[PATCH v2] irq/arm-gicv3.h: Customize ICC_IGRPEN0/1 init
Sebastian Huber
Mon Jul 4 06:06:42 UTC 2022
On 04/07/2022 03:43, Chris Johns wrote:
> On 1/7/2022 11:21 pm, Sebastian Huber wrote:
>> Use the existing WRITE_SR() abstraction to access the interrupt group 0 and 1
>> enable registers. This fixes the build for the AArch32 target.
>> bsps/include/dev/irq/arm-gicv3.h | 30 ++++++++-----------
>> spec/build/bsps/aarch64/a53/grp.yml | 2 ++
>> spec/build/bsps/aarch64/a53/obj.yml | 1 -
>> spec/build/bsps/aarch64/a72/grp.yml | 2 ++
>> spec/build/bsps/aarch64/a72/obj.yml | 1 -
>> spec/build/bsps/aarch64/grp.yml | 1 -
>> spec/build/bsps/aarch64/xilinx-versal/grp.yml | 2 ++
>> spec/build/bsps/aarch64/xilinx-versal/obj.yml | 1 -
>> spec/build/bsps/arm/fvp/grp.yml | 2 ++
>> spec/build/bsps/arm/fvp/obj.yml | 1 -
>> spec/build/bsps/arm/grp.yml | 1 -
>> spec/build/bsps/objarmgic.yml | 21 +++++++++++++
>> spec/build/bsps/optarmgic-icc-igrpen0.yml | 20 +++++++++++++
>> spec/build/bsps/optarmgic-icc-igrpen1.yml | 17 +++++++++++
>> 14 files changed, 78 insertions(+), 24 deletions(-)
>> create mode 100644 spec/build/bsps/objarmgic.yml
>> create mode 100644 spec/build/bsps/optarmgic-icc-igrpen0.yml
>> create mode 100644 spec/build/bsps/optarmgic-icc-igrpen1.yml
>> diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
>> index a79368ebdf..4cd8cfaaed 100644
>> --- a/bsps/include/dev/irq/arm-gicv3.h
>> +++ b/bsps/include/dev/irq/arm-gicv3.h
>> @@ -116,9 +116,11 @@ extern "C" {
>> #else /* ARM_MULTILIB_ARCH_V4 */
>> /* AArch64 GICv3 registers are not named in GCC */
>> -#define ICC_IGRPEN0 "S3_0_C12_C12_6, %0"
>> -#define ICC_IGRPEN1 "S3_0_C12_C12_7, %0"
>> +#define ICC_IGRPEN0_EL1 "S3_0_C12_C12_6, %0"
>> +#define ICC_IGRPEN1_EL1 "S3_0_C12_C12_7, %0"
>> #define ICC_IGRPEN1_EL3 "S3_6_C12_C12_7, %0"
>> +#define ICC_IGRPEN0 ICC_IGRPEN0_EL1
>> +#define ICC_IGRPEN1 ICC_IGRPEN1_EL1
>> #define ICC_PMR "S3_0_C4_C6_0, %0"
>> #define ICC_EOIR1 "S3_0_C12_C12_1, %0"
>> #define ICC_SRE "S3_0_C12_C12_5, %0"
>> @@ -300,20 +302,6 @@ static void gicv3_init_dist(volatile gic_dist *dist)
>> - * A better way to access these registers than special opcodes
>> -#define isb() __asm __volatile("isb" : : : "memory")
>> -#define WRITE_SPECIALREG(reg, _val) \
>> - __asm __volatile("msr " __STRING(reg) ", %0" : : "r"((uint64_t)_val))
>> -#define gic_icc_write(reg, val) \
>> -do { \
>> - WRITE_SPECIALREG(icc_ ##reg ##_el1, val); \
>> - isb(); \
>> -} while (0)
>> static void gicv3_init_cpu_interface(uint32_t cpu_index)
>> uint32_t sre_value = 0x7;
>> @@ -334,8 +322,14 @@ static void gicv3_init_cpu_interface(uint32_t cpu_index)
>> sgi_ppi->icspiprior[id] = PRIORITY_DEFAULT;
>> - /* Enable interrupt groups 0 and 1 */
>> - gic_icc_write(IGRPEN1, 1);
>> + /* Initialize the group 0 and 1 interrupt enable */
>> +#ifdef BSP_ARM_GIC_ICC_IGRPEN0
>> + WRITE_SR(ICC_IGRPEN0, BSP_ARM_GIC_ICC_IGRPEN0);
>> +#endif
> I think more things will surface in this driver over time and configuring at the
> per register level may become unwieldy. This write depends on the EL levels
> available, secure/non-secure support and the boot wrapper used for the different
> classes of devices. Maybe the config support and macro reflecting this would
> serve us better over time?
I also thought about using a general define for this, however, the
ICC_BPR0 and ICC_BPR1 have processor- and application specific values.
My plan was to add BSP options for these registers in a follow up patch.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
