[PATCH v2 08/13] gcov: Add fork(), etc. gcov wrappers
Sebastian Huber
Fri Jul 1 11:49:48 UTC 2022
The compiler wraps fork(), etc. system calls if coverage generation is enabled.
These functions must be provided by the system. For RTEMS, they just return an
error status.
Update #4670.
cpukit/libcsupport/src/gcovfork.c | 94 +++++++++++++++++++++++++++++++
spec/build/cpukit/librtemscpu.yml | 1 +
2 files changed, 95 insertions(+)
create mode 100644 cpukit/libcsupport/src/gcovfork.c
diff --git a/cpukit/libcsupport/src/gcovfork.c b/cpukit/libcsupport/src/gcovfork.c
new file mode 100644
index 0000000000..763412d735
--- /dev/null
+++ b/cpukit/libcsupport/src/gcovfork.c
@@ -0,0 +1,94 @@
+ * @file
+ * @ingroup libcsupport
+ * @brief This source file contains functions required by GCC if code and
+ * branch coverage instrumentation (gcov) is enabled.
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/types.h>
+#include <errno.h>
+#include <rtems/seterr.h>
+int __gcov_execl( const char *, char *, ... );
+int __gcov_execl( const char *path, char *arg, ... )
+ rtems_set_errno_and_return_minus_one( ENOSYS );
+int __gcov_execlp( const char *, char *, ... );
+int __gcov_execlp( const char *path, char *arg, ... )
+int __gcov_execle( const char *, char *, ... );
+int __gcov_execle( const char *path, char *arg, ... )
+int __gcov_execv( const char *, char *const[] );
+int __gcov_execv( const char *path, char *const argv[] )
+int __gcov_execvp( const char *, char *const[] );
+int __gcov_execvp( const char *path, char *const argv[] )
+int __gcov_execve( const char *, char *const[], char *const[] );
+int __gcov_execve( const char *path, char *const argv[], char *const envp[] )
+pid_t __gcov_fork( void );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 965419c389..4a8a0ee1ad 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -640,6 +640,7 @@ source:
- cpukit/libcsupport/src/ftruncate.c
- cpukit/libcsupport/src/ftrylockfile.c
- cpukit/libcsupport/src/funlockfile.c
+- cpukit/libcsupport/src/gcovfork.c
- cpukit/libcsupport/src/getchark.c
- cpukit/libcsupport/src/getdents.c
- cpukit/libcsupport/src/getegid.c
2.35.3
