[PATCH rtems-lwip v1 5/9] embeddedsw: Import Xilinx driver source
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Jul 1 22:31:08 UTC 2022
Import source for axi_ethernetlite, axi_ethernet, and CGEM. CGEM is also
known as emacps and ps7_ethernet. These sources were imported at
revision b9b64f53e11723c8df0dfda1c59742428b6f1df1.
COPYING.embeddedsw | 29 +
ORIGIN.embeddedsw | 2 +
.../ports/xilinx/include/netif/xadapter.h | 87 ++
.../ports/xilinx/include/netif/xemacpsif.h | 166 +++
.../ports/xilinx/include/netif/xpqueue.h | 54 +
.../ports/xilinx/include/netif/xtopology.h | 60 +
.../src/contrib/ports/xilinx/netif/xadapter.c | 425 +++++++
.../ports/xilinx/netif/xemac_ieee_reg.h | 101 ++
.../contrib/ports/xilinx/netif/xemacpsif.c | 795 ++++++++++++
.../ports/xilinx/netif/xemacpsif_dma.c | 930 ++++++++++++++
.../contrib/ports/xilinx/netif/xemacpsif_hw.c | 276 ++++
.../ports/xilinx/netif/xemacpsif_physpeed.c | 1037 +++++++++++++++
.../src/contrib/ports/xilinx/netif/xpqueue.c | 93 ++
.../drivers/emacps/src/xemacps.c | 487 +++++++
.../drivers/emacps/src/xemacps.h | 843 ++++++++++++
.../drivers/emacps/src/xemacps_bd.h | 762 +++++++++++
.../drivers/emacps/src/xemacps_bdring.c | 1076 ++++++++++++++++
.../drivers/emacps/src/xemacps_bdring.h | 215 ++++
.../drivers/emacps/src/xemacps_control.c | 1133 +++++++++++++++++
.../drivers/emacps/src/xemacps_hw.h | 646 ++++++++++
.../drivers/emacps/src/xemacps_intr.c | 242 ++++
.../drivers/scugic/src/xscugic.h | 601 +++++++++
.../drivers/scugic/src/xscugic_hw.h | 697 ++++++++++
.../src/arm/ARMv8/64bit/xil_cache.h | 75 ++
.../standalone/src/arm/ARMv8/64bit/xil_mmu.h | 94 ++
.../standalone/src/arm/common/xil_exception.h | 408 ++++++
.../bsp/standalone/src/common/xil_assert.c | 126 ++
.../bsp/standalone/src/common/xil_assert.h | 176 +++
.../lib/bsp/standalone/src/common/xil_io.h | 412 ++++++
.../lib/bsp/standalone/src/common/xil_types.h | 203 +++
.../lib/bsp/standalone/src/common/xstatus.h | 522 ++++++++
31 files changed, 12773 insertions(+)
create mode 100644 COPYING.embeddedsw
create mode 100644 ORIGIN.embeddedsw
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xadapter.h
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xemacpsif.h
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xpqueue.h
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xtopology.h
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemac_ieee_reg.h
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_hw.c
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_physpeed.c
create mode 100644 embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xpqueue.c
create mode 100644 embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.c
create mode 100644 embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.h
create mode 100644 embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bd.h
create mode 100644 embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.c
create mode 100644 embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.h
create mode 100644 embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_control.c
create mode 100644 embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_hw.h
create mode 100644 embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_intr.c
create mode 100644 embeddedsw/XilinxProcessorIPLib/drivers/scugic/src/xscugic.h
create mode 100644 embeddedsw/XilinxProcessorIPLib/drivers/scugic/src/xscugic_hw.h
create mode 100644 embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h
create mode 100644 embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_mmu.h
create mode 100644 embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h
create mode 100644 embeddedsw/lib/bsp/standalone/src/common/xil_assert.c
create mode 100644 embeddedsw/lib/bsp/standalone/src/common/xil_assert.h
create mode 100644 embeddedsw/lib/bsp/standalone/src/common/xil_io.h
create mode 100644 embeddedsw/lib/bsp/standalone/src/common/xil_types.h
create mode 100644 embeddedsw/lib/bsp/standalone/src/common/xstatus.h
diff --git a/COPYING.embeddedsw b/COPYING.embeddedsw
new file mode 100644
index 0000000..814be7b
--- /dev/null
+++ b/COPYING.embeddedsw
@@ -0,0 +1,29 @@
+ * Copyright (C) 2007 - 2021 Xilinx, Inc.
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without modification,
+ * are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. The name of the author may not be used to endorse or promote products
+ * derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
+ * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+ * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
+ * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
+ * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+ * This file is part of the lwIP TCP/IP stack.
diff --git a/ORIGIN.embeddedsw b/ORIGIN.embeddedsw
index 0000000..b5ad15e
--- /dev/null
+++ b/ORIGIN.embeddedsw
@@ -0,0 +1,2 @@
+The files under the embeddedsw/ directory are sourced from:
+https://github.com/Xilinx/embeddedsw.git
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xadapter.h b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xadapter.h
index 0000000..4d32b7f
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xadapter.h
@@ -0,0 +1,87 @@
+ * OF SUCH DAMAGE.
+#ifndef __XADAPTER_H_
+#define __XADAPTER_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "lwipopts.h"
+#if !NO_SYS
+#include "lwip/sys.h"
+#endif
+#include "lwip/netif.h"
+#include "lwip/ip.h"
+#include "netif/xtopology.h"
+struct xemac_s {
+ enum xemac_types type;
+ int topology_index;
+ void *state;
+#if !NO_SYS
+ sys_sem_t sem_rx_data_available;
+#if defined(__arm__) && !defined(ARMR5)
+ TimerHandle_t xTimer;
+#endif
+#endif
+enum ethernet_link_status {
+ ETH_LINK_UNDEFINED = 0,
+ ETH_LINK_UP,
+ ETH_LINK_DOWN,
+ ETH_LINK_NEGOTIATING
+void eth_link_detect(struct netif *netif);
+void lwip_raw_init();
+int xemacif_input(struct netif *netif);
+void xemacif_input_thread(struct netif *netif);
+struct netif * xemac_add(struct netif *netif,
+ ip_addr_t *ipaddr, ip_addr_t *netmask, ip_addr_t *gw,
+ unsigned char *mac_ethernet_address,
+ UINTPTR mac_baseaddr);
+#if defined (__arm__) || defined (__aarch64__)
+void xemacpsif_resetrx_on_no_rxdata(struct netif *netif);
+#endif
+/* global lwip debug variable used for debugging */
+extern int lwip_runtime_debug;
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xemacpsif.h b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xemacpsif.h
index 0000000..f108920
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xemacpsif.h
@@ -0,0 +1,166 @@
+ * Copyright (C) 2010 - 2019 Xilinx, Inc.
+ * OF SUCH DAMAGE.
+#ifndef __NETIF_XEMACPSIF_H__
+#define __NETIF_XEMACPSIF_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "xlwipconfig.h"
+#include "netif/etharp.h"
+#include "netif/xadapter.h"
+#include "xstatus.h"
+#include "sleep.h"
+#include "xparameters.h"
+#include "xparameters_ps.h" /* defines XPAR values */
+#include "xil_types.h"
+#include "xil_assert.h"
+#include "xil_io.h"
+#include "xil_exception.h"
+#include "xpseudo_asm.h"
+#include "xil_cache.h"
+#include "xil_printf.h"
+#include "xscugic.h"
+#include "xemacps.h" /* defines XEmacPs API */
+#include "netif/xpqueue.h"
+#if defined (__aarch64__) && (EL1_NONSECURE == 1)
+#include "xil_smc.h"
+#endif
+#define ZYNQ_EMACPS_0_BASEADDR 0xE000B000
+#define ZYNQ_EMACPS_1_BASEADDR 0xE000C000
+#define ZYNQMP_EMACPS_0_BASEADDR 0xFF0B0000
+#define ZYNQMP_EMACPS_1_BASEADDR 0xFF0C0000
+#define ZYNQMP_EMACPS_2_BASEADDR 0xFF0D0000
+#define ZYNQMP_EMACPS_3_BASEADDR 0xFF0E0000
+#define CRL_APB_GEM0_REF_CTRL 0xFF5E0050
+#define CRL_APB_GEM1_REF_CTRL 0xFF5E0054
+#define CRL_APB_GEM2_REF_CTRL 0xFF5E0058
+#define CRL_APB_GEM3_REF_CTRL 0xFF5E005C
+#define CRL_APB_GEM_DIV0_MASK 0x00003F00
+#define CRL_APB_GEM_DIV0_SHIFT 8
+#define CRL_APB_GEM_DIV1_MASK 0x003F0000
+#define CRL_APB_GEM_DIV1_SHIFT 16
+#define VERSAL_EMACPS_0_BASEADDR 0xFF0C0000
+#define VERSAL_EMACPS_1_BASEADDR 0xFF0D0000
+#define VERSAL_CRL_GEM0_REF_CTRL 0xFF5E0118
+#define VERSAL_CRL_GEM1_REF_CTRL 0xFF5E011C
+#define VERSAL_CRL_GEM_DIV_MASK 0x0003FF00
+#define VERSAL_CRL_APB_GEM_DIV_SHIFT 8
+#if defined (ARMR5) || (__aarch64__) || (ARMA53_32) || (__MICROBLAZE__)
+#if defined (USE_JUMBO_FRAMES)
+#define ZYNQMP_USE_JUMBO
+#endif
+#endif
+#define GEM_VERSION_ZYNQMP 7
+#define GEM_VERSION_VERSAL 0x107
+#define MAX_FRAME_SIZE_JUMBO (XEMACPS_MTU_JUMBO + XEMACPS_HDR_SIZE + XEMACPS_TRL_SIZE)
+void xemacpsif_setmac(u32_t index, u8_t *addr);
+u8_t* xemacpsif_getmac(u32_t index);
+err_t xemacpsif_init(struct netif *netif);
+s32_t xemacpsif_input(struct netif *netif);
+/* xaxiemacif_hw.c */
+void xemacps_error_handler(XEmacPs * Temac);
+/* structure within each netif, encapsulating all information required for
+ * using a particular temac instance
+typedef struct {
+ XEmacPs emacps;
+ /* queue to store overflow packets */
+ pq_queue_t *recv_q;
+ pq_queue_t *send_q;
+ /* pointers to memory holding buffer descriptors (used only with SDMA) */
+ void *rx_bdspace;
+ void *tx_bdspace;
+ unsigned int last_rx_frms_cntr;
+} xemacpsif_s;
+extern xemacpsif_s xemacpsif;
+s32_t is_tx_space_available(xemacpsif_s *emac);
+/* xemacpsif_dma.c */
+void process_sent_bds(xemacpsif_s *xemacpsif, XEmacPs_BdRing *txring);
+u32_t phy_setup_emacps (XEmacPs *xemacpsp, u32_t phy_addr);
+void detect_phy(XEmacPs *xemacpsp);
+void emacps_send_handler(void *arg);
+#if LWIP_UDP_OPT_BLOCK_TX_TILL_COMPLETE
+XStatus emacps_sgsend(xemacpsif_s *xemacpsif, struct pbuf *p,
+ u32_t block_till_tx_complete, u32_t *to_block_index);
+#else
+XStatus emacps_sgsend(xemacpsif_s *xemacpsif, struct pbuf *p);
+#endif
+void emacps_recv_handler(void *arg);
+void emacps_error_handler(void *arg,u8 Direction, u32 ErrorWord);
+void setup_rx_bds(xemacpsif_s *xemacpsif, XEmacPs_BdRing *rxring);
+void HandleTxErrors(struct xemac_s *xemac);
+void HandleEmacPsError(struct xemac_s *xemac);
+XEmacPs_Config *xemacps_lookup_config(unsigned mac_base);
+void init_emacps(xemacpsif_s *xemacps, struct netif *netif);
+void setup_isr (struct xemac_s *xemac);
+XStatus init_dma(struct xemac_s *xemac);
+void start_emacps (xemacpsif_s *xemacps);
+void free_txrx_pbufs(xemacpsif_s *xemacpsif);
+void free_onlytx_pbufs(xemacpsif_s *xemacpsif);
+void init_emacps_on_error (xemacpsif_s *xemacps, struct netif *netif);
+void clean_dma_txdescs(struct xemac_s *xemac);
+void resetrx_on_no_rxdata(xemacpsif_s *xemacpsif);
+void reset_dma(struct xemac_s *xemac);
+#ifdef __cplusplus
+#endif
+#endif /* __NETIF_XAXIEMACIF_H__ */
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xpqueue.h b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xpqueue.h
index 0000000..132f02f
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xpqueue.h
@@ -0,0 +1,54 @@
+ * Copyright (C) 2007 - 2019 Xilinx, Inc.
+ * OF SUCH DAMAGE.
+#ifndef __LWIP_PBUF_QUEUE_H_
+#define __LWIP_PBUF_QUEUE_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define PQ_QUEUE_SIZE 4096
+typedef struct {
+ void *data[PQ_QUEUE_SIZE];
+ int head, tail, len;
+} pq_queue_t;
+pq_queue_t* pq_create_queue();
+int pq_enqueue(pq_queue_t *q, void *p);
+void* pq_dequeue(pq_queue_t *q);
+int pq_qlength(pq_queue_t *q);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xtopology.h b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xtopology.h
index 0000000..51718f1
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xtopology.h
@@ -0,0 +1,60 @@
+ * OF SUCH DAMAGE.
+#ifndef __XTOPOLOGY_H_
+#define __XTOPOLOGY_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+enum xemac_types { xemac_type_unknown = -1, xemac_type_xps_emaclite, xemac_type_xps_ll_temac, xemac_type_axi_ethernet, xemac_type_emacps };
+struct xtopology_t {
+ UINTPTR emac_baseaddr;
+ enum xemac_types emac_type;
+ UINTPTR intc_baseaddr;
+ unsigned intc_emac_intr; /* valid only for xemac_type_xps_emaclite */
+ UINTPTR scugic_baseaddr; /* valid only for Zynq */
+ unsigned scugic_emac_intr; /* valid only for GEM */
+extern int xtopology_n_emacs;
+extern struct xtopology_t xtopology[];
+int xtopology_find_index(unsigned base);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c
index 0000000..9594ff5
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c
@@ -0,0 +1,425 @@
+ * OF SUCH DAMAGE.
+#include "xemac_ieee_reg.h"
+#if !NO_SYS
+#endif
+#include "lwip/mem.h"
+#include "lwip/stats.h"
+#include "lwip/tcp.h"
+#include "lwip/udp.h"
+#include "lwip/priv/tcp_priv.h"
+#ifdef XLWIP_CONFIG_INCLUDE_EMACLITE
+#include "netif/xemacliteif.h"
+#endif
+#ifdef XLWIP_CONFIG_INCLUDE_AXI_ETHERNET
+#include "netif/xaxiemacif.h"
+#endif
+#ifdef XLWIP_CONFIG_INCLUDE_GEM
+#include "netif/xemacpsif.h"
+#endif
+#if !NO_SYS
+#include "lwip/tcpip.h"
+#define THREAD_STACKSIZE 256
+#define LINK_DETECT_THREAD_INTERVAL 1000 /* one second */
+void link_detect_thread(void *p);
+#endif
+int lwip_runtime_debug = 0;
+enum ethernet_link_status eth_link_status = ETH_LINK_UNDEFINED;
+u32_t phyaddrforemac;
+void
+lwip_raw_init()
+ ip_init(); /* Doesn't do much, it should be called to handle future changes. */
+#if LWIP_UDP
+ udp_init(); /* Clears the UDP PCB list. */
+#endif
+#if LWIP_TCP
+ tcp_init(); /* Clears the TCP PCB list and clears some internal TCP timers. */
+ /* Note: you must call tcp_fasttmr() and tcp_slowtmr() at the */
+ /* predefined regular intervals after this initialization. */
+#endif
+static enum xemac_types
+find_mac_type(unsigned base)
+ int i;
+ for (i = 0; i < xtopology_n_emacs; i++) {
+ if (xtopology[i].emac_baseaddr == base)
+ return xtopology[i].emac_type;
+ return xemac_type_unknown;
+int
+xtopology_find_index(unsigned base)
+ int i;
+ return i;
+ return -1;
+ * xemac_add: this is a wrapper around lwIP's netif_add function.
+ * The objective is to provide portability between the different Xilinx MAC's
+ * This function can be used to add both xps_ethernetlite and xps_ll_temac
+ * based interfaces
+struct netif *
+xemac_add(struct netif *netif,
+ int i;
+#if !NO_SYS
+ /* Start thread to detect link periodically for Hot Plug autodetect */
+ sys_thread_new("link_detect_thread", link_detect_thread, netif,
+ THREAD_STACKSIZE, tskIDLE_PRIORITY);
+#endif
+ /* set mac address */
+ netif->hwaddr_len = 6;
+ for (i = 0; i < 6; i++)
+ netif->hwaddr[i] = mac_ethernet_address[i];
+ /* initialize based on MAC type */
+ switch (find_mac_type(mac_baseaddr)) {
+ case xemac_type_xps_emaclite:
+ return netif_add(netif, ipaddr, netmask, gw,
+ (void*)mac_baseaddr,
+ xemacliteif_init,
+#if NO_SYS
+ ethernet_input
+#else
+ tcpip_input
+#endif
+#else
+ return NULL;
+#endif
+ case xemac_type_axi_ethernet:
+ xaxiemacif_init,
+#if NO_SYS
+ ethernet_input
+#else
+ tcpip_input
+#endif
+#else
+ return NULL;
+#endif
+ case xemac_type_emacps:
+ xemacpsif_init,
+#if NO_SYS
+ ethernet_input
+#else
+ tcpip_input
+#endif
+#endif
+#endif
+ default:
+ xil_printf("unable to determine type of EMAC with baseaddress 0x%08x\r\n",
+ mac_baseaddr);
+ return NULL;
+#if !NO_SYS
+ * The input thread calls lwIP to process any received packets.
+ * This thread waits until a packet is received (sem_rx_data_available),
+ * and then calls xemacif_input which processes 1 packet at a time.
+void
+xemacif_input_thread(struct netif *netif)
+ struct xemac_s *emac = (struct xemac_s *)netif->state;
+ while (1) {
+ /* sleep until there are packets to process
+ * This semaphore is set by the packet receive interrupt
+ * routine.
+ sys_sem_wait(&emac->sem_rx_data_available);
+ /* move all received packets to lwIP */
+ xemacif_input(netif);
+#endif
+int
+xemacif_input(struct netif *netif)
+ int n_packets = 0;
+ switch (emac->type) {
+ n_packets = xemacliteif_input(netif);
+ break;
+#else
+ print("incorrect configuration: xps_ethernetlite drivers not present?");
+ while(1);
+ return 0;
+#endif
+ n_packets = xaxiemacif_input(netif);
+ break;
+#else
+ print("incorrect configuration: axi_ethernet drivers not present?");
+ while(1);
+ return 0;
+#endif
+ n_packets = xemacpsif_input(netif);
+ break;
+#else
+ xil_printf("incorrect configuration: ps7_ethernet drivers not present?\r\n");
+ while(1);
+ return 0;
+#endif
+#endif
+ default:
+ print("incorrect configuration: unknown temac type");
+ while(1);
+ return 0;
+ return n_packets;
+#if defined(XLWIP_CONFIG_INCLUDE_GEM)
+static u32_t phy_link_detect(XEmacPs *xemacp, u32_t phy_addr)
+ u16_t status;
+ /* Read Phy Status register twice to get the confirmation of the current
+ * link status.
+ XEmacPs_PhyRead(xemacp, phy_addr, IEEE_STATUS_REG_OFFSET, &status);
+ if (status & IEEE_STAT_LINK_STATUS)
+ return 1;
+ return 0;
+#elif defined(XLWIP_CONFIG_INCLUDE_AXI_ETHERNET)
+static u32_t phy_link_detect(XAxiEthernet *xemacp, u32_t phy_addr)
+ u16_t status;
+ * link status.
+ XAxiEthernet_PhyRead(xemacp, phy_addr, IEEE_STATUS_REG_OFFSET, &status);
+ return 1;
+ return 0;
+#elif defined(XLWIP_CONFIG_INCLUDE_EMACLITE)
+static u32_t phy_link_detect(XEmacLite *xemacp, u32_t phy_addr)
+ u16_t status;
+ * link status.
+ XEmacLite_PhyRead(xemacp, phy_addr, IEEE_STATUS_REG_OFFSET, &status);
+ return 1;
+ return 0;
+#endif
+static u32_t phy_autoneg_status(XEmacPs *xemacp, u32_t phy_addr)
+ u16_t status;
+ * link status.
+ if (status & IEEE_STAT_AUTONEGOTIATE_COMPLETE)
+ return 1;
+ return 0;
+static u32_t phy_autoneg_status(XAxiEthernet *xemacp, u32_t phy_addr)
+ u16_t status;
+ * link status.
+ return 1;
+ return 0;
+static u32_t phy_autoneg_status(XEmacLite *xemacp, u32_t phy_addr)
+ u16_t status;
+ * link status.
+ return 1;
+ return 0;
+#endif
+ u32_t link_speed, phy_link_status;
+ struct xemac_s *xemac = (struct xemac_s *)(netif->state);
+ xemacpsif_s *xemacs = (xemacpsif_s *)(xemac->state);
+ XEmacPs *xemacp = &xemacs->emacps;
+ xaxiemacif_s *xemacs = (xaxiemacif_s *)(xemac->state);
+ XAxiEthernet *xemacp = &xemacs->axi_ethernet;
+ xemacliteif_s *xemacs = (xemacliteif_s *)(xemac->state);
+ XEmacLite *xemacp = xemacs->instance;
+#endif
+ if ((xemacp->IsReady != (u32)XIL_COMPONENT_IS_READY) ||
+ (eth_link_status == ETH_LINK_UNDEFINED))
+ return;
+ phy_link_status = phy_link_detect(xemacp, phyaddrforemac);
+ if ((eth_link_status == ETH_LINK_UP) && (!phy_link_status))
+ eth_link_status = ETH_LINK_DOWN;
+ switch (eth_link_status) {
+ case ETH_LINK_UNDEFINED:
+ case ETH_LINK_UP:
+ return;
+ case ETH_LINK_DOWN:
+ netif_set_link_down(netif);
+ eth_link_status = ETH_LINK_NEGOTIATING;
+ xil_printf("Ethernet Link down\r\n");
+ break;
+ case ETH_LINK_NEGOTIATING:
+ if (phy_link_status &&
+ phy_autoneg_status(xemacp, phyaddrforemac)) {
+ /* Initiate Phy setup to get link speed */
+ link_speed = phy_setup_emacps(xemacp,
+ phyaddrforemac);
+ XEmacPs_SetOperatingSpeed(xemacp, link_speed);
+ link_speed = phy_setup_axiemac(xemacp);
+ XAxiEthernet_SetOperatingSpeed(xemacp,
+ link_speed);
+#endif
+ netif_set_link_up(netif);
+ eth_link_status = ETH_LINK_UP;
+ xil_printf("Ethernet Link up\r\n");
+ break;
+#if !NO_SYS
+ struct netif *netif = (struct netif *) p;
+ while (1) {
+ /* Call eth_link_detect() every second to detect Ethernet link
+ * change.
+ eth_link_detect(netif);
+ vTaskDelay(LINK_DETECT_THREAD_INTERVAL / portTICK_RATE_MS);
+#endif
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemac_ieee_reg.h b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemac_ieee_reg.h
index 0000000..4c240a9
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemac_ieee_reg.h
@@ -0,0 +1,101 @@
+ * Copyright (C) 2018 - 2019 Xilinx, Inc.
+ * OF SUCH DAMAGE.
+#ifndef __XEMAC_IEEE_REGS_H_
+#define __XEMAC_IEEE_REGS_H_
+/* Advertisement control register. */
+#define ADVERTISE_10HALF 0x0020 /* Try for 10mbps half-duplex */
+#define ADVERTISE_1000XFULL 0x0020 /* Try for 1000BASE-X full-duplex */
+#define ADVERTISE_10FULL 0x0040 /* Try for 10mbps full-duplex */
+#define ADVERTISE_1000XHALF 0x0040 /* Try for 1000BASE-X half-duplex */
+#define ADVERTISE_100HALF 0x0080 /* Try for 100mbps half-duplex */
+#define ADVERTISE_1000XPAUSE 0x0080 /* Try for 1000BASE-X pause */
+#define ADVERTISE_100FULL 0x0100 /* Try for 100mbps full-duplex */
+#define ADVERTISE_1000XPSE_ASYM 0x0100 /* Try for 1000BASE-X asym pause */
+#define ADVERTISE_100BASE4 0x0200 /* Try for 100mbps 4k packets */
+#define ADVERTISE_100_AND_10 (ADVERTISE_10FULL | ADVERTISE_100FULL | \
+ ADVERTISE_10HALF | ADVERTISE_100HALF)
+#define ADVERTISE_100 (ADVERTISE_100FULL | ADVERTISE_100HALF)
+#define ADVERTISE_10 (ADVERTISE_10FULL | ADVERTISE_10HALF)
+#define ADVERTISE_1000 0x0300
+#define IEEE_CONTROL_REG_OFFSET 0
+#define IEEE_STATUS_REG_OFFSET 1
+#define IEEE_AUTONEGO_ADVERTISE_REG 4
+#define IEEE_PARTNER_ABILITIES_1_REG_OFFSET 5
+#define IEEE_PARTNER_ABILITIES_2_REG_OFFSET 8
+#define IEEE_PARTNER_ABILITIES_3_REG_OFFSET 10
+#define IEEE_1000_ADVERTISE_REG_OFFSET 9
+#define IEEE_MMD_ACCESS_CONTROL_REG 13
+#define IEEE_MMD_ACCESS_ADDRESS_DATA_REG 14
+#define IEEE_COPPER_SPECIFIC_CONTROL_REG 16
+#define IEEE_SPECIFIC_STATUS_REG 17
+#define IEEE_COPPER_SPECIFIC_STATUS_REG_2 19
+#define IEEE_EXT_PHY_SPECIFIC_CONTROL_REG 20
+#define IEEE_CONTROL_REG_MAC 21
+#define IEEE_PAGE_ADDRESS_REGISTER 22
+#define IEEE_CTRL_1GBPS_LINKSPEED_MASK 0x2040
+#define IEEE_CTRL_LINKSPEED_MASK 0x0040
+#define IEEE_CTRL_LINKSPEED_1000M 0x0040
+#define IEEE_CTRL_LINKSPEED_100M 0x2000
+#define IEEE_CTRL_LINKSPEED_10M 0x0000
+#define IEEE_CTRL_FULL_DUPLEX 0x100
+#define IEEE_CTRL_RESET_MASK 0x8000
+#define IEEE_CTRL_AUTONEGOTIATE_ENABLE 0x1000
+#define IEEE_STAT_AUTONEGOTIATE_CAPABLE 0x0008
+#define IEEE_STAT_AUTONEGOTIATE_COMPLETE 0x0020
+#define IEEE_STAT_AUTONEGOTIATE_RESTART 0x0200
+#define IEEE_STAT_LINK_STATUS 0x0004
+#define IEEE_STAT_1GBPS_EXTENSIONS 0x0100
+#define IEEE_AN1_ABILITY_MASK 0x1FE0
+#define IEEE_AN3_ABILITY_MASK_1GBPS 0x0C00
+#define IEEE_AN1_ABILITY_MASK_100MBPS 0x0380
+#define IEEE_AN1_ABILITY_MASK_10MBPS 0x0060
+#define IEEE_RGMII_TXRX_CLOCK_DELAYED_MASK 0x0030
+#define IEEE_SPEED_MASK 0xC000
+#define IEEE_SPEED_1000 0x8000
+#define IEEE_SPEED_100 0x4000
+#define IEEE_ASYMMETRIC_PAUSE_MASK 0x0800
+#define IEEE_PAUSE_MASK 0x0400
+#define IEEE_AUTONEG_ERROR_MASK 0x8000
+#define IEEE_MMD_ACCESS_CTRL_DEVAD_MASK 0x1F
+#define IEEE_MMD_ACCESS_CTRL_PIDEVAD_MASK 0x801F
+#define IEEE_MMD_ACCESS_CTRL_NOPIDEVAD_MASK 0x401F
+#endif /* __XEMAC_IEEE_REGS_H_ */
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c
index 0000000..1bf3abb
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c
@@ -0,0 +1,795 @@
+ * Copyright (C) 2010 - 2021 Xilinx, Inc.
+ * OF SUCH DAMAGE.
+#include <stdio.h>
+#include <string.h>
+#include <xparameters.h>
+#include "lwip/opt.h"
+#include "lwip/def.h"
+#include "lwip/pbuf.h"
+#include "lwip/igmp.h"
+#if LWIP_IPV6
+#include "lwip/ethip6.h"
+#endif
+/* Define those to better describe your network interface. */
+#define IFNAME0 't'
+#define IFNAME1 'e'
+#if LWIP_IGMP
+static err_t xemacpsif_mac_filter_update (struct netif *netif,
+ ip_addr_t *group, u8_t action);
+static u8_t xemacps_mcast_entry_mask = 0;
+#endif
+#if LWIP_IPV6 && LWIP_IPV6_MLD
+static err_t xemacpsif_mld6_mac_filter_update (struct netif *netif,
+static u8_t xemacps_mld6_mcast_entry_mask;
+#endif
+XEmacPs_Config *mac_config;
+struct netif *NetIf;
+#if !NO_SYS
+int32_t lExpireCounter = 0;
+#define RESETRXTIMEOUT 10
+#endif
+#endif
+extern volatile u32_t notifyinfo[4*XLWIP_CONFIG_N_TX_DESC];
+#endif
+ * this function is always called with interrupts off
+ * this function also assumes that there are available BD's
+static err_t _unbuffered_low_level_output(xemacpsif_s *xemacpsif,
+ struct pbuf *p, u32_t block_till_tx_complete, u32_t *to_block_index )
+#else
+ struct pbuf *p)
+#endif
+ XStatus status = 0;
+ err_t err = ERR_MEM;
+#if ETH_PAD_SIZE
+ pbuf_header(p, -ETH_PAD_SIZE); /* drop the padding word */
+#endif
+ if (block_till_tx_complete == 1) {
+ status = emacps_sgsend(xemacpsif, p, 1, to_block_index);
+ } else {
+ status = emacps_sgsend(xemacpsif, p, 0, to_block_index);
+#else
+ status = emacps_sgsend(xemacpsif, p);
+#endif
+ if (status != XST_SUCCESS) {
+#if LINK_STATS
+ lwip_stats.link.drop++;
+#endif
+ } else {
+ err = ERR_OK;
+#if ETH_PAD_SIZE
+ pbuf_header(p, ETH_PAD_SIZE); /* reclaim the padding word */
+#endif
+#if LINK_STATS
+ lwip_stats.link.xmit++;
+#endif /* LINK_STATS */
+ return err;
+ * low_level_output():
+ * Should do the actual transmission of the packet. The packet is
+ * contained in the pbuf that is passed to the function. This pbuf
+ * might be chained.
