[PATCH v2 07/13] build: Allow separate optimization flags
Sebastian Huber
Fri Jul 1 11:49:47 UTC 2022
Allow separate optimization flags for the BSP, cpukit, and tests. For example,
the BSP and cpukit may be built without optimization if coverage
instrumentation is enabled, however, the tests may still use optimization.
Update #4670.
spec/build/bsps/bspopts.yml | 8 ++++++++
spec/build/bsps/optbspoptflags.yml | 18 ++++++++++++++++++
spec/build/bsps/optcflags.yml | 17 +++++++++++++++++
spec/build/bsps/optcpukitoptflags.yml | 18 ++++++++++++++++++
spec/build/bsps/opto0.yml | 4 +---
spec/build/bsps/opto1.yml | 4 +---
spec/build/bsps/opto2.yml | 4 +---
spec/build/bsps/optog.yml | 4 +---
spec/build/bsps/optos.yml | 4 +---
spec/build/bsps/opttestoptflags.yml | 18 ++++++++++++++++++
spec/build/cpukit/grp.yml | 6 ++++--
spec/build/testsuites/grp.yml | 6 ++++--
wscript | 2 +-
13 files changed, 93 insertions(+), 20 deletions(-)
create mode 100644 spec/build/bsps/optbspoptflags.yml
create mode 100644 spec/build/bsps/optcflags.yml
create mode 100644 spec/build/bsps/optcpukitoptflags.yml
create mode 100644 spec/build/bsps/opttestoptflags.yml
diff --git a/spec/build/bsps/bspopts.yml b/spec/build/bsps/bspopts.yml
index d43136e94e..4a4c06d321 100644
--- a/spec/build/bsps/bspopts.yml
+++ b/spec/build/bsps/bspopts.yml
@@ -7,6 +7,12 @@ guard: __BSP_OPTIONS_H
include-headers: []
install-path: ${BSP_INCLUDEDIR}
links:
+- role: build-dependency
+ uid: optbspoptflags
+ uid: optcpukitoptflags
+ uid: opttestoptflags
uid: optabi
@@ -17,6 +23,8 @@ links:
uid: optfatalverb
uid: optincludes
+ uid: optcflags
uid: optlinkflags
diff --git a/spec/build/bsps/optbspoptflags.yml b/spec/build/bsps/optbspoptflags.yml
new file mode 100644
index 0000000000..40dbb6c7ab
--- /dev/null
+++ b/spec/build/bsps/optbspoptflags.yml
@@ -0,0 +1,18 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- substitute: null
+- split: null
+- env-assign: null
+build-type: option
+copyrights:
+- Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+default: ${OPTIMIZATION_FLAGS}
+default-by-variant: []
+description: |
+ Optimization flags passed to C and C++ compilers for the BSP.
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_OPTIMIZATION_FLAGS
+type: build
diff --git a/spec/build/bsps/optcflags.yml b/spec/build/bsps/optcflags.yml
index 0000000000..ef03940bff
--- /dev/null
+++ b/spec/build/bsps/optcflags.yml
@@ -0,0 +1,17 @@
+actions:
+- set-value: |
+ ${BSP_OPTIMIZATION_FLAGS}
+- substitute: null
+- split: null
+- env-assign: null
+build-type: option
+copyrights:
+default: null
+description: ''
+enabled-by: true
+links: []
+name: BSP_CFLAGS
+type: build
diff --git a/spec/build/bsps/optcpukitoptflags.yml b/spec/build/bsps/optcpukitoptflags.yml
index 0000000000..3baec4b8c8
--- /dev/null
+++ b/spec/build/bsps/optcpukitoptflags.yml
@@ -0,0 +1,18 @@
+actions:
+- get-string: null
+- substitute: null
+- split: null
+- env-assign: null
+build-type: option
+copyrights:
+description: |
+ Optimization flags passed to C and C++ compilers for the CPU kit.
