[PATCH] cpukit/aarch64: Remove _CPU_ISR_install_vector
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Jul 5 19:35:13 UTC 2022
This function was never actually used and is dead code.
cpukit/score/cpu/aarch64/cpu.c | 25 -------------------
.../cpu/aarch64/include/rtems/score/cpu.h | 6 -----
2 files changed, 31 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
index f0062adf30..923f53da08 100644
--- a/cpukit/score/cpu/aarch64/cpu.c
+++ b/cpukit/score/cpu/aarch64/cpu.c
@@ -174,31 +174,6 @@ uint32_t _CPU_ISR_Get_level( void )
return ( level & AARCH64_PSTATE_I ) != 0;
-void _CPU_ISR_install_vector(
- uint32_t vector,
- CPU_ISR_handler new_handler,
- CPU_ISR_handler *old_handler
-#pragma GCC diagnostic push
-#pragma GCC diagnostic ignored "-Warray-bounds"
- /* Redirection table starts at the end of the vector table */
- CPU_ISR_handler *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS * 4);
- CPU_ISR_handler current_handler = table [vector];
- /* The current handler is now the old one */
- if (old_handler != NULL) {
- *old_handler = current_handler;
- /* Write only if necessary to avoid writes to a maybe read-only memory */
- if (current_handler != new_handler) {
- table [vector] = new_handler;
-#pragma GCC diagnostic pop
void _CPU_Initialize( void )
/* Do nothing */
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index fdc0e3d929..47a8e97985 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -306,12 +306,6 @@ void _CPU_Initialize( void );
typedef void ( *CPU_ISR_handler )( void );
- uint32_t vector,
* @brief CPU switch context.
2.30.2