+static err_t low_level_output(struct netif *netif, struct pbuf *p)
+ s32_t freecnt;
+ XEmacPs_BdRing *txring;
+ u32_t notfifyblocksleepcntr;
+ u32_t to_block_index;
+#endif
+ SYS_ARCH_DECL_PROTECT(lev);
+ xemacpsif_s *xemacpsif = (xemacpsif_s *)(xemac->state);
+ SYS_ARCH_PROTECT(lev);
+ /* check if space is available to send */
+ freecnt = is_tx_space_available(xemacpsif);
+ if (freecnt <= 5) {
+ txring = &(XEmacPs_GetTxRing(&xemacpsif->emacps));
+ process_sent_bds(xemacpsif, txring);
+ if (is_tx_space_available(xemacpsif)) {
+ if (netif_is_opt_block_tx_set(netif, NETIF_ENABLE_BLOCKING_TX_FOR_PACKET)) {
+ err = _unbuffered_low_level_output(xemacpsif, p, 1, &to_block_index);
+ } else {
+ err = _unbuffered_low_level_output(xemacpsif, p, 0, &to_block_index);
+#else
+ err = _unbuffered_low_level_output(xemacpsif, p);
+#endif
+ } else {
+#if LINK_STATS
+#endif
+ printf("pack dropped, no space\r\n");
+ SYS_ARCH_UNPROTECT(lev);
+ goto return_pack_dropped;
+ /* Wait for approx 1 second before timing out */
+ notfifyblocksleepcntr = 900000;
+ while(notifyinfo[to_block_index] == 1) {
+ usleep(1);
+ notfifyblocksleepcntr--;
+ if (notfifyblocksleepcntr <= 0) {
+ err = ERR_TIMEOUT;
+ break;
+ netif_clear_opt_block_tx(netif, NETIF_ENABLE_BLOCKING_TX_FOR_PACKET);
+#endif
+return_pack_dropped:
+ return err;
+ * low_level_input():
+ * Should allocate a pbuf and transfer the bytes of the incoming
+ * packet from the interface into the pbuf.
+static struct pbuf * low_level_input(struct netif *netif)
+ struct pbuf *p;
+ /* see if there is data to process */
+ if (pq_qlength(xemacpsif->recv_q) == 0)
+ return NULL;
+ /* return one packet from receive q */
+ p = (struct pbuf *)pq_dequeue(xemacpsif->recv_q);
+ return p;
+ * xemacpsif_output():
+ * This function is called by the TCP/IP stack when an IP packet
+ * should be sent. It calls the function called low_level_output() to
+ * do the actual transmission of the packet.
+static err_t xemacpsif_output(struct netif *netif, struct pbuf *p,
+ const ip_addr_t *ipaddr)
+ /* resolve hardware address, then send (or queue) packet */
+ return etharp_output(netif, p, ipaddr);
+ * xemacpsif_input():
+ * This function should be called when a packet is ready to be read
+ * from the interface. It uses the function low_level_input() that
+ * should handle the actual reception of bytes from the network
+ * interface.
+ * Returns the number of packets read (max 1 packet on success,
+ * 0 if there are no packets)
+ struct eth_hdr *ethhdr;
+ struct pbuf *p;
+#if !NO_SYS
+ while (1)
+#endif
+ /* move received packet into a new pbuf */
+ p = low_level_input(netif);
+ /* no packet could be read, silently ignore this */
+ if (p == NULL) {
+ return 0;
+ /* points to packet payload, which starts with an Ethernet header */
+ ethhdr = p->payload;
+ #if LINK_STATS
+ lwip_stats.link.recv++;
+ #endif /* LINK_STATS */
+ switch (htons(ethhdr->type)) {
+ /* IP or ARP packet? */
+ case ETHTYPE_IP:
+ case ETHTYPE_ARP:
+ #if LWIP_IPV6
+ /*IPv6 Packet?*/
+ case ETHTYPE_IPV6:
+ #endif
+ #if PPPOE_SUPPORT
+ /* PPPoE packet? */
+ case ETHTYPE_PPPOEDISC:
+ case ETHTYPE_PPPOE:
+ #endif /* PPPOE_SUPPORT */
+ /* full packet send to tcpip_thread to process */
+ if (netif->input(p, netif) != ERR_OK) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("xemacpsif_input: IP input error\r\n"));
+ pbuf_free(p);
+ p = NULL;
+ break;
+ default:
+ pbuf_free(p);
+ p = NULL;
+ break;
+ return 1;
+#if !NO_SYS
+void vTimerCallback( TimerHandle_t pxTimer )
+ /* Do something if the pxTimer parameter is NULL */
+ configASSERT(pxTimer);
+ lExpireCounter++;
+ /* If the timer has expired 100 times then reset RX */
+ if(lExpireCounter >= RESETRXTIMEOUT) {
+ lExpireCounter = 0;
+ xemacpsif_resetrx_on_no_rxdata(NetIf);
+#endif
+#endif
+static err_t low_level_init(struct netif *netif)
+ UINTPTR mac_address = (UINTPTR)(netif->state);
+ struct xemac_s *xemac;
+ xemacpsif_s *xemacpsif;
+ u32 dmacrreg;
+ s32_t status = XST_SUCCESS;
+ NetIf = netif;
+ xemacpsif = mem_malloc(sizeof *xemacpsif);
+ if (xemacpsif == NULL) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("xemacpsif_init: out of memory\r\n"));
+ return ERR_MEM;
+ xemac = mem_malloc(sizeof *xemac);
+ if (xemac == NULL) {
+ return ERR_MEM;
+ xemac->state = (void *)xemacpsif;
+ xemac->topology_index = xtopology_find_index(mac_address);
+ xemac->type = xemac_type_emacps;
+ xemacpsif->send_q = NULL;
+ xemacpsif->recv_q = pq_create_queue();
+ if (!xemacpsif->recv_q)
+ return ERR_MEM;
+ /* maximum transfer unit */
+#ifdef ZYNQMP_USE_JUMBO
+ netif->mtu = XEMACPS_MTU_JUMBO - XEMACPS_HDR_SIZE;
+#else
+ netif->mtu = XEMACPS_MTU - XEMACPS_HDR_SIZE;
+#endif
+#if LWIP_IGMP
+ netif->igmp_mac_filter = xemacpsif_mac_filter_update;
+#endif
+ netif->mld_mac_filter = xemacpsif_mld6_mac_filter_update;
+#endif
+ netif->flags = NETIF_FLAG_BROADCAST | NETIF_FLAG_ETHARP |
+ NETIF_FLAG_LINK_UP;
+ netif->flags |= NETIF_FLAG_MLD6;
+#endif
+#if LWIP_IGMP
+ netif->flags |= NETIF_FLAG_IGMP;
+#endif
+#if !NO_SYS
+ sys_sem_new(&xemac->sem_rx_data_available, 0);
+#endif
+ /* obtain config of this emac */
+ mac_config = (XEmacPs_Config *)xemacps_lookup_config((unsigned)(UINTPTR)netif->state);
+ /* Request device to indicate that this library is using it */
+ if (mac_config->BaseAddress == VERSAL_EMACPS_0_BASEADDR) {
+ Xil_Smc(PM_REQUEST_DEVICE_SMC_FID, DEV_GEM_0, 1, 0, 100, 1, 0, 0);
+ Xil_Smc(PM_REQUEST_DEVICE_SMC_FID, DEV_GEM_1, 1, 0, 100, 1, 0, 0);
+#endif
+ status = XEmacPs_CfgInitialize(&xemacpsif->emacps, mac_config,
+ mac_config->BaseAddress);
+ xil_printf("In %s:EmacPs Configuration Failed....\r\n", __func__);
+ /* initialize the mac */
+ init_emacps(xemacpsif, netif);
+ dmacrreg = XEmacPs_ReadReg(xemacpsif->emacps.Config.BaseAddress,
+ XEMACPS_DMACR_OFFSET);
+ dmacrreg = dmacrreg | (0x00000010);
+ XEmacPs_WriteReg(xemacpsif->emacps.Config.BaseAddress,
+ XEMACPS_DMACR_OFFSET, dmacrreg);
+#if !NO_SYS
+ /* Freertos tick is 10ms by default; set period to the same */
+ xemac->xTimer = xTimerCreate("Timer", 10, pdTRUE, ( void * ) 1, vTimerCallback);
+ if (xemac->xTimer == NULL) {
+ xil_printf("In %s:Timer creation failed....\r\n", __func__);
+ } else {
+ if(xTimerStart(xemac->xTimer, 0) != pdPASS) {
+ xil_printf("In %s:Timer start failed....\r\n", __func__);
+#endif
+#endif
+ setup_isr(xemac);
+ init_dma(xemac);
+ start_emacps(xemacpsif);
+ /* replace the state in netif (currently the emac baseaddress)
+ * with the mac instance pointer.
+ netif->state = (void *)xemac;
+ return ERR_OK;
+ u32 dmacrreg;
+ xemacpsif = (xemacpsif_s *)(xemac->state);
+ free_txrx_pbufs(xemacpsif);
+ init_emacps_on_error(xemacpsif, NetIf);
+ dmacrreg = dmacrreg | (0x01000000);
+ setup_isr(xemac);
+ init_dma(xemac);
+ u32 netctrlreg;
+ netctrlreg = XEmacPs_ReadReg(xemacpsif->emacps.Config.BaseAddress,
+ XEMACPS_NWCTRL_OFFSET);
+ netctrlreg = netctrlreg & (~XEMACPS_NWCTRL_TXEN_MASK);
+ XEMACPS_NWCTRL_OFFSET, netctrlreg);
+ free_onlytx_pbufs(xemacpsif);
+ clean_dma_txdescs(xemac);
+ netctrlreg = netctrlreg | (XEMACPS_NWCTRL_TXEN_MASK);
+static u8_t xemacpsif_ip6_addr_ismulticast(ip6_addr_t* ip_addr)
+ if(ip6_addr_ismulticast_linklocal(ip_addr)||
+ ip6_addr_ismulticast_iflocal(ip_addr) ||
+ ip6_addr_ismulticast_adminlocal(ip_addr)||
+ ip6_addr_ismulticast_sitelocal(ip_addr) ||
+ ip6_addr_ismulticast_orglocal(ip_addr) ||
+ ip6_addr_ismulticast_global(ip_addr)) {
+ /*Return TRUE if IPv6 is Multicast type*/
+ return TRUE;
+ } else {
+ return FALSE;
+static void xemacpsif_mld6_mac_hash_update (struct netif *netif, u8_t *ip_addr,
+ u8_t action)
+ u8_t multicast_mac_addr[6];
+ struct xemac_s *xemac = (struct xemac_s *) (netif->state);
+ xemacpsif_s *xemacpsif = (xemacpsif_s *) (xemac->state);
+ multicast_mac_addr[0] = LL_IP6_MULTICAST_ADDR_0;
+ multicast_mac_addr[1] = LL_IP6_MULTICAST_ADDR_1;
+ multicast_mac_addr[2] = ip_addr[12];
+ multicast_mac_addr[3] = ip_addr[13];
+ multicast_mac_addr[4] = ip_addr[14];
+ multicast_mac_addr[5] = ip_addr[15];
+ /* Wait till all sent packets are acknowledged from HW */
+ while(txring->HwCnt);
+ /* Stop Ethernet */
+ XEmacPs_Stop(&xemacpsif->emacps);
+ if (action == NETIF_ADD_MAC_FILTER) {
+ /* Set Mulitcast mac address in hash table */
+ XEmacPs_SetHash(&xemacpsif->emacps, multicast_mac_addr);
+ } else if (action == NETIF_DEL_MAC_FILTER) {
+ /* Remove Mulitcast mac address in hash table */
+ XEmacPs_DeleteHash(&xemacpsif->emacps, multicast_mac_addr);
+ /* Reset DMA */
+ reset_dma(xemac);
+ /* Start Ethernet */
+ XEmacPs_Start(&xemacpsif->emacps);
+static err_t xemacpsif_mld6_mac_filter_update (struct netif *netif, ip_addr_t *group,
+ u8_t action)
+ u8_t temp_mask;
+ unsigned int i;
+ u8_t * ip_addr = (u8_t *) group;
+ if(!(xemacpsif_ip6_addr_ismulticast((ip6_addr_t*) ip_addr))) {
+ ("%s: The requested MAC address is not a multicast address.\r\n", __func__)); LWIP_DEBUGF(NETIF_DEBUG,
+ ("Multicast address add operation failure !!\r\n"));
+ return ERR_ARG;
+ for (i = 0; i < XEMACPS_MAX_MAC_ADDR; i++) {
+ temp_mask = (0x01) << i;
+ if ((xemacps_mld6_mcast_entry_mask & temp_mask) == temp_mask) {
+ continue;
+ xemacps_mld6_mcast_entry_mask |= temp_mask;
+ /* Update mac address in hash table */
+ xemacpsif_mld6_mac_hash_update(netif, ip_addr, action);
+ ("%s: Multicast MAC address successfully added.\r\n", __func__));
+ return ERR_OK;
+ ("%s: No multicast address registers left.\r\n", __func__));
+ ("Multicast MAC address add operation failure !!\r\n"));
+ return ERR_MEM;
+ if ((xemacps_mld6_mcast_entry_mask & temp_mask) != temp_mask) {
+ continue;
+ xemacps_mld6_mcast_entry_mask &= (~temp_mask);
+ ("%s: Multicast MAC address successfully removed.\r\n", __func__));
+ return ERR_OK;
+ ("%s: No multicast address registers present with\r\n", __func__));
+ ("the requested Multicast MAC address.\r\n"));
+ ("Multicast MAC address removal failure!!.\r\n"));
+ return ERR_MEM;
+ return ERR_ARG;
+#endif
+#if LWIP_IGMP
+static void xemacpsif_mac_hash_update (struct netif *netif, u8_t *ip_addr,
+ u8_t action)
+ multicast_mac_addr[0] = 0x01;
+ multicast_mac_addr[1] = 0x00;
+ multicast_mac_addr[2] = 0x5E;
+ multicast_mac_addr[3] = ip_addr[1] & 0x7F;
+ multicast_mac_addr[4] = ip_addr[2];
+ multicast_mac_addr[5] = ip_addr[3];
+ if (action == IGMP_ADD_MAC_FILTER) {
+ } else if (action == IGMP_DEL_MAC_FILTER) {
+ /* Reset DMA */
+ reset_dma(xemac);
+static err_t xemacpsif_mac_filter_update (struct netif *netif, ip_addr_t *group,
+ u8_t action)
+ u8_t temp_mask;
+ unsigned int i;
+ if ((ip_addr[0] < 224) && (ip_addr[0] > 239)) {
+ return ERR_ARG;
+ if ((xemacps_mcast_entry_mask & temp_mask) == temp_mask) {
+ continue;
+ xemacps_mcast_entry_mask |= temp_mask;
+ xemacpsif_mac_hash_update(netif, ip_addr, action);
+ return ERR_OK;
+ if (i == XEMACPS_MAX_MAC_ADDR) {
+ return ERR_MEM;
+ if ((xemacps_mcast_entry_mask & temp_mask) != temp_mask) {
+ continue;
+ xemacps_mcast_entry_mask &= (~temp_mask);
+ return ERR_OK;
+ return ERR_MEM;
+ return ERR_OK;
+#endif
+ * xemacpsif_init():
+ * Should be called at the beginning of the program to set up the
+ * network interface. It calls the function low_level_init() to do the
+ * actual setup of the hardware.
+#if LWIP_SNMP
+ /* ifType ethernetCsmacd(6) @see RFC1213 */
+ netif->link_type = 6;
+ /* your link speed here */
+ netif->link_speed = ;
+ netif->ts = 0;
+ netif->ifinoctets = 0;
+ netif->ifinucastpkts = 0;
+ netif->ifinnucastpkts = 0;
+ netif->ifindiscards = 0;
+ netif->ifoutoctets = 0;
+ netif->ifoutucastpkts = 0;
+ netif->ifoutnucastpkts = 0;
+ netif->ifoutdiscards = 0;
+#endif
+ netif->name[0] = IFNAME0;
+ netif->name[1] = IFNAME1;
+ netif->output = xemacpsif_output;
+ netif->linkoutput = low_level_output;
+#if LWIP_IPV6
+ netif->output_ip6 = ethip6_output;
+#endif
+ low_level_init(netif);
+ return ERR_OK;
+ * xemacpsif_resetrx_on_no_rxdata():
+ * Should be called by the user at regular intervals, typically
+ * from a timer (100 msecond). This is to provide a SW workaround
+ * for the HW bug (SI #692601). Please refer to the function header
+ * for the function resetrx_on_no_rxdata in xemacpsif_dma.c to
+ * know more about the SI.
+ resetrx_on_no_rxdata(xemacpsif);
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
index 0000000..2da3566
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
@@ -0,0 +1,930 @@
+ * OF SUCH DAMAGE.
+#include "lwip/inet_chksum.h"
+#include "xil_mmu.h"
+#include "xreg_cortexr5.h"
+#endif
+#ifdef CONFIG_XTRACE
+#include "xtrace.h"
+#endif
+#if !NO_SYS
+#include "FreeRTOS.h"
+#include "semphr.h"
+#include "timers.h"
+#endif
+#define INTC_BASE_ADDR XPAR_SCUGIC_0_CPU_BASEADDR
+#define INTC_DIST_BASE_ADDR XPAR_SCUGIC_0_DIST_BASEADDR
+/* Byte alignment of BDs */
+#define BD_ALIGNMENT (XEMACPS_DMABD_MINIMUM_ALIGNMENT*2)
+/* A max of 4 different ethernet interfaces are supported */
+static UINTPTR tx_pbufs_storage[4*XLWIP_CONFIG_N_TX_DESC];
+static UINTPTR rx_pbufs_storage[4*XLWIP_CONFIG_N_RX_DESC];
+static s32_t emac_intr_num;
+volatile u32_t notifyinfo[4*XLWIP_CONFIG_N_TX_DESC];
+#endif
+ * Each BD is of 8 bytes of size and the BDs (BD chain) need to be put
+ * at uncached memory location. If they are not put at uncached
+ * locations, the user needs to flush or invalidate for each BD/packet.
+ * However, the flush or invalidate can happen over a cache line which can
+ * span multiple BDs. This means a flush or invalidate of one BD can actually
+ * flush/invalidate multiple BDs adjacent to the targeted BD.Assuming that
+ * the user and hardware both update the BD fields, this operation from user
+ * can potentially overwrite the updates done by hardware or user.
+ * To avoid this, it is always safe to put the BD chains for Rx and tx side
+ * The Xilinx standalone BSP for Cortex A9 implements only primary page tables.
+ * Each table entry corresponds to 1 MB of address map. This means, if a memory
+ * region has to be made uncached, the minimum granularity will be of 1 MB.
+ * The implementation below allocates a 1 MB of u8 array aligned to 1 MB.
+ * This ensures that this array is put at 1 MB aligned memory (e.g. 0x1200000)
+ * and accupies memory of 1 MB. The init_dma function then changes 1 MB of this
+ * region to make it uncached (strongly ordered).
+ * This increases the bss section of the program significantly and can be a
+ * wastage of memory. The reason beings, BDs will hardly occupy few KBs of
+ * memory and the rest of 1 MB of memory will be unused.
+ * If a program uses other peripherals that have DMAs/bus masters and need
+ * uncached memory, they may also end of following the same approach. This
+ * definitely aggravates the memory wastage issue. To avoid all this, the user
+ * can create a new 1 MB section in the linker script and reserve it for such
+ * use cases that need uncached memory location. They can then have their own
+ * memory allocation logic in their application that allocates uncached memory
+ * from this 1 MB location. For such a case, changes need to be done in this
+ * file and appropriate uncached memory allocated through other means can be
+ * used.
+ * The present implementation here allocates 1 MB of uncached memory. It
+ * reserves of 64 KB of memory for each BD chain. 64 KB of memory means 8192 of
+ * BDs for each BD chain which is more than enough for any application.
+ * Assuming that both emac0 and emac1 are present, 256 KB of memory is allocated
+ * for BDs. The rest 768 KB of memory is just unused.
+#if defined __aarch64__
+u8_t bd_space[0x200000] __attribute__ ((aligned (0x200000)));
+#else
+u8_t bd_space[0x100000] __attribute__ ((aligned (0x100000)));
+#endif
+static volatile u32_t bd_space_index = 0;
+static volatile u32_t bd_space_attr_set = 0;
+#if !NO_SYS
+long xInsideISR = 0;
+#endif
+#define XEMACPS_BD_TO_INDEX(ringptr, bdptr) \
+ (((UINTPTR)bdptr - (UINTPTR)(ringptr)->BaseBdAddr) / (ringptr)->Separation)
+ s32_t freecnt = 0;
+ txring = &(XEmacPs_GetTxRing(&emac->emacps));
+ /* tx space is available as long as there are valid BD's */
+ freecnt = XEmacPs_BdRingGetFreeCnt(txring);
+ return freecnt;
+static inline
+u32_t get_base_index_txpbufsstorage (xemacpsif_s *xemacpsif)
+ u32_t index;
+#ifdef XPAR_XEMACPS_0_BASEADDR
+ if (xemacpsif->emacps.Config.BaseAddress == XPAR_XEMACPS_0_BASEADDR) {
+ index = 0;
+#endif
+#ifdef XPAR_XEMACPS_1_BASEADDR
+ if (xemacpsif->emacps.Config.BaseAddress == XPAR_XEMACPS_1_BASEADDR) {
+ index = XLWIP_CONFIG_N_TX_DESC;
+#endif
+#ifdef XPAR_XEMACPS_2_BASEADDR
+ if (xemacpsif->emacps.Config.BaseAddress == XPAR_XEMACPS_2_BASEADDR) {
+ index = 2 * XLWIP_CONFIG_N_TX_DESC;
+#endif
+#ifdef XPAR_XEMACPS_3_BASEADDR
+ if (xemacpsif->emacps.Config.BaseAddress == XPAR_XEMACPS_3_BASEADDR) {
+ index = 3 * XLWIP_CONFIG_N_TX_DESC;
+#endif
+ return index;
+static inline
+u32_t get_base_index_tasknotifyinfo (xemacpsif_s *xemacpsif)
+ u32_t index;
+ index = 0;
+#endif
+#endif
+#endif
+#endif
+ return index;
+#endif
+static inline
+u32_t get_base_index_rxpbufsstorage (xemacpsif_s *xemacpsif)
+ u32_t index;
+ index = 0;
+#endif
+ index = XLWIP_CONFIG_N_RX_DESC;
+#endif
+ index = 2 * XLWIP_CONFIG_N_RX_DESC;
+#endif
+ index = 3 * XLWIP_CONFIG_N_RX_DESC;
+#endif
+ return index;
+ XEmacPs_Bd *txbdset;
+ XEmacPs_Bd *curbdpntr;
+ s32_t n_bds;
+ XStatus status;
+ s32_t n_pbufs_freed = 0;
+ u32_t bdindex;
+ struct pbuf *p;
+ u32 *temp;
+ u32_t index;
+ u32_t tx_task_notifier_index;
+#endif
+ index = get_base_index_txpbufsstorage (xemacpsif);
+ tx_task_notifier_index = get_base_index_tasknotifyinfo (xemacpsif);
+#endif
+ while (1) {
+ /* obtain processed BD's */
+ n_bds = XEmacPs_BdRingFromHwTx(txring,
+ XLWIP_CONFIG_N_TX_DESC, &txbdset);
+ if (n_bds == 0) {
+ return;
+ /* free the processed BD's */
+ n_pbufs_freed = n_bds;
+ curbdpntr = txbdset;
+ while (n_pbufs_freed > 0) {
+ bdindex = XEMACPS_BD_TO_INDEX(txring, curbdpntr);
+ temp = (u32 *)curbdpntr;
+ *temp = 0;
+ temp++;
+ if (bdindex == (XLWIP_CONFIG_N_TX_DESC - 1)) {
+ *temp = 0xC0000000;
+ } else {
+ *temp = 0x80000000;
+ dsb();
+ p = (struct pbuf *)tx_pbufs_storage[index + bdindex];
+ if (p != NULL) {
+ pbuf_free(p);
+ notifyinfo[tx_task_notifier_index + bdindex] = 0;
+#endif
+ tx_pbufs_storage[index + bdindex] = 0;
+ curbdpntr = XEmacPs_BdRingNext(txring, curbdpntr);
+ n_pbufs_freed--;
+ dsb();
+ status = XEmacPs_BdRingFree(txring, n_bds, txbdset);
+ LWIP_DEBUGF(NETIF_DEBUG, ("Failure while freeing in Tx Done ISR\r\n"));
+ return;
+ XEmacPs_BdRing *txringptr;
+ u32_t regval;
+#if !NO_SYS
+ xInsideISR++;
+#endif
+ xemac = (struct xemac_s *)(arg);
+ txringptr = &(XEmacPs_GetTxRing(&xemacpsif->emacps));
+ regval = XEmacPs_ReadReg(xemacpsif->emacps.Config.BaseAddress, XEMACPS_TXSR_OFFSET);
+ XEmacPs_WriteReg(xemacpsif->emacps.Config.BaseAddress,XEMACPS_TXSR_OFFSET, regval);
+ /* If Transmit done interrupt is asserted, process completed BD's */
+ process_sent_bds(xemacpsif, txringptr);
+#if !NO_SYS
+ xInsideISR--;
+#endif
+#else
+#endif
+ struct pbuf *q;
+ s32_t n_pbufs;
+ XEmacPs_Bd *txbdset, *txbd, *last_txbd = NULL;
+ XEmacPs_Bd *temp_txbd;
+ XStatus status;
+ u32_t bdindex = 0;
+ u32_t index;
+ u32_t max_fr_size;
+#endif
+#endif
+ /* first count the number of pbufs */
+ for (q = p, n_pbufs = 0; q != NULL; q = q->next)
+ n_pbufs++;
+ /* obtain as many BD's */
+ status = XEmacPs_BdRingAlloc(txring, n_pbufs, &txbdset);
+ LWIP_DEBUGF(NETIF_DEBUG, ("sgsend: Error allocating TxBD\r\n"));
+ return XST_FAILURE;
+ for(q = p, txbd = txbdset; q != NULL; q = q->next) {
+ bdindex = XEMACPS_BD_TO_INDEX(txring, txbd);
+ if (tx_pbufs_storage[index + bdindex] != 0) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("PBUFS not available\r\n"));
+ /* Send the data from the pbuf to the interface, one pbuf at a
+ time. The size of the data in each pbuf is kept in the ->len
+ variable. */
+ if (xemacpsif->emacps.Config.IsCacheCoherent == 0) {
+ Xil_DCacheFlushRange((UINTPTR)q->payload, (UINTPTR)q->len);
+ XEmacPs_BdSetAddressTx(txbd, (UINTPTR)q->payload);
+ max_fr_size = MAX_FRAME_SIZE_JUMBO - 18;
+#else
+ max_fr_size = XEMACPS_MAX_FRAME_SIZE - 18;
+#endif
+ if (q->len > max_fr_size)
+ XEmacPs_BdSetLength(txbd, max_fr_size & 0x3FFF);
+ else
+ XEmacPs_BdSetLength(txbd, q->len & 0x3FFF);
+ tx_pbufs_storage[index + bdindex] = (UINTPTR)q;
+ pbuf_ref(q);
+ last_txbd = txbd;
+ XEmacPs_BdClearLast(txbd);
+ txbd = XEmacPs_BdRingNext(txring, txbd);
+ notifyinfo[tx_task_notifier_index + bdindex] = 1;
+ *to_block_index = tx_task_notifier_index + bdindex;
+#endif
+ XEmacPs_BdSetLast(last_txbd);
+ /* For fragmented packets, remember the 1st BD allocated for the 1st
+ packet fragment. The used bit for this BD should be cleared at the end
+ after clearing out used bits for other fragments. For packets without
+ just remember the allocated BD. */
+ temp_txbd = txbdset;
+ txbd = txbdset;
+ q = p->next;
+ for(; q != NULL; q = q->next) {
+ XEmacPs_BdClearTxUsed(txbd);
+ XEmacPs_BdClearTxUsed(temp_txbd);
+ dsb();
+ status = XEmacPs_BdRingToHw(txring, n_pbufs, txbdset);
+ LWIP_DEBUGF(NETIF_DEBUG, ("sgsend: Error submitting TxBD\r\n"));
+ /* Start transmit */
+ XEmacPs_WriteReg((xemacpsif->emacps).Config.BaseAddress,
+ (XEmacPs_ReadReg((xemacpsif->emacps).Config.BaseAddress,
+ XEMACPS_NWCTRL_OFFSET) | XEMACPS_NWCTRL_STARTTX_MASK));
+ return status;
+ XEmacPs_Bd *rxbd;
+ XStatus status;
+ struct pbuf *p;
+ u32_t freebds;
+ u32_t bdindex;
+ u32 *temp;
+ u32_t index;
+ index = get_base_index_rxpbufsstorage (xemacpsif);
+ freebds = XEmacPs_BdRingGetFreeCnt (rxring);
+ while (freebds > 0) {
+ freebds--;
+ p = pbuf_alloc(PBUF_RAW, MAX_FRAME_SIZE_JUMBO, PBUF_POOL);
+#else
+ p = pbuf_alloc(PBUF_RAW, XEMACPS_MAX_FRAME_SIZE, PBUF_POOL);
+#endif
+ if (!p) {
+#if LINK_STATS
+ lwip_stats.link.memerr++;
+#endif
+ printf("unable to alloc pbuf in recv_handler\r\n");
+ return;
+ status = XEmacPs_BdRingAlloc(rxring, 1, &rxbd);
+ LWIP_DEBUGF(NETIF_DEBUG, ("setup_rx_bds: Error allocating RxBD\r\n"));
+ pbuf_free(p);
+ return;
+ status = XEmacPs_BdRingToHw(rxring, 1, rxbd);
+ LWIP_DEBUGF(NETIF_DEBUG, ("Error committing RxBD to hardware: "));
+ if (status == XST_DMA_SG_LIST_ERROR) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("XST_DMA_SG_LIST_ERROR: this function was called out of sequence with XEmacPs_BdRingAlloc()\r\n"));
+ else {
+ LWIP_DEBUGF(NETIF_DEBUG, ("set of BDs was rejected because the first BD did not have its start-of-packet bit set, or the last BD did not have its end-of-packet bit set, or any one of the BD set has 0 as length value\r\n"));
+ pbuf_free(p);
+ XEmacPs_BdRingUnAlloc(rxring, 1, rxbd);
+ return;
+ Xil_DCacheInvalidateRange((UINTPTR)p->payload, (UINTPTR)MAX_FRAME_SIZE_JUMBO);
+#else
+ Xil_DCacheInvalidateRange((UINTPTR)p->payload, (UINTPTR)XEMACPS_MAX_FRAME_SIZE);
+#endif
+ bdindex = XEMACPS_BD_TO_INDEX(rxring, rxbd);
+ temp = (u32 *)rxbd;
+ temp++;
+ /* Status field should be cleared first to avoid drops */
+ *temp = 0;
+ dsb();
+ /* Set high address when required */
+#ifdef __aarch64__
+ XEmacPs_BdWrite(rxbd, XEMACPS_BD_ADDR_HI_OFFSET,
+ (((UINTPTR)p->payload) & ULONG64_HI_MASK) >> 32U);
+#endif
+ /* Set address field; add WRAP bit on last descriptor */
+ if (bdindex == (XLWIP_CONFIG_N_RX_DESC - 1)) {
+ XEmacPs_BdWrite(rxbd, XEMACPS_BD_ADDR_OFFSET, ((UINTPTR)p->payload | XEMACPS_RXBUF_WRAP_MASK));
+ } else {
+ XEmacPs_BdWrite(rxbd, XEMACPS_BD_ADDR_OFFSET, (UINTPTR)p->payload);
+ rx_pbufs_storage[index + bdindex] = (UINTPTR)p;
+ struct pbuf *p;
+ XEmacPs_Bd *rxbdset, *curbdptr;
+ XEmacPs_BdRing *rxring;
+ volatile s32_t bd_processed;
+ s32_t rx_bytes, k;
+ u32_t bdindex;
+ u32_t regval;
+ u32_t index;
+ u32_t gigeversion;
+ rxring = &XEmacPs_GetRxRing(&xemacpsif->emacps);
+#if !NO_SYS
+ xInsideISR++;
+#endif
+ gigeversion = ((Xil_In32(xemacpsif->emacps.Config.BaseAddress + 0xFC)) >> 16) & 0xFFF;
+ * If Reception done interrupt is asserted, call RX call back function
+ * to handle the processed BDs and then raise the according flag.
