[PATCH rtems-lwip v1 3/9] telnetd01: Break out network startup
Kinsey Moore kinsey.moore at oarcorp.com
Fri Jul 1 22:31:06 UTC 2022
This moves network startup in to a BSP-defined function so that tests
can be more generic.
 rtemslwip/beaglebone/netstart.c | 43 +++++++++++++++++++++++++++++++++
 rtemslwip/include/netstart.h    | 41 +++++++++++++++++++++++++++++++
 rtemslwip/test/telnetd01/init.c | 26 +++++++++++++++++---
 3 files changed, 107 insertions(+), 3 deletions(-)
 create mode 100644 rtemslwip/beaglebone/netstart.c
 create mode 100644 rtemslwip/include/netstart.h
diff --git a/rtemslwip/beaglebone/netstart.c b/rtemslwip/beaglebone/netstart.c
new file mode 100644
index 0000000..33384b6
--- /dev/null
+++ b/rtemslwip/beaglebone/netstart.c
@@ -0,0 +1,43 @@
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <netstart.h>
+#include "soc_AM335x.h"
+#include "beaglebone.h"
+#include <lwip/tcpip.h>
+int start_networking(
+  struct netif  *net_interface,
+  ip_addr_t     *ipaddr,
+  ip_addr_t     *netmask,
+  ip_addr_t     *gateway,
+  unsigned char *mac_ethernet_address
+  tcpip_init( NULL, NULL );
+  return 0;
diff --git a/rtemslwip/include/netstart.h b/rtemslwip/include/netstart.h
index 0000000..d5c58d4
--- /dev/null
+++ b/rtemslwip/include/netstart.h
@@ -0,0 +1,41 @@
+ * are met:
+#ifndef _RTEMSLWIP_NETSTART_H
+#define _RTEMSLWIP_NETSTART_H
+#include <lwip/init.h>
+#include <lwip/sockets.h>
+#include <lwip/ip_addr.h>
+#endif
diff --git a/rtemslwip/test/telnetd01/init.c b/rtemslwip/test/telnetd01/init.c
index 0a20bd8..a671fdd 100644
--- a/rtemslwip/test/telnetd01/init.c
+++ b/rtemslwip/test/telnetd01/init.c
@@ -28,13 +28,15 @@
 #include <rtems/telnetd.h>
 #include <lwip/dhcp.h>
-#include <lwip/tcpip.h>
+#include <arch/sys_arch.h>
 #include <tmacros.h>
 const char rtems_test_name[] = "TELNETD 1";
-//struct rtems_bsdnet_config rtems_bsdnet_config;
+struct netif net_interface;
 rtems_shell_env_t env;
@@ -86,10 +88,28 @@ rtems_shell_cmd_t shell_NETINFO_Command = {
 static rtems_task Init( rtems_task_argument argument )
   rtems_status_code sc;
+  int ret;
   TEST_BEGIN();
-  lwip_init();
+  ip_addr_t ipaddr, netmask, gw;
+  IP_ADDR4( &ipaddr, 10, 0, 2, 14 );
+  IP_ADDR4( &netmask, 255, 255, 255, 0 );
+  IP_ADDR4( &gw, 10, 0, 2, 3 );
+  unsigned char mac_ethernet_address[] = { 0x00, 0x0a, 0x35, 0x00, 0x22, 0x01 };
+  ret = start_networking(
+    &net_interface,
+    &ipaddr,
+    &netmask,
+    &gw,
+    mac_ethernet_address
+  if ( ret != 0 ) {
+    return;
   rtems_shell_init_environment();
2.30.2
