface? Given this is in the score a buffer plus length
interface would make more sense? It would make the interface more efficient.
The per char could be a convenience function version of the buffer and length
call for those use cases than want it, ie ....
> +static void _IO_Gcov_dump( const void *data, unsigned length, void *arg )
> + IO_Gcov_context *ctx;
> + IO_Put_char put_char;
> + void *ctx_arg;
> + const char *in;
> + const void *end;
> + ctx = arg;
> + in = data;
> + end = in + length;
> + put_char = ctx->put_char;
> + ctx_arg = ctx->arg;
> + while ( in != end ) {
> + ( *put_char )( *in, ctx_arg );
> + ++in;
