[PATCH] STM32F4 GPIO: Remove old comments
Duc Doan dtbpkmte at gmail.com
Wed Jul 6 11:14:30 UTC 2022
 bsps/arm/stm32f4/gpio/gpio.c | 14 --------------
 1 file changed, 14 deletions(-)
diff --git a/bsps/arm/stm32f4/gpio/gpio.c b/bsps/arm/stm32f4/gpio/gpio.c
index b632236d8d..8e3f7c7131 100644
--- a/bsps/arm/stm32f4/gpio/gpio.c
+++ b/bsps/arm/stm32f4/gpio/gpio.c
@@ -330,11 +330,6 @@ rtems_status_code stm32f4_gpio_deinit(rtems_gpio *base) {
     return RTEMS_SUCCESSFUL;
-  * @note Warning: only one pin can be passed as argument
-  * @note If using interrupt mode, use rtems_gpio_configure_interrupt().
-  * @note If using alternate mode, use rtems_gpio_configure().
 rtems_status_code stm32f4_gpio_set_pin_mode(
     rtems_gpio *base,
     rtems_gpio_pin_mode mode
@@ -374,9 +369,6 @@ rtems_status_code stm32f4_gpio_set_pin_mode(
 rtems_status_code stm32f4_gpio_set_pull(
     rtems_gpio *base,
     rtems_gpio_pull pull
@@ -404,12 +396,6 @@ rtems_status_code stm32f4_gpio_set_pull(
-  * TODO
-  * @note This function defaults to not using pull resistor.
-  *       Use rtems_gpio_set_pull() afterwards to change.
 rtems_status_code stm32f4_gpio_configure_interrupt(
     rtems_gpio *base,
     rtems_gpio_isr isr,
2.36.1
