[PATCH rtems-lwip v1 9/9] lwip.py: Remove dead code
Kinsey Moore kinsey.moore at oarcorp.com
Fri Jul 1 22:31:12 UTC 2022
 lwip.py | 8 --------
 1 file changed, 8 deletions(-)
diff --git a/lwip.py b/lwip.py
index 335fb18..3e89026 100644
--- a/lwip.py
+++ b/lwip.py
@@ -75,14 +75,6 @@ def build(bld):
     source_files.append('./uLan/ports/os/rtems/arch/sys_arch.c')
     source_files.append('./rtemslwip/common/syslog.c')
-    #source_files.append('./lwip/ports/port/sys_arch.c')
-    #source_files.append('./lwip/ports/port/perf.c')
-    #source_files.append('./lwip/ports/port/netif/fifo.c')
-    #source_files.append('./lwip/ports/port/netif/list.c')
-    #source_files.append('./lwip/ports/port/netif/pcapif.c')
-    #source_files.append('./lwip/ports/port/netif/sio.c')
-    #source_files.append('./lwip/ports/port/netif/tapif.c')
     def walk_sources(path):
         sources = []
         for root, dirs, files in os.walk(path):
2.30.2
