[PATCH] bsps/aarch64: Use MMU pages appropriately
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Jul 5 19:35:43 UTC 2022
There were two bugs with MMU page use that were partially hiding each
other. The linker script page table section was 4x the size it needed to
be and the page table allocation routine was allocating pages PTRSIZE
times larger than it needed to. On ILP32, this resulted in incorrect but
functional allocation. On LP64, this resulted in allocation failures
earlier than expected.
bsps/aarch64/include/bsp/aarch64-mmu.h | 4 ++--
spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml | 6 +++---
spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml | 6 +++---
spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml | 6 +++---
spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_lp64.yml | 6 +++---
5 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/bsps/aarch64/include/bsp/aarch64-mmu.h b/bsps/aarch64/include/bsp/aarch64-mmu.h
index 6e589cd6cd..bca7e0ce8d 100644
--- a/bsps/aarch64/include/bsp/aarch64-mmu.h
+++ b/bsps/aarch64/include/bsp/aarch64-mmu.h
@@ -145,8 +145,8 @@ BSP_START_TEXT_SECTION static inline rtems_status_code
aarch64_mmu_page_table_alloc( uint64_t **page_table )
/* First page table is already in use as TTB0 */
- static uintptr_t *current_page_table =
- (uintptr_t *) bsp_translation_table_base;
+ static uintptr_t current_page_table =
+ (uintptr_t) bsp_translation_table_base;
current_page_table += MMU_PAGE_SIZE;
*page_table = (uint64_t *) current_page_table;
diff --git a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
index 3030fd0ae9..2d7a922495 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml
@@ -29,9 +29,9 @@ content: |
MEMORY {
- RAM : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_VERSAL_RAM_LENGTH} - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - (0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
- NOCACHE : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}, LENGTH = ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}
- RAM_MMU : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}
+ RAM : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_VERSAL_RAM_LENGTH} - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
+ NOCACHE : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}, LENGTH = ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}
+ RAM_MMU : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}
REGION_ALIAS ("REGION_START", RAM);
diff --git a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
index bd5d1f791b..76c0220f0e 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
MEMORY {
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml
index b530969de7..568e663c49 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml
@@ -30,9 +30,9 @@ content: |
MEMORY {
- RAM : ORIGIN = ${BSP_XILINX_ZYNQMP_RAM_BASE} + ${BSP_XILINX_ZYNQMP_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_ZYNQMP_RAM_LENGTH} - ${BSP_XILINX_ZYNQMP_LOAD_OFFSET} - ${BSP_XILINX_ZYNQMP_NOCACHE_LENGTH} - (0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
- NOCACHE : ORIGIN = ${BSP_XILINX_ZYNQMP_RAM_BASE} + ${BSP_XILINX_ZYNQMP_RAM_LENGTH} - (0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) - ${BSP_XILINX_ZYNQMP_NOCACHE_LENGTH}, LENGTH = ${BSP_XILINX_ZYNQMP_NOCACHE_LENGTH}
- RAM_MMU : ORIGIN = ${BSP_XILINX_ZYNQMP_RAM_BASE} + ${BSP_XILINX_ZYNQMP_RAM_LENGTH} - (0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x4000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}
+ RAM : ORIGIN = ${BSP_XILINX_ZYNQMP_RAM_BASE} + ${BSP_XILINX_ZYNQMP_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_ZYNQMP_RAM_LENGTH} - ${BSP_XILINX_ZYNQMP_LOAD_OFFSET} - ${BSP_XILINX_ZYNQMP_NOCACHE_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
+ NOCACHE : ORIGIN = ${BSP_XILINX_ZYNQMP_RAM_BASE} + ${BSP_XILINX_ZYNQMP_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) - ${BSP_XILINX_ZYNQMP_NOCACHE_LENGTH}, LENGTH = ${BSP_XILINX_ZYNQMP_NOCACHE_LENGTH}
+ RAM_MMU : ORIGIN = ${BSP_XILINX_ZYNQMP_RAM_BASE} + ${BSP_XILINX_ZYNQMP_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_lp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_lp64.yml
index d9696be5d4..4a26c59944 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_lp64.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_lp64.yml
MEMORY {
2.30.2
