[PATCH v2 01/13] build: Add more flags to BuildItemContext
Sebastian Huber
Fri Jul 1 11:49:41 UTC 2022
Add cppflags, cflags, and cxxflags to BuildItemContext. This allows to
propagate the flags from parent items to child items.
Update #4670.
wscript | 93 +++++++++++++++++++++++++++++++++++++++++++--------------
1 file changed, 70 insertions(+), 23 deletions(-)
diff --git a/wscript b/wscript
index 8ad0ed30b1..e6abdaa7b5 100755
--- a/wscript
+++ b/wscript
@@ -513,6 +513,9 @@ class GroupItem(Item):
def prepare_build(self, bld, bic):
return BuildItemContext(
bic.includes + self.get_values(bld, "includes"),
+ bic.cppflags,
+ bic.cflags,
+ bic.cxxflags,
self.data["use-before"] + bic.use + self.data["use-after"],
bic.ldflags + self.get_values(bld, "ldflags"),
bic.objects,
@@ -578,13 +581,24 @@ class ObjectsItem(Item):
def __init__(self, uid, data):
super(ObjectsItem, self).__init__(uid, data)
+ def prepare_build(self, bld, bic):
+ return BuildItemContext(
+ bic.includes + self.substitute(bld, self.data["includes"]),
+ bic.cppflags + self.substitute(bld, self.data["cppflags"]),
+ bic.cflags + self.substitute(bld, self.data["cflags"]),
+ bic.cxxflags + self.substitute(bld, self.data["cxxflags"]),
+ bic.use,
+ bic.ldflags,
+ bic.objects,
def do_build(self, bld, bic):
bld.objects(
- asflags=self.substitute(bld, self.data["cppflags"]),
- cflags=self.substitute(bld, self.data["cflags"]),
- cppflags=self.substitute(bld, self.data["cppflags"]),
- cxxflags=self.substitute(bld, self.data["cxxflags"]),
- includes=bic.includes + self.substitute(bld, self.data["includes"]),
+ asflags=bic.cppflags,
+ cflags=bic.cflags,
+ cppflags=bic.cppflags,
+ cxxflags=bic.cxxflags,
+ includes=bic.includes,
source=self.data["source"],
target=self.uid,
@@ -600,15 +614,23 @@ class BSPItem(Item):
- bic.includes + bld.env.BSP_INCLUDES.split(), [], [], []
+ bic.includes
+ + bld.env.BSP_INCLUDES.split()
+ + self.substitute(bld, self.data["includes"]),
bld(
features="c cstlib",
install_path="${BSP_LIBDIR}",
target="rtemsbsp",
@@ -622,15 +644,23 @@ class LibraryItem(Item):
super(LibraryItem, self).__init__(uid, data)
- return BuildItemContext(bic.includes, [], [], [])
+ bic.use,
+ bic.ldflags,
bld(
features="c cxx cstlib",
install_path=self.data["install-path"],
target=self.get(bld, "target"),
@@ -650,22 +680,32 @@ class TestProgramItem(Item):
return [{"and": [{"not": self.exclude}, self.data["enabled-by"]]}]
- return BuildItemContext(bic.includes, bic.use, bic.ldflags, [])
+ bic.cppflags
+ + bld.env[self.cppflags]
+ + self.substitute(bld, self.data["cppflags"]),
+ self.data["use-before"] + bic.use + self.data["use-after"],
+ bic.ldflags + self.substitute(bld, self.data["ldflags"]),
bld(
- cppflags=bld.env[self.cppflags] + self.substitute(bld, self.data["cppflags"]),
features=self.data["features"],
install_path=None,
- ldflags=bic.ldflags + self.substitute(bld, self.data["ldflags"]),
+ ldflags=bic.ldflags,
start_files=True,
stlib=self.data["stlib"],
- use=bic.objects + self.data["use-before"] + bic.use + self.data["use-after"],
+ use=bic.objects + bic.use,
@@ -1105,8 +1145,13 @@ class ConfigItemContext(object):
class BuildItemContext(object):
- def __init__(self, includes, use, ldflags, objects):
+ def __init__(
+ self, includes, cppflags, cflags, cxxflags, use, ldflags, objects
self.includes = includes
+ self.cppflags = cppflags
+ self.cflags = cflags
+ self.cxxflags = cxxflags
self.use = use
self.ldflags = ldflags
self.objects = objects
@@ -1555,7 +1600,9 @@ def build(bld):
append_variant_builds(bld)
return
long_command_line_workaround(bld)
- bic = BuildItemContext(bld.env.ARCH_INCLUDES.split(), [], [], [])
+ bic = BuildItemContext(
+ bld.env.ARCH_INCLUDES.split(), [], [], [], [], [], []
bsps[bld.env.ARCH][bld.env.BSP_BASE].build(bld, bic)
items[bld.env.TOPGROUP].build(bld, bic)
2.35.3
