[PATCH] tester: Make the SIS time limit user configurable
Wed Jul 6 00:21:09 UTC 2022
Optimization may affect the time but host speed is more likely
Ok to commit
On Tue, Jul 5, 2022, 6:51 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Let the user set the test time limit in a config file to
> provide site specific overrides. Optimisation can effect
> the time a test may take to run.
>  tester/rtems/testing/bsps/erc32-sis.ini      |  5 +-
>  tester/rtems/testing/bsps/gr740-sis.ini      |  5 +-
>  tester/rtems/testing/bsps/griscv-sis-cov.ini |  5 +-
>  tester/rtems/testing/bsps/griscv-sis.ini     |  5 +-
>  tester/rtems/testing/bsps/leon2-sis.ini      |  5 +-
>  tester/rtems/testing/bsps/leon3-run.ini      |  3 +-
>  tester/rtems/testing/bsps/leon3-sis-cov.ini  |  5 +-
>  tester/rtems/testing/bsps/leon3-sis.ini      |  5 +-
>  tester/rtems/testing/bsps/sis-run.ini        |  5 +-
>  tester/rtems/testing/sis.cfg                 | 72 ++++++++++++++++++++
>  10 files changed, 89 insertions(+), 26 deletions(-)
>  create mode 100644 tester/rtems/testing/sis.cfg
> diff --git a/tester/rtems/testing/bsps/erc32-sis.ini
> b/tester/rtems/testing/bsps/erc32-sis.ini
> index fca2122..a025265 100644
> --- a/tester/rtems/testing/bsps/erc32-sis.ini
> +++ b/tester/rtems/testing/bsps/erc32-sis.ini
> @@ -34,6 +34,5 @@
>  [erc32-sis]
>  bsp          = erc32
>  arch         = sparc
> -tester       = %{_rtscripts}/run.cfg
> -bsp_run_cmd  = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> -bsp_run_opts = -nouartrx -r -tlim 600 s
> +tester       = %{_rtscripts}/sis.cfg
> +bsp_run_opts =
> diff --git a/tester/rtems/testing/bsps/gr740-sis.ini
> b/tester/rtems/testing/bsps/gr740-sis.ini
> index b71048c..c42d716 100644
> --- a/tester/rtems/testing/bsps/gr740-sis.ini
> +++ b/tester/rtems/testing/bsps/gr740-sis.ini
> @@ -33,6 +33,5 @@
>  [gr740-sis]
>  bsp          = gr740
>  arch         = sparc
> -bsp_run_opts = -gr740 -nouartrx -r -tlim 200 s -m 4
> +bsp_run_opts = -gr740 -m 4
> diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini
> b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> index 9ab37a8..fa86b55 100644
> --- a/tester/rtems/testing/bsps/griscv-sis-cov.ini
> +++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> @@ -34,7 +34,6 @@
>  [griscv-sis-cov]
>  bsp            = griscv-sis
>  arch           = riscv
> -bsp_run_opts   = -nouartrx -r -tlim 300 s -m 4 -cov
> +bsp_run_opts   = -m 4 -cov
>  bsp_covoar_cmd = -S %{bsp_symbol_path} -E %{cov_explanations} -f TSIM
> diff --git a/tester/rtems/testing/bsps/griscv-sis.ini
> b/tester/rtems/testing/bsps/griscv-sis.ini
> index b21cba1..bf32851 100644
> --- a/tester/rtems/testing/bsps/griscv-sis.ini
> +++ b/tester/rtems/testing/bsps/griscv-sis.ini
> @@ -34,6 +34,5 @@
>  [griscv-sis]
>  bsp          = griscv
>  arch         = riscv
> diff --git a/tester/rtems/testing/bsps/leon2-sis.ini
> b/tester/rtems/testing/bsps/leon2-sis.ini
> index 61205ad..810320c 100644
> --- a/tester/rtems/testing/bsps/leon2-sis.ini
> +++ b/tester/rtems/testing/bsps/leon2-sis.ini
> @@ -34,6 +34,5 @@
>  [leon2-sis]
>  bsp          = leon2
>  arch         = sparc
> -bsp_run_opts = -leon2 -nouartrx -r -tlim 200 s
> +bsp_run_opts = -leon2
