[PATCH v2 10/13] gcov: Add wrapper to dump the gcov info
Fri Jul 1 11:49:50 UTC 2022
Update #4670.
 cpukit/libtest/testgcovbspreset.c     | 54 +++++++++++++++++++++++++++
 cpukit/libtest/testgcovcpufatalhalt.c | 54 +++++++++++++++++++++++++++
 spec/build/cpukit/librtemstest.yml    |  2 +
 3 files changed, 110 insertions(+)
 create mode 100644 cpukit/libtest/testgcovbspreset.c
 create mode 100644 cpukit/libtest/testgcovcpufatalhalt.c
diff --git a/cpukit/libtest/testgcovbspreset.c b/cpukit/libtest/testgcovbspreset.c
new file mode 100644
index 0000000000..6e10615f8c
--- /dev/null
+++ b/cpukit/libtest/testgcovbspreset.c
@@ -0,0 +1,54 @@
+ * @file
+ * @ingroup RTEMSTest
+ * @brief This source file contains the implementation of a wrapper for
+ *   bsp_reset() which dumps the gcov information using
+ *   rtems_test_gcov_dump_info() before the real bsp_reset() is called.
+ * Copyright (C) 2021, 2022 embedded brains GmbH
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test-info.h>
+#include <rtems/score/cpu.h>
+void __real_bsp_reset( void );
+void __wrap_bsp_reset( void );
+  rtems_test_gcov_dump_info();
+  __real_bsp_reset();
diff --git a/cpukit/libtest/testgcovcpufatalhalt.c b/cpukit/libtest/testgcovcpufatalhalt.c
index 0000000000..dd8f10149c
--- /dev/null
+++ b/cpukit/libtest/testgcovcpufatalhalt.c
@@ -0,0 +1,54 @@
+ * @file
+ *   _CPU_Fatal_halt() which dumps the gcov information using
+ *   rtems_test_gcov_dump_info() before the real _CPU_Fatal_halt() is called.
+ * are met:
+#endif
+void __real__CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error );
+void __wrap__CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error );
+  __real__CPU_Fatal_halt( source, error );
diff --git a/spec/build/cpukit/librtemstest.yml b/spec/build/cpukit/librtemstest.yml
index cb04690066..ddbf6e3e76 100644
--- a/spec/build/cpukit/librtemstest.yml
+++ b/spec/build/cpukit/librtemstest.yml
@@ -38,6 +38,8 @@ source:
 - cpukit/libtest/testbeginend.c
 - cpukit/libtest/testbusy.c
 - cpukit/libtest/testextension.c
+- cpukit/libtest/testgcovcpufatalhalt.c
+- cpukit/libtest/testgcovbspreset.c
 - cpukit/libtest/testgcovdumpinfo.c
 - cpukit/libtest/testparallel.c
 - cpukit/libtest/testrun.c
2.35.3