+ regval = XEmacPs_ReadReg(xemacpsif->emacps.Config.BaseAddress, XEMACPS_RXSR_OFFSET);
+ XEmacPs_WriteReg(xemacpsif->emacps.Config.BaseAddress, XEMACPS_RXSR_OFFSET, regval);
+ if (gigeversion <= 2) {
+ while(1) {
+ bd_processed = XEmacPs_BdRingFromHwRx(rxring, XLWIP_CONFIG_N_RX_DESC, &rxbdset);
+ if (bd_processed <= 0) {
+ break;
+ for (k = 0, curbdptr=rxbdset; k < bd_processed; k++) {
+ bdindex = XEMACPS_BD_TO_INDEX(rxring, curbdptr);
+ p = (struct pbuf *)rx_pbufs_storage[index + bdindex];
+ * Adjust the buffer size to the actual number of bytes received.
+ rx_bytes = XEmacPs_GetRxFrameSize(&xemacpsif->emacps, curbdptr);
+#else
+ rx_bytes = XEmacPs_BdGetLength(curbdptr);
+#endif
+ pbuf_realloc(p, rx_bytes);
+ /* Invalidate RX frame before queuing to handle
+ * L1 cache prefetch conditions on any architecture.
+ Xil_DCacheInvalidateRange((UINTPTR)p->payload, rx_bytes);
+ /* store it in the receive queue,
+ * where it'll be processed by a different handler
+ if (pq_enqueue(xemacpsif->recv_q, (void*)p) < 0) {
+#if LINK_STATS
+#endif
+ pbuf_free(p);
+ curbdptr = XEmacPs_BdRingNext( rxring, curbdptr);
+ /* free up the BD's */
+ XEmacPs_BdRingFree(rxring, bd_processed, rxbdset);
+ setup_rx_bds(xemacpsif, rxring);
+#if !NO_SYS
+ sys_sem_signal(&xemac->sem_rx_data_available);
+ xInsideISR--;
+#endif
+ return;
+ XEmacPs_Bd bdtemplate;
+ txringptr = &XEmacPs_GetTxRing(&xemacpsif->emacps);
+ XEmacPs_BdClear(&bdtemplate);
+ XEmacPs_BdSetStatus(&bdtemplate, XEMACPS_TXBUF_USED_MASK);
+ * Create the TxBD ring
+ XEmacPs_BdRingCreate(txringptr, (UINTPTR) xemacpsif->tx_bdspace,
+ (UINTPTR) xemacpsif->tx_bdspace, BD_ALIGNMENT,
+ XLWIP_CONFIG_N_TX_DESC);
+ XEmacPs_BdRingClone(txringptr, &bdtemplate, XEMACPS_SEND);
+ XEmacPs_BdRing *rxringptr, *txringptr;
+ XEmacPs_Bd *rxbd;
+ struct pbuf *p;
+ XStatus status;
+ s32_t i;
+ u32_t bdindex;
+ volatile UINTPTR tempaddress;
+ u32_t index;
+ XEmacPs_Bd *bdtxterminate = NULL;
+ XEmacPs_Bd *bdrxterminate = NULL;
+ u32 *temp;
+ struct xtopology_t *xtopologyp = &xtopology[xemac->topology_index];
+ * The BDs need to be allocated in uncached memory. Hence the 1 MB
+ * address range allocated for Bd_Space is made uncached
+ * by setting appropriate attributes in the translation table.
+ * The Bd_Space is aligned to 1MB and has a size of 1 MB. This ensures
+ * a reserved uncached area used only for BDs.
+ if (bd_space_attr_set == 0) {
+ Xil_SetTlbAttributes((s32_t)bd_space, STRONG_ORDERD_SHARED | PRIV_RW_USER_RW); // addr, attr
+#else
+ Xil_SetTlbAttributes((u64)bd_space, NORM_NONCACHE | INNER_SHAREABLE);
+#else
+ Xil_SetTlbAttributes((s32_t)bd_space, DEVICE_MEMORY); // addr, attr
+#endif
+#endif
+ bd_space_attr_set = 1;
+ rxringptr = &XEmacPs_GetRxRing(&xemacpsif->emacps);
+ LWIP_DEBUGF(NETIF_DEBUG, ("rxringptr: 0x%08x\r\n", rxringptr));
+ LWIP_DEBUGF(NETIF_DEBUG, ("txringptr: 0x%08x\r\n", txringptr));
+ /* Allocate 64k for Rx and Tx bds each to take care of extreme cases */
+ tempaddress = (UINTPTR)&(bd_space[bd_space_index]);
+ xemacpsif->rx_bdspace = (void *)tempaddress;
+ bd_space_index += 0x10000;
+ xemacpsif->tx_bdspace = (void *)tempaddress;
+ if (gigeversion > 2) {
+ bdrxterminate = (XEmacPs_Bd *)tempaddress;
+ bdtxterminate = (XEmacPs_Bd *)tempaddress;
+ LWIP_DEBUGF(NETIF_DEBUG, ("rx_bdspace: %p \r\n", xemacpsif->rx_bdspace));
+ LWIP_DEBUGF(NETIF_DEBUG, ("tx_bdspace: %p \r\n", xemacpsif->tx_bdspace));
+ if (!xemacpsif->rx_bdspace || !xemacpsif->tx_bdspace) {
+ xil_printf("%s@%d: Error: Unable to allocate memory for TX/RX buffer descriptors",
+ __FILE__, __LINE__);
+ return ERR_IF;
+ * Setup RxBD space.
+ * Setup a BD template for the Rx channel. This template will be copied to
+ * every RxBD. We will not have to explicitly set these again.
+ * Create the RxBD ring
+ status = XEmacPs_BdRingCreate(rxringptr, (UINTPTR) xemacpsif->rx_bdspace,
+ (UINTPTR) xemacpsif->rx_bdspace, BD_ALIGNMENT,
+ XLWIP_CONFIG_N_RX_DESC);
+ LWIP_DEBUGF(NETIF_DEBUG, ("Error setting up RxBD space\r\n"));
+ return ERR_IF;
+ status = XEmacPs_BdRingClone(rxringptr, &bdtemplate, XEMACPS_RECV);
+ LWIP_DEBUGF(NETIF_DEBUG, ("Error initializing RxBD space\r\n"));
+ return ERR_IF;
+ status = XEmacPs_BdRingCreate(txringptr, (UINTPTR) xemacpsif->tx_bdspace,
+ return ERR_IF;
+ /* We reuse the bd template, as the same one will work for both rx and tx. */
+ status = XEmacPs_BdRingClone(txringptr, &bdtemplate, XEMACPS_SEND);
+ return ERR_IF;
+ * Allocate RX descriptors, 1 RxBD at a time.
+ for (i = 0; i < XLWIP_CONFIG_N_RX_DESC; i++) {
+#else
+#endif
+ if (!p) {
+#if LINK_STATS
+#endif
+ printf("unable to alloc pbuf in init_dma\r\n");
+ return ERR_IF;
+ status = XEmacPs_BdRingAlloc(rxringptr, 1, &rxbd);
+ LWIP_DEBUGF(NETIF_DEBUG, ("init_dma: Error allocating RxBD\r\n"));
+ pbuf_free(p);
+ return ERR_IF;
+ /* Enqueue to HW */
+ status = XEmacPs_BdRingToHw(rxringptr, 1, rxbd);
+ LWIP_DEBUGF(NETIF_DEBUG, ("Error: committing RxBD to HW\r\n"));
+ pbuf_free(p);
+ XEmacPs_BdRingUnAlloc(rxringptr, 1, rxbd);
+ return ERR_IF;
+ bdindex = XEMACPS_BD_TO_INDEX(rxringptr, rxbd);
+ *temp = 0;
+ *temp = 0x00000002;
+ temp++;
+ *temp = 0;
+ dsb();
+#else
+#endif
+ XEmacPs_BdSetAddressRx(rxbd, (UINTPTR)p->payload);
+ XEmacPs_SetQueuePtr(&(xemacpsif->emacps), xemacpsif->emacps.RxBdRing.BaseBdAddr, 0, XEMACPS_RECV);
+ XEmacPs_SetQueuePtr(&(xemacpsif->emacps), xemacpsif->emacps.TxBdRing.BaseBdAddr, 1, XEMACPS_SEND);
+ }else {
+ XEmacPs_SetQueuePtr(&(xemacpsif->emacps), xemacpsif->emacps.TxBdRing.BaseBdAddr, 0, XEMACPS_SEND);
+ * This version of GEM supports priority queuing and the current
+ * driver is using tx priority queue 1 and normal rx queue for
+ * packet transmit and receive. The below code ensure that the
+ * other queue pointers are parked to known state for avoiding
+ * the controller to malfunction by fetching the descriptors
+ * from these queues.
+ XEmacPs_BdClear(bdrxterminate);
+ XEmacPs_BdSetAddressRx(bdrxterminate, (XEMACPS_RXBUF_NEW_MASK |
+ XEMACPS_RXBUF_WRAP_MASK));
+ XEmacPs_Out32((xemacpsif->emacps.Config.BaseAddress + XEMACPS_RXQ1BASE_OFFSET),
+ (UINTPTR)bdrxterminate);
+ XEmacPs_BdClear(bdtxterminate);
+ XEmacPs_BdSetStatus(bdtxterminate, (XEMACPS_TXBUF_USED_MASK |
+ XEMACPS_TXBUF_WRAP_MASK));
+ XEmacPs_Out32((xemacpsif->emacps.Config.BaseAddress + XEMACPS_TXQBASE_OFFSET),
+ (UINTPTR)bdtxterminate);
+#if !NO_SYS
+ xPortInstallInterruptHandler(xtopologyp->scugic_emac_intr,
+ ( Xil_InterruptHandler ) XEmacPs_IntrHandler,
+ (void *)&xemacpsif->emacps);
+#else
+ * Connect the device driver handler that will be called when an
+ * interrupt for the device occurs, the handler defined above performs
+ * the specific interrupt processing for the device.
+ XScuGic_RegisterHandler(INTC_BASE_ADDR, xtopologyp->scugic_emac_intr,
+ (Xil_ExceptionHandler)XEmacPs_IntrHandler,
+#endif
+ * Enable the interrupt for emacps.
+ XScuGic_EnableIntr(INTC_DIST_BASE_ADDR, (u32) xtopologyp->scugic_emac_intr);
+ emac_intr_num = (u32) xtopologyp->scugic_emac_intr;
+ return 0;
+ * resetrx_on_no_rxdata():
+ * It is called at regular intervals through the API xemacpsif_resetrx_on_no_rxdata
+ * called by the user.
+ * The EmacPs has a HW bug (SI# 692601) on the Rx path for heavy Rx traffic.
+ * Under heavy Rx traffic because of the HW bug there are times when the Rx path
+ * becomes unresponsive. The workaround for it is to check for the Rx path for
+ * traffic (by reading the stats registers regularly). If the stats register
+ * does not increment for sometime (proving no Rx traffic), the function resets
+ * the Rx data path.
+ u32_t regctrl;
+ u32_t tempcntr;
+ if (gigeversion == 2) {
+ tempcntr = XEmacPs_ReadReg(xemacpsif->emacps.Config.BaseAddress, XEMACPS_RXCNT_OFFSET);
+ if ((!tempcntr) && (!(xemacpsif->last_rx_frms_cntr))) {
+ regctrl = XEmacPs_ReadReg(xemacpsif->emacps.Config.BaseAddress,
+ regctrl &= (~XEMACPS_NWCTRL_RXEN_MASK);
+ XEMACPS_NWCTRL_OFFSET, regctrl);
+ regctrl = XEmacPs_ReadReg(xemacpsif->emacps.Config.BaseAddress, XEMACPS_NWCTRL_OFFSET);
+ regctrl |= (XEMACPS_NWCTRL_RXEN_MASK);
+ XEmacPs_WriteReg(xemacpsif->emacps.Config.BaseAddress, XEMACPS_NWCTRL_OFFSET, regctrl);
+ xemacpsif->last_rx_frms_cntr = tempcntr;
+ s32_t index;
+ s32_t index1;
+ struct pbuf *p;
+ index1 = get_base_index_txpbufsstorage (xemacpsif);
+ for (index = index1; index < (index1 + XLWIP_CONFIG_N_TX_DESC); index++) {
+ if (tx_pbufs_storage[index] != 0) {
+ p = (struct pbuf *)tx_pbufs_storage[index];
+ pbuf_free(p);
+ tx_pbufs_storage[index] = 0;
+ index1 = get_base_index_rxpbufsstorage(xemacpsif);
+ for (index = index1; index < (index1 + XLWIP_CONFIG_N_RX_DESC); index++) {
+ p = (struct pbuf *)rx_pbufs_storage[index];
+ pbuf_free(p);
+ s32_t index;
+ s32_t index1;
+ struct pbuf *p;
+ pbuf_free(p);
+/* reset Tx and Rx DMA pointers after XEmacPs_Stop */
+ u8 txqueuenum;
+ XEmacPs_BdRing *txringptr = &XEmacPs_GetTxRing(&xemacpsif->emacps);
+ XEmacPs_BdRing *rxringptr = &XEmacPs_GetRxRing(&xemacpsif->emacps);
+ XEmacPs_BdRingPtrReset(txringptr, xemacpsif->tx_bdspace);
+ XEmacPs_BdRingPtrReset(rxringptr, xemacpsif->rx_bdspace);
+ txqueuenum = 1;
+ } else {
+ txqueuenum = 0;
+ XEmacPs_SetQueuePtr(&(xemacpsif->emacps), xemacpsif->emacps.TxBdRing.BaseBdAddr, txqueuenum, XEMACPS_SEND);
+void emac_disable_intr(void)
+ XScuGic_DisableIntr(INTC_DIST_BASE_ADDR, emac_intr_num);
+void emac_enable_intr(void)
+ XScuGic_EnableIntr(INTC_DIST_BASE_ADDR, emac_intr_num);
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_hw.c b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_hw.c
index 0000000..a1fdeda
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_hw.c
@@ -0,0 +1,276 @@
+ * OF SUCH DAMAGE.
+#if XPAR_GIGE_PCS_PMA_1000BASEX_CORE_PRESENT == 1 || \
+ XPAR_GIGE_PCS_PMA_SGMII_CORE_PRESENT == 1
+#define PCM_PMA_CORE_PRESENT
+#else
+#undef PCM_PMA_CORE_PRESENT
+#endif
+u32_t link_speed = 100;
+extern XEmacPs_Config XEmacPs_ConfigTable[];
+extern u32_t phymapemac0[32];
+extern u32_t phymapemac1[32];
+extern u32_t phyaddrforemac;
+extern enum ethernet_link_status eth_link_status;
+#if !NO_SYS
+extern long xInsideISR;
+#endif
+ XEmacPs_Config *cfgptr = NULL;
+ s32_t i;
+ for (i = 0; i < XPAR_XEMACPS_NUM_INSTANCES; i++) {
+ if (XEmacPs_ConfigTable[i].BaseAddress == mac_base) {
+ cfgptr = &XEmacPs_ConfigTable[i];
+ break;
+ return (cfgptr);
+ XEmacPs *xemacpsp;
+ u32_t i;
+ u32_t phyfoundforemac0 = FALSE;
+ u32_t phyfoundforemac1 = FALSE;
+ xemacpsp = &xemacps->emacps;
+ XEmacPs_SetOptions(xemacpsp, XEMACPS_JUMBO_ENABLE_OPTION);
+#endif
+#ifdef LWIP_IGMP
+ XEmacPs_SetOptions(xemacpsp, XEMACPS_MULTICAST_OPTION);
+#endif
+ status = XEmacPs_SetMacAddress(xemacpsp, (void*)(netif->hwaddr), 1);
+ xil_printf("In %s:Emac Mac Address set failed...\r\n",__func__);
+ XEmacPs_SetMdioDivisor(xemacpsp, MDC_DIV_224);
+/* Please refer to file header comments for the file xemacpsif_physpeed.c
+ * to know more about the PHY programming sequence.
+ * For PCS PMA core, phy_setup_emacps is called with the predefined PHY address
+ * exposed through xaparemeters.h
+ * For RGMII case, assuming multiple PHYs can be present on the MDIO bus,
+ * detect_phy is called to get the addresses of the PHY present on
+ * a particular MDIO bus (emac0 or emac1). This address map is populated
+ * in phymapemac0 or phymapemac1.
+ * phy_setup_emacps is then called for each PHY present on the MDIO bus.
+#ifdef PCM_PMA_CORE_PRESENT
+#ifdef XPAR_GIGE_PCS_PMA_1000BASEX_CORE_PRESENT
+ link_speed = phy_setup_emacps(xemacpsp, XPAR_PCSPMA_1000BASEX_PHYADDR);
+#elif XPAR_GIGE_PCS_PMA_SGMII_CORE_PRESENT
+ link_speed = phy_setup_emacps(xemacpsp, XPAR_PCSPMA_SGMII_PHYADDR);
+#endif
+#else
+ detect_phy(xemacpsp);
+ for (i = 31; i > 0; i--) {
+ if (xemacpsp->Config.BaseAddress == XPAR_XEMACPS_0_BASEADDR) {
+ if (phymapemac0[i] == TRUE) {
+ link_speed = phy_setup_emacps(xemacpsp, i);
+ phyfoundforemac0 = TRUE;
+ phyaddrforemac = i;
+ } else {
+ if (phymapemac1[i] == TRUE) {
+ phyfoundforemac1 = TRUE;
+ /* If no PHY was detected, use broadcast PHY address of 0 */
+ if (phyfoundforemac0 == FALSE)
+ link_speed = phy_setup_emacps(xemacpsp, 0);
+ } else {
+ if (phyfoundforemac1 == FALSE)
+#endif
+ if (link_speed == XST_FAILURE) {
+ xil_printf("Phy setup failure %s \n\r",__func__);
+ return;
+ } else {
+ XEmacPs_SetOperatingSpeed(xemacpsp, link_speed);
+ /* Setting the operating speed of the MAC needs a delay. */
+ volatile s32_t wait;
+ for (wait=0; wait < 20000; wait++);
+ * Setup callbacks
+ XEmacPs_SetHandler(&xemacpsif->emacps, XEMACPS_HANDLER_DMASEND,
+ (void *) emacps_send_handler,
+ (void *) xemac);
+ XEmacPs_SetHandler(&xemacpsif->emacps, XEMACPS_HANDLER_DMARECV,
+ (void *) emacps_recv_handler,
+ (void *) xemac);
+ XEmacPs_SetHandler(&xemacpsif->emacps, XEMACPS_HANDLER_ERROR,
+ (void *) emacps_error_handler,
+ (void *) xemac);
+ /* start the temac */
+ XEmacPs_Start(&xemacps->emacps);
+void restart_emacps_transmitter (xemacpsif_s *xemacps) {
+ u32_t Reg;
+ Reg = XEmacPs_ReadReg(xemacps->emacps.Config.BaseAddress,
+ Reg = Reg & (~XEMACPS_NWCTRL_TXEN_MASK);
+ XEmacPs_WriteReg(xemacps->emacps.Config.BaseAddress,
+ XEMACPS_NWCTRL_OFFSET, Reg);
+ Reg = Reg | (XEMACPS_NWCTRL_TXEN_MASK);
+#if !NO_SYS
+ xInsideISR++;
+#endif
+ txring = &XEmacPs_GetTxRing(&xemacpsif->emacps);
+ if (ErrorWord != 0) {
+ switch (Direction) {
+ case XEMACPS_RECV:
+ if (ErrorWord & XEMACPS_RXSR_HRESPNOK_MASK) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("Receive DMA error\r\n"));
+ HandleEmacPsError(xemac);
+ if (ErrorWord & XEMACPS_RXSR_RXOVR_MASK) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("Receive over run\r\n"));
+ emacps_recv_handler(arg);
+ if (ErrorWord & XEMACPS_RXSR_BUFFNA_MASK) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("Receive buffer not available\r\n"));
+ break;
+ case XEMACPS_SEND:
+ if (ErrorWord & XEMACPS_TXSR_HRESPNOK_MASK) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("Transmit DMA error\r\n"));
+ if (ErrorWord & XEMACPS_TXSR_URUN_MASK) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("Transmit under run\r\n"));
+ HandleTxErrors(xemac);
+ if (ErrorWord & XEMACPS_TXSR_BUFEXH_MASK) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("Transmit buffer exhausted\r\n"));
+ if (ErrorWord & XEMACPS_TXSR_RXOVR_MASK) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("Transmit retry excessed limits\r\n"));
+ if (ErrorWord & XEMACPS_TXSR_FRAMERX_MASK) {
+ LWIP_DEBUGF(NETIF_DEBUG, ("Transmit collision\r\n"));
+ break;
+#if !NO_SYS
+ xInsideISR--;
+#endif
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_physpeed.c b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_physpeed.c
new file mode 100644
index 0000000..069020a
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_physpeed.c
@@ -0,0 +1,1037 @@
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without modification,
+ * are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. The name of the author may not be used to endorse or promote products
+ * derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
+ * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+ * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
+ * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
+ * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+ * This file is part of the lwIP TCP/IP stack.
+* This file xemacpsif_physpeed.c implements functionalities to:
+* - Detect the available PHYs connected to a MAC
+* - Negotiate speed
+* - Configure speed
+* - Configure the SLCR registers for the negotiated speed
+* In a typical use case, users of the APIs implemented in this file need to
+* do the following.
+* - Call the API detect_phy. It probes for the available PHYs connected to a MAC.
+* The MACs can be Emac0 (XPAR_XEMACPS_0_BASEADDR, 0xE000B000) or Emac1
+* (XPAR_XEMACPS_0_BASEADDR, 0xE000C000). It populates an array to notify
+* about the detected PHYs. The array phymapemac0 is used for Emac0 and
+* phymapemac1 is for Emac1.
+* - The users need to parse the corresponding arrays, phymapemac0 or phymapemac1
+* to know the available PHYs for a MAC. The users then need to call
+* phy_setup_emacps to setup the PHYs for proper speed setting. The API
+* phy_setup_emacps should be called with the PHY address for which the speed
+* needs to be negotiated or configured. In a specific use case, if 2 PHYs are
+* connected to Emac0 with addresses of 7 and 11, then users get these address
+* details from phymapemac0 (after calling detect_phy) and then call
+* phy_setup_emacps twice, with ab address of 7 and 11.
+* - Points to note: The MAC can operate at only one speed. If a MAC is connected
+* to multiple PHYs, then all PHYs must negotiate and configured for the same
+* speed.
+* - This file implements static functions to set proper SLCR clocks. As stated
+* above, all PHYs connected to a PHY must operate at same speed and the SLCR
+* clock will be setup accordingly.
+* This file implements the following PHY types.
+* - The standard RGMII.
+* - It provides support for GMII to RGMII converter Xilinx IP. This Xilinx IP
+* sits on the MDIO bus with a predefined PHY address. This IP exposes register
+* that needs to be programmed with the negotiated speed.
+* For example, in a typical design, the Emac0 or Emac1 exposes GMII interface.
+* The user can then use the Xilinx IP that converts GMII to RGMII.
+* The external PHY (most typically Marvell 88E1116R) negotiates for speed
+* with the remote PHY. The implementation in this file then programs the
+* Xilinx IP with this negotiated speed. The Xilinx IP has a predefined IP
+* address exposed through xparameters.h
+* - The SGMII and 1000 BaseX PHY interfaces.
+* If the PHY interface is SGMII or 1000 BaseX a separate "get_IEEE_phy_speed"
+* is used which is different from standard RGMII "get_IEEE_phy_speed".
+* The 1000 BaseX always operates at 1000 Mbps. The SGMII interface can
+* negotiate speed accordingly.
+* For SGMII or 1000 BaseX interfaces, the detect_phy should not be called.
+* The phy addresses for these interfaces are fixed at the design time.
+* Point to note:
+* A MAC can not be connected to PHYs where there is a mix between
+* SGMII or 1000 Basex or GMII/MII/RGMII.
+* In a typical multiple PHY designs, it is expected that the PHYs connected
+* will be RGMII or GMII.
+* The users can choose not to negotiate speed from lwip settings GUI.
+* If they opt to choose a particular PHY speed, then the PHY will hard code
+* the speed to operate only at the corresponding speed. It will not advertise
+* any other speeds. It is users responsibility to ensure that the remote PHY
+* supports the speed programmed through the lwip gui.
+* The following combination of MDIO/PHY are supported:
+* - Multiple PHYs connected to the MDIO bus of a MAC. If Emac0 MDIO is connected
+* to single/multiple PHYs, it is supported. Similarly Emac1 MDIO connected to
+* single/multiple PHYs is supported.
+* - A design where both the interfaces are present and are connected to their own
+* MDIO bus is supported.
+* The following MDIO/PHY setup is not supported:
+* - A design has both the MACs present. MDIO bus is available only for one MAC
+* (Emac0 or Emac1). This MDIO bus has multiple PHYs available for both the
+* MACs. The negotiated speed for PHYs sitting on the MDIO bus of one MAC will
+* not be see for the other MAC and hence the speed/SLCR settings of the other
+* MAC cannot be programmed. Hence this kind of design will not work for
+* this implementation.
