Integrating the Formal Methods part of Qualification
Chris Johns
chrisj at rtems.org
Mon Jul 4 01:49:06 UTC 2022
On 2/7/2022 12:59 am, Andrew Butterfield wrote:
> On 1 Jul 2022, at 00:59, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>> On 28/6/2022 11:09 pm, Andrew.Butterfield at scss.tcd.ie
>> <mailto:Andrew.Butterfield at scss.tcd.ie> wrote:
>>> Dear RTEMS Developers,
>>> While the validation tests from the RTEMS pre-qualification activity are
>>> now merged into the RTEMS master, the work done in investigating and
>>> deploying formal methods techniques is not yet merged.
>>> The activity had two main phases: a planning phase (Nov 2018-Oct 2019)
>>> that explored various formal techniques, followed by an execution phase
>>> (Oct 2019-Nov 2021) that then applied selected techniques to selected
>>> parts of RTEMS. Some discussions occurred with the RTEMS community
>>> via the mailings lists over this time. A short third phase (Nov 2021 - Dec 2021)
>>> then reported on the outcomes. Each phase resulted in a technical report.
>>> The key decision made was to use Promela/SPIN for test generation, and
>>> to apply it to the Chains API, the Event Manager, and the SMP scheduler
>>> thread queues. This involved developing models in the Promela language
>>> and using the SPIN model-checker tool to both check their correctness
>>> and to generate execution scenarios that could be used to generate tests.
>>> Tools were developed using Python 3.8 to support this. Initial documentation
>>> about tools and how to use them was put into the 2nd phase report.
>> Congratulations for the work and results you and others have managed to achieve.
>> It is exciting to see this happening with RTEMS and being made public.
>>> We now come to the part where we explore the best way to integrate this
>>> into RTEMS. I am proposing to do this under the guidance of Sebastian Huber.
>>> The first suggested step is adding in new documentation to the RTEMS
>>> Software Engineering manual, as a new Formal Methods chapter. This would
>>> provide some motivation, as well as a "howto".
>>> I assume that I would initially describe the proposed changes using the patch
>>> review process described in the section on Preparing and Sending Patches in
>>> the User Manual.
>>> How do you feel I should best proceed?
>> It is hard for me to answer until I understand what is being submitted and who
>> maintains it? I am sure you understand this due to the specialised nature of the
>> work.
> Indeed, I quite agree. I have some short answers below, with suggestions.
Thanks.
>> What will be submitted, ie SPIN files, scripts, etc?
> Promela/SPIN model files (ASCII text, C-like syntax)
> C template files (.h,.c) to assist test code generation
> YAML files to provide a mapping from model concepts to RTEMS C test code
> python scripts to automate the test generation
> Documentation - largely RTEMS compliant sphinx sources (.rst)
>> Where are you looking to add these pieces?
> Everything except the documentation could live in a top-level folder ('formal')
> in rtems-central.
> In fact there is no particular constraint from my perspective for where they can go.
Using rtems-central is fine.
> The plan would be to add the pertinent parts of our project documentation into
> new chapters
> in the RTEMS software engineering manual. So that would be eng/ in the
> rtems-docs repo.
Great.
>> How is the verification run against the code? Do we manage regression testing
>> and is that even possible?
> The python scripts basically run SPIN in such a way as to generate scenarios
> that model
> correct behaviour which then get turned into standard RTEMS test programs. These all
> get added into a new testsuite in the rtems repo (testsuites/models, say).
> They are properly integrated into the RTEMS test system, so get built and run by
> waf.
> This is similar to how the tests generated by Sebastian in testsuites/validation
> are handled.
> From the perspective of a user that works out of git.rtems.org/rtems
> <http://git.rtems.org/rtems>,
> there will be no obvious impact - just some extra tests in among the ones that
> already exist.
Thanks and this make sense.
>> I hope my simple questions highlight a lack of understand on how this works and
>> how we maintain it and use it once integrated.
> I intend to continue to work and maintain this for the foreseeable future. I
> would hope as this beds in that other Promela/SPIN users out there will also get
> more involved over time.
Thank, it is appreciated.
> It is expected that Promela models will be as static as the corresponding APIs.
> They capture the specified behaviour of API calls, not their detailed
> implementation.
> The python scripts should also be fairly stable, although I can see some
> tweaking for a while to improve workflow issues that might arise.
> There are some extra python libraries that are required over and above what is
> currently specified in rtems-central/requirements.txt
This all makes sense to me. Thank you for taking the time to respond.