+enabled-by: true
+format: '{}'
+links: []
+name: CPUKIT_OPTIMIZATION_FLAGS
+type: build
diff --git a/spec/build/bsps/opto0.yml b/spec/build/bsps/opto0.yml
index 406286980f..9f54709c07 100644
--- a/spec/build/bsps/opto0.yml
+++ b/spec/build/bsps/opto0.yml
@@ -3,8 +3,6 @@ actions:
- get-string: null
- split: null
- env-assign: null
-- env-append: CFLAGS
-- env-append: CXXFLAGS
build-type: option
copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
@@ -15,7 +13,7 @@ default:
- -ffunction-sections
description: |
- Optimization flags passed to the C and C++ compiler
+ Default optimization flags for C and C++ compilers.
enabled-by: true
links: []
diff --git a/spec/build/bsps/opto1.yml b/spec/build/bsps/opto1.yml
index 52d285c2ab..e0668a887b 100644
--- a/spec/build/bsps/opto1.yml
+++ b/spec/build/bsps/opto1.yml
- get-string: null
- split: null
- env-assign: null
build-type: option
copyrights:
description: |
enabled-by: true
links: []
diff --git a/spec/build/bsps/opto2.yml b/spec/build/bsps/opto2.yml
index 071e5411d5..7b54556c5b 100644
--- a/spec/build/bsps/opto2.yml
+++ b/spec/build/bsps/opto2.yml
- get-string: null
- split: null
- env-assign: null
build-type: option
copyrights:
description: |
enabled-by: true
links: []
diff --git a/spec/build/bsps/optog.yml b/spec/build/bsps/optog.yml
index d08bd7b2b2..2eab2acdd1 100644
--- a/spec/build/bsps/optog.yml
+++ b/spec/build/bsps/optog.yml
- get-string: null
- split: null
- env-assign: null
build-type: option
copyrights:
description: |
enabled-by: true
links: []
diff --git a/spec/build/bsps/optos.yml b/spec/build/bsps/optos.yml
index df9e0efd02..1c2c106064 100644
--- a/spec/build/bsps/optos.yml
+++ b/spec/build/bsps/optos.yml
- get-string: null
- split: null
- env-assign: null
build-type: option
copyrights:
description: |
enabled-by: true
links: []
diff --git a/spec/build/bsps/opttestoptflags.yml b/spec/build/bsps/opttestoptflags.yml
index 0000000000..43e0c92c07
--- /dev/null
+++ b/spec/build/bsps/opttestoptflags.yml
@@ -0,0 +1,18 @@
+actions:
+- get-string: null
+- substitute: null
+- split: null
+- env-assign: null
+build-type: option
+copyrights:
+description: |
+ Optimization flags passed to C and C++ compiler for tests.
+enabled-by: true
+format: '{}'
+links: []
+name: TEST_OPTIMIZATION_FLAGS
+type: build
diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
index 24aa2f0634..ec9cab2167 100644
--- a/spec/build/cpukit/grp.yml
+++ b/spec/build/cpukit/grp.yml
@@ -1,10 +1,12 @@
build-type: group
-cflags: []
+cflags:
+- ${CPUKIT_OPTIMIZATION_FLAGS}
copyrights:
cppflags: []
-cxxflags: []
+cxxflags:
enabled-by: true
includes: []
install: []
diff --git a/spec/build/testsuites/grp.yml b/spec/build/testsuites/grp.yml
index 82c7b87f2e..18c8ccd4d8 100644
--- a/spec/build/testsuites/grp.yml
+++ b/spec/build/testsuites/grp.yml
@@ -1,10 +1,12 @@
build-type: group
-cflags: []
+cflags:
+- ${TEST_OPTIMIZATION_FLAGS}
copyrights:
cppflags: []
-cxxflags: []
+cxxflags:
enabled-by: true
includes:
- ${BSP_INCLUDES}
diff --git a/wscript b/wscript
index 9894dcd7fd..4071cc9ef8 100755
--- a/wscript
+++ b/wscript
@@ -625,7 +625,7 @@ class BSPItem(Item):
+ bld.env.BSP_INCLUDES
+ self.substitute(bld, self.data["includes"]),
self.substitute(bld, self.data["cppflags"]),
- self.substitute(bld, self.data["cflags"]),
+ bld.env.BSP_CFLAGS + self.substitute(bld, self.data["cflags"]),
2.35.3
