[tools] tester: Remove hard coded time limits for SIS
Chris Johns
chrisj at rtems.org
Tue Jul 5 08:21:06 UTC 2022
On 5/7/2022 4:29 pm, Sebastian Huber wrote:
> On 05/07/2022 08:23, Chris Johns wrote:
>> On 5/7/2022 4:02 pm, Sebastian Huber wrote:
>>> On 05/07/2022 07:14, Chris Johns wrote:
>>>> On 5/7/2022 2:58 pm, Sebastian Huber wrote:
>>>>> On 05/07/2022 03:08, Chris Johns wrote:
>>>>>> On 5/7/2022 9:44 am, Joel Sherrill wrote:
>>>>>>> The limit removed in sis and tsim is the simulated cpu time used. If not
>>>>>>> using
>>>>>>> that, the behavior of the tester is to let the simulator run for so much
>>>>>>> real
>>>>>>> processor time.
>>>>>>> Replacing these with a command line argument is probably good but just
>>>>>>> removing
>>>>>>> these mean these simulators will just run much longer before being killed.
>>>>>>> How best to capture the distinction between target run time and host run
>>>>>>> time?
>>>>>> Thank you for the explanation. I was not sure how the option effected things
>>>>>> and
>>>>>> yes it does matter we have this set correctly.
>>>>>> Options can be set in the $HOME/.rtemstesterrc is via the --user-config
>>>>>> option.
>>>>>> Maybe this can be used to control the time out for specific user tests?
>>>>> I would not make this more complicated than necessary. We have a --timeout
>>>>> command line option and the default timeout value can be set by *.ini
>>>>> files. The
>>>>> simulator speed is just a detail similar to running a target at 100MHz or
>>>>> 1GHz.
>>>> It is actually simpler to have this option and to measure time against the cpu
>>>> time. The work loads on SMP hosts with qemu shows simulation timeouts are
>>>> difficult to get right.
>>> I don't know what is wrong with the patch. Overruling command line options is
>>> just bad.
>> It does not work that way. When simulating the timeout in the tester is a catch
>> all. It may triggered if the simulator locks up. With real hardware it is the
>> timeout but that is a different use case. A simulator timeout is preferred when
>> available.
> Ok, good. Who will fix this?
I am sorry I am not following. The tests have valid times for the default
optimisation. What is broken?