> diff --git a/tester/rtems/testing/bsps/leon3-run.ini
> b/tester/rtems/testing/bsps/leon3-run.ini
> index a8c97a6..99c391b 100644
> --- a/tester/rtems/testing/bsps/leon3-run.ini
> +++ b/tester/rtems/testing/bsps/leon3-run.ini
> @@ -34,6 +34,5 @@
>  [leon3-run]
>  bsp          = leon3
>  arch         = sparc
> -bsp_run_cmd  = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run
>  bsp_run_opts = -a -leon3
> diff --git a/tester/rtems/testing/bsps/leon3-sis-cov.ini
> b/tester/rtems/testing/bsps/leon3-sis-cov.ini
> index d8ffe28..7c6a279 100644
> --- a/tester/rtems/testing/bsps/leon3-sis-cov.ini
> +++ b/tester/rtems/testing/bsps/leon3-sis-cov.ini
> @@ -34,7 +34,6 @@
>  [leon3-sis-cov]
>  bsp            = leon3-sis
>  arch           = sparc
> -bsp_run_opts   = -leon3 -nouartrx -r -tlim 200 s -cov
> +bsp_run_opts   = -leon3 -cov
> diff --git a/tester/rtems/testing/bsps/leon3-sis.ini
> b/tester/rtems/testing/bsps/leon3-sis.ini
> index 2f933a7..9035f48 100644
> --- a/tester/rtems/testing/bsps/leon3-sis.ini
> +++ b/tester/rtems/testing/bsps/leon3-sis.ini
> @@ -34,6 +34,5 @@
>  [leon3-sis]
>  bsp          = leon3
>  arch         = sparc
> -bsp_run_opts = -leon3 -nouartrx -r -tlim 200 s -m 4
> +bsp_run_opts = -leon3 -m 4
> diff --git a/tester/rtems/testing/bsps/sis-run.ini
> b/tester/rtems/testing/bsps/sis-run.ini
> index 55c30ac..c34eae4 100644
> --- a/tester/rtems/testing/bsps/sis-run.ini
> +++ b/tester/rtems/testing/bsps/sis-run.ini
> @@ -34,6 +34,5 @@
>  [sis-run]
>  bsp          = sis
>  arch         = sparc
> -bsp_run_opts = -a -nouartrx
> +bsp_run_opts = -a
> diff --git a/tester/rtems/testing/sis.cfg b/tester/rtems/testing/sis.cfg
> new file mode 100644
> index 0000000..bb8d0bc
> --- /dev/null
> +++ b/tester/rtems/testing/sis.cfg
> @@ -0,0 +1,72 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2022 Chris Johns (chrisj at rtems.org)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are
> met:
> +# 1. Redistributions of source code must retain the above copyright
> notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> +# this list of conditions and the following disclaimer in the
> documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
> IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
> BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# SIS. The main simulator for SPARC/LEON
> +# Use sis command to run the executable in the spike simulator.
> +%include %{_configdir}/base.cfg
> +%include %{_configdir}/checks.cfg
> +# Console.
> +%define console_stdio
> +%include %{_configdir}/console.cfg
> +# RTEMS version
> +%include %{_rtdir}/rtems/version.cfg
> +# Timeout option. This is the default for timeout for the CPU realtime
> +# clock
> +%ifn %{defined sis_time_limit}
> + %define sis_time_limit -tlim 400 s
> +%endif
> +# Default command
> +%ifn %{defined bsp_run_cmd}
> + %define bsp_run_cmd %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> +%endif
> +%define sis_cmd %{bsp_run_cmd}
> +%define sis_opts -nouartrx -r %{sis_time_limit} %{bsp_run_opts}
> +# Executable
> +%execute %{sis_cmd} %{sis_opts} %{test_executable}
> 2.24.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220705/269d31c8/attachment-0001.htm>