+#include "lwipopts.h"
+#include "xparameters_ps.h"
+#include "xparameters.h"
+#if defined (__aarch64__)
+#include "bspconfig.h"
+#include "xil_smc.h"
+#endif
+#define PHY_DETECT_REG 1
+#define PHY_IDENTIFIER_1_REG 2
+#define PHY_IDENTIFIER_2_REG 3
+#define PHY_DETECT_MASK 0x1808
+#define PHY_MARVELL_IDENTIFIER 0x0141
+#define PHY_TI_IDENTIFIER 0x2000
+#define PHY_REALTEK_IDENTIFIER 0x001c
+#define PHY_XILINX_PCS_PMA_ID1 0x0174
+#define PHY_XILINX_PCS_PMA_ID2 0x0C00
+#define XEMACPS_GMII2RGMII_SPEED1000_FD 0x140
+#define XEMACPS_GMII2RGMII_SPEED100_FD 0x2100
+#define XEMACPS_GMII2RGMII_SPEED10_FD 0x100
+#define XEMACPS_GMII2RGMII_REG_NUM 0x10
+#define PHY_REGCR 0x0D
+#define PHY_ADDAR 0x0E
+#define PHY_RGMIIDCTL 0x86
+#define PHY_RGMIICTL 0x32
+#define PHY_STS 0x11
+#define PHY_TI_CR 0x10
+#define PHY_TI_CFG4 0x31
+#define PHY_REGCR_ADDR 0x001F
+#define PHY_REGCR_DATA 0x401F
+#define PHY_TI_CRVAL 0x5048
+#define PHY_TI_CFG4RESVDBIT7 0x80
+/* Frequency setting */
+#define SLCR_LOCK_ADDR (XPS_SYS_CTRL_BASEADDR + 0x4)
+#define SLCR_UNLOCK_ADDR (XPS_SYS_CTRL_BASEADDR + 0x8)
+#define SLCR_GEM0_CLK_CTRL_ADDR (XPS_SYS_CTRL_BASEADDR + 0x140)
+#define SLCR_GEM1_CLK_CTRL_ADDR (XPS_SYS_CTRL_BASEADDR + 0x144)
+#define SLCR_GEM_SRCSEL_EMIO 0x40
+#define SLCR_LOCK_KEY_VALUE 0x767B
+#define SLCR_UNLOCK_KEY_VALUE 0xDF0D
+#define SLCR_ADDR_GEM_RST_CTRL (XPS_SYS_CTRL_BASEADDR + 0x214)
+#define EMACPS_SLCR_DIV_MASK 0xFC0FC0FF
+#else
+#endif
+#define IEEE_CTRL_RESET 0x9140
+#define IEEE_CTRL_ISOLATE_DISABLE 0xFBFF
+#endif
+u32_t phymapemac0[32];
+u32_t phymapemac1[32];
+#if defined (PCM_PMA_CORE_PRESENT) || defined (CONFIG_LINKSPEED_AUTODETECT)
+static u32_t get_IEEE_phy_speed(XEmacPs *xemacpsp, u32_t phy_addr);
+#endif
+static void SetUpSLCRDivisors(UINTPTR mac_baseaddr, s32_t speed);
+#if defined (CONFIG_LINKSPEED1000) || defined (CONFIG_LINKSPEED100) \
+ || defined (CONFIG_LINKSPEED10)
+static u32_t configure_IEEE_phy_speed(XEmacPs *xemacpsp, u32_t phy_addr, u32_t speed);
+#endif
+u32_t phy_setup_emacps (XEmacPs *xemacpsp, u32_t phy_addr)
+ u32_t link_speed;
+ u16_t regval;
+ u16_t phy_id;
+ if(phy_addr == 0) {
+ for (phy_addr = 31; phy_addr > 0; phy_addr--) {
+ XEmacPs_PhyRead(xemacpsp, phy_addr, PHY_IDENTIFIER_1_REG,
+ &phy_id);
+ if (phy_id == PHY_XILINX_PCS_PMA_ID1) {
+ XEmacPs_PhyRead(xemacpsp, phy_addr, PHY_IDENTIFIER_2_REG,
+ &phy_id);
+ if (phy_id == PHY_XILINX_PCS_PMA_ID2) {
+ /* Found a valid PHY address */
+ LWIP_DEBUGF(NETIF_DEBUG, ("XEmacPs detect_phy: PHY detected at address %d.\r\n",
+ phy_addr));
+ break;
+ link_speed = get_IEEE_phy_speed(xemacpsp, phy_addr);
+ if (link_speed == 1000)
+ SetUpSLCRDivisors(xemacpsp->Config.BaseAddress,1000);
+ else if (link_speed == 100)
+ SetUpSLCRDivisors(xemacpsp->Config.BaseAddress,100);
+ else
+ SetUpSLCRDivisors(xemacpsp->Config.BaseAddress,10);
+ xil_printf("link speed for phy address %d: %d\r\n", phy_addr, link_speed);
+ return link_speed;
+ u16_t temp;
+ u16_t control;
+ u16_t status;
+ u16_t partner_capabilities;
+ xil_printf("Start PHY autonegotiation \r\n");
+ XEmacPs_PhyRead(xemacpsp, phy_addr, IEEE_CONTROL_REG_OFFSET, &control);
+ control |= IEEE_CTRL_AUTONEGOTIATE_ENABLE;
+ control |= IEEE_STAT_AUTONEGOTIATE_RESTART;
+ control &= IEEE_CTRL_ISOLATE_DISABLE;
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, IEEE_CONTROL_REG_OFFSET, control);
+ xil_printf("Waiting for PHY to complete autonegotiation.\r\n");
+ XEmacPs_PhyRead(xemacpsp, phy_addr, IEEE_STATUS_REG_OFFSET, &status);
+ while ( !(status & IEEE_STAT_AUTONEGOTIATE_COMPLETE) ) {
+ sleep(1);
+ &status);
+ xil_printf("autonegotiation complete \r\n");
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, IEEE_PAGE_ADDRESS_REGISTER, 1);
+ XEmacPs_PhyRead(xemacpsp, phy_addr, IEEE_PARTNER_ABILITIES_1_REG_OFFSET, &temp);
+ if ((temp & 0x0020) == 0x0020) {
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, IEEE_PAGE_ADDRESS_REGISTER, 0);
+ return 1000;
+ else {
+ xil_printf("Link error, temp = %x\r\n", temp);
+ return 0;
+#elif XPAR_GIGE_PCS_PMA_SGMII_CORE_PRESENT == 1
+ xil_printf("Waiting for Link to be up; Polling for SGMII core Reg \r\n");
+ while(!(temp & 0x8000)) {
+ if((temp & 0x0C00) == 0x0800) {
+ return 1000;
+ else if((temp & 0x0C00) == 0x0400) {
+ return 100;
+ else if((temp & 0x0C00) == 0x0000) {
+ return 10;
+ } else {
+ xil_printf("get_IEEE_phy_speed(): Invalid speed bit value, Defaulting to Speed = 10 Mbps\r\n");
+ XEmacPs_PhyRead(xemacpsp, phy_addr, IEEE_CONTROL_REG_OFFSET, &temp);
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, IEEE_CONTROL_REG_OFFSET, 0x0100);
+ return 10;
+#endif
+#else /*PCM_PMA_CORE_PRESENT not defined, GMII/RGMII case*/
+void detect_phy(XEmacPs *xemacpsp)
+ u16_t phy_reg;
+ u32_t phy_addr;
+ u32_t emacnum;
+ emacnum = 0;
+ else
+ emacnum = 1;
+ XEmacPs_PhyRead(xemacpsp, phy_addr, PHY_DETECT_REG,
+ &phy_reg);
+ if ((phy_reg != 0xFFFF) &&
+ ((phy_reg & PHY_DETECT_MASK) == PHY_DETECT_MASK)) {
+ phy_addr));
+ if (emacnum == 0)
+ phymapemac0[phy_addr] = TRUE;
+ else
+ phymapemac1[phy_addr] = TRUE;
+ &phy_reg);
+ if ((phy_reg != PHY_MARVELL_IDENTIFIER) &&
+ (phy_reg != PHY_TI_IDENTIFIER) &&
+ (phy_reg != PHY_REALTEK_IDENTIFIER)) {
+ xil_printf("WARNING: Not a Marvell or TI or Realtek Ethernet PHY. Please verify the initialization sequence\r\n");
+ u32_t link_speed;
+ u32_t conv_present = 0;
+ u32_t convspeeddupsetting = 0;
+ u32_t convphyaddr = 0;
+#ifdef XPAR_GMII2RGMIICON_0N_ETH0_ADDR
+ convphyaddr = XPAR_GMII2RGMIICON_0N_ETH0_ADDR;
+ conv_present = 1;
+#endif
+#ifdef XPAR_GMII2RGMIICON_0N_ETH1_ADDR
+ convphyaddr = XPAR_GMII2RGMIICON_0N_ETH1_ADDR;
+ conv_present = 1;
+#endif
+#ifdef CONFIG_LINKSPEED_AUTODETECT
+ if (link_speed == 1000) {
+ convspeeddupsetting = XEMACPS_GMII2RGMII_SPEED1000_FD;
+ } else if (link_speed == 100) {
+ convspeeddupsetting = XEMACPS_GMII2RGMII_SPEED100_FD;
+ } else if (link_speed != XST_FAILURE){
+ convspeeddupsetting = XEMACPS_GMII2RGMII_SPEED10_FD;
+ } else {
+ xil_printf("Phy setup error \r\n");
+#elif defined(CONFIG_LINKSPEED1000)
+ link_speed = 1000;
+ configure_IEEE_phy_speed(xemacpsp, phy_addr, link_speed);
+ sleep(1);
+#elif defined(CONFIG_LINKSPEED100)
+ link_speed = 100;
+ sleep(1);
+#elif defined(CONFIG_LINKSPEED10)
+ link_speed = 10;
+ sleep(1);
+#endif
+ if (conv_present) {
+ XEmacPs_PhyWrite(xemacpsp, convphyaddr,
+ XEMACPS_GMII2RGMII_REG_NUM, convspeeddupsetting);
+#if defined CONFIG_LINKSPEED_AUTODETECT
+static u32_t get_TI_phy_speed(XEmacPs *xemacpsp, u32_t phy_addr)
+ u16_t control;
+ u16_t status;
+ u16_t status_speed;
+ u32_t timeout_counter = 0;
+ u32_t phyregtemp;
+ u32_t RetStatus;
+ XEmacPs_PhyRead(xemacpsp, phy_addr, 0x1F, (u16_t *)&phyregtemp);
+ phyregtemp |= 0x4000;
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, 0x1F, phyregtemp);
+ RetStatus = XEmacPs_PhyRead(xemacpsp, phy_addr, 0x1F, (u16_t *)&phyregtemp);
+ if (RetStatus != XST_SUCCESS) {
+ xil_printf("Error during sw reset \n\r");
+ XEmacPs_PhyRead(xemacpsp, phy_addr, 0, (u16_t *)&phyregtemp);
+ phyregtemp |= 0x8000;
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, 0, phyregtemp);
+ * Delay
+ sleep(1);
+ RetStatus = XEmacPs_PhyRead(xemacpsp, phy_addr, 0, (u16_t *)&phyregtemp);
+ xil_printf("Error during reset \n\r");
+ /* FIFO depth */
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, PHY_TI_CR, PHY_TI_CRVAL);
+ RetStatus = XEmacPs_PhyRead(xemacpsp, phy_addr, PHY_TI_CR, (u16_t *)&phyregtemp);
+ xil_printf("Error writing to 0x10 \n\r");
+ /* TX/RX tuning */
+ /* Write to PHY_RGMIIDCTL */
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, PHY_REGCR, PHY_REGCR_ADDR);
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, PHY_ADDAR, PHY_RGMIIDCTL);
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, PHY_REGCR, PHY_REGCR_DATA);
+ RetStatus = XEmacPs_PhyWrite(xemacpsp, phy_addr, PHY_ADDAR, 0xA8);
+ xil_printf("Error in tuning");
+ /* Read PHY_RGMIIDCTL */
+ RetStatus = XEmacPs_PhyRead(xemacpsp, phy_addr, PHY_ADDAR, (u16_t *)&phyregtemp);
+ /* Write PHY_RGMIICTL */
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, PHY_ADDAR, PHY_RGMIICTL);
+ RetStatus = XEmacPs_PhyWrite(xemacpsp, phy_addr, PHY_ADDAR, 0xD3);
+ /* Read PHY_RGMIICTL */
+ /* SW workaround for unstable link when RX_CTRL is not STRAP MODE 3 or 4 */
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, PHY_ADDAR, PHY_TI_CFG4);
+ phyregtemp &= ~(PHY_TI_CFG4RESVDBIT7);
+ RetStatus = XEmacPs_PhyWrite(xemacpsp, phy_addr, PHY_ADDAR, phyregtemp);
+ XEmacPs_PhyRead(xemacpsp, phy_addr, IEEE_AUTONEGO_ADVERTISE_REG, &control);
+ control |= IEEE_ASYMMETRIC_PAUSE_MASK;
+ control |= IEEE_PAUSE_MASK;
+ control |= ADVERTISE_100;
+ control |= ADVERTISE_10;
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, IEEE_AUTONEGO_ADVERTISE_REG, control);
+ XEmacPs_PhyRead(xemacpsp, phy_addr, IEEE_1000_ADVERTISE_REG_OFFSET,
+ &control);
+ control |= ADVERTISE_1000;
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, IEEE_1000_ADVERTISE_REG_OFFSET,
+ control);
+ sleep(1);
+ timeout_counter++;
+ if (timeout_counter == 30) {
+ xil_printf("Auto negotiation error \r\n");
+ XEmacPs_PhyRead(xemacpsp, phy_addr, PHY_STS, &status_speed);
+ if ((status_speed & 0xC000) == 0x8000) {
+ return 1000;
+ } else if ((status_speed & 0xC000) == 0x4000) {
+ return 100;
+ } else {
+ return 10;
+ return XST_SUCCESS;
+static u32_t get_Marvell_phy_speed(XEmacPs *xemacpsp, u32_t phy_addr)
+ u16_t temp;
+ u16_t control;
+ u16_t status;
+ u32_t temp_speed;
+ XEmacPs_PhyWrite(xemacpsp,phy_addr, IEEE_PAGE_ADDRESS_REGISTER, 2);
+ XEmacPs_PhyRead(xemacpsp, phy_addr, IEEE_CONTROL_REG_MAC, &control);
+ control |= IEEE_RGMII_TXRX_CLOCK_DELAYED_MASK;
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, IEEE_CONTROL_REG_MAC, control);
+ &control);
+ control);
+ XEmacPs_PhyRead(xemacpsp, phy_addr, IEEE_COPPER_SPECIFIC_CONTROL_REG,
+ &control);
+ control |= (7 << 12); /* max number of gigabit attempts */
+ control |= (1 << 11); /* enable downshift */
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, IEEE_COPPER_SPECIFIC_CONTROL_REG,
+ control);
+ control |= IEEE_CTRL_RESET_MASK;
+ while (1) {
+ if (control & IEEE_CTRL_RESET_MASK)
+ continue;
+ else
+ break;
+ sleep(1);
+ IEEE_COPPER_SPECIFIC_STATUS_REG_2, &temp);
+ XEmacPs_PhyRead(xemacpsp, phy_addr,IEEE_SPECIFIC_STATUS_REG,
+ &status_speed);
+ if (status_speed & 0x400) {
+ temp_speed = status_speed & IEEE_SPEED_MASK;
+ if (temp_speed == IEEE_SPEED_1000)
+ return 1000;
+ else if(temp_speed == IEEE_SPEED_100)
+ return 100;
+ else
+ return 10;
+static u32_t get_Realtek_phy_speed(XEmacPs *xemacpsp, u32_t phy_addr)
+ u16_t control;
+ u16_t status;
+ u32_t temp_speed;
+ &control);
+ control);
+ while (1) {
+ continue;
+ else
+ break;
+ sleep(1);
+ &status_speed);
+ return 1000;
+ return 100;
+ else
+ return 10;
+ u16_t phy_identity;
+ u32_t RetStatus;
+ &phy_identity);
+ if (phy_identity == PHY_TI_IDENTIFIER) {
+ RetStatus = get_TI_phy_speed(xemacpsp, phy_addr);
+ } else if (phy_identity == PHY_REALTEK_IDENTIFIER) {
+ RetStatus = get_Realtek_phy_speed(xemacpsp, phy_addr);
+ } else {
+ RetStatus = get_Marvell_phy_speed(xemacpsp, phy_addr);
+ return RetStatus;
+#endif
+ u16_t control;
+ u16_t autonereg;
+ XEmacPs_PhyRead(xemacpsp, phy_addr, IEEE_AUTONEGO_ADVERTISE_REG, &autonereg);
+ autonereg |= IEEE_ASYMMETRIC_PAUSE_MASK;
+ autonereg |= IEEE_PAUSE_MASK;
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, IEEE_AUTONEGO_ADVERTISE_REG, autonereg);
+ control &= ~IEEE_CTRL_LINKSPEED_1000M;
+ control &= ~IEEE_CTRL_LINKSPEED_100M;
+ control &= ~IEEE_CTRL_LINKSPEED_10M;
+ if (speed == 1000) {
+ control |= IEEE_CTRL_LINKSPEED_1000M;
+ /* Don't advertise PHY speed of 100 Mbps */
+ autonereg &= (~ADVERTISE_100);
+ /* Don't advertise PHY speed of 10 Mbps */
+ autonereg &= (~ADVERTISE_10);
+ /* Advertise PHY speed of 1000 Mbps */
+ XEmacPs_PhyRead(xemacpsp, phy_addr, IEEE_1000_ADVERTISE_REG_OFFSET, &autonereg);
+ autonereg |= ADVERTISE_1000;
+ XEmacPs_PhyWrite(xemacpsp, phy_addr, IEEE_1000_ADVERTISE_REG_OFFSET, autonereg);
+ else if (speed == 100) {
+ control |= IEEE_CTRL_LINKSPEED_100M;
+ /* Don't advertise PHY speed of 1000 Mbps */
+ autonereg &= (~ADVERTISE_1000);
+ /* Advertise PHY speed of 100 Mbps */
+ autonereg |= ADVERTISE_100;
+ else if (speed == 10) {
+ control |= IEEE_CTRL_LINKSPEED_10M;
+ /* Advertise PHY speed of 10 Mbps */
+ autonereg |= ADVERTISE_10;
+ control | IEEE_CTRL_RESET_MASK);
+ for (wait=0; wait < 100000; wait++);
+ return 0;
+#endif
+#endif /*PCM_PMA_CORE_PRESENT*/
+ volatile UINTPTR slcrBaseAddress;
+ u32_t SlcrDiv0 = 0;
+ u32_t SlcrDiv1 = 0;
+ u32_t SlcrTxClkCntrl;
+ volatile UINTPTR CrlApbBaseAddr;
+ u32_t CrlApbDiv0 = 0;
+ u32_t CrlApbDiv1 = 0;
+ u32_t CrlApbGemCtrl;
+#if defined (__aarch64__) && (EL1_NONSECURE == 1)
+ u32_t ClkId;
+#endif
+ gigeversion = ((Xil_In32(mac_baseaddr + 0xFC)) >> 16) & 0xFFF;
+ Xil_Out32(SLCR_UNLOCK_ADDR, SLCR_UNLOCK_KEY_VALUE);
+ if (mac_baseaddr == ZYNQ_EMACPS_0_BASEADDR) {
+ slcrBaseAddress = SLCR_GEM0_CLK_CTRL_ADDR;
+ } else {
+ slcrBaseAddress = SLCR_GEM1_CLK_CTRL_ADDR;
+ if(Xil_In32(slcrBaseAddress) &
+ SLCR_GEM_SRCSEL_EMIO) {
+ return;
+#ifdef XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV0
+ SlcrDiv0 = XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV0;
+ SlcrDiv1 = XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV1;
+#endif
+ } else {
+#ifdef XPAR_PS7_ETHERNET_1_ENET_SLCR_1000MBPS_DIV0
+ SlcrDiv0 = XPAR_PS7_ETHERNET_1_ENET_SLCR_1000MBPS_DIV0;
+ SlcrDiv1 = XPAR_PS7_ETHERNET_1_ENET_SLCR_1000MBPS_DIV1;
+#endif
+ } else if (speed == 100) {
+#ifdef XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV0
+ SlcrDiv0 = XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV0;
+ SlcrDiv1 = XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV1;
+#endif
+ } else {
+#ifdef XPAR_PS7_ETHERNET_1_ENET_SLCR_100MBPS_DIV0
+ SlcrDiv0 = XPAR_PS7_ETHERNET_1_ENET_SLCR_100MBPS_DIV0;
+ SlcrDiv1 = XPAR_PS7_ETHERNET_1_ENET_SLCR_100MBPS_DIV1;
+#endif
+ } else {
+#ifdef XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV0
+ SlcrDiv0 = XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV0;
+ SlcrDiv1 = XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV1;
+#endif
+ } else {
+#ifdef XPAR_PS7_ETHERNET_1_ENET_SLCR_10MBPS_DIV0
+ SlcrDiv0 = XPAR_PS7_ETHERNET_1_ENET_SLCR_10MBPS_DIV0;
+ SlcrDiv1 = XPAR_PS7_ETHERNET_1_ENET_SLCR_10MBPS_DIV1;
+#endif
+ if (SlcrDiv0 != 0 && SlcrDiv1 != 0) {
+ SlcrTxClkCntrl = Xil_In32(slcrBaseAddress);
+ SlcrTxClkCntrl &= EMACPS_SLCR_DIV_MASK;
+ SlcrTxClkCntrl |= (SlcrDiv1 << 20);
+ SlcrTxClkCntrl |= (SlcrDiv0 << 8);
+ Xil_Out32(slcrBaseAddress, SlcrTxClkCntrl);
+ Xil_Out32(SLCR_LOCK_ADDR, SLCR_LOCK_KEY_VALUE);
+ } else {
+ xil_printf("Clock Divisors incorrect - Please check\r\n");
+ } else if (gigeversion == GEM_VERSION_ZYNQMP) {
+ /* Setup divisors in CRL_APB for Zynq Ultrascale+ MPSoC */
+ if (mac_baseaddr == ZYNQMP_EMACPS_0_BASEADDR) {
+ CrlApbBaseAddr = CRL_APB_GEM0_REF_CTRL;
+ } else if (mac_baseaddr == ZYNQMP_EMACPS_1_BASEADDR) {
+ CrlApbBaseAddr = CRL_APB_GEM1_REF_CTRL;
+ } else if (mac_baseaddr == ZYNQMP_EMACPS_2_BASEADDR) {
+ CrlApbBaseAddr = CRL_APB_GEM2_REF_CTRL;
+ } else if (mac_baseaddr == ZYNQMP_EMACPS_3_BASEADDR) {
+ CrlApbBaseAddr = CRL_APB_GEM3_REF_CTRL;
+#ifdef XPAR_PSU_ETHERNET_0_ENET_SLCR_1000MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_0_ENET_SLCR_1000MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_0_ENET_SLCR_1000MBPS_DIV1;
+#endif
+#ifdef XPAR_PSU_ETHERNET_1_ENET_SLCR_1000MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_1_ENET_SLCR_1000MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_1_ENET_SLCR_1000MBPS_DIV1;
+#endif
+#ifdef XPAR_PSU_ETHERNET_2_ENET_SLCR_1000MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_2_ENET_SLCR_1000MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_2_ENET_SLCR_1000MBPS_DIV1;
+#endif
+#ifdef XPAR_PSU_ETHERNET_3_ENET_SLCR_1000MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_3_ENET_SLCR_1000MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_3_ENET_SLCR_1000MBPS_DIV1;
+#endif
+#ifdef XPAR_PSU_ETHERNET_0_ENET_SLCR_100MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_0_ENET_SLCR_100MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_0_ENET_SLCR_100MBPS_DIV1;
+#endif
+#ifdef XPAR_PSU_ETHERNET_1_ENET_SLCR_100MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_1_ENET_SLCR_100MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_1_ENET_SLCR_100MBPS_DIV1;
+#endif
+#ifdef XPAR_PSU_ETHERNET_2_ENET_SLCR_100MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_2_ENET_SLCR_100MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_2_ENET_SLCR_100MBPS_DIV1;
+#endif
+#ifdef XPAR_PSU_ETHERNET_3_ENET_SLCR_100MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_3_ENET_SLCR_100MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_3_ENET_SLCR_100MBPS_DIV1;
+#endif
+ } else {
+#ifdef XPAR_PSU_ETHERNET_0_ENET_SLCR_10MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_0_ENET_SLCR_10MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_0_ENET_SLCR_10MBPS_DIV1;
+#endif
+#ifdef XPAR_PSU_ETHERNET_1_ENET_SLCR_10MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_1_ENET_SLCR_10MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_1_ENET_SLCR_10MBPS_DIV1;
+#endif
+#ifdef XPAR_PSU_ETHERNET_2_ENET_SLCR_10MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_2_ENET_SLCR_10MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_2_ENET_SLCR_10MBPS_DIV1;
+#endif
+#ifdef XPAR_PSU_ETHERNET_3_ENET_SLCR_10MBPS_DIV0
+ CrlApbDiv0 = XPAR_PSU_ETHERNET_3_ENET_SLCR_10MBPS_DIV0;
+ CrlApbDiv1 = XPAR_PSU_ETHERNET_3_ENET_SLCR_10MBPS_DIV1;
+#endif
+ if (CrlApbDiv0 != 0 && CrlApbDiv1 != 0) {
+ #if defined (__aarch64__) && (EL1_NONSECURE == 1)
+ XSmc_OutVar RegRead;
+ RegRead = Xil_Smc(MMIO_READ_SMC_FID, (u64)(CrlApbBaseAddr),
+ 0, 0, 0, 0, 0, 0);
+ CrlApbGemCtrl = RegRead.Arg0 >> 32;
+ #else
+ CrlApbGemCtrl = Xil_In32(CrlApbBaseAddr);
+ #endif
+ CrlApbGemCtrl &= ~CRL_APB_GEM_DIV0_MASK;
+ CrlApbGemCtrl |= CrlApbDiv0 << CRL_APB_GEM_DIV0_SHIFT;
+ CrlApbGemCtrl &= ~CRL_APB_GEM_DIV1_MASK;
+ CrlApbGemCtrl |= CrlApbDiv1 << CRL_APB_GEM_DIV1_SHIFT;
+ Xil_Smc(MMIO_WRITE_SMC_FID, (u64)(CrlApbBaseAddr) | ((u64)(0xFFFFFFFF) << 32),
+ (u64)CrlApbGemCtrl, 0, 0, 0, 0, 0);
+ do {
+ } while((RegRead.Arg0 >> 32) != CrlApbGemCtrl);
+ #else
+ Xil_Out32(CrlApbBaseAddr, CrlApbGemCtrl);
+ #endif
+ } else {
+ } else if (gigeversion == GEM_VERSION_VERSAL) {
+ /* Setup divisors in CRL for Versal */
+ if (mac_baseaddr == VERSAL_EMACPS_0_BASEADDR) {
+ CrlApbBaseAddr = VERSAL_CRL_GEM0_REF_CTRL;
+ ClkId = CLK_GEM0_REF;
+#endif
+ } else if (mac_baseaddr == VERSAL_EMACPS_1_BASEADDR) {
+ CrlApbBaseAddr = VERSAL_CRL_GEM1_REF_CTRL;
+ ClkId = CLK_GEM1_REF;
+#endif
+#ifdef XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_0_ENET_SLCR_1000MBPS_DIV0
+ CrlApbDiv0 = XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_0_ENET_SLCR_1000MBPS_DIV0;
+#endif
+#ifdef XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_1_ENET_SLCR_1000MBPS_DIV0
+ CrlApbDiv0 = XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_1_ENET_SLCR_1000MBPS_DIV0;
+#endif
+#ifdef XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_0_ENET_SLCR_100MBPS_DIV0
+ CrlApbDiv0 = XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_0_ENET_SLCR_100MBPS_DIV0;
+#endif
+#ifdef XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_1_ENET_SLCR_100MBPS_DIV0
+ CrlApbDiv0 = XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_1_ENET_SLCR_100MBPS_DIV0;
+#endif
+ } else {
+#ifdef XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_0_ENET_SLCR_10MBPS_DIV0
+ CrlApbDiv0 = XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_0_ENET_SLCR_10MBPS_DIV0;
+#endif
+#ifdef XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_1_ENET_SLCR_10MBPS_DIV0
+ CrlApbDiv0 = XPAR_VERSAL_CIPS_0_PSPMC_0_PSV_ETHERNET_1_ENET_SLCR_10MBPS_DIV0;
+#endif
+ if (CrlApbDiv0 != 0) {
+ Xil_Smc(PM_SET_DIVIDER_SMC_FID, (((u64)CrlApbDiv0 << 32) | ClkId), 0, 0, 0, 0, 0, 0);
+#else
+ CrlApbGemCtrl &= ~VERSAL_CRL_GEM_DIV_MASK;
+ CrlApbGemCtrl |= CrlApbDiv0 << VERSAL_CRL_APB_GEM_DIV_SHIFT;
+#endif
+ } else {
+ return;
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xpqueue.c b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xpqueue.c
index 0000000..b5a773e
--- /dev/null
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xpqueue.c
@@ -0,0 +1,93 @@
+ * Copyright (C) 2007 - 2019 Xilinx, Inc.
+ * OF SUCH DAMAGE.
+#include <stdlib.h>
+#include "netif/xpqueue.h"
+#include "xil_printf.h"
+#define NUM_QUEUES 2
+pq_queue_t pq_queue[NUM_QUEUES];
+pq_queue_t *
+pq_create_queue()
+ static int i;
+ pq_queue_t *q = NULL;
+ if (i >= NUM_QUEUES) {
+ xil_printf("ERR: Max Queues allocated\n\r");
+ return q;
+ q = &pq_queue[i++];
+ if (!q)
+ return q;
+ q->head = q->tail = q->len = 0;
+ return q;
+int
+pq_enqueue(pq_queue_t *q, void *p)
+ if (q->len == PQ_QUEUE_SIZE)
+ return -1;
+ q->data[q->head] = p;
+ q->head = (q->head + 1)%PQ_QUEUE_SIZE;
+ q->len++;
+ return 0;
+void*
+pq_dequeue(pq_queue_t *q)
+ int ptail;
+ if (q->len == 0)
+ return NULL;
+ ptail = q->tail;
+ q->tail = (q->tail + 1)%PQ_QUEUE_SIZE;
+ q->len--;
+ return q->data[ptail];
+int
+pq_qlength(pq_queue_t *q)
+ return q->len;
diff --git a/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.c b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.c
index 0000000..88a35cb
--- /dev/null
+++ b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.c
@@ -0,0 +1,487 @@
+* Copyright (C) 2010 - 2020 Xilinx, Inc. All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xemacps.c
+* @addtogroup emacps_v3_16
+* The XEmacPs driver. Functions in this file are the minimum required functions
+* for this driver. See xemacps.h for a detailed description of the driver.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver Who Date Changes
+* 1.00a wsy 01/10/10 First release
+* 2.1 srt 07/15/14 Add support for Zynq Ultrascale Mp GEM specification and
+* 64-bit changes.
+* 3.00 kvn 02/13/15 Modified code for MISRA-C:2012 compliance.
+* 3.0 hk 02/20/15 Added support for jumbo frames. Increase AHB burst.
+* Disable extended mode. Perform all 64 bit changes under
+* check for arch64.
+* 3.1 hk 08/10/15 Update upper 32 bit tx and rx queue ptr registers
+* 3.5 hk 08/14/17 Update cache coherency information of the interface in
+* its config structure.
+* 3.8 hk 09/17/18 Cleanup stale comments.
+* 3.8 mus 11/05/18 Support 64 bit DMA addresses for Microblaze-X platform.
+* 3.10 hk 05/16/19 Clear status registers properly in reset
+* 3.11 sd 02/14/20 Add clock support
+* </pre>
+/***************************** Include Files *********************************/
+#include "xemacps.h"
+/************************** Constant Definitions *****************************/
+/**************************** Type Definitions *******************************/
+/***************** Macros (Inline Functions) Definitions *********************/
+/************************** Function Prototypes ******************************/
+void XEmacPs_StubHandler(void); /* Default handler routine */
+/************************** Variable Definitions *****************************/
+* Initialize a specific XEmacPs instance/driver. The initialization entails:
+* - Initialize fields of the XEmacPs instance structure
+* - Reset hardware and apply default options
+* - Configure the DMA channels
+* The PHY is setup independently from the device. Use the MII or whatever other
+* interface may be present for setup.
+* @param InstancePtr is a pointer to the instance to be worked on.
+* @param CfgPtr is the device configuration structure containing required
+* hardware build data.
+* @param EffectiveAddress is the base address of the device. If address
+* translation is not utilized, this parameter can be passed in using
+* CfgPtr->Config.BaseAddress to specify the physical base address.
+* @return
+* - XST_SUCCESS if initialization was successful
+LONG XEmacPs_CfgInitialize(XEmacPs *InstancePtr, XEmacPs_Config * CfgPtr,
+ UINTPTR EffectiveAddress)
+ /* Verify arguments */
+ Xil_AssertNonvoid(InstancePtr != NULL);
+ Xil_AssertNonvoid(CfgPtr != NULL);
+ /* Set device base address and ID */
+ InstancePtr->Config.DeviceId = CfgPtr->DeviceId;
+ InstancePtr->Config.BaseAddress = EffectiveAddress;
+ InstancePtr->Config.IsCacheCoherent = CfgPtr->IsCacheCoherent;
+#if defined (XCLOCKING)
+ InstancePtr->Config.RefClk = CfgPtr->RefClk;
+#endif
+ InstancePtr->Config.S1GDiv0 = CfgPtr->S1GDiv0;
+ InstancePtr->Config.S1GDiv1 = CfgPtr->S1GDiv1;
+ InstancePtr->Config.S100MDiv0 = CfgPtr->S100MDiv0;
+ InstancePtr->Config.S100MDiv1 = CfgPtr->S100MDiv1;
+ InstancePtr->Config.S10MDiv0 = CfgPtr->S10MDiv0;
+ InstancePtr->Config.S10MDiv1 = CfgPtr->S10MDiv1;
+ /* Set callbacks to an initial stub routine */
+ InstancePtr->SendHandler = ((XEmacPs_Handler)((void*)XEmacPs_StubHandler));
+ InstancePtr->RecvHandler = ((XEmacPs_Handler)(void*)XEmacPs_StubHandler);
+ InstancePtr->ErrorHandler = ((XEmacPs_ErrHandler)(void*)XEmacPs_StubHandler);
+ /* Reset the hardware and set default options */
+ InstancePtr->IsReady = XIL_COMPONENT_IS_READY;
+ XEmacPs_Reset(InstancePtr);
+ return (LONG)(XST_SUCCESS);
+* Start the Ethernet controller as follows:
+* - Enable transmitter if XTE_TRANSMIT_ENABLE_OPTION is set
+* - Enable receiver if XTE_RECEIVER_ENABLE_OPTION is set
+* - Start the SG DMA send and receive channels and enable the device
+* interrupt
+* @return N/A
+* @note
+* Hardware is configured with scatter-gather DMA, the driver expects to start
+* the scatter-gather channels and expects that the user has previously set up
+* the buffer descriptor lists.
+* This function makes use of internal resources that are shared between the
+* Start, Stop, and Set/ClearOptions functions. So if one task might be setting
+* device options while another is trying to start the device, the user is
+* required to provide protection of this shared data (typically using a
+* semaphore).
+* This function must not be preempted by an interrupt that may service the
+* device.
+void XEmacPs_Start(XEmacPs *InstancePtr)
+ u32 Reg;
+ /* Assert bad arguments and conditions */
+ Xil_AssertVoid(InstancePtr != NULL);
+ Xil_AssertVoid(InstancePtr->IsReady == (u32)XIL_COMPONENT_IS_READY);
+ if (InstancePtr->IsStarted != (u32)XIL_COMPONENT_IS_STARTED) {
+ Xil_ClockEnable(InstancePtr->Config.RefClk);
+#endif
+ /* Start DMA */
+ /* When starting the DMA channels, both transmit and receive sides
+ * need an initialized BD list.
+ if (InstancePtr->Version == 2) {
+ Xil_AssertVoid(InstancePtr->RxBdRing.BaseBdAddr != 0);
+ Xil_AssertVoid(InstancePtr->TxBdRing.BaseBdAddr != 0);
+ XEmacPs_WriteReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_RXQBASE_OFFSET,
+ InstancePtr->RxBdRing.BaseBdAddr);
+ XEMACPS_TXQBASE_OFFSET,
+ InstancePtr->TxBdRing.BaseBdAddr);
+ /* clear any existed int status */
+ XEmacPs_WriteReg(InstancePtr->Config.BaseAddress, XEMACPS_ISR_OFFSET,
+ XEMACPS_IXR_ALL_MASK);
+ /* Enable transmitter if not already enabled */
+ if ((InstancePtr->Options & (u32)XEMACPS_TRANSMITTER_ENABLE_OPTION)!=0x00000000U) {
+ Reg = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_NWCTRL_OFFSET);
+ if ((!(Reg & XEMACPS_NWCTRL_TXEN_MASK))==TRUE) {
+ Reg | (u32)XEMACPS_NWCTRL_TXEN_MASK);
+ /* Enable receiver if not already enabled */
+ if ((InstancePtr->Options & XEMACPS_RECEIVER_ENABLE_OPTION) != 0x00000000U) {
+ if ((!(Reg & XEMACPS_NWCTRL_RXEN_MASK))==TRUE) {
+ Reg | (u32)XEMACPS_NWCTRL_RXEN_MASK);
+ /* Enable TX and RX interrupts */
+ XEmacPs_IntEnable(InstancePtr, (XEMACPS_IXR_TX_ERR_MASK |
+ XEMACPS_IXR_RX_ERR_MASK | (u32)XEMACPS_IXR_FRAMERX_MASK |
+ (u32)XEMACPS_IXR_TXCOMPL_MASK));
+ /* Enable TX Q1 Interrupts */
+ if (InstancePtr->Version > 2)
+ XEmacPs_IntQ1Enable(InstancePtr, XEMACPS_INTQ1_IXR_ALL_MASK);
+ /* Mark as started */
+ InstancePtr->IsStarted = XIL_COMPONENT_IS_STARTED;
+ return;
+* Gracefully stop the Ethernet MAC as follows:
+* - Disable all interrupts from this device
+* - Stop DMA channels
+* - Disable the tansmitter and receiver
+* Device options currently in effect are not changed.
