[PATCH] validation: Test thread idle bodies
Tue Jul 5 09:55:47 UTC 2022
 .../testsuites/validation/validation-0.yml    |   1 +
 .../tc-thread-idle-body-no-return.c           | 194 ++++++++++++++++++
 2 files changed, 195 insertions(+)
 create mode 100644 testsuites/validation/tc-thread-idle-body-no-return.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 926b03240f..dffb1d0726 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -16,6 +16,7 @@ source:
 - testsuites/validation/tc-mem-rtems-calloc.c
 - testsuites/validation/tc-mem-rtems-malloc.c
 - testsuites/validation/tc-mem-posix-memalign.c
+- testsuites/validation/tc-thread-idle-body-no-return.c
 - testsuites/validation/tr-event-send-receive.c
 - testsuites/validation/ts-validation-0.c
 stlib: []
diff --git a/testsuites/validation/tc-thread-idle-body-no-return.c b/testsuites/validation/tc-thread-idle-body-no-return.c
new file mode 100644
index 0000000000..5234a460f9
--- /dev/null
+++ b/testsuites/validation/tc-thread-idle-body-no-return.c
@@ -0,0 +1,194 @@
+ * @file
+ * @ingroup RTEMSTestCaseScoreThreadValIdleBodyNoReturn
+ * Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <bsp.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseScoreThreadValIdleBodyNoReturn \
+ *   spec:/score/thread/val/idle-body-no-return
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+ * @brief Tests thread idle body behaviour.
+ * This test case performs the following actions:
+ * - Create threads which execute an thread idle body.  Check that the thread
+ *   idle body does not return.  If it would return, then an
+ *   INTERNAL_ERROR_THREAD_EXITTED fatal error would occur.
+ *   - Check that the CPU port thread idle body does not return.
+ *   - Where the BSP provides an idle thread body, check that it does not
+ *     return.
+ *   - Clean up all used resources.
+ * @brief Test context for spec:/score/thread/val/idle-body-no-return test
+ *   case.
+typedef struct {
+   * @brief This member contains a counter.
+  uint32_t counter;;
+} ScoreThreadValIdleBodyNoReturn_Context;
+static ScoreThreadValIdleBodyNoReturn_Context
+  ScoreThreadValIdleBodyNoReturn_Instance;
+typedef ScoreThreadValIdleBodyNoReturn_Context Context;
+static void CheckIdleBody( Context *ctx, rtems_task_entry entry )
+  rtems_id id;
+  ctx->counter = 0;
+  id = CreateTask( "WORK", PRIO_LOW );
+  StartTask( id, entry, ctx );
+  while ( ctx->counter == 0 ) {
+    rtems_status_code sc;
+    sc = rtems_task_wake_after( 1 );
+    T_rsc_success( sc );
+  T_eq_u32( ctx->counter, 1 );
+  DeleteTask( id );
+static void CPUThreadIdleBody( rtems_task_argument arg )
+  Context *ctx;
+  ctx = (Context *) arg;
+  ++ctx->counter;
+  (void) _CPU_Thread_Idle_body( 0 );
+#if defined(BSP_IDLE_TASK_BODY)
+static void BSPIdleTaskBody( rtems_task_argument arg )
+  Context *ctx;
+  ++ctx->counter;
+  (void) BSP_IDLE_TASK_BODY( 0 );
+#endif
+static T_fixture ScoreThreadValIdleBodyNoReturn_Fixture = {
+  .setup = NULL,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = NULL,
+  .initial_context = &ScoreThreadValIdleBodyNoReturn_Instance
+ * @brief Create threads which execute an thread idle body.  Check that the
+ *   thread idle body does not return.  If it would return, then an
+static void ScoreThreadValIdleBodyNoReturn_Action_0(
+  ScoreThreadValIdleBodyNoReturn_Context *ctx
+  SetSelfPriority( PRIO_NORMAL );
+   * Check that the CPU port thread idle body does not return.
+  CheckIdleBody( ctx, CPUThreadIdleBody );
+   * Where the BSP provides an idle thread body, check that it does not return.
+  #if defined(BSP_IDLE_TASK_BODY)
+  CheckIdleBody( ctx, BSPIdleTaskBody );
+  #endif
+   * Clean up all used resources.
+  RestoreRunnerPriority();
+ * @fn void T_case_body_ScoreThreadValIdleBodyNoReturn( void )
+T_TEST_CASE_FIXTURE(
+  ScoreThreadValIdleBodyNoReturn,
+  &ScoreThreadValIdleBodyNoReturn_Fixture
+  ScoreThreadValIdleBodyNoReturn_Context *ctx;
+  ctx = T_fixture_context();
+  ScoreThreadValIdleBodyNoReturn_Action_0( ctx );
2.35.3
