[PATCH v2] irq/arm-gicv3.h: Customize ICC_IGRPEN0/1 init
Sebastian Huber
Tue Jul 5 05:53:16 UTC 2022
On 05/07/2022 00:28, Chris Johns wrote:
> On 4/7/2022 4:06 pm, Sebastian Huber wrote:
>> On 04/07/2022 03:43, Chris Johns wrote:
>>> On 1/7/2022 11:21 pm, Sebastian Huber wrote:
>>>> Use the existing WRITE_SR() abstraction to access the interrupt group 0 and 1
>>>> enable registers. This fixes the build for the AArch32 target.
>>>> bsps/include/dev/irq/arm-gicv3.h | 30 ++++++++-----------
>>>> spec/build/bsps/aarch64/a53/grp.yml | 2 ++
>>>> spec/build/bsps/aarch64/a53/obj.yml | 1 -
>>>> spec/build/bsps/aarch64/a72/grp.yml | 2 ++
>>>> spec/build/bsps/aarch64/a72/obj.yml | 1 -
>>>> spec/build/bsps/aarch64/grp.yml | 1 -
>>>> spec/build/bsps/aarch64/xilinx-versal/grp.yml | 2 ++
>>>> spec/build/bsps/aarch64/xilinx-versal/obj.yml | 1 -
>>>> spec/build/bsps/arm/fvp/grp.yml | 2 ++
>>>> spec/build/bsps/arm/fvp/obj.yml | 1 -
>>>> spec/build/bsps/arm/grp.yml | 1 -
>>>> spec/build/bsps/objarmgic.yml | 21 +++++++++++++
>>>> spec/build/bsps/optarmgic-icc-igrpen0.yml | 20 +++++++++++++
>>>> spec/build/bsps/optarmgic-icc-igrpen1.yml | 17 +++++++++++
>>>> 14 files changed, 78 insertions(+), 24 deletions(-)
>>>> create mode 100644 spec/build/bsps/objarmgic.yml
>>>> create mode 100644 spec/build/bsps/optarmgic-icc-igrpen0.yml
>>>> create mode 100644 spec/build/bsps/optarmgic-icc-igrpen1.yml
>>>> diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
>>>> index a79368ebdf..4cd8cfaaed 100644
>>>> --- a/bsps/include/dev/irq/arm-gicv3.h
>>>> +++ b/bsps/include/dev/irq/arm-gicv3.h
>>>> @@ -116,9 +116,11 @@ extern "C" {
>>>> #else /* ARM_MULTILIB_ARCH_V4 */
>>>> /* AArch64 GICv3 registers are not named in GCC */
>>>> -#define ICC_IGRPEN0 "S3_0_C12_C12_6, %0"
>>>> -#define ICC_IGRPEN1 "S3_0_C12_C12_7, %0"
>>>> +#define ICC_IGRPEN0_EL1 "S3_0_C12_C12_6, %0"
>>>> +#define ICC_IGRPEN1_EL1 "S3_0_C12_C12_7, %0"
>>>> #define ICC_IGRPEN1_EL3 "S3_6_C12_C12_7, %0"
>>>> +#define ICC_IGRPEN0 ICC_IGRPEN0_EL1
>>>> +#define ICC_IGRPEN1 ICC_IGRPEN1_EL1
>>>> #define ICC_PMR "S3_0_C4_C6_0, %0"
>>>> #define ICC_EOIR1 "S3_0_C12_C12_1, %0"
>>>> #define ICC_SRE "S3_0_C12_C12_5, %0"
>>>> @@ -300,20 +302,6 @@ static void gicv3_init_dist(volatile gic_dist *dist)
>>>> - * A better way to access these registers than special opcodes
>>>> -#define isb() __asm __volatile("isb" : : : "memory")
>>>> -#define WRITE_SPECIALREG(reg, _val) \
>>>> - __asm __volatile("msr " __STRING(reg) ", %0" : : "r"((uint64_t)_val))
>>>> -#define gic_icc_write(reg, val) \
>>>> -do { \
>>>> - WRITE_SPECIALREG(icc_ ##reg ##_el1, val); \
>>>> - isb(); \
>>>> -} while (0)
>>>> static void gicv3_init_cpu_interface(uint32_t cpu_index)
>>>> uint32_t sre_value = 0x7;
>>>> @@ -334,8 +322,14 @@ static void gicv3_init_cpu_interface(uint32_t cpu_index)
>>>> sgi_ppi->icspiprior[id] = PRIORITY_DEFAULT;
>>>> - /* Enable interrupt groups 0 and 1 */
>>>> - gic_icc_write(IGRPEN1, 1);
>>>> + /* Initialize the group 0 and 1 interrupt enable */
>>>> +#ifdef BSP_ARM_GIC_ICC_IGRPEN0
>>>> + WRITE_SR(ICC_IGRPEN0, BSP_ARM_GIC_ICC_IGRPEN0);
>>>> +#endif
>>> I think more things will surface in this driver over time and configuring at the
>>> per register level may become unwieldy. This write depends on the EL levels
>>> available, secure/non-secure support and the boot wrapper used for the different
>>> classes of devices. Maybe the config support and macro reflecting this would
>>> serve us better over time?
>> I also thought about using a general define for this, however, the ICC_BPR0 and
>> ICC_BPR1 have processor- and application specific values.
> This maybe the case for R class devices. A and M should or will use TF-[A/M] and
> I have no idea what boot stack is present for R so I cannot comment.
The Cortex-M usually have another interrupt controller.
>> My plan was to add BSP options for these registers in a follow up patch.
> I see the spec support in this patch more of an issue than the exact define in
> the code here. Others look and then copy what they see and per reg options is
> rarely the best approach.
The real problem are people doing their first BSP development in
isolation. There is plenty of bad code to copy from.
> What about a BSP or class specific call to allow localised initialisation and
> then we can avoid these defines? Maybe the BSP should set this up before
> starting the system? I do not know which path is the best one.
We just have to set up four registers in the GIC CPU Interface (the
group enable and the binary point). I don't think we need another layer
of complexity. The GICv3 support is added to a BSP via:
+- role: build-dependency
+ uid: ../../objarmgic
Ok, this should be objarmgicv3.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