+* This function will disable all interrupts. Default interrupts settings that
+* had been enabled will be restored when XEmacPs_Start() is called.
+* @note
+* Start, Stop, SetOptions, and ClearOptions functions. So if one task might be
+* setting device options while another is trying to start the device, the user
+* is required to provide protection of this shared data (typically using a
+* semaphore).
+* Stopping the DMA channels causes this function to block until the DMA
+* operation is complete.
+void XEmacPs_Stop(XEmacPs *InstancePtr)
+ u32 Reg;
+ /* Disable all interrupts */
+ XEmacPs_WriteReg(InstancePtr->Config.BaseAddress, XEMACPS_IDR_OFFSET,
+ /* Disable the receiver & transmitter */
+ Reg &= (u32)(~XEMACPS_NWCTRL_RXEN_MASK);
+ Reg &= (u32)(~XEMACPS_NWCTRL_TXEN_MASK);
+ /* Mark as stopped */
+ InstancePtr->IsStarted = 0U;
+ Xil_ClockDisable(InstancePtr->Config.RefClk);
+#endif
+* Perform a graceful reset of the Ethernet MAC. Resets the DMA channels, the
+* transmitter, and the receiver.
+* Steps to reset
+* - Stops transmit and receive channels
+* - Stops DMA
+* - Configure transmit and receive buffer size to default
+* - Clear transmit and receive status register and counters
+* - Clear all interrupt sources
+* - Clear phy (if there is any previously detected) address
+* - Clear MAC addresses (1-4) as well as Type IDs and hash value
+* All options are placed in their default state. Any frames in the
+* descriptor lists will remain in the lists. The side effect of doing
+* this is that after a reset and following a restart of the device, frames
+* were in the list before the reset may be transmitted or received.
+* The upper layer software is responsible for re-configuring (if necessary)
+* and restarting the MAC after the reset. Note also that driver statistics
+* are not cleared on reset. It is up to the upper layer software to clear the
+* statistics if needed.
+* When a reset is required, the driver notifies the upper layer software of
+* this need through the ErrorHandler callback and specific status codes.
+* The upper layer software is responsible for calling this Reset function
+* and then re-configuring the device.
+void XEmacPs_Reset(XEmacPs *InstancePtr)
+ u32 Reg;
+ u8 i;
+ s8 EmacPs_zero_MAC[6] = { 0x0, 0x0, 0x0, 0x0, 0x0, 0x0 };
+ /* Stop the device and reset hardware */
+ XEmacPs_Stop(InstancePtr);
+ InstancePtr->Options = XEMACPS_DEFAULT_OPTIONS;
+ InstancePtr->Version = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress, 0xFC);
+ InstancePtr->Version = (InstancePtr->Version >> 16) & 0xFFF;
+ InstancePtr->MaxMtuSize = XEMACPS_MTU;
+ InstancePtr->MaxFrameSize = XEMACPS_MTU + XEMACPS_HDR_SIZE +
+ XEMACPS_TRL_SIZE;
+ InstancePtr->MaxVlanFrameSize = InstancePtr->MaxFrameSize +
+ XEMACPS_HDR_VLAN_SIZE;
+ InstancePtr->RxBufMask = XEMACPS_RXBUF_LEN_MASK;
+ /* Setup hardware with default values */
+ (XEMACPS_NWCTRL_STATCLR_MASK |
+ XEMACPS_NWCTRL_MDEN_MASK) &
+ (u32)(~XEMACPS_NWCTRL_LOOPEN_MASK));
+ XEMACPS_NWCFG_OFFSET);
+ Reg &= XEMACPS_NWCFG_MDCCLKDIV_MASK;
+ Reg = Reg | (u32)XEMACPS_NWCFG_100_MASK |
+ (u32)XEMACPS_NWCFG_FDEN_MASK |
+ (u32)XEMACPS_NWCFG_UCASTHASHEN_MASK;
+ XEMACPS_NWCFG_OFFSET, Reg);
+ if (InstancePtr->Version > 2) {
+ XEmacPs_WriteReg(InstancePtr->Config.BaseAddress, XEMACPS_NWCFG_OFFSET,
+ (XEmacPs_ReadReg(InstancePtr->Config.BaseAddress, XEMACPS_NWCFG_OFFSET) |
+ XEMACPS_NWCFG_DWIDTH_64_MASK));
+ XEMACPS_DMACR_OFFSET,
+ (((((u32)XEMACPS_RX_BUF_SIZE / (u32)XEMACPS_RX_BUF_UNIT) +
+ (((((u32)XEMACPS_RX_BUF_SIZE %
+ (u32)XEMACPS_RX_BUF_UNIT))!=(u32)0) ? 1U : 0U)) <<
+ (u32)(XEMACPS_DMACR_RXBUF_SHIFT)) &
+ (u32)(XEMACPS_DMACR_RXBUF_MASK)) |
+ (u32)XEMACPS_DMACR_RXSIZE_MASK |
+ (u32)XEMACPS_DMACR_TXSIZE_MASK);
+ XEmacPs_WriteReg(InstancePtr->Config.BaseAddress, XEMACPS_DMACR_OFFSET,
+ (XEmacPs_ReadReg(InstancePtr->Config.BaseAddress, XEMACPS_DMACR_OFFSET) |
+#if defined(__aarch64__) || defined(__arch64__)
+ (u32)XEMACPS_DMACR_ADDR_WIDTH_64 |
+#endif
+ (u32)XEMACPS_DMACR_INCR16_AHB_BURST));
+ XEMACPS_TXSR_OFFSET, XEMACPS_SR_ALL_MASK);
+ XEmacPs_SetQueuePtr(InstancePtr, 0, 0x00U, (u16)XEMACPS_SEND);
+ XEmacPs_SetQueuePtr(InstancePtr, 0, 0x01U, (u16)XEMACPS_SEND);
+ XEmacPs_SetQueuePtr(InstancePtr, 0, 0x00U, (u16)XEMACPS_RECV);
+ XEMACPS_RXSR_OFFSET, XEMACPS_SR_ALL_MASK);
+ XEMACPS_ISR_OFFSET);
+ Reg);
+ XEmacPs_ClearHash(InstancePtr);
+ for (i = 1U; i < 5U; i++) {
+ (void)XEmacPs_SetMacAddress(InstancePtr, EmacPs_zero_MAC, i);
+ (void)XEmacPs_SetTypeIdCheck(InstancePtr, 0x00000000U, i);
+ /* clear all counters */
+ for (i = 0U; i < (u8)((XEMACPS_LAST_OFFSET - XEMACPS_OCTTXL_OFFSET) / 4U);
+ i++) {
+ (void)XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_OCTTXL_OFFSET + (u32)(((u32)i) * ((u32)4)));
+ /* Disable the receiver */
+ /* Sync default options with hardware but leave receiver and
+ * transmitter disabled. They get enabled with XEmacPs_Start() if
+ * XEMACPS_TRANSMITTER_ENABLE_OPTION and
+ * XEMACPS_RECEIVER_ENABLE_OPTION are set.
+ (void)XEmacPs_SetOptions(InstancePtr, InstancePtr->Options &
+ ~((u32)XEMACPS_TRANSMITTER_ENABLE_OPTION |
+ (u32)XEMACPS_RECEIVER_ENABLE_OPTION));
+ (void)XEmacPs_ClearOptions(InstancePtr, ~InstancePtr->Options);
+ * This is a stub for the asynchronous callbacks. The stub is here in case the
+ * upper layer forgot to set the handler(s). On initialization, all handlers are
+ * set to this callback. It is considered an error for this handler to be
+ * invoked.
+ Xil_AssertVoidAlways();
+* This function sets the start address of the transmit/receive buffer queue.
+* @param QPtr is the address of the Queue to be written
+* @param QueueNum is the Buffer Queue Index
+* @param Direction indicates Transmit/Receive
+* @note
+* The buffer queue addresses has to be set before starting the transfer, so
+* this function has to be called in prior to XEmacPs_Start()
+void XEmacPs_SetQueuePtr(XEmacPs *InstancePtr, UINTPTR QPtr, u8 QueueNum,
+ u16 Direction)
+ /* If already started, then there is nothing to do */
+ if (InstancePtr->IsStarted == (u32)XIL_COMPONENT_IS_STARTED) {
+ return;
+ if (QueueNum == 0x00U) {
+ if (Direction == XEMACPS_SEND) {
+ (QPtr & ULONG64_LO_MASK));
+ } else {
+ else {
+ XEMACPS_TXQ1BASE_OFFSET,
+#ifdef __aarch64__
+ /* Set the MSB of TX Queue start address */
+ XEMACPS_MSBBUF_TXQBASE_OFFSET,
+ (u32)((QPtr & ULONG64_HI_MASK) >> 32U));
+ } else {
+ /* Set the MSB of RX Queue start address */
+ XEMACPS_MSBBUF_RXQBASE_OFFSET,
+#endif
diff --git a/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.h b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.h
index 0000000..ac3e7a7
--- /dev/null
+++ b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.h
@@ -0,0 +1,843 @@
+ * @file xemacps.h
+* @details
+ * The Xilinx Embedded Processor Block Ethernet driver.
+ * For a full description of XEMACPS features, please see the hardware spec.
+ * This driver supports the following features:
+ * - Memory mapped access to host interface registers
+ * - Statistics counter registers for RMON/MIB
+ * - API for interrupt driven frame transfers for hardware configured DMA
+ * - Virtual memory support
+ * - Unicast, broadcast, and multicast receive address filtering
+ * - Full and half duplex operation
+ * - Automatic PAD & FCS insertion and stripping
+ * - Flow control
+ * - Support up to four 48bit addresses
+ * - Address checking for four specific 48bit addresses
+ * - VLAN frame support
+ * - Pause frame support
+ * - Large frame support up to 1536 bytes
+ * - Checksum offload
+ * <b>Driver Description</b>
+ * The device driver enables higher layer software (e.g., an application) to
+ * communicate to the XEmacPs. The driver handles transmission and reception
+ * of Ethernet frames, as well as configuration and control. No pre or post
+ * processing of frame data is performed. The driver does not validate the
+ * contents of an incoming frame in addition to what has already occurred in
+ * hardware.
+ * A single device driver can support multiple devices even when those devices
+ * have significantly different configurations.
+ * <b>Initialization & Configuration</b>
+ * The XEmacPs_Config structure is used by the driver to configure itself.
+ * This configuration structure is typically created by the tool-chain based
+ * on hardware build properties.
+ * The driver instance can be initialized in
+ * - XEmacPs_CfgInitialize(InstancePtr, CfgPtr, EffectiveAddress): Uses a
+ * configuration structure provided by the caller. If running in a system
+ * with address translation, the provided virtual memory base address
+ * replaces the physical address present in the configuration structure.
+ * The device supports DMA only as current development plan. No FIFO mode is
+ * supported. The driver expects to start the DMA channels and expects that
+ * the user has set up the buffer descriptor lists.
+ * <b>Interrupts and Asynchronous Callbacks</b>
+ * The driver has no dependencies on the interrupt controller. When an
+ * interrupt occurs, the handler will perform a small amount of
+ * housekeeping work, determine the source of the interrupt, and call the
+ * appropriate callback function. All callbacks are registered by the user
+ * level application.
+ * <b>Virtual Memory</b>
+ * All virtual to physical memory mappings must occur prior to accessing the
+ * driver API.
+ * For DMA transactions, user buffers supplied to the driver must be in terms
+ * of their physical address.
+ * <b>DMA</b>
+ * The DMA engine uses buffer descriptors (BDs) to describe Ethernet frames.
+ * These BDs are typically chained together into a list the hardware follows
+ * when transferring data in and out of the packet buffers. Each BD describes
+ * a memory region containing either a full or partial Ethernet packet.
+ * Interrupt coalescing is not supported from this built-in DMA engine.
+ * This API requires the user to understand how the DMA operates. The
+ * following paragraphs provide some explanation, but the user is encouraged
+ * to read documentation in xemacps_bdring.h as well as study example code
+ * that accompanies this driver.
+ * The API is designed to get BDs to and from the DMA engine in the most
+ * efficient means possible. The first step is to establish a memory region
+ * to contain all BDs for a specific channel. This is done with
+ * XEmacPs_BdRingCreate(). This function sets up a BD ring that hardware will
+ * follow as BDs are processed. The ring will consist of a user defined number
+ * of BDs which will all be partially initialized. For example on the transmit
+ * channel, the driver will initialize all BDs' so that they are configured
+ * for transmit. The more fields that can be permanently setup at
+ * initialization, then the fewer accesses will be needed to each BD while
+ * the DMA engine is in operation resulting in better throughput and CPU
+ * utilization. The best case initialization would require the user to set
+ * only a frame buffer address and length prior to submitting the BD to the
+ * engine.
+ * BDs move through the engine with the help of functions
+ * XEmacPs_BdRingAlloc(), XEmacPs_BdRingToHw(), XEmacPs_BdRingFromHw(),
+ * and XEmacPs_BdRingFree().
+ * All these functions handle BDs that are in place. That is, there are no
+ * copies of BDs kept anywhere and any BD the user interacts with is an actual
+ * BD from the same ring hardware accesses.
+ * BDs in the ring go through a series of states as follows:
+ * 1. Idle. The driver controls BDs in this state.
+ * 2. The user has data to transfer. XEmacPs_BdRingAlloc() is called to
+ * reserve BD(s). Once allocated, the user may setup the BD(s) with
+ * frame buffer address, length, and other attributes. The user controls
+ * BDs in this state.
+ * 3. The user submits BDs to the DMA engine with XEmacPs_BdRingToHw. BDs
+ * in this state are either waiting to be processed by hardware, are in
+ * process, or have been processed. The DMA engine controls BDs in this
+ * state.
+ * 4. Processed BDs are retrieved with XEmacEpv_BdRingFromHw() by the
+ * user. Once retrieved, the user can examine each BD for the outcome of
+ * the DMA transfer. The user controls BDs in this state. After examining
+ * the BDs the user calls XEmacPs_BdRingFree() which places the BDs back
+ * into state 1.
+ * Each of the four BD accessor functions operate on a set of BDs. A set is
+ * defined as a segment of the BD ring consisting of one or more BDs. The user
+ * views the set as a pointer to the first BD along with the number of BDs for
+ * that set. The set can be navigated by using macros XEmacPs_BdNext(). The
+ * user must exercise extreme caution when changing BDs in a set as there is
+ * nothing to prevent doing a mBdNext past the end of the set and modifying a
+ * BD out of bounds.
+ * XEmacPs_BdRingAlloc() + XEmacPs_BdRingToHw(), as well as
+ * XEmacPs_BdRingFromHw() + XEmacPs_BdRingFree() are designed to be used in
+ * tandem. The same BD set retrieved with BdRingAlloc should be the same one
+ * provided to hardware with BdRingToHw. Same goes with BdRingFromHw and
+ * BdRIngFree.
+ * <b>Alignment & Data Cache Restrictions</b>
+ * Due to the design of the hardware, all RX buffers, BDs need to be 4-byte
+ * aligned. Please reference xemacps_bd.h for cache related macros.
+ * DMA Tx:
+ * - If frame buffers exist in cached memory, then they must be flushed
+ * prior to committing them to hardware.
+ * DMA Rx:
+ * - If frame buffers exist in cached memory, then the cache must be
+ * invalidated for the memory region containing the frame prior to data
+ * access
+ * Both cache invalidate/flush are taken care of in driver code.
+ * <b>Buffer Copying</b>
+ * The driver is designed for a zero-copy buffer scheme. That is, the driver
+ * will not copy buffers. This avoids potential throughput bottlenecks within
+ * the driver. If byte copying is required, then the transfer will take longer
+ * to complete.
+ * <b>Checksum Offloading</b>
+ * The Embedded Processor Block Ethernet can be configured to perform IP, TCP
+ * and UDP checksum offloading in both receive and transmit directions.
+ * IP packets contain a 16-bit checksum field, which is the 16-bit 1s
+ * complement of the 1s complement sum of all 16-bit words in the header.
+ * TCP and UDP packets contain a 16-bit checksum field, which is the 16-bit
+ * 1s complement of the 1s complement sum of all 16-bit words in the header,
+ * the data and a conceptual pseudo header.
+ * To calculate these checksums in software requires each byte of the packet
+ * to be read. For TCP and UDP this can use a large amount of processing power.
+ * Offloading the checksum calculation to hardware can result in significant
+ * performance improvements.
+ * The transmit checksum offload is only available to use DMA in packet buffer
+ * mode. This is because the complete frame to be transmitted must be read
+ * into the packet buffer memory before the checksum can be calculated and
+ * written to the header at the beginning of the frame.
+ * For IP, TCP or UDP receive checksum offload to be useful, the operating
+ * system containing the protocol stack must be aware that this offload is
+ * available so that it can make use of the fact that the hardware has verified
+ * the checksum.
+ * When receive checksum offloading is enabled in the hardware, the IP header
+ * checksum is checked, where the packet meets the following criteria:
+ * 1. If present, the VLAN header must be four octets long and the CFI bit
+ * must not be set.
+ * 2. Encapsulation must be RFC 894 Ethernet Type Encoding or RFC 1042 SNAP
+ * encoding.
+ * 3. IP v4 packet.
+ * 4. IP header is of a valid length.
+ * 5. Good IP header checksum.
+ * 6. No IP fragmentation.
+ * 7. TCP or UDP packet.
+ * When an IP, TCP or UDP frame is received, the receive buffer descriptor
+ * gives an indication if the hardware was able to verify the checksums.
+ * There is also an indication if the frame had SNAP encapsulation. These
+ * indication bits will replace the type ID match indication bits when the
+ * receive checksum offload is enabled.
+ * If any of the checksums are verified incorrect by the hardware, the packet
+ * is discarded and the appropriate statistics counter incremented.
+ * <b>PHY Interfaces</b>
+ * RGMII 1.3 is the only interface supported.
+ * <b>Asserts</b>
+ * Asserts are used within all Xilinx drivers to enforce constraints on
+ * parameters. Asserts can be turned off on a system-wide basis by defining,
+ * at compile time, the NDEBUG identifier. By default, asserts are turned on
+ * and it is recommended that users leave asserts on during development. For
+ * deployment use -DNDEBUG compiler switch to remove assert code.
+ * @note
+ * Xilinx drivers are typically composed of two parts, one is the driver
+ * and the other is the adapter. The driver is independent of OS and processor
+ * and is intended to be highly portable. The adapter is OS-specific and
+ * facilitates communication between the driver and an OS.
+ * This driver is intended to be RTOS and processor independent. Any needs for
+ * dynamic memory management, threads or thread mutual exclusion, or cache
+ * control must be satisfied bythe layer above this driver.
+ * <pre>
+ * MODIFICATION HISTORY:
+ * Ver Who Date Changes
+ * 1.00a wsy 01/10/10 First release
+ * 1.00a asa 11/21/11 The function XEmacPs_BdRingFromHwTx in file
+ * xemacps_bdring.c is modified. Earlier it was checking for
+ * "BdLimit"(passed argument) number of BDs for finding out
+ * which BDs are successfully processed. Now one more check
+ * is added. It looks for BDs till the current BD pointer
+ * reaches HwTail. By doing this processing time is saved.
+ * 1.00a asa 01/24/12 The function XEmacPs_BdRingFromHwTx in file
+ * xemacps_bdring.c is modified. Now start of packet is
+ * searched for returning the number of BDs processed.
+ * 1.02a asa 11/05/12 Added a new API for deleting an entry from the HASH
+ * registers. Added a new API to set the bust length.
+ * Added some new hash-defines.
+ * 1.03a asa 01/23/12 Fix for CR #692702 which updates error handling for
+ * Rx errors. Under heavy Rx traffic, there will be a large
+ * number of errors related to receive buffer not available.
+ * Because of a HW bug (SI #692601), under such heavy errors,
+ * the Rx data path can become unresponsive. To reduce the
+ * probabilities for hitting this HW bug, the SW writes to
+ * bit 18 to flush a packet from Rx DPRAM immediately. The
+ * changes for it are done in the function
+ * XEmacPs_IntrHandler.
+ * 1.05a asa 09/23/13 Cache operations on BDs are not required and hence
+ * removed. It is expected that all BDs are allocated in
+ * from uncached area.
+ * 1.06a asa 11/02/13 Changed the value for XEMACPS_RXBUF_LEN_MASK from 0x3fff
+ * to 0x1fff. This fixes the CR#744902.
+ * Made changes in example file xemacps_example.h to fix compilation
+ * issues with iarcc compiler.
+ * 2.0 adk 10/12/13 Updated as per the New Tcl API's
+ * 2.1 adk 11/08/14 Fixed the CR#811288. Changes are made in the driver tcl file.
+ * 2.1 bss 09/08/14 Modified driver tcl to fix CR#820349 to export phy
+ * address in xparameters.h when GMII to RGMII converter
+ * is present in hw.
+ * 2.1 srt 07/15/14 Add support for Zynq Ultrascale Mp GEM specification and 64-bit
+ * changes.
+ * 2.2 adk 29/10/14 Fixed CR#827686 when PCS/PMA core is configured with
+ * 1000BASE-X mode export proper values to the xparameters.h
+ * file. Changes are made in the driver tcl file.
+ * 3.0 adk 08/1/15 Don't include gem in peripheral test when gem is
+ * configured with PCS/PMA Core. Changes are made in the
+ * test app tcl(CR:827686).
+ * 3.0 kvn 02/13/15 Modified code for MISRA-C:2012 compliance.
+ * 3.0 hk 03/18/15 Added support for jumbo frames. Increase AHB burst.
+ * Disable extended mode. Perform all 64 bit changes under
+ * check for arch64.
+ * Remove "used bit set" from TX error interrupt masks.
+ * 3.1 hk 07/27/15 Do not call error handler with '0' error code when
+ * there is no error. CR# 869403
+ * 08/10/15 Update upper 32 bit tx and rx queue ptr registers.
+ * 3.2 hk 02/22/16 Added SGMII support for Zynq Ultrascale+ MPSoC.
+ * 3.4 ms 01/23/17 Modified xil_printf statement in main function for all
+ * examples to ensure that "Successfully ran" and "Failed"
+ * strings are available in all examples. This is a fix
+ * for CR-965028.
+ * ms 03/17/17 Modified text file in examples folder for doxygen
+ * generation.
+ * ms 04/05/17 Added tabspace for return statements in functions of
+ * xemacps_ieee1588_example.c for proper documentation
+ * while generating doxygen.
+ * 3.5 hk 08/14/17 Update cache coherency information of the interface in
+ * its config structure.
+ * 3.6 rb 09/08/17 HwCnt variable (in XEmacPs_BdRing structure) is
+ * changed to volatile.
+ * Add API XEmacPs_BdRingPtrReset() to reset pointers
+ * 3.8 hk 07/19/18 Fixed CPP, GCC and doxygen warnings - CR-1006327
+ * hk 09/17/18 Fix PTP interrupt masks and cleanup comments.
+ * 3.9 hk 01/23/19 Add RX watermark support
+ * 3.11 sd 02/14/20 Add clock support
+ * 3.13 nsk 12/14/20 Updated the tcl to not to use the instance names.
+ * </pre>
+#ifndef XEMACPS_H /* prevent circular inclusions */
+#define XEMACPS_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+/***************************** Include Files ********************************/
+#include "xil_types.h"
+#include "xil_assert.h"
+#include "xstatus.h"
+#include "xemacps_hw.h"
+#include "xemacps_bd.h"
+#include "xemacps_bdring.h"
+#include "xil_clocking.h"
+#endif
+/************************** Constant Definitions ****************************/
+ * Device information
+#define XEMACPS_DEVICE_NAME "xemacps"
+#define XEMACPS_DEVICE_DESC "Xilinx PS 10/100/1000 MAC"
+/** @name Configuration options
+ * Device configuration options. See the XEmacPs_SetOptions(),
+ * XEmacPs_ClearOptions() and XEmacPs_GetOptions() for information on how to
+ * use options.
+ * The default state of the options are noted and are what the device and
+ * driver will be set to after calling XEmacPs_Reset() or
+ * XEmacPs_Initialize().
+#define XEMACPS_PROMISC_OPTION 0x00000001U
+/**< Accept all incoming packets.
+ * This option defaults to disabled (cleared) */
+#define XEMACPS_FRAME1536_OPTION 0x00000002U
+/**< Frame larger than 1516 support for Tx & Rx.
+#define XEMACPS_VLAN_OPTION 0x00000004U
+/**< VLAN Rx & Tx frame support.
+#define XEMACPS_FLOW_CONTROL_OPTION 0x00000010U
+/**< Enable recognition of flow control frames on Rx
+ * This option defaults to enabled (set) */
+#define XEMACPS_FCS_STRIP_OPTION 0x00000020U
+/**< Strip FCS and PAD from incoming frames. Note: PAD from VLAN frames is not
+ * stripped.
+#define XEMACPS_FCS_INSERT_OPTION 0x00000040U
+/**< Generate FCS field and add PAD automatically for outgoing frames.
+#define XEMACPS_LENTYPE_ERR_OPTION 0x00000080U
+/**< Enable Length/Type error checking for incoming frames. When this option is
+ * set, the MAC will filter frames that have a mismatched type/length field
+ * and if XEMACPS_REPORT_RXERR_OPTION is set, the user is notified when these
+ * types of frames are encountered. When this option is cleared, the MAC will
+ * allow these types of frames to be received.
+#define XEMACPS_TRANSMITTER_ENABLE_OPTION 0x00000100U
+/**< Enable the transmitter.
+#define XEMACPS_RECEIVER_ENABLE_OPTION 0x00000200U
+/**< Enable the receiver
+#define XEMACPS_BROADCAST_OPTION 0x00000400U
+/**< Allow reception of the broadcast address
+#define XEMACPS_MULTICAST_OPTION 0x00000800U
+/**< Allows reception of multicast addresses programmed into hash
+ * This option defaults to disabled (clear) */
+#define XEMACPS_RX_CHKSUM_ENABLE_OPTION 0x00001000U
+/**< Enable the RX checksum offload
+#define XEMACPS_TX_CHKSUM_ENABLE_OPTION 0x00002000U
+/**< Enable the TX checksum offload
+#define XEMACPS_JUMBO_ENABLE_OPTION 0x00004000U
+#define XEMACPS_SGMII_ENABLE_OPTION 0x00008000U
+#define XEMACPS_DEFAULT_OPTIONS \
+ ((u32)XEMACPS_FLOW_CONTROL_OPTION | \
+ (u32)XEMACPS_FCS_INSERT_OPTION | \
+ (u32)XEMACPS_FCS_STRIP_OPTION | \
+ (u32)XEMACPS_BROADCAST_OPTION | \
+ (u32)XEMACPS_LENTYPE_ERR_OPTION | \
+ (u32)XEMACPS_TRANSMITTER_ENABLE_OPTION | \
+ (u32)XEMACPS_RECEIVER_ENABLE_OPTION | \
+ (u32)XEMACPS_RX_CHKSUM_ENABLE_OPTION | \
+ (u32)XEMACPS_TX_CHKSUM_ENABLE_OPTION)
+/**< Default options set when device is initialized or reset */
+/** @name Callback identifiers
+ * These constants are used as parameters to XEmacPs_SetHandler()
+#define XEMACPS_HANDLER_DMASEND 1U
+#define XEMACPS_HANDLER_DMARECV 2U
+#define XEMACPS_HANDLER_ERROR 3U
+/* Constants to determine the configuration of the hardware device. They are
+ * used to allow the driver to verify it can operate with the hardware.
+#define XEMACPS_MDIO_DIV_DFT MDC_DIV_32 /**< Default MDIO clock divisor */
+/* The next few constants help upper layers determine the size of memory
+ * pools used for Ethernet buffers and descriptor lists.
+#define XEMACPS_MAC_ADDR_SIZE 6U /* size of Ethernet header */
+#define XEMACPS_MTU 1500U /* max MTU size of Ethernet frame */
+#define XEMACPS_MTU_JUMBO 10240U /* max MTU size of jumbo frame */
+#define XEMACPS_HDR_SIZE 14U /* size of Ethernet header */
+#define XEMACPS_HDR_VLAN_SIZE 18U /* size of Ethernet header with VLAN */
+#define XEMACPS_TRL_SIZE 4U /* size of Ethernet trailer (FCS) */
+#define XEMACPS_MAX_FRAME_SIZE (XEMACPS_MTU + XEMACPS_HDR_SIZE + \
+ XEMACPS_TRL_SIZE)
+#define XEMACPS_MAX_VLAN_FRAME_SIZE (XEMACPS_MTU + XEMACPS_HDR_SIZE + \
+ XEMACPS_HDR_VLAN_SIZE + XEMACPS_TRL_SIZE)
+#define XEMACPS_MAX_VLAN_FRAME_SIZE_JUMBO (XEMACPS_MTU_JUMBO + XEMACPS_HDR_SIZE + \
+/* DMACR Bust length hash defines */
+#define XEMACPS_SINGLE_BURST 0x00000001
+#define XEMACPS_4BYTE_BURST 0x00000004
+#define XEMACPS_8BYTE_BURST 0x00000008
+#define XEMACPS_16BYTE_BURST 0x00000010
+/**************************** Type Definitions ******************************/
+/** @name Typedefs for callback functions
+ * These callbacks are invoked in interrupt context.
+ * Callback invoked when frame(s) have been sent or received in interrupt
+ * driven DMA mode. To set the send callback, invoke XEmacPs_SetHandler().
+ * @param CallBackRef is user data assigned when the callback was set.
+ * @note
+ * See xemacps_hw.h for bitmasks definitions and the device hardware spec for
+ * further information on their meaning.
+typedef void (*XEmacPs_Handler) (void *CallBackRef);
+ * Callback when an asynchronous error occurs. To set this callback, invoke
+ * XEmacPs_SetHandler() with XEMACPS_HANDLER_ERROR in the HandlerType
+ * parameter.
+ * @param Direction defines either receive or transmit error(s) has occurred.
+ * @param ErrorWord definition varies with Direction
+typedef void (*XEmacPs_ErrHandler) (void *CallBackRef, u8 Direction,
+ u32 ErrorWord);
+ * This typedef contains configuration information for a device.
+typedef struct {
+ u16 DeviceId; /**< Unique ID of device */
+ UINTPTR BaseAddress;/**< Physical base address of IPIF registers */
+ u8 IsCacheCoherent; /**< Applicable only to A53 in EL1 mode;
+ * describes whether Cache Coherent or not */
+ u32 RefClk; /**< Input clock */
+#endif
+ u16 S1GDiv0; /**< 1Gbps Clock Divider 0 */
+ u8 S1GDiv1; /**< 1Gbps Clock Divider 1 */
+ u16 S100MDiv0; /**< 100Mbps Clock Divider 0 */
+ u8 S100MDiv1; /**< 100Mbps Clock Divider 1 */
+ u16 S10MDiv0; /**< 10Mbps Clock Divider 0 */
+ u8 S10MDiv1; /**< 10Mbps Clock Divider 1 */
+} XEmacPs_Config;
+ * The XEmacPs driver instance data. The user is required to allocate a
+ * structure of this type for every XEmacPs device in the system. A pointer
+ * to a structure of this type is then passed to the driver API functions.
