[PATCH] bsps/arm/stm32f4 Optimize get pin and change from HAL to LL
Duc Doan
dtbpkmte at gmail.com
Wed Jul 6 11:03:41 UTC 2022
Hello Cedric,
Thank you for your feedback. I agree with you that there are places that could be optimized out. Here is a new patch for that.
Best,
Duc Doan
bsps/arm/stm32f4/gpio/gpio.c | 87 ++++++++++++------------------------
1 file changed, 29 insertions(+), 58 deletions(-)
diff --git a/bsps/arm/stm32f4/gpio/gpio.c b/bsps/arm/stm32f4/gpio/gpio.c
index e971f91140..b632236d8d 100644
--- a/bsps/arm/stm32f4/gpio/gpio.c
+++ b/bsps/arm/stm32f4/gpio/gpio.c
@@ -22,9 +22,18 @@
/*********** Helpers *****************/
-static stm32f4_gpio *get_gpio_from_base(
- rtems_gpio *base
+ * @brief Macro to get stm32f4_gpio object from a base rtems_gpio
+ * object.
+ * This is a wrapper of RTEMS_CONTAINER_OF macro
+ * @param base The pointer to a rtems_gpio object
+ * @retval The pointer to the stm32f4_gpio object owning
+ * the specified rtems_gpio object
+#define get_gpio_from_base(base) \
+ RTEMS_CONTAINER_OF(base, stm32f4_gpio, base)
/*********** GPIO API ***************/
static rtems_status_code stm32f4_gpio_get(
@@ -115,44 +124,6 @@ static GPIO_TypeDef *GPIOx[] = {
#endif /* STM32F429X */
-static uint16_t GPIO_PIN_x[] = {
- GPIO_PIN_0,
- GPIO_PIN_1,
- GPIO_PIN_2,
- GPIO_PIN_3,
- GPIO_PIN_4,
- GPIO_PIN_5,
- GPIO_PIN_6,
- GPIO_PIN_7,
- GPIO_PIN_8,
- GPIO_PIN_9,
- GPIO_PIN_10,
- GPIO_PIN_11,
- GPIO_PIN_12,
- GPIO_PIN_13,
- GPIO_PIN_14,
- GPIO_PIN_15
-static uint32_t LL_EXTI_LINE_x[] = {
- LL_EXTI_LINE_0,
- LL_EXTI_LINE_1,
- LL_EXTI_LINE_2,
- LL_EXTI_LINE_3,
- LL_EXTI_LINE_4,
- LL_EXTI_LINE_5,
- LL_EXTI_LINE_6,
- LL_EXTI_LINE_7,
- LL_EXTI_LINE_8,
- LL_EXTI_LINE_9,
- LL_EXTI_LINE_10,
- LL_EXTI_LINE_11,
- LL_EXTI_LINE_12,
- LL_EXTI_LINE_13,
- LL_EXTI_LINE_14,
- LL_EXTI_LINE_15
static unsigned int EXTIx_IRQn[] = {
EXTI0_IRQn,
EXTI1_IRQn,
@@ -200,13 +171,13 @@ static unsigned int EXTIx_IRQn[] = {
* @brief Converts pin number from 0-15 to HAL pin mask.
* @param pin is the pin number from 0-15
-#define STM32F4_GET_HAL_GPIO_PIN(pin) (GPIO_PIN_x[( pin )])
+#define STM32F4_GET_HAL_GPIO_PIN(pin) ((uint16_t) (1 << ( pin )))
* @brief Get EXTI Line from pin number 0-15
-#define STM32F4_GET_LL_EXTI_LINE(pin) (LL_EXTI_LINE_x[( pin )])
+#define STM32F4_GET_LL_EXTI_LINE(pin) (0x1UL << ( pin ))
* @brief Get EXTI IRQ number from pin 0-15
@@ -229,14 +200,6 @@ static stm32f4_interrupt isr_table[16];
void exti_handler(void *arg);
-/************* Helpers implementation ********************/
- rtems_gpio *base
- return RTEMS_CONTAINER_OF(base, stm32f4_gpio, base);
/********** STM32F4 GPIO API functions ************/
@@ -523,7 +486,8 @@ rtems_status_code stm32f4_gpio_remove_interrupt(
rtems_status_code sc = rtems_interrupt_handler_remove(
STM32F4_GET_EXTI_IRQn(gpio->pin),
exti_handler,
- &isr_table[gpio->pin].arg);
+ &isr_table[gpio->pin].arg
if (sc == RTEMS_SUCCESSFUL) {
isr_table[gpio->pin] = (stm32f4_interrupt){0};
@@ -554,9 +518,12 @@ rtems_status_code stm32f4_gpio_write(
stm32f4_gpio *gpio = get_gpio_from_base(base);
- uint32_t pin_mask = STM32F4_GET_HAL_GPIO_PIN(gpio->pin);
- HAL_GPIO_WritePin(gpio->port, pin_mask, value);
+ if (value)
+ LL_GPIO_SetOutputPin(gpio->port, STM32F4_GET_HAL_GPIO_PIN(gpio->pin));
+ else
+ LL_GPIO_ResetOutputPin(gpio->port, STM32F4_GET_HAL_GPIO_PIN(gpio->pin));
return RTEMS_SUCCESSFUL;
@@ -566,9 +533,11 @@ rtems_status_code stm32f4_gpio_read(
- *value = HAL_GPIO_ReadPin(gpio->port, pin_mask);
+ *value = LL_GPIO_IsInputPinSet(
+ gpio->port,
+ STM32F4_GET_HAL_GPIO_PIN(gpio->pin)
@@ -577,9 +546,11 @@ rtems_status_code stm32f4_gpio_toggle(
- HAL_GPIO_TogglePin(gpio->port, pin_mask);
+ LL_GPIO_TogglePin(
+ gpio->port,
2.36.1