+typedef struct XEmacPs_Instance {
+ XEmacPs_Config Config; /* Hardware configuration */
+ u32 IsStarted; /* Device is currently started */
+ u32 IsReady; /* Device is initialized and ready */
+ u32 Options; /* Current options word */
+ XEmacPs_BdRing TxBdRing; /* Transmit BD ring */
+ XEmacPs_BdRing RxBdRing; /* Receive BD ring */
+ XEmacPs_Handler SendHandler;
+ XEmacPs_Handler RecvHandler;
+ void *SendRef;
+ void *RecvRef;
+ XEmacPs_ErrHandler ErrorHandler;
+ void *ErrorRef;
+ u32 Version;
+ u32 RxBufMask;
+ u32 MaxMtuSize;
+ u32 MaxFrameSize;
+ u32 MaxVlanFrameSize;
+} XEmacPs;
+/***************** Macros (Inline Functions) Definitions ********************/
+* Retrieve the Tx ring object. This object can be used in the various Ring
+* API functions.
+* @param InstancePtr is the DMA channel to operate on.
+* @return TxBdRing attribute
+* @note
+* C-style signature:
+* XEmacPs_BdRing XEmacPs_GetTxRing(XEmacPs *InstancePtr)
+#define XEmacPs_GetTxRing(InstancePtr) ((InstancePtr)->TxBdRing)
+* Retrieve the Rx ring object. This object can be used in the various Ring
+* API functions.
+* @return RxBdRing attribute
+* @note
+* XEmacPs_BdRing XEmacPs_GetRxRing(XEmacPs *InstancePtr)
+#define XEmacPs_GetRxRing(InstancePtr) ((InstancePtr)->RxBdRing)
+* Enable interrupts specified in <i>Mask</i>. The corresponding interrupt for
+* each bit set to 1 in <i>Mask</i>, will be enabled.
+* @param Mask contains a bit mask of interrupts to enable. The mask can
+* be formed using a set of bitwise or'd values.
+* @note
+* The state of the transmitter and receiver are not modified by this function.
+* void XEmacPs_IntEnable(XEmacPs *InstancePtr, u32 Mask)
+#define XEmacPs_IntEnable(InstancePtr, Mask) \
+ XEmacPs_WriteReg((InstancePtr)->Config.BaseAddress, \
+ XEMACPS_IER_OFFSET, \
+ ((Mask) & XEMACPS_IXR_ALL_MASK));
+* Disable interrupts specified in <i>Mask</i>. The corresponding interrupt for
+* @param Mask contains a bit mask of interrupts to disable. The mask can
+* @note
+* void XEmacPs_IntDisable(XEmacPs *InstancePtr, u32 Mask)
+#define XEmacPs_IntDisable(InstancePtr, Mask) \
+ XEMACPS_IDR_OFFSET, \
+* @note
+* void XEmacPs_IntQ1Enable(XEmacPs *InstancePtr, u32 Mask)
+#define XEmacPs_IntQ1Enable(InstancePtr, Mask) \
+ XEMACPS_INTQ1_IER_OFFSET, \
+ ((Mask) & XEMACPS_INTQ1_IXR_ALL_MASK));
+* @note
+#define XEmacPs_IntQ1Disable(InstancePtr, Mask) \
+ XEMACPS_INTQ1_IDR_OFFSET, \
+* This macro triggers trasmit circuit to send data currently in TX buffer(s).
+* @param InstancePtr is a pointer to the XEmacPs instance to be worked on.
+* @return
+* @note
+* Signature: void XEmacPs_Transmit(XEmacPs *InstancePtr)
+#define XEmacPs_Transmit(InstancePtr) \
+ XEMACPS_NWCTRL_OFFSET, \
+ (XEmacPs_ReadReg((InstancePtr)->Config.BaseAddress, \
+ XEMACPS_NWCTRL_OFFSET) | XEMACPS_NWCTRL_STARTTX_MASK))
+* This macro determines if the device is configured with checksum offloading
+* on the receive channel
+* @return
+* Boolean TRUE if the device is configured with checksum offloading, or
+* FALSE otherwise.
+* @note
+* Signature: u32 XEmacPs_IsRxCsum(XEmacPs *InstancePtr)
+#define XEmacPs_IsRxCsum(InstancePtr) \
+ ((XEmacPs_ReadReg((InstancePtr)->Config.BaseAddress, \
+ XEMACPS_NWCFG_OFFSET) & XEMACPS_NWCFG_RXCHKSUMEN_MASK) != 0U \
+ ? TRUE : FALSE)
+* on the transmit channel
+* @return
+* FALSE otherwise.
+* @note
+* Signature: u32 XEmacPs_IsTxCsum(XEmacPs *InstancePtr)
+#define XEmacPs_IsTxCsum(InstancePtr) \
+ XEMACPS_DMACR_OFFSET) & XEMACPS_DMACR_TCPCKSUM_MASK) != 0U \
+ ? TRUE : FALSE)
+/************************** Function Prototypes *****************************/
+* This macro sets RX watermark register.
+* @param High is the non-zero RX high watermark value. When SRAM fill level
+* is above this, a pause frame will be sent.
+* @param Low is the non-zero RX low watermark value. When SRAM fill level
+* is below this, a zero length pause frame will be sent IF the last
+* pause frame sent was non-zero.
+* @return None
+* @note
+* Signature: void XEmacPs_SetRXWatermark(XEmacPs *InstancePtr, u16 High,
+* u16 Low)
+#define XEmacPs_SetRXWatermark(InstancePtr, High, Low) \
+ XEMACPS_RXWATERMARK_OFFSET, \
+ (High & XEMACPS_RXWM_HIGH_MASK) | \
+ ((Low << XEMACPS_RXWM_LOW_SHFT_MSK) & XEMACPS_RXWM_LOW_MASK) |)
+* This macro gets RX watermark register.
+* @return RX watermark register value
+* @note
+* Signature: void XEmacPs_GetRXWatermark(XEmacPs *InstancePtr)
+#define XEmacPs_GetRXWatermark(InstancePtr) \
+ XEmacPs_ReadReg((InstancePtr)->Config.BaseAddress, \
+ XEMACPS_RXWATERMARK_OFFSET)
+ * Initialization functions in xemacps.c
+LONG XEmacPs_CfgInitialize(XEmacPs *InstancePtr, XEmacPs_Config *CfgPtr,
+ UINTPTR EffectiveAddress);
+void XEmacPs_Start(XEmacPs *InstancePtr);
+void XEmacPs_Stop(XEmacPs *InstancePtr);
+void XEmacPs_Reset(XEmacPs *InstancePtr);
+ u16 Direction);
+ * Lookup configuration in xemacps_sinit.c
+XEmacPs_Config *XEmacPs_LookupConfig(u16 DeviceId);
+ * Interrupt-related functions in xemacps_intr.c
+ * DMA only and FIFO is not supported. This DMA does not support coalescing.
+LONG XEmacPs_SetHandler(XEmacPs *InstancePtr, u32 HandlerType,
+ void *FuncPointer, void *CallBackRef);
+void XEmacPs_IntrHandler(void *XEmacPsPtr);
+ * MAC configuration/control functions in XEmacPs_control.c
+LONG XEmacPs_SetOptions(XEmacPs *InstancePtr, u32 Options);
+LONG XEmacPs_ClearOptions(XEmacPs *InstancePtr, u32 Options);
+u32 XEmacPs_GetOptions(XEmacPs *InstancePtr);
+LONG XEmacPs_SetMacAddress(XEmacPs *InstancePtr, void *AddressPtr, u8 Index);
+LONG XEmacPs_DeleteHash(XEmacPs *InstancePtr, void *AddressPtr);
+void XEmacPs_GetMacAddress(XEmacPs *InstancePtr, void *AddressPtr, u8 Index);
+LONG XEmacPs_SetHash(XEmacPs *InstancePtr, void *AddressPtr);
+void XEmacPs_ClearHash(XEmacPs *InstancePtr);
+void XEmacPs_GetHash(XEmacPs *InstancePtr, void *AddressPtr);
+void XEmacPs_SetMdioDivisor(XEmacPs *InstancePtr,
+ XEmacPs_MdcDiv Divisor);
+void XEmacPs_SetOperatingSpeed(XEmacPs *InstancePtr, u16 Speed);
+u16 XEmacPs_GetOperatingSpeed(XEmacPs *InstancePtr);
+LONG XEmacPs_PhyRead(XEmacPs *InstancePtr, u32 PhyAddress,
+ u32 RegisterNum, u16 *PhyDataPtr);
+LONG XEmacPs_PhyWrite(XEmacPs *InstancePtr, u32 PhyAddress,
+ u32 RegisterNum, u16 PhyData);
+LONG XEmacPs_SetTypeIdCheck(XEmacPs *InstancePtr, u32 Id_Check, u8 Index);
+LONG XEmacPs_SendPausePacket(XEmacPs *InstancePtr);
+void XEmacPs_DMABLengthUpdate(XEmacPs *InstancePtr, s32 BLength);
+#ifdef __cplusplus
+#endif
+#endif /* end of protection macro */
diff --git a/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bd.h b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bd.h
new file mode 100644
index 0000000..aff79ff
--- /dev/null
+++ b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bd.h
@@ -0,0 +1,762 @@
+ * @file xemacps_bd.h
+ * This header provides operations to manage buffer descriptors in support
+ * of scatter-gather DMA.
+ * The API exported by this header defines abstracted macros that allow the
+ * user to read/write specific BD fields.
+ * <b>Buffer Descriptors</b>
+ * A buffer descriptor (BD) defines a DMA transaction. The macros defined by
+ * this header file allow access to most fields within a BD to tailor a DMA
+ * transaction according to user and hardware requirements. See the hardware
+ * IP DMA spec for more information on BD fields and how they affect transfers.
+ * The XEmacPs_Bd structure defines a BD. The organization of this structure
+ * is driven mainly by the hardware for use in scatter-gather DMA transfers.
+ * <b>Performance</b>
+ * Limiting I/O to BDs can improve overall performance of the DMA channel.
+ * <pre>
+ * 2.1 srt 07/15/14 Add support for Zynq Ultrascale MP GEM specification
+ * and 64-bit changes.
+ * 3.0 hk 02/20/15 Added support for jumbo frames.
+ * 3.2 hk 11/18/15 Change BD typedef and number of words.
+ * 3.8 hk 08/18/18 Remove duplicate definition of XEmacPs_BdSetLength
+ * 3.8 mus 11/05/18 Support 64 bit DMA addresses for Microblaze-X platform.
+ * </pre>
+#ifndef XEMACPS_BD_H /* prevent circular inclusions */
+#define XEMACPS_BD_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <string.h>
+#ifdef __aarch64__
+/* Minimum BD alignment */
+#define XEMACPS_DMABD_MINIMUM_ALIGNMENT 64U
+#define XEMACPS_BD_NUM_WORDS 4U
+#else
+#define XEMACPS_DMABD_MINIMUM_ALIGNMENT 4U
+#define XEMACPS_BD_NUM_WORDS 2U
+#endif
+ * The XEmacPs_Bd is the type for buffer descriptors (BDs).
+typedef u32 XEmacPs_Bd[XEMACPS_BD_NUM_WORDS];
+ * Zero out BD fields
+ * @param BdPtr is the BD pointer to operate on
+ * @return Nothing
+ * @note
+ * C-style signature:
+ * void XEmacPs_BdClear(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdClear(BdPtr) \
+ memset((BdPtr), 0, sizeof(XEmacPs_Bd))
+* Read the given Buffer Descriptor word.
+* @param BaseAddress is the base address of the BD to read
+* @param Offset is the word offset to be read
+* @return The 32-bit value of the field
+* @note
+* u32 XEmacPs_BdRead(UINTPTR BaseAddress, UINTPTR Offset)
+#define XEmacPs_BdRead(BaseAddress, Offset) \
+ (*(u32 *)((UINTPTR)((void*)(BaseAddress)) + (u32)(Offset)))
+* Write the given Buffer Descriptor word.
+* @param BaseAddress is the base address of the BD to write
+* @param Offset is the word offset to be written
+* @param Data is the 32-bit value to write to the field
+* @return None.
+* @note
+* void XEmacPs_BdWrite(UINTPTR BaseAddress, UINTPTR Offset, UINTPTR Data)
+#define XEmacPs_BdWrite(BaseAddress, Offset, Data) \
+ (*(u32 *)((UINTPTR)(void*)(BaseAddress) + (u32)(Offset)) = (u32)(Data))
+ * Set the BD's Address field (word 0).
+ * @param Addr is the value to write to BD's status field.
+ * @note :
+ * void XEmacPs_BdSetAddressTx(XEmacPs_Bd* BdPtr, UINTPTR Addr)
+#define XEmacPs_BdSetAddressTx(BdPtr, Addr) \
+ XEmacPs_BdWrite((BdPtr), XEMACPS_BD_ADDR_OFFSET, \
+ (u32)((Addr) & ULONG64_LO_MASK)); \
+ XEmacPs_BdWrite((BdPtr), XEMACPS_BD_ADDR_HI_OFFSET, \
+ (u32)(((Addr) & ULONG64_HI_MASK) >> 32U));
+#else
+ XEmacPs_BdWrite((BdPtr), XEMACPS_BD_ADDR_OFFSET, (u32)(Addr))
+#endif
+ * @note : Due to some bits are mixed within receive BD's address field,
+ * read-modify-write is performed.
+ * void XEmacPs_BdSetAddressRx(XEmacPs_Bd* BdPtr, UINTPTR Addr)
+#ifdef __aarch64__
+#define XEmacPs_BdSetAddressRx(BdPtr, Addr) \
+ ((XEmacPs_BdRead((BdPtr), XEMACPS_BD_ADDR_OFFSET) & \
+ ~XEMACPS_RXBUF_ADD_MASK) | ((u32)((Addr) & ULONG64_LO_MASK)))); \
+#else
+ ~XEMACPS_RXBUF_ADD_MASK) | (UINTPTR)(Addr)))
+#endif
+ * Set the BD's Status field (word 1).
+ * @param Data is the value to write to BD's status field.
+ * @note
+ * void XEmacPs_BdSetStatus(XEmacPs_Bd* BdPtr, UINTPTR Data)
+#define XEmacPs_BdSetStatus(BdPtr, Data) \
+ XEmacPs_BdWrite((BdPtr), XEMACPS_BD_STAT_OFFSET, \
+ XEmacPs_BdRead((BdPtr), XEMACPS_BD_STAT_OFFSET) | (Data))
+ * Retrieve the BD's Packet DMA transfer status word (word 1).
+ * @return Status word
+ * @note
+ * u32 XEmacPs_BdGetStatus(XEmacPs_Bd* BdPtr)
+ * Due to the BD bit layout differences in transmit and receive. User's
+ * caution is required.
+#define XEmacPs_BdGetStatus(BdPtr) \
+ * Get the address (bits 0..31) of the BD's buffer address (word 0)
+ * @note
+ * UINTPTR XEmacPs_BdGetBufAddr(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdGetBufAddr(BdPtr) \
+ (XEmacPs_BdRead((BdPtr), XEMACPS_BD_ADDR_OFFSET) | \
+ (XEmacPs_BdRead((BdPtr), XEMACPS_BD_ADDR_HI_OFFSET)) << 32U)
+#else
+ (XEmacPs_BdRead((BdPtr), XEMACPS_BD_ADDR_OFFSET))
+#endif
+ * Set transfer length in bytes for the given BD. The length must be set each
+ * time a BD is submitted to hardware.
+ * @param LenBytes is the number of bytes to transfer.
+ * @note
+ * void XEmacPs_BdSetLength(XEmacPs_Bd* BdPtr, u32 LenBytes)
+#define XEmacPs_BdSetLength(BdPtr, LenBytes) \
+ ((XEmacPs_BdRead((BdPtr), XEMACPS_BD_STAT_OFFSET) & \
+ ~XEMACPS_TXBUF_LEN_MASK) | (LenBytes)))
+ * Retrieve the BD length field.
+ * For Tx channels, the returned value is the same as that written with
+ * XEmacPs_BdSetLength().
+ * For Rx channels, the returned value is the size of the received packet.
+ * @return Length field processed by hardware or set by
+ * @note
+ * UINTPTR XEmacPs_BdGetLength(XEmacPs_Bd* BdPtr)
+ * XEAMCPS_RXBUF_LEN_MASK is same as XEMACPS_TXBUF_LEN_MASK.
+#define XEmacPs_BdGetLength(BdPtr) \
+ (XEmacPs_BdRead((BdPtr), XEMACPS_BD_STAT_OFFSET) & \
+ XEMACPS_RXBUF_LEN_MASK)
+ * Retrieve the RX frame size.
+ * The returned value is the size of the received packet.
+ * This API supports jumbo frame sizes if enabled.
+ * @param InstancePtr is the pointer to XEmacps instance
+ * @note
+ * UINTPTR XEmacPs_GetRxFrameSize(XEmacPs* InstancePtr, XEmacPs_Bd* BdPtr)
+ * RxBufMask is dependent on whether jumbo is enabled or not.
+#define XEmacPs_GetRxFrameSize(InstancePtr, BdPtr) \
+ (InstancePtr)->RxBufMask)
+ * Test whether the given BD has been marked as the last BD of a packet.
+ * @return TRUE if BD represents the "Last" BD of a packet, FALSE otherwise
+ * @note
+ * UINTPTR XEmacPs_BdIsLast(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsLast(BdPtr) \
+ XEMACPS_RXBUF_EOF_MASK)!=0U ? TRUE : FALSE)
+ * Tell the DMA engine that the given transmit BD marks the end of the current
+ * packet to be processed.
+ * @note
+ * void XEmacPs_BdSetLast(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdSetLast(BdPtr) \
+ (XEmacPs_BdWrite((BdPtr), XEMACPS_BD_STAT_OFFSET, \
+ XEmacPs_BdRead((BdPtr), XEMACPS_BD_STAT_OFFSET) | \
+ XEMACPS_TXBUF_LAST_MASK))
+ * Tell the DMA engine that the current packet does not end with the given
+ * BD.
+ * @note
+ * void XEmacPs_BdClearLast(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdClearLast(BdPtr) \
+ XEmacPs_BdRead((BdPtr), XEMACPS_BD_STAT_OFFSET) & \
+ ~XEMACPS_TXBUF_LAST_MASK))
+ * Set this bit to mark the last descriptor in the receive buffer descriptor
+ * list.
+ * @note
+ * void XEmacPs_BdSetRxWrap(XEmacPs_Bd* BdPtr)
+/*#define XEmacPs_BdSetRxWrap(BdPtr) \
+ (XEmacPs_BdWrite((BdPtr), XEMACPS_BD_ADDR_OFFSET, \
+ XEmacPs_BdRead((BdPtr), XEMACPS_BD_ADDR_OFFSET) | \
+ XEMACPS_RXBUF_WRAP_MASK))
+ * Determine the wrap bit of the receive BD which indicates end of the
+ * BD list.
+ * @note
+ * u8 XEmacPs_BdIsRxWrap(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsRxWrap(BdPtr) \
+ XEMACPS_RXBUF_WRAP_MASK)!=0U ? TRUE : FALSE)
+ * Sets this bit to mark the last descriptor in the transmit buffer
+ * descriptor list.
+ * @note
+ * void XEmacPs_BdSetTxWrap(XEmacPs_Bd* BdPtr)
+/*#define XEmacPs_BdSetTxWrap(BdPtr) \
+ XEMACPS_TXBUF_WRAP_MASK))
+ * Determine the wrap bit of the transmit BD which indicates end of the
+ * BD list.
+ * @note
+ * u8 XEmacPs_BdGetTxWrap(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsTxWrap(BdPtr) \
+ XEMACPS_TXBUF_WRAP_MASK)!=0U ? TRUE : FALSE)
+ * Must clear this bit to enable the MAC to write data to the receive
+ * buffer. Hardware sets this bit once it has successfully written a frame to
+ * memory. Once set, software has to clear the bit before the buffer can be
+ * used again. This macro clear the new bit of the receive BD.
+ * @note
+ * void XEmacPs_BdClearRxNew(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdClearRxNew(BdPtr) \
+ XEmacPs_BdRead((BdPtr), XEMACPS_BD_ADDR_OFFSET) & \
+ ~XEMACPS_RXBUF_NEW_MASK))
+ * Determine the new bit of the receive BD.
+ * @note
+ * UINTPTR XEmacPs_BdIsRxNew(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsRxNew(BdPtr) \
+ XEMACPS_RXBUF_NEW_MASK)!=0U ? TRUE : FALSE)
+ * Software sets this bit to disable the buffer to be read by the hardware.
+ * Hardware sets this bit for the first buffer of a frame once it has been
+ * successfully transmitted. This macro sets this bit of transmit BD to avoid
+ * confusion.
+ * @note
+ * void XEmacPs_BdSetTxUsed(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdSetTxUsed(BdPtr) \
+ XEMACPS_TXBUF_USED_MASK))
+ * Software clears this bit to enable the buffer to be read by the hardware.
+ * successfully transmitted. This macro clears this bit of transmit BD.
+ * @note
+ * void XEmacPs_BdClearTxUsed(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdClearTxUsed(BdPtr) \
+ ~XEMACPS_TXBUF_USED_MASK))
+ * Determine the used bit of the transmit BD.
+ * @note
+ * UINTPTR XEmacPs_BdIsTxUsed(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsTxUsed(BdPtr) \
+ XEMACPS_TXBUF_USED_MASK)!=0U ? TRUE : FALSE)
+ * Determine if a frame fails to be transmitted due to too many retries.
+ * @note
+ * UINTPTR XEmacPs_BdIsTxRetry(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsTxRetry(BdPtr) \
+ XEMACPS_TXBUF_RETRY_MASK)!=0U ? TRUE : FALSE)
+ * Determine if a frame fails to be transmitted due to data can not be
+ * feteched in time or buffers are exhausted.
+ * @note
+ * UINTPTR XEmacPs_BdIsTxUrun(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsTxUrun(BdPtr) \
+ XEMACPS_TXBUF_URUN_MASK)!=0U ? TRUE : FALSE)
+ * Determine if a frame fails to be transmitted due to buffer is exhausted
+ * mid-frame.
+ * @note
+ * UINTPTR XEmacPs_BdIsTxExh(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsTxExh(BdPtr) \
+ XEMACPS_TXBUF_EXH_MASK)!=0U ? TRUE : FALSE)
+ * Sets this bit, no CRC will be appended to the current frame. This control
+ * bit must be set for the first buffer in a frame and will be ignored for
+ * the subsequent buffers of a frame.
+ * @note
+ * This bit must be clear when using the transmit checksum generation offload,
+ * otherwise checksum generation and substitution will not occur.
+ * UINTPTR XEmacPs_BdSetTxNoCRC(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdSetTxNoCRC(BdPtr) \
+ XEMACPS_TXBUF_NOCRC_MASK))
+ * Clear this bit, CRC will be appended to the current frame. This control
+ * @note
+ * UINTPTR XEmacPs_BdClearTxNoCRC(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdClearTxNoCRC(BdPtr) \
+ ~XEMACPS_TXBUF_NOCRC_MASK))
+ * Determine the broadcast bit of the receive BD.
+ * @note
+ * UINTPTR XEmacPs_BdIsRxBcast(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsRxBcast(BdPtr) \
+ XEMACPS_RXBUF_BCAST_MASK)!=0U ? TRUE : FALSE)
+ * Determine the multicast hash bit of the receive BD.
+ * @note
+ * UINTPTR XEmacPs_BdIsRxMultiHash(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsRxMultiHash(BdPtr) \
+ XEMACPS_RXBUF_MULTIHASH_MASK)!=0U ? TRUE : FALSE)
+ * Determine the unicast hash bit of the receive BD.
+ * @note
+ * UINTPTR XEmacPs_BdIsRxUniHash(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsRxUniHash(BdPtr) \
+ XEMACPS_RXBUF_UNIHASH_MASK)!=0U ? TRUE : FALSE)
+ * Determine if the received frame is a VLAN Tagged frame.
+ * @note
+ * UINTPTR XEmacPs_BdIsRxVlan(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsRxVlan(BdPtr) \
+ XEMACPS_RXBUF_VLAN_MASK)!=0U ? TRUE : FALSE)
+ * Determine if the received frame has Type ID of 8100h and null VLAN
+ * identifier(Priority tag).
+ * @note
+ * UINTPTR XEmacPs_BdIsRxPri(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsRxPri(BdPtr) \
+ XEMACPS_RXBUF_PRI_MASK)!=0U ? TRUE : FALSE)
+ * Determine if the received frame's Concatenation Format Indicator (CFI) of
+ * the frames VLANTCI field was set.
+ * @note
+ * UINTPTR XEmacPs_BdIsRxCFI(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsRxCFI(BdPtr) \
+ XEMACPS_RXBUF_CFI_MASK)!=0U ? TRUE : FALSE)
+ * Determine the End Of Frame (EOF) bit of the receive BD.
+ * @note
+ * UINTPTR XEmacPs_BdGetRxEOF(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsRxEOF(BdPtr) \
+ * Determine the Start Of Frame (SOF) bit of the receive BD.
+ * @note
+ * UINTPTR XEmacPs_BdGetRxSOF(XEmacPs_Bd* BdPtr)
+#define XEmacPs_BdIsRxSOF(BdPtr) \
+ XEMACPS_RXBUF_SOF_MASK)!=0U ? TRUE : FALSE)
+#ifdef __cplusplus
+#endif
diff --git a/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.c b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.c
index 0000000..829f37c
--- /dev/null
+++ b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.c
@@ -0,0 +1,1076 @@
+* @file xemacps_bdring.c
+* This file implements buffer descriptor ring related functions.
+* <pre>
+* 1.00a asa 11/21/11 The function XEmacPs_BdRingFromHwTx is modified.
+* Earlier it used to search in "BdLimit" number of BDs to
+* know which BDs are processed. Now one more check is
+* added. It looks for BDs till the current BD pointer
+* reaches HwTail. By doing this processing time is saved.
+* 1.00a asa 01/24/12 The function XEmacPs_BdRingFromHwTx in file
+* xemacps_bdring.c is modified. Now start of packet is
+* searched for returning the number of BDs processed.
+* 1.05a asa 09/23/13 Cache operations on BDs are not required and hence
+* removed. It is expected that all BDs are allocated in
+* from uncached area. Fix for CR #663885.
+* 2.1 srt 07/15/14 Add support for Zynq Ultrascale Mp architecture.
+* 3.0 kvn 02/13/15 Modified code for MISRA-C:2012 compliance.
+* 3.6 rb 09/08/17 Add XEmacPs_BdRingPtrReset() API to reset BD ring
+* pointers
+* </pre>
+#include "xil_cache.h"
+ * Compute the virtual address of a descriptor from its physical address
+ * @param BdPtr is the physical address of the BD
+ * @returns Virtual address of BdPtr
+ * @note Assume BdPtr is always a valid BD in the ring
+#define XEMACPS_PHYS_TO_VIRT(BdPtr) \
+ ((UINTPTR)(BdPtr) + (RingPtr->BaseBdAddr - RingPtr->PhysBaseAddr))
+ * Compute the physical address of a descriptor from its virtual address
+ * @returns Physical address of BdPtr
+#define XEMACPS_VIRT_TO_PHYS(BdPtr) \
+ ((UINTPTR)(BdPtr) - (RingPtr->BaseBdAddr - RingPtr->PhysBaseAddr))
+ * Move the BdPtr argument ahead an arbitrary number of BDs wrapping around
+ * to the beginning of the ring if needed.
+ * We know if a wrapaound should occur if the new BdPtr is greater than
+ * the high address in the ring OR if the new BdPtr crosses over the
+ * 0xFFFFFFFF to 0 boundary. The latter test is a valid one since we do not
+ * allow a BD space to span this boundary.
+ * @param RingPtr is the ring BdPtr appears in
+ * @param BdPtr on input is the starting BD position and on output is the
+ * final BD position
+ * @param NumBd is the number of BD spaces to increment
+#define XEMACPS_RING_SEEKAHEAD(RingPtr, BdPtr, NumBd) \
+ UINTPTR Addr = (UINTPTR)(void *)(BdPtr); \
+ Addr += ((RingPtr)->Separation * (NumBd)); \
+ if ((Addr > (RingPtr)->HighBdAddr) || ((UINTPTR)(void *)(BdPtr) > Addr)) \
+ Addr -= (RingPtr)->Length; \
+ (BdPtr) = (XEmacPs_Bd*)(void *)Addr; \
+ * Move the BdPtr argument backwards an arbitrary number of BDs wrapping
+ * around to the end of the ring if needed.
+ * We know if a wrapaound should occur if the new BdPtr is less than
+ * the base address in the ring OR if the new BdPtr crosses over the
+#define XEMACPS_RING_SEEKBACK(RingPtr, BdPtr, NumBd) \
+ Addr -= ((RingPtr)->Separation * (NumBd)); \
+ if ((Addr < (RingPtr)->BaseBdAddr) || ((UINTPTR)(void*)(BdPtr) < Addr)) \
+ Addr += (RingPtr)->Length; \
+ (BdPtr) = (XEmacPs_Bd*)(void*)Addr; \
+static void XEmacPs_BdSetRxWrap(UINTPTR BdPtr);
+static void XEmacPs_BdSetTxWrap(UINTPTR BdPtr);
+ * Using a memory segment allocated by the caller, create and setup the BD list
+ * for the given DMA channel.
+ * @param RingPtr is the instance to be worked on.
+ * @param PhysAddr is the physical base address of user memory region.
+ * @param VirtAddr is the virtual base address of the user memory region. If
+ * address translation is not being utilized, then VirtAddr should be
+ * equivalent to PhysAddr.
+ * @param Alignment governs the byte alignment of individual BDs. This function
+ * will enforce a minimum alignment of 4 bytes with no maximum as long
+ * as it is specified as a power of 2.
+ * @param BdCount is the number of BDs to setup in the user memory region. It
+ * is assumed the region is large enough to contain the BDs.
+ * @return
+ * - XST_SUCCESS if initialization was successful
+ * - XST_NO_FEATURE if the provided instance is a non DMA type
+ * channel.
+ * - XST_INVALID_PARAM under any of the following conditions:
+ * 1) PhysAddr and/or VirtAddr are not aligned to the given Alignment
+ * parameter.
+ * 2) Alignment parameter does not meet minimum requirements or is not a
+ * power of 2 value.
+ * 3) BdCount is 0.
+ * - XST_DMA_SG_LIST_ERROR if the memory segment containing the list spans
+ * over address 0x00000000 in virtual address space.
+ * @note
+ * Make sure to pass in the right alignment value.
+LONG XEmacPs_BdRingCreate(XEmacPs_BdRing * RingPtr, UINTPTR PhysAddr,
+ UINTPTR VirtAddr, u32 Alignment, u32 BdCount)
+ u32 i;
+ UINTPTR BdVirtAddr;
+ UINTPTR BdPhyAddr;
+ UINTPTR VirtAddrLoc = VirtAddr;
+ /* In case there is a failure prior to creating list, make sure the
+ * following attributes are 0 to prevent calls to other functions
+ * from doing anything.
+ RingPtr->AllCnt = 0U;
+ RingPtr->FreeCnt = 0U;
+ RingPtr->HwCnt = 0U;
+ RingPtr->PreCnt = 0U;
+ RingPtr->PostCnt = 0U;
+ /* Make sure Alignment parameter meets minimum requirements */
+ if (Alignment < (u32)XEMACPS_DMABD_MINIMUM_ALIGNMENT) {
+ return (LONG)(XST_INVALID_PARAM);
+ /* Make sure Alignment is a power of 2 */
+ if (((Alignment - 0x00000001U) & Alignment)!=0x00000000U) {
+ /* Make sure PhysAddr and VirtAddr are on same Alignment */
+ if (((PhysAddr % Alignment)!=(u32)0) || ((VirtAddrLoc % Alignment)!=(u32)0)) {
+ /* Is BdCount reasonable? */
+ if (BdCount == 0x00000000U) {
+ /* Figure out how many bytes will be between the start of adjacent BDs */
+ RingPtr->Separation = ((u32)sizeof(XEmacPs_Bd));
+ /* Must make sure the ring doesn't span address 0x00000000. If it does,
+ * then the next/prev BD traversal macros will fail.
+ if (VirtAddrLoc > ((VirtAddrLoc + (RingPtr->Separation * BdCount)) - (u32)1)) {
+ return (LONG)(XST_DMA_SG_LIST_ERROR);
+ /* Initial ring setup:
+ * - Clear the entire space
+ * - Setup each BD's BDA field with the physical address of the next BD
+ (void)memset((void *) VirtAddrLoc, 0, (RingPtr->Separation * BdCount));
+ BdVirtAddr = VirtAddrLoc;
+ BdPhyAddr = PhysAddr + RingPtr->Separation;
+ for (i = 1U; i < BdCount; i++) {
+ BdVirtAddr += RingPtr->Separation;
+ BdPhyAddr += RingPtr->Separation;
+ /* Setup and initialize pointers and counters */
+ RingPtr->RunState = (u32)(XST_DMA_SG_IS_STOPPED);
+ RingPtr->BaseBdAddr = VirtAddrLoc;
+ RingPtr->PhysBaseAddr = PhysAddr;
+ RingPtr->HighBdAddr = BdVirtAddr;
+ RingPtr->Length =
+ ((RingPtr->HighBdAddr - RingPtr->BaseBdAddr) + RingPtr->Separation);
+ RingPtr->AllCnt = (u32)BdCount;
+ RingPtr->FreeCnt = (u32)BdCount;
+ RingPtr->FreeHead = (XEmacPs_Bd *)(void *)VirtAddrLoc;
+ RingPtr->PreHead = (XEmacPs_Bd *)VirtAddrLoc;
+ RingPtr->HwHead = (XEmacPs_Bd *)VirtAddrLoc;
+ RingPtr->HwTail = (XEmacPs_Bd *)VirtAddrLoc;
+ RingPtr->PostHead = (XEmacPs_Bd *)VirtAddrLoc;
+ RingPtr->BdaRestart = (XEmacPs_Bd *)(void *)PhysAddr;
+ * Clone the given BD into every BD in the list.
+ * every field of the source BD is replicated in every BD of the list.
+ * This function can be called only when all BDs are in the free group such as
+ * they are immediately after initialization with XEmacPs_BdRingCreate().
+ * This prevents modification of BDs while they are in use by hardware or the
+ * user.
+ * @param RingPtr is the pointer of BD ring instance to be worked on.
+ * @param SrcBdPtr is the source BD template to be cloned into the list. This
+ * BD will be modified.
+ * @param Direction is either XEMACPS_SEND or XEMACPS_RECV that indicates
+ * which direction.
+ * @return
+ * - XST_SUCCESS if the list was modified.
+ * - XST_DMA_SG_NO_LIST if a list has not been created.
+ * - XST_DMA_SG_LIST_ERROR if some of the BDs in this channel are under
+ * hardware or user control.
+ * - XST_DEVICE_IS_STARTED if the DMA channel has not been stopped.
+LONG XEmacPs_BdRingClone(XEmacPs_BdRing * RingPtr, XEmacPs_Bd * SrcBdPtr,
+ u8 Direction)
+ u32 i;
+ UINTPTR CurBd;
+ /* Can't do this function if there isn't a ring */
+ if (RingPtr->AllCnt == 0x00000000U) {
+ return (LONG)(XST_DMA_SG_NO_LIST);
+ /* Can't do this function with the channel running */
+ if (RingPtr->RunState == (u32)XST_DMA_SG_IS_STARTED) {
+ return (LONG)(XST_DEVICE_IS_STARTED);
+ /* Can't do this function with some of the BDs in use */
+ if (RingPtr->FreeCnt != RingPtr->AllCnt) {
+ if ((Direction != (u8)XEMACPS_SEND) && (Direction != (u8)XEMACPS_RECV)) {
+ /* Starting from the top of the ring, save BD.Next, overwrite the entire
+ * BD with the template, then restore BD.Next
+ CurBd = RingPtr->BaseBdAddr;
+ for (i = 0U; i < RingPtr->AllCnt; i++) {
+ memcpy((void *)CurBd, SrcBdPtr, sizeof(XEmacPs_Bd));
+ CurBd += RingPtr->Separation;
+ CurBd -= RingPtr->Separation;
+ if (Direction == XEMACPS_RECV) {
+ XEmacPs_BdSetRxWrap(CurBd);
+ else {
+ XEmacPs_BdSetTxWrap(CurBd);
+ * Reserve locations in the BD list. The set of returned BDs may be modified
+ * in preparation for future DMA transaction(s). Once the BDs are ready to be
+ * submitted to hardware, the user must call XEmacPs_BdRingToHw() in the same
+ * order which they were allocated here. Example:
+ * <pre>
+ * NumBd = 2,
+ * Status = XEmacPs_BdRingAlloc(MyRingPtr, NumBd, &MyBdSet),
+ * if (Status != XST_SUCCESS)
+ * *Not enough BDs available for the request*
+ * CurBd = MyBdSet,
+ * for (i=0; i<NumBd; i++)
+ * * Prepare CurBd *.....
+ * * Onto next BD *
+ * CurBd = XEmacPs_BdRingNext(MyRingPtr, CurBd),
+ * * Give list to hardware *
+ * Status = XEmacPs_BdRingToHw(MyRingPtr, NumBd, MyBdSet),
+ * </pre>
+ * A more advanced use of this function may allocate multiple sets of BDs.
+ * They must be allocated and given to hardware in the correct sequence:
+ * <pre>
+ * * Legal *
+ * XEmacPs_BdRingAlloc(MyRingPtr, NumBd1, &MySet1),
+ * XEmacPs_BdRingToHw(MyRingPtr, NumBd1, MySet1),
+ * * Legal *
+ * XEmacPs_BdRingAlloc(MyRingPtr, NumBd2, &MySet2),
+ * XEmacPs_BdRingToHw(MyRingPtr, NumBd2, MySet2),
+ * * Not legal *
+ * </pre>
+ * Use the API defined in xemacps_bd.h to modify individual BDs. Traversal
+ * of the BD set can be done using XEmacPs_BdRingNext() and
+ * XEmacPs_BdRingPrev().
+ * @param RingPtr is a pointer to the BD ring instance to be worked on.
+ * @param NumBd is the number of BDs to allocate
+ * @param BdSetPtr is an output parameter, it points to the first BD available
+ * for modification.
+ * @return
+ * - XST_SUCCESS if the requested number of BDs was returned in the BdSetPtr
+ * parameter.
+ * - XST_FAILURE if there were not enough free BDs to satisfy the request.
+ * @note This function should not be preempted by another XEmacPs_Bd function
+ * call that modifies the BD space. It is the caller's responsibility to
+ * provide a mutual exclusion mechanism.
+ * @note Do not modify more BDs than the number requested with the NumBd
+ * parameter. Doing so will lead to data corruption and system
+ * instability.
+LONG XEmacPs_BdRingAlloc(XEmacPs_BdRing * RingPtr, u32 NumBd,
+ XEmacPs_Bd ** BdSetPtr)
+ LONG Status;
+ /* Enough free BDs available for the request? */
+ if (RingPtr->FreeCnt < NumBd) {
+ Status = (LONG)(XST_FAILURE);
+ } else {
+ /* Set the return argument and move FreeHead forward */
+ *BdSetPtr = RingPtr->FreeHead;
+ XEMACPS_RING_SEEKAHEAD(RingPtr, RingPtr->FreeHead, NumBd);
+ RingPtr->FreeCnt -= NumBd;
+ RingPtr->PreCnt += NumBd;
+ Status = (LONG)(XST_SUCCESS);
+ return Status;
+ * Fully or partially undo an XEmacPs_BdRingAlloc() operation. Use this
+ * function if all the BDs allocated by XEmacPs_BdRingAlloc() could not be
+ * transferred to hardware with XEmacPs_BdRingToHw().
+ * This function helps out in situations when an unrelated error occurs after
+ * BDs have been allocated but before they have been given to hardware.
+ * An example of this type of error would be an OS running out of resources.
+ * This function is not the same as XEmacPs_BdRingFree(). The Free function
+ * returns BDs to the free list after they have been processed by hardware,
+ * while UnAlloc returns them before being processed by hardware.
+ * There are two scenarios where this function can be used. Full UnAlloc or
+ * Partial UnAlloc. A Full UnAlloc means all the BDs Alloc'd will be returned:
+ * <pre>
+ * Status = XEmacPs_BdRingAlloc(MyRingPtr, 10, &BdPtr),
+ * if (Error)
+ * Status = XEmacPs_BdRingUnAlloc(MyRingPtr, 10, &BdPtr),
+ * </pre>
+ * A partial UnAlloc means some of the BDs Alloc'd will be returned:
+ * <pre>
+ * BdsLeft = 10,
+ * CurBdPtr = BdPtr,
+ * while (BdsLeft)
+ * if (Error)
+ * Status = XEmacPs_BdRingUnAlloc(MyRingPtr, BdsLeft, CurBdPtr),
+ * CurBdPtr = XEmacPs_BdRingNext(MyRingPtr, CurBdPtr),
+ * BdsLeft--,
+ * </pre>
+ * A partial UnAlloc must include the last BD in the list that was Alloc'd.
+ * @param RingPtr is a pointer to the instance to be worked on.
+ * @return
+ * - XST_SUCCESS if the BDs were unallocated.
+ * - XST_FAILURE if NumBd parameter was greater that the number of BDs in
+ * the preprocessing state.
+LONG XEmacPs_BdRingUnAlloc(XEmacPs_BdRing * RingPtr, u32 NumBd,
+ XEmacPs_Bd * BdSetPtr)
+ LONG Status;
+ (void) BdSetPtr;
+ Xil_AssertNonvoid(RingPtr != NULL);
+ Xil_AssertNonvoid(BdSetPtr != NULL);
+ /* Enough BDs in the free state for the request? */
+ if (RingPtr->PreCnt < NumBd) {
+ } else {
+ /* Set the return argument and move FreeHead backward */
+ XEMACPS_RING_SEEKBACK(RingPtr, (RingPtr->FreeHead), NumBd);
+ RingPtr->FreeCnt += NumBd;
+ RingPtr->PreCnt -= NumBd;
+ return Status;
+ * Enqueue a set of BDs to hardware that were previously allocated by
+ * XEmacPs_BdRingAlloc(). Once this function returns, the argument BD set goes
+ * under hardware control. Any changes made to these BDs after this point will
+ * corrupt the BD list leading to data corruption and system instability.
+ * The set will be rejected if the last BD of the set does not mark the end of
+ * a packet (see XEmacPs_BdSetLast()).
+ * @param NumBd is the number of BDs in the set.
+ * @param BdSetPtr is the first BD of the set to commit to hardware.
+ * @return
+ * - XST_SUCCESS if the set of BDs was accepted and enqueued to hardware.
+ * - XST_FAILURE if the set of BDs was rejected because the last BD of the set
+ * did not have its "last" bit set.
+ * - XST_DMA_SG_LIST_ERROR if this function was called out of sequence with
+LONG XEmacPs_BdRingToHw(XEmacPs_BdRing * RingPtr, u32 NumBd,
+ XEmacPs_Bd *CurBdPtr;
+ u32 i;
+ LONG Status;
+ /* if no bds to process, simply return. */
+ if (0U == NumBd){
+ } else {
+ /* Make sure we are in sync with XEmacPs_BdRingAlloc() */
+ if ((RingPtr->PreCnt < NumBd) || (RingPtr->PreHead != BdSetPtr)) {
+ Status = (LONG)(XST_DMA_SG_LIST_ERROR);
+ } else {
+ CurBdPtr = BdSetPtr;
+ for (i = 0U; i < NumBd; i++) {
+ CurBdPtr = (XEmacPs_Bd *)((void *)XEmacPs_BdRingNext(RingPtr, CurBdPtr));
+ /* Adjust ring pointers & counters */
+ XEMACPS_RING_SEEKAHEAD(RingPtr, RingPtr->PreHead, NumBd);
+ RingPtr->HwTail = CurBdPtr;
+ RingPtr->HwCnt += NumBd;
+ return Status;
+ * Returns a set of BD(s) that have been processed by hardware. The returned
+ * BDs may be examined to determine the outcome of the DMA transaction(s).
+ * Once the BDs have been examined, the user must call XEmacPs_BdRingFree()
+ * in the same order which they were retrieved here. Example:
+ * <pre>
+ * NumBd = XEmacPs_BdRingFromHwTx(MyRingPtr, MaxBd, &MyBdSet),
+ * if (NumBd == 0)
+ * * hardware has nothing ready for us yet*
+ * * Examine CurBd for post processing *.....
+ * XEmacPs_BdRingFree(MyRingPtr, NumBd, MyBdSet), *Return list*
+ * </pre>
+ * They must be retrieved from hardware and freed in the correct sequence:
+ * <pre>
+ * * Legal *
+ * XEmacPs_BdRingFromHwTx(MyRingPtr, NumBd1, &MySet1),
+ * XEmacPs_BdRingFree(MyRingPtr, NumBd1, MySet1),
+ * * Legal *
+ * XEmacPs_BdRingFromHwTx(MyRingPtr, NumBd2, &MySet2),
+ * XEmacPs_BdRingFree(MyRingPtr, NumBd2, MySet2),
+ * * Not legal *
+ * </pre>
+ * If hardware has only partially completed a packet spanning multiple BDs,
+ * then none of the BDs for that packet will be included in the results.
+ * @param BdLimit is the maximum number of BDs to return in the set.
+ * for examination.
+ * @return
+ * The number of BDs processed by hardware. A value of 0 indicates that no
+ * data is available. No more than BdLimit BDs will be returned.
+ * @note Treat BDs returned by this function as read-only.
+u32 XEmacPs_BdRingFromHwTx(XEmacPs_BdRing * RingPtr, u32 BdLimit,
+ u32 BdStr = 0U;
+ u32 BdCount;
+ u32 BdPartialCount;
+ u32 Sop = 0U;
+ u32 Status;
+ u32 BdLimitLoc = BdLimit;
+ CurBdPtr = RingPtr->HwHead;
+ BdCount = 0U;
+ BdPartialCount = 0U;
+ /* If no BDs in work group, then there's nothing to search */
+ if (RingPtr->HwCnt == 0x00000000U) {
+ *BdSetPtr = NULL;
+ Status = 0U;
+ } else {
+ if (BdLimitLoc > RingPtr->HwCnt){
+ BdLimitLoc = RingPtr->HwCnt;
+ /* Starting at HwHead, keep moving forward in the list until:
+ * - A BD is encountered with its new/used bit set which means
+ * hardware has not completed processing of that BD.
+ * - RingPtr->HwTail is reached and RingPtr->HwCnt is reached.
+ * - The number of requested BDs has been processed
+ while (BdCount < BdLimitLoc) {
+ /* Read the status */
+ if(CurBdPtr != NULL){
+ BdStr = XEmacPs_BdRead(CurBdPtr, XEMACPS_BD_STAT_OFFSET);
+ if ((Sop == 0x00000000U) && ((BdStr & XEMACPS_TXBUF_USED_MASK)!=0x00000000U)){
+ Sop = 1U;
+ if (Sop == 0x00000001U) {
+ BdCount++;
+ BdPartialCount++;
+ /* hardware has processed this BD so check the "last" bit.
+ * If it is clear, then there are more BDs for the current
+ * packet. Keep a count of these partial packet BDs.
+ if ((Sop == 0x00000001U) && ((BdStr & XEMACPS_TXBUF_LAST_MASK)!=0x00000000U)) {
+ Sop = 0U;
+ /* Move on to next BD in work group */
+ CurBdPtr = XEmacPs_BdRingNext(RingPtr, CurBdPtr);
+ /* Subtract off any partial packet BDs found */
+ BdCount -= BdPartialCount;
+ /* If BdCount is non-zero then BDs were found to return. Set return
+ * parameters, update pointers and counters, return success
+ if (BdCount > 0x00000000U) {
+ *BdSetPtr = RingPtr->HwHead;
+ RingPtr->HwCnt -= BdCount;
+ RingPtr->PostCnt += BdCount;
+ XEMACPS_RING_SEEKAHEAD(RingPtr, RingPtr->HwHead, BdCount);
+ Status = (BdCount);
+ } else {
+ *BdSetPtr = NULL;
+ Status = 0U;
+ return Status;
+ * <pre>
+ * NumBd = XEmacPs_BdRingFromHwRx(MyRingPtr, MaxBd, &MyBdSet),
+ * if (NumBd == 0)
+ * *hardware has nothing ready for us yet*
+ * XEmacPs_BdRingFree(MyRingPtr, NumBd, MyBdSet), * Return list *
+ * </pre>
+ * <pre>
+ * * Legal *
+ * XEmacPs_BdRingFromHwRx(MyRingPtr, NumBd1, &MySet1),
+ * * Legal *
+ * XEmacPs_BdRingFromHwRx(MyRingPtr, NumBd2, &MySet2),
+ * * Not legal *
+ * </pre>
+ * @return
+u32 XEmacPs_BdRingFromHwRx(XEmacPs_BdRing * RingPtr, u32 BdLimit,
+ u32 BdStr = 0U;
+ u32 BdCount;
+ u32 Status;
+ BdCount = 0U;
+ *BdSetPtr = NULL;
+ Status = 0U;
+ } else {
+ * hardware has completed processing of that BD.
+ while (BdCount < BdLimit) {
+ if(CurBdPtr!=NULL){
+ if ((!(XEmacPs_BdIsRxNew(CurBdPtr)))==TRUE) {
+ break;
+ BdCount++;
+ /* hardware has processed this BD so check the "last" bit. If
+ * it is clear, then there are more BDs for the current packet.
+ * Keep a count of these partial packet BDs.
+ if ((BdStr & XEMACPS_RXBUF_EOF_MASK)!=0x00000000U) {
+ } else {
+ BdPartialCount++;
+ else {
+ *BdSetPtr = NULL;
+ Status = 0U;
+ return Status;
+ * Frees a set of BDs that had been previously retrieved with
+ * XEmacPs_BdRingFromHw().
+ * @param NumBd is the number of BDs to free.
+ * @param BdSetPtr is the head of a list of BDs returned by
+ * @return
+ * - XST_SUCCESS if the set of BDs was freed.
+LONG XEmacPs_BdRingFree(XEmacPs_BdRing * RingPtr, u32 NumBd,
+ LONG Status;
+ if (0x00000000U == NumBd){
+ } else {
+ /* Make sure we are in sync with XEmacPs_BdRingFromHw() */
+ if ((RingPtr->PostCnt < NumBd) || (RingPtr->PostHead != BdSetPtr)) {
+ } else {
+ /* Update pointers and counters */
+ RingPtr->PostCnt -= NumBd;
+ XEMACPS_RING_SEEKAHEAD(RingPtr, RingPtr->PostHead, NumBd);
+ return Status;
+ * Check the internal data structures of the BD ring for the provided channel.
+ * The following checks are made:
+ * - Is the BD ring linked correctly in physical address space.
+ * - Do the internal pointers point to BDs in the ring.
+ * - Do the internal counters add up.
+ * The channel should be stopped prior to calling this function.
+ * @return
+ * - XST_DMA_SG_NO_LIST if the list has not been created.
+ * - XST_IS_STARTED if the channel is not stopped.
+ * - XST_DMA_SG_LIST_ERROR if a problem is found with the internal data
+ * structures. If this value is returned, the channel should be reset to
+ * avoid data corruption or system instability.
+LONG XEmacPs_BdRingCheck(XEmacPs_BdRing * RingPtr, u8 Direction)
+ UINTPTR AddrV, AddrP;
+ u32 i;
+ /* Is the list created */
+ /* Can't check if channel is running */
+ return (LONG)(XST_IS_STARTED);
+ /* RunState doesn't make sense */
+ if (RingPtr->RunState != (u32)XST_DMA_SG_IS_STOPPED) {
+ /* Verify internal pointers point to correct memory space */
+ AddrV = (UINTPTR) RingPtr->FreeHead;
+ if ((AddrV < RingPtr->BaseBdAddr) || (AddrV > RingPtr->HighBdAddr)) {
+ AddrV = (UINTPTR) RingPtr->PreHead;
+ AddrV = (UINTPTR) RingPtr->HwHead;
+ AddrV = (UINTPTR) RingPtr->HwTail;
+ AddrV = (UINTPTR) RingPtr->PostHead;
+ /* Verify internal counters add up */
+ if ((RingPtr->HwCnt + RingPtr->PreCnt + RingPtr->FreeCnt +
+ RingPtr->PostCnt) != RingPtr->AllCnt) {
+ /* Verify BDs are linked correctly */
+ AddrV = RingPtr->BaseBdAddr;
+ AddrP = RingPtr->PhysBaseAddr + RingPtr->Separation;
+ for (i = 1U; i < RingPtr->AllCnt; i++) {
+ /* Check BDA for this BD. It should point to next physical addr */
+ if (XEmacPs_BdRead(AddrV, XEMACPS_BD_ADDR_OFFSET) != AddrP) {
+ /* Move on to next BD */
+ AddrV += RingPtr->Separation;
+ AddrP += RingPtr->Separation;
+ /* Last BD should have wrap bit set */
+ if (XEMACPS_SEND == Direction) {
+ if ((!XEmacPs_BdIsTxWrap(AddrV))==TRUE) {
+ else { /* XEMACPS_RECV */
+ if ((!XEmacPs_BdIsRxWrap(AddrV))==TRUE) {
+ /* No problems found */
+ return (LONG)(XST_SUCCESS);
+ * list.
+ * @note
+ u32 DataValueRx;
+ u32 *TempPtr;
+ BdPtr += (u32)(XEMACPS_BD_ADDR_OFFSET);
+ TempPtr = (u32 *)BdPtr;
+ if(TempPtr != NULL) {
+ DataValueRx = *TempPtr;
+ DataValueRx |= XEMACPS_RXBUF_WRAP_MASK;
+ *TempPtr = DataValueRx;
+ * @note
+ u32 DataValueTx;
+ u32 *TempPtr;
+ BdPtr += (u32)(XEMACPS_BD_STAT_OFFSET);
+ DataValueTx = *TempPtr;
+ DataValueTx |= XEMACPS_TXBUF_WRAP_MASK;
+ *TempPtr = DataValueTx;
+ * Reset BD ring head and tail pointers.
+ * @param virtaddrloc is the virtual base address of the user memory region.
+ * @note
+ * Should be called after XEmacPs_Stop()
+ * @note
+ * void XEmacPs_BdRingPtrReset(XEmacPs_BdRing * RingPtr, void *virtaddrloc)
+void XEmacPs_BdRingPtrReset(XEmacPs_BdRing * RingPtr, void *virtaddrloc)
+ RingPtr->FreeHead = virtaddrloc;
+ RingPtr->PreHead = virtaddrloc;
+ RingPtr->HwHead = virtaddrloc;
+ RingPtr->HwTail = virtaddrloc;
+ RingPtr->PostHead = virtaddrloc;
diff --git a/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.h b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.h
index 0000000..f5653db
--- /dev/null
+++ b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.h
@@ -0,0 +1,215 @@
+* Copyright (C) 2010 - 2020 Xilinx, Inc. All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xemacps_bdring.h
+* @addtogroup emacps_v3_16
+* The Xiline EmacPs Buffer Descriptor ring driver. This is part of EmacPs
+* DMA functionalities.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver Who Date Changes
+* 1.00a wsy 01/10/10 First release
+* 3.6 rb 09/08/17 HwCnt variable (in XEmacPs_BdRing structure) is
+* changed to volatile.
+* </pre>
+#ifndef XEMACPS_BDRING_H /* prevent curcular inclusions */
+#define XEMACPS_BDRING_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+/**************************** Type Definitions *******************************/
+/** This is an internal structure used to maintain the DMA list */
+typedef struct {
+ UINTPTR PhysBaseAddr;/**< Physical address of 1st BD in list */
+ UINTPTR BaseBdAddr; /**< Virtual address of 1st BD in list */
+ UINTPTR HighBdAddr; /**< Virtual address of last BD in the list */
+ u32 Length; /**< Total size of ring in bytes */
+ u32 RunState; /**< Flag to indicate DMA is started */
+ u32 Separation; /**< Number of bytes between the starting address
+ of adjacent BDs */
+ XEmacPs_Bd *FreeHead;
+ /**< First BD in the free group */
+ XEmacPs_Bd *PreHead;/**< First BD in the pre-work group */
+ XEmacPs_Bd *HwHead; /**< First BD in the work group */
+ XEmacPs_Bd *HwTail; /**< Last BD in the work group */
+ XEmacPs_Bd *PostHead;
+ /**< First BD in the post-work group */
+ XEmacPs_Bd *BdaRestart;
+ /**< BDA to load when channel is started */
+ volatile u32 HwCnt; /**< Number of BDs in work group */
+ u32 PreCnt; /**< Number of BDs in pre-work group */
+ u32 FreeCnt; /**< Number of allocatable BDs in the free group */
+ u32 PostCnt; /**< Number of BDs in post-work group */
+ u32 AllCnt; /**< Total Number of BDs for channel */
+} XEmacPs_BdRing;
+/***************** Macros (Inline Functions) Definitions *********************/
+* Use this macro at initialization time to determine how many BDs will fit
+* in a BD list within the given memory constraints.
+* The results of this macro can be provided to XEmacPs_BdRingCreate().
+* @param Alignment specifies what byte alignment the BDs must fall on and
+* must be a power of 2 to get an accurate calculation (32, 64, 128,...)
+* @param Bytes is the number of bytes to be used to store BDs.
+* @return Number of BDs that can fit in the given memory area
+* @note
+* u32 XEmacPs_BdRingCntCalc(u32 Alignment, u32 Bytes)
+#define XEmacPs_BdRingCntCalc(Alignment, Bytes) \
+ (u32)((Bytes) / (sizeof(XEmacPs_Bd)))
+* Use this macro at initialization time to determine how many bytes of memory
+* is required to contain a given number of BDs at a given alignment.
+* @param Alignment specifies what byte alignment the BDs must fall on. This
+* parameter must be a power of 2 to get an accurate calculation (32, 64,
+* 128,...)
+* @param NumBd is the number of BDs to calculate memory size requirements for
+* @return The number of bytes of memory required to create a BD list with the
+* given memory constraints.
+* @note
+* u32 XEmacPs_BdRingMemCalc(u32 Alignment, u32 NumBd)
+#define XEmacPs_BdRingMemCalc(Alignment, NumBd) \
+ (u32)(sizeof(XEmacPs_Bd) * (NumBd))
+* Return the total number of BDs allocated by this channel with
+* XEmacPs_BdRingCreate().
+* @param RingPtr is the DMA channel to operate on.
+* @return The total number of BDs allocated for this channel.
+* @note
+* u32 XEmacPs_BdRingGetCnt(XEmacPs_BdRing* RingPtr)
+#define XEmacPs_BdRingGetCnt(RingPtr) ((RingPtr)->AllCnt)
+* Return the number of BDs allocatable with XEmacPs_BdRingAlloc() for pre-
+* processing.
+* @return The number of BDs currently allocatable.
+* @note
+* u32 XEmacPs_BdRingGetFreeCnt(XEmacPs_BdRing* RingPtr)
+#define XEmacPs_BdRingGetFreeCnt(RingPtr) ((RingPtr)->FreeCnt)
+* Return the next BD from BdPtr in a list.
+* @param BdPtr is the BD to operate on.
+* @return The next BD in the list relative to the BdPtr parameter.
+* @note
+* XEmacPs_Bd *XEmacPs_BdRingNext(XEmacPs_BdRing* RingPtr,
+* XEmacPs_Bd *BdPtr)
+#define XEmacPs_BdRingNext(RingPtr, BdPtr) \
+ (((UINTPTR)((void *)(BdPtr)) >= (RingPtr)->HighBdAddr) ? \
+ (XEmacPs_Bd*)((void*)(RingPtr)->BaseBdAddr) : \
+ (XEmacPs_Bd*)((UINTPTR)((void *)(BdPtr)) + (RingPtr)->Separation))
+* Return the previous BD from BdPtr in the list.
+* @return The previous BD in the list relative to the BdPtr parameter.
+* @note
+* XEmacPs_Bd *XEmacPs_BdRingPrev(XEmacPs_BdRing* RingPtr,
+#define XEmacPs_BdRingPrev(RingPtr, BdPtr) \
+ (((UINTPTR)(BdPtr) <= (RingPtr)->BaseBdAddr) ? \
+ (XEmacPs_Bd*)(RingPtr)->HighBdAddr : \
+ (XEmacPs_Bd*)((UINTPTR)(BdPtr) - (RingPtr)->Separation))
+/************************** Function Prototypes ******************************/
+ * Scatter gather DMA related functions in xemacps_bdring.c
+ UINTPTR VirtAddr, u32 Alignment, u32 BdCount);
+ u8 Direction);
+ XEmacPs_Bd ** BdSetPtr);
+ XEmacPs_Bd * BdSetPtr);
+LONG XEmacPs_BdRingCheck(XEmacPs_BdRing * RingPtr, u8 Direction);
+void XEmacPs_BdRingPtrReset(XEmacPs_BdRing * RingPtr, void *virtaddrloc);
+#ifdef __cplusplus
+#endif
+#endif /* end of protection macros */
diff --git a/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_control.c b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_control.c
index 0000000..4c72f20
--- /dev/null
+++ b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_control.c
@@ -0,0 +1,1133 @@
+* Copyright (C) 2009 - 2020 Xilinx, Inc. All rights reserved.
+ * @file xemacps_control.c
+ * Functions in this file implement general purpose command and control related
+ * functionality. See xemacps.h for a detailed description of the driver.
+ * <pre>
+ * register. Added a new API for setting the BURST length
+ * in DMACR register.
+ * 2.1 srt 07/15/14 Add support for Zynq Ultrascale Mp architecture.
+ * </pre>
+/***************************** Include Files *********************************/
+#include "xemacps.h"
+/************************** Constant Definitions *****************************/
+/************************** Variable Definitions *****************************/
+ * Set the MAC address for this driver/device. The address is a 48-bit value.
+ * The device must be stopped before calling this function.
+ * @param InstancePtr is a pointer to the instance to be worked on.
+ * @param AddressPtr is a pointer to a 6-byte MAC address.
+ * @param Index is a index to which MAC (1-4) address.
+ * @return
+ * - XST_SUCCESS if the MAC address was set successfully
+ * - XST_DEVICE_IS_STARTED if the device has not yet been stopped
+ u32 MacAddr;
+ u8 *Aptr = (u8 *)(void *)AddressPtr;
+ u8 IndexLoc = Index;
+ LONG Status;
+ Xil_AssertNonvoid(InstancePtr != NULL);
+ Xil_AssertNonvoid(Aptr != NULL);
+ Xil_AssertNonvoid(InstancePtr->IsReady == (u32)XIL_COMPONENT_IS_READY);
+ Xil_AssertNonvoid((IndexLoc <= (u8)XEMACPS_MAX_MAC_ADDR) && (IndexLoc > 0x00U));
+ /* Be sure device has been stopped */
+ if (InstancePtr->IsStarted == (u32)XIL_COMPONENT_IS_STARTED) {
+ Status = (LONG)(XST_DEVICE_IS_STARTED);
+ else{
+ /* Index ranges 1 to 4, for offset calculation is 0 to 3. */
+ IndexLoc--;
+ /* Set the MAC bits [31:0] in BOT */
+ MacAddr = *(Aptr);
+ MacAddr |= ((u32)(*(Aptr+1)) << 8U);
+ MacAddr |= ((u32)(*(Aptr+2)) << 16U);
+ MacAddr |= ((u32)(*(Aptr+3)) << 24U);
+ XEmacPs_WriteReg(InstancePtr->Config.BaseAddress,
+ ((u32)XEMACPS_LADDR1L_OFFSET + ((u32)IndexLoc * (u32)8)), MacAddr);
+ /* There are reserved bits in TOP so don't affect them */
+ MacAddr = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ ((u32)XEMACPS_LADDR1H_OFFSET + ((u32)IndexLoc * (u32)8)));
+ MacAddr &= (u32)(~XEMACPS_LADDR_MACH_MASK);
+ /* Set MAC bits [47:32] in TOP */
+ MacAddr |= (u32)(*(Aptr+4));
+ MacAddr |= (u32)(*(Aptr+5)) << 8U;
+ ((u32)XEMACPS_LADDR1H_OFFSET + ((u32)IndexLoc * (u32)8)), MacAddr);
+ return Status;
+ * Get the MAC address for this driver/device.
+ * @param AddressPtr is an output parameter, and is a pointer to a buffer into
+ * which the current MAC address will be copied.
+ u32 MacAddr;
+ Xil_AssertVoid(InstancePtr != NULL);
+ Xil_AssertVoid(Aptr != NULL);
+ Xil_AssertVoid(InstancePtr->IsReady == (u32)XIL_COMPONENT_IS_READY);
+ Xil_AssertVoid((IndexLoc <= (u8)XEMACPS_MAX_MAC_ADDR) && (IndexLoc > 0x00U));
+ IndexLoc--;
+ ((u32)XEMACPS_LADDR1L_OFFSET + ((u32)IndexLoc * (u32)8)));
+ *Aptr = (u8) MacAddr;
+ *(Aptr+1) = (u8) (MacAddr >> 8U);
+ *(Aptr+2) = (u8) (MacAddr >> 16U);
+ *(Aptr+3) = (u8) (MacAddr >> 24U);
+ /* Read MAC bits [47:32] in TOP */
+ *(Aptr+4) = (u8) MacAddr;
+ *(Aptr+5) = (u8) (MacAddr >> 8U);
+ * Set 48-bit MAC addresses in hash table.
+ * The hash address register is 64 bits long and takes up two locations in
+ * the memory map. The least significant bits are stored in hash register
+ * bottom and the most significant bits in hash register top.
+ * The unicast hash enable and the multicast hash enable bits in the network
+ * configuration register enable the reception of hash matched frames. The
+ * destination address is reduced to a 6 bit index into the 64 bit hash
+ * register using the following hash function. The hash function is an XOR
+ * of every sixth bit of the destination address.
+ * <pre>
+ * hash_index[05] = da[05]^da[11]^da[17]^da[23]^da[29]^da[35]^da[41]^da[47]
+ * hash_index[04] = da[04]^da[10]^da[16]^da[22]^da[28]^da[34]^da[40]^da[46]
+ * hash_index[03] = da[03]^da[09]^da[15]^da[21]^da[27]^da[33]^da[39]^da[45]
+ * hash_index[02] = da[02]^da[08]^da[14]^da[20]^da[26]^da[32]^da[38]^da[44]
+ * hash_index[01] = da[01]^da[07]^da[13]^da[19]^da[25]^da[31]^da[37]^da[43]
+ * hash_index[00] = da[00]^da[06]^da[12]^da[18]^da[24]^da[30]^da[36]^da[42]
+ * </pre>
+ * da[0] represents the least significant bit of the first byte received,
+ * that is, the multicast/unicast indicator, and da[47] represents the most
+ * significant bit of the last byte received.
+ * If the hash index points to a bit that is set in the hash register then
+ * the frame will be matched according to whether the frame is multicast
+ * or unicast.
+ * A multicast match will be signaled if the multicast hash enable bit is
+ * set, da[0] is logic 1 and the hash index points to a bit set in the hash
+ * register.
+ * A unicast match will be signaled if the unicast hash enable bit is set,
+ * da[0] is logic 0 and the hash index points to a bit set in the hash
+ * register.
+ * To receive all multicast frames, the hash register should be set with
+ * all ones and the multicast hash enable bit should be set in the network
+ * configuration register.
+ * @return
+ * - XST_SUCCESS if the HASH MAC address was set successfully
+ * - XST_INVALID_PARAM if the HASH MAC address passed in does not meet
+ * requirement after calculation
+ * @note
+ * Having Aptr be unsigned type prevents the following operations from sign
+ * extending.
+ u32 HashAddr;
+ u8 Temp1, Temp2, Temp3, Temp4, Temp5, Temp6, Temp7, Temp8;
+ u32 Result;
+ LONG Status;
+ Xil_AssertNonvoid(AddressPtr != NULL);
+ } else {
+ Temp1 = (*(Aptr+0)) & 0x3FU;
+ Temp2 = ((*(Aptr+0) >> 6U) & 0x03U) | ((*(Aptr+1) & 0x0FU) << 2U);
+ Temp3 = ((*(Aptr+1) >> 4U) & 0x0FU) | ((*(Aptr+2) & 0x3U) << 4U);
+ Temp4 = ((*(Aptr+2) >> 2U) & 0x3FU);
+ Temp5 = (*(Aptr+3)) & 0x3FU;
+ Temp6 = ((*(Aptr+3) >> 6U) & 0x03U) | ((*(Aptr+4) & 0x0FU) << 2U);
+ Temp7 = ((*(Aptr+4) >> 4U) & 0x0FU) | ((*(Aptr+5) & 0x03U) << 4U);
+ Temp8 = ((*(Aptr+5) >> 2U) & 0x3FU);
+ Result = (u32)((u32)Temp1 ^ (u32)Temp2 ^ (u32)Temp3 ^ (u32)Temp4 ^
+ (u32)Temp5 ^ (u32)Temp6 ^ (u32)Temp7 ^ (u32)Temp8);
+ if (Result >= (u32)XEMACPS_MAX_HASH_BITS) {
+ Status = (LONG)(XST_INVALID_PARAM);
+ } else {
+ if (Result < (u32)32) {
+ HashAddr = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_HASHL_OFFSET);
+ HashAddr |= (u32)(0x00000001U << Result);
+ XEMACPS_HASHL_OFFSET, HashAddr);
+ } else {
+ XEMACPS_HASHH_OFFSET);
+ HashAddr |= (u32)(0x00000001U << (u32)(Result - (u32)32));
+ XEMACPS_HASHH_OFFSET, HashAddr);
+ return Status;
+ * Delete 48-bit MAC addresses in hash table.
+ * @return
+ * - XST_SUCCESS if the HASH MAC address was deleted successfully
+ * @note
+ * extending.
+ u32 HashAddr;
+ u32 Result;
+ LONG Status;
+ } else {
+ Temp3 = ((*(Aptr+1) >> 4U) & 0x0FU) | ((*(Aptr+2) & 0x03U) << 4U);
+ if (Result >= (u32)(XEMACPS_MAX_HASH_BITS)) {
+ } else {
+ HashAddr &= (u32)(~(0x00000001U << Result));
+ } else {
+ HashAddr &= (u32)(~(0x00000001U << (u32)(Result - (u32)32)));
+ return Status;
+ * Clear the Hash registers for the mac address pointed by AddressPtr.
+ XEMACPS_HASHL_OFFSET, 0x0U);
+ /* write bits [63:32] in TOP */
+ XEMACPS_HASHH_OFFSET, 0x0U);
+ * Get the Hash address for this driver/device.
+ * which the current HASH MAC address will be copied.
+ u32 *Aptr = (u32 *)(void *)AddressPtr;
+ Xil_AssertVoid(AddressPtr != NULL);
+ *(Aptr+0) = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ /* Read Hash bits [63:32] in TOP */
+ *(Aptr+1) = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ * Set the Type ID match for this driver/device. The register is a 32-bit
+ * value. The device must be stopped before calling this function.
+ * @param Id_Check is type ID to be configured.
+ * @param Index is a index to which Type ID (1-4).
+ * @return
+ LONG Status;
+ Xil_AssertNonvoid((IndexLoc <= (u8)XEMACPS_MAX_TYPE_ID) && (IndexLoc > 0x00U));
+ } else {
+ IndexLoc--;
+ /* Set the ID bits in MATCHx register */
+ ((u32)XEMACPS_MATCH1_OFFSET + ((u32)IndexLoc * (u32)4)), Id_Check);
+ return Status;
+ * Set options for the driver/device. The driver should be stopped with
+ * XEmacPs_Stop() before changing options.
+ * @param Options are the options to set. Multiple options can be set by OR'ing
+ * XTE_*_OPTIONS constants together. Options not specified are not
+ * affected.
+ * @return
+ * - XST_SUCCESS if the options were set successfully
+ * @note
+ * See xemacps.h for a description of the available options.
+ u32 Reg; /* Generic register contents */
+ u32 RegNetCfg; /* Reflects original contents of NET_CONFIG */
+ u32 RegNewNetCfg; /* Reflects new contents of NET_CONFIG */
+ LONG Status;
+ } else {
+ /* Many of these options will change the NET_CONFIG registers.
+ * To reduce the amount of IO to the device, group these options here
+ * and change them all at once.
+ /* Grab current register contents */
+ RegNetCfg = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_NWCFG_OFFSET);
+ RegNewNetCfg = RegNetCfg;
+ * It is configured to max 1536.
+ if ((Options & XEMACPS_FRAME1536_OPTION) != 0x00000000U) {
+ RegNewNetCfg |= (XEMACPS_NWCFG_1536RXEN_MASK);
+ /* Turn on VLAN packet only, only VLAN tagged will be accepted */
+ if ((Options & XEMACPS_VLAN_OPTION) != 0x00000000U) {
+ RegNewNetCfg |= XEMACPS_NWCFG_NVLANDISC_MASK;
+ /* Turn on FCS stripping on receive packets */
+ if ((Options & XEMACPS_FCS_STRIP_OPTION) != 0x00000000U) {
+ RegNewNetCfg |= XEMACPS_NWCFG_FCSREM_MASK;
+ /* Turn on length/type field checking on receive packets */
+ if ((Options & XEMACPS_LENTYPE_ERR_OPTION) != 0x00000000U) {
+ RegNewNetCfg |= XEMACPS_NWCFG_LENERRDSCRD_MASK;
+ /* Turn on flow control */
+ if ((Options & XEMACPS_FLOW_CONTROL_OPTION) != 0x00000000U) {
+ RegNewNetCfg |= XEMACPS_NWCFG_PAUSEEN_MASK;
+ /* Turn on promiscuous frame filtering (all frames are received) */
+ if ((Options & XEMACPS_PROMISC_OPTION) != 0x00000000U) {
+ RegNewNetCfg |= XEMACPS_NWCFG_COPYALLEN_MASK;
+ /* Allow broadcast address reception */
+ if ((Options & XEMACPS_BROADCAST_OPTION) != 0x00000000U) {
+ RegNewNetCfg &= (u32)(~XEMACPS_NWCFG_BCASTDI_MASK);
+ /* Allow multicast address filtering */
+ if ((Options & XEMACPS_MULTICAST_OPTION) != 0x00000000U) {
+ RegNewNetCfg |= XEMACPS_NWCFG_MCASTHASHEN_MASK;
+ /* enable RX checksum offload */
+ if ((Options & XEMACPS_RX_CHKSUM_ENABLE_OPTION) != 0x00000000U) {
+ RegNewNetCfg |= XEMACPS_NWCFG_RXCHKSUMEN_MASK;
+ /* Enable jumbo frames */
+ if (((Options & XEMACPS_JUMBO_ENABLE_OPTION) != 0x00000000U) &&
+ (InstancePtr->Version > 2)) {
+ RegNewNetCfg |= XEMACPS_NWCFG_JUMBO_MASK;
+ XEMACPS_JUMBOMAXLEN_OFFSET, XEMACPS_RX_BUF_SIZE_JUMBO);
+ Reg = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_DMACR_OFFSET);
+ Reg &= ~XEMACPS_DMACR_RXBUF_MASK;
+ Reg |= (((((u32)XEMACPS_RX_BUF_SIZE_JUMBO / (u32)XEMACPS_RX_BUF_UNIT) +
+ (((((u32)XEMACPS_RX_BUF_SIZE_JUMBO %
+ (u32)XEMACPS_RX_BUF_UNIT))!=(u32)0) ? 1U : 0U)) <<
+ (u32)(XEMACPS_DMACR_RXBUF_SHIFT)) &
+ (u32)(XEMACPS_DMACR_RXBUF_MASK));
+ XEMACPS_DMACR_OFFSET, Reg);
+ InstancePtr->MaxMtuSize = XEMACPS_MTU_JUMBO;
+ InstancePtr->MaxFrameSize = XEMACPS_MTU_JUMBO +
+ XEMACPS_HDR_SIZE + XEMACPS_TRL_SIZE;
+ InstancePtr->MaxVlanFrameSize = InstancePtr->MaxFrameSize +
+ XEMACPS_HDR_VLAN_SIZE;
+ InstancePtr->RxBufMask = XEMACPS_RXBUF_LEN_JUMBO_MASK;
+ if (((Options & XEMACPS_SGMII_ENABLE_OPTION) != 0x00000000U) &&
+ RegNewNetCfg |= (XEMACPS_NWCFG_SGMIIEN_MASK |
+ XEMACPS_NWCFG_PCSSEL_MASK);
+ /* Officially change the NET_CONFIG registers if it needs to be
+ * modified.
+ if (RegNetCfg != RegNewNetCfg) {
+ XEMACPS_NWCFG_OFFSET, RegNewNetCfg);
+ /* Enable TX checksum offload */
+ if ((Options & XEMACPS_TX_CHKSUM_ENABLE_OPTION) != 0x00000000U) {
+ Reg |= XEMACPS_DMACR_TCPCKSUM_MASK;
+ /* Enable transmitter */
+ if ((Options & XEMACPS_TRANSMITTER_ENABLE_OPTION) != 0x00000000U) {
+ XEMACPS_NWCTRL_OFFSET);
+ Reg |= XEMACPS_NWCTRL_TXEN_MASK;
+ XEMACPS_NWCTRL_OFFSET, Reg);
+ /* Enable receiver */
+ if ((Options & XEMACPS_RECEIVER_ENABLE_OPTION) != 0x00000000U) {
+ Reg |= XEMACPS_NWCTRL_RXEN_MASK;
+ /* The remaining options not handled here are managed elsewhere in the
+ * driver. No register modifications are needed at this time. Reflecting
+ * the option in InstancePtr->Options is good enough for now.
+ /* Set options word to its new value */
+ InstancePtr->Options |= Options;
+ return Status;
+ * Clear options for the driver/device
+ * @param Options are the options to clear. Multiple options can be cleared by
+ * OR'ing XEMACPS_*_OPTIONS constants together. Options not specified
+ * are not affected.
+ * @return
+ * @note
+ u32 Reg; /* Generic */
+ LONG Status;
+ } else {
+ /* There is only RX configuration!?
+ * It is configured in two different length, up to 1536 and 10240 bytes
+ RegNewNetCfg &= (u32)(~XEMACPS_NWCFG_1536RXEN_MASK);
+ /* Turn off VLAN packet only */
+ RegNewNetCfg &= (u32)(~XEMACPS_NWCFG_NVLANDISC_MASK);
+ /* Turn off FCS stripping on receive packets */
+ RegNewNetCfg &= (u32)(~XEMACPS_NWCFG_FCSREM_MASK);
+ /* Turn off length/type field checking on receive packets */
+ RegNewNetCfg &= (u32)(~XEMACPS_NWCFG_LENERRDSCRD_MASK);
+ /* Turn off flow control */
+ RegNewNetCfg &= (u32)(~XEMACPS_NWCFG_PAUSEEN_MASK);
+ /* Turn off promiscuous frame filtering (all frames are received) */
+ RegNewNetCfg &= (u32)(~XEMACPS_NWCFG_COPYALLEN_MASK);
+ /* Disallow broadcast address filtering => broadcast reception */
+ RegNewNetCfg |= XEMACPS_NWCFG_BCASTDI_MASK;
+ /* Disallow multicast address filtering */
+ RegNewNetCfg &= (u32)(~XEMACPS_NWCFG_MCASTHASHEN_MASK);
+ /* Disable RX checksum offload */
+ RegNewNetCfg &= (u32)(~XEMACPS_NWCFG_RXCHKSUMEN_MASK);
+ /* Disable jumbo frames */
+ RegNewNetCfg &= (u32)(~XEMACPS_NWCFG_JUMBO_MASK);
+ Reg |= (((((u32)XEMACPS_RX_BUF_SIZE / (u32)XEMACPS_RX_BUF_UNIT) +
+ (((((u32)XEMACPS_RX_BUF_SIZE %
+ InstancePtr->MaxMtuSize = XEMACPS_MTU;
+ InstancePtr->MaxFrameSize = XEMACPS_MTU +
+ InstancePtr->RxBufMask = XEMACPS_RXBUF_LEN_MASK;
+ RegNewNetCfg &= (u32)(~(XEMACPS_NWCFG_SGMIIEN_MASK |
+ XEMACPS_NWCFG_PCSSEL_MASK));
+ * modified.
+ /* Disable TX checksum offload */
+ Reg &= (u32)(~XEMACPS_DMACR_TCPCKSUM_MASK);
+ /* Disable transmitter */
+ Reg &= (u32)(~XEMACPS_NWCTRL_TXEN_MASK);
+ /* Disable receiver */
+ Reg &= (u32)(~XEMACPS_NWCTRL_RXEN_MASK);
+ * option in InstancePtr->Options is good enough for now.
+ InstancePtr->Options &= ~Options;
+ return Status;
+ * Get current option settings
+ * @return
+ * A bitmask of XTE_*_OPTION constants. Any bit set to 1 is to be interpreted
+ * as a set option.
+ * @note
+ return (InstancePtr->Options);
+ * Send a pause packet
+ * @return
+ * - XST_SUCCESS if pause frame transmission was initiated
+ * - XST_DEVICE_IS_STOPPED if the device has not been started.
+ u32 Reg;
+ LONG Status;
+ /* Make sure device is ready for this operation */
+ if (InstancePtr->IsStarted != (u32)XIL_COMPONENT_IS_STARTED) {
+ Status = (LONG)(XST_DEVICE_IS_STOPPED);
+ } else {
+ /* Send flow control frame */
+ Reg |= XEMACPS_NWCTRL_PAUSETX_MASK;
+ return Status;
+ * XEmacPs_GetOperatingSpeed gets the current operating link speed. This may
+ * be the value set by XEmacPs_SetOperatingSpeed() or a hardware default.
+ * @param InstancePtr references the TEMAC channel on which to operate.
+ * @return XEmacPs_GetOperatingSpeed returns the link speed in units of
+ * megabits per second.
+ * @note
+ u32 Reg;
+ u16 Status;
+ if ((Reg & XEMACPS_NWCFG_1000_MASK) != 0x00000000U) {
+ Status = (u16)(1000);
+ } else {
+ if ((Reg & XEMACPS_NWCFG_100_MASK) != 0x00000000U) {
+ Status = (u16)(100);
+ } else {
+ Status = (u16)(10);
+ return Status;
+ * XEmacPs_SetOperatingSpeed sets the current operating link speed. For any
+ * traffic to be passed, this speed must match the current MII/GMII/SGMII/RGMII
+ * link speed.
+ * @param Speed is the speed to set in units of Mbps. Valid values are 10, 100,
+ * or 1000. XEmacPs_SetOperatingSpeed ignores invalid values.
+ * @note
+ u32 Reg;
+ Xil_AssertVoid((Speed == (u16)10) || (Speed == (u16)100) || (Speed == (u16)1000));
+ Reg &= (u32)(~(XEMACPS_NWCFG_1000_MASK | XEMACPS_NWCFG_100_MASK));
+ switch (Speed) {
+ case (u16)10:
+ break;
+ case (u16)100:
+ Reg |= XEMACPS_NWCFG_100_MASK;
+ break;
+ case (u16)1000:
+ Reg |= XEMACPS_NWCFG_1000_MASK;
+ break;
+ /* Set register and return */
+ XEMACPS_NWCFG_OFFSET, Reg);
+ * Set the MDIO clock divisor.
+ * Calculating the divisor:
+ * <pre>
+ * f[HOSTCLK]
+ * f[MDC] = -----------------
+ * (1 + Divisor) * 2
+ * </pre>
+ * where f[HOSTCLK] is the bus clock frequency in MHz, and f[MDC] is the
+ * MDIO clock frequency in MHz to the PHY. Typically, f[MDC] should not
+ * exceed 2.5 MHz. Some PHYs can tolerate faster speeds which means faster
+ * access. Here is the table to show values to generate MDC,
+ * <pre>
+ * 000 : divide pclk by 8 (pclk up to 20 MHz)
+ * 001 : divide pclk by 16 (pclk up to 40 MHz)
+ * 010 : divide pclk by 32 (pclk up to 80 MHz)
+ * 011 : divide pclk by 48 (pclk up to 120 MHz)
+ * 100 : divide pclk by 64 (pclk up to 160 MHz)
+ * 101 : divide pclk by 96 (pclk up to 240 MHz)
+ * 110 : divide pclk by 128 (pclk up to 320 MHz)
+ * 111 : divide pclk by 224 (pclk up to 540 MHz)
+ * </pre>
+ * @param Divisor is the divisor to set. Range is 0b000 to 0b111.
+void XEmacPs_SetMdioDivisor(XEmacPs *InstancePtr, XEmacPs_MdcDiv Divisor)
+ u32 Reg;
+ Xil_AssertVoid(Divisor <= (XEmacPs_MdcDiv)0x7); /* only last three bits are valid */
+ /* clear these three bits, could be done with mask */
+ Reg &= (u32)(~XEMACPS_NWCFG_MDCCLKDIV_MASK);
+ Reg |= ((u32)Divisor << XEMACPS_NWCFG_MDC_SHIFT_MASK);
+* Read the current value of the PHY register indicated by the PhyAddress and
+* the RegisterNum parameters. The MAC provides the driver with the ability to
+* talk to a PHY that adheres to the Media Independent Interface (MII) as
+* defined in the IEEE 802.3 standard.
+* Prior to PHY access with this function, the user should have setup the MDIO
+* clock with XEmacPs_SetMdioDivisor().
+* @param InstancePtr is a pointer to the XEmacPs instance to be worked on.
+* @param PhyAddress is the address of the PHY to be read (supports multiple
+* PHYs)
+* @param RegisterNum is the register number, 0-31, of the specific PHY register
+* to read
+* @param PhyDataPtr is an output parameter, and points to a 16-bit buffer into
+* which the current value of the register will be copied.
+* @return
+* - XST_SUCCESS if the PHY was read from successfully
+* - XST_EMAC_MII_BUSY if there is another PHY operation in progress
+* @note
+* This function is not thread-safe. The user must provide mutually exclusive
+* access to this function if there are to be multiple threads that can call it.
+* There is the possibility that this function will not return if the hardware
+* is broken (i.e., it never sets the status bit indicating that the read is
+* done). If this is of concern to the user, the user should provide a mechanism
+* suitable to their needs for recovery.
+* For the duration of this function, all host interface reads and writes are
+* blocked to the current XEmacPs instance.
+LONG XEmacPs_PhyRead(XEmacPs *InstancePtr, u32 PhyAddress,
+ u32 RegisterNum, u16 *PhyDataPtr)
+ u32 Mgtcr;
+ volatile u32 Ipisr;
+ u32 IpReadTemp;
+ LONG Status;
+ /* Make sure no other PHY operation is currently in progress */
+ if ((!(XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_NWSR_OFFSET) &
+ XEMACPS_NWSR_MDIOIDLE_MASK))==TRUE) {
+ Status = (LONG)(XST_EMAC_MII_BUSY);
+ } else {
+ /* Construct Mgtcr mask for the operation */
+ Mgtcr = XEMACPS_PHYMNTNC_OP_MASK | XEMACPS_PHYMNTNC_OP_R_MASK |
+ (PhyAddress << XEMACPS_PHYMNTNC_PHAD_SHFT_MSK) |
+ (RegisterNum << XEMACPS_PHYMNTNC_PREG_SHFT_MSK);
+ /* Write Mgtcr and wait for completion */
+ XEMACPS_PHYMNTNC_OFFSET, Mgtcr);
+ do {
+ Ipisr = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_NWSR_OFFSET);
+ IpReadTemp = Ipisr;
+ } while ((IpReadTemp & XEMACPS_NWSR_MDIOIDLE_MASK) == 0x00000000U);
+ /* Read data */
+ *PhyDataPtr = (u16)XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_PHYMNTNC_OFFSET);
+ return Status;
+* Write data to the specified PHY register. The Ethernet driver does not
+* require the device to be stopped before writing to the PHY. Although it is
+* probably a good idea to stop the device, it is the responsibility of the
+* application to deem this necessary. The MAC provides the driver with the
+* ability to talk to a PHY that adheres to the Media Independent Interface
+* (MII) as defined in the IEEE 802.3 standard.
+* @param PhyAddress is the address of the PHY to be written (supports multiple
+* PHYs)
+* to write
+* @param PhyData is the 16-bit value that will be written to the register
+* @return
+* - XST_SUCCESS if the PHY was written to successfully. Since there is no error
+* status from the MAC on a write, the user should read the PHY to verify the
+* write was successful.
+* @note
+* is broken (i.e., it never sets the status bit indicating that the write is
+LONG XEmacPs_PhyWrite(XEmacPs *InstancePtr, u32 PhyAddress,
+ u32 RegisterNum, u16 PhyData)
+ u32 Mgtcr;
+ u32 IpWriteTemp;
+ LONG Status;
+ } else {
+ Mgtcr = XEMACPS_PHYMNTNC_OP_MASK | XEMACPS_PHYMNTNC_OP_W_MASK |
+ (RegisterNum << XEMACPS_PHYMNTNC_PREG_SHFT_MSK) | (u32)PhyData;
+ do {
+ IpWriteTemp = Ipisr;
+ } while ((IpWriteTemp & XEMACPS_NWSR_MDIOIDLE_MASK) == 0x00000000U);
+ return Status;
+* API to update the Burst length in the DMACR register.
+* @param BLength is the length in bytes for the dma burst.
+* @return None
+void XEmacPs_DMABLengthUpdate(XEmacPs *InstancePtr, s32 BLength)
+ u32 Reg;
+ u32 RegUpdateVal = 0;
+ Xil_AssertVoid((BLength == XEMACPS_SINGLE_BURST) ||
+ (BLength == XEMACPS_4BYTE_BURST) ||
+ (BLength == XEMACPS_8BYTE_BURST) ||
+ (BLength == XEMACPS_16BYTE_BURST));
+ switch (BLength) {
+ case XEMACPS_SINGLE_BURST:
+ RegUpdateVal = XEMACPS_DMACR_SINGLE_AHB_BURST;
+ break;
+ case XEMACPS_4BYTE_BURST:
+ RegUpdateVal = XEMACPS_DMACR_INCR4_AHB_BURST;
+ break;
+ case XEMACPS_8BYTE_BURST:
+ RegUpdateVal = XEMACPS_DMACR_INCR8_AHB_BURST;
+ break;
+ case XEMACPS_16BYTE_BURST:
+ RegUpdateVal = XEMACPS_DMACR_INCR16_AHB_BURST;
+ break;
+ Reg &= (u32)(~XEMACPS_DMACR_BLENGTH_MASK);
+ Reg |= RegUpdateVal;
+ XEmacPs_WriteReg(InstancePtr->Config.BaseAddress, XEMACPS_DMACR_OFFSET,
+ Reg);
diff --git a/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_hw.h b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_hw.h
new file mode 100644
index 0000000..701c8a9
--- /dev/null
+++ b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_hw.h
@@ -0,0 +1,646 @@
+* @file xemacps_hw.h
+* This header file contains identifiers and low-level driver functions (or
+* macros) that can be used to access the PS Ethernet MAC (XEmacPs) device.
+* High-level driver functions are defined in xemacps.h.
+* @note
+* <pre>
+* 1.00a wsy 01/10/10 First release.
+* 1.02a asa 11/05/12 Added hash defines for DMACR burst length configuration.
+* 1.05a kpc 28/06/13 Added XEmacPs_ResetHw function prototype
+* 1.06a asa 11/02/13 Changed the value for XEMACPS_RXBUF_LEN_MASK from 0x3fff
+* to 0x1fff. This fixes the CR#744902.
+* 2.1 srt 07/15/14 Add support for Zynq Ultrascale Mp GEM specification.
+* 3.0 kvn 12/16/14 Changed name of XEMACPS_NWCFG_LENGTHERRDSCRD_MASK to
+* XEMACPS_NWCFG_LENERRDSCRD_MASK as it exceeds 31 characters.
+* 3.0 kpc 1/23/15 Corrected the extended descriptor macro values.
+* 3.0 hk 03/18/15 Added support for jumbo frames.
+* Remove "used bit set" from TX error interrupt masks.
+* 3.1 hk 08/10/15 Update upper 32 bit tx and rx queue ptr register offsets.
+* 3.2 hk 02/22/16 Added SGMII support for Zynq Ultrascale+ MPSoC.
+* 3.8 hk 09/17/18 Fix PTP interrupt masks.
+* 3.9 hk 01/23/19 Add RX watermark support
+* 3.10 hk 05/16/19 Clear status registers properly in reset
+* </pre>
+#ifndef XEMACPS_HW_H /* prevent circular inclusions */
+#define XEMACPS_HW_H /* by using protection macros */
+#include "xil_types.h"
+#include "xil_assert.h"
+#include "xil_io.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define XEMACPS_MAX_MAC_ADDR 4U /**< Maxmum number of mac address
+ supported */
+#define XEMACPS_MAX_TYPE_ID 4U /**< Maxmum number of type id supported */
+#ifdef __aarch64__
+#define XEMACPS_BD_ALIGNMENT 64U /**< Minimum buffer descriptor alignment
+ on the local bus */
+#else
+#define XEMACPS_BD_ALIGNMENT 4U /**< Minimum buffer descriptor alignment
+#endif
+#define XEMACPS_RX_BUF_ALIGNMENT 4U /**< Minimum buffer alignment when using
+ options that impose alignment
+ restrictions on the buffer data on
+ the local bus */
+/** @name Direction identifiers
+ * These are used by several functions and callbacks that need
+ * to specify whether an operation specifies a send or receive channel.
+#define XEMACPS_SEND 1U /**< send direction */
+#define XEMACPS_RECV 2U /**< receive direction */
+/** @name MDC clock division
+ * currently supporting 8, 16, 32, 48, 64, 96, 128, 224.
+typedef enum { MDC_DIV_8 = 0U, MDC_DIV_16, MDC_DIV_32, MDC_DIV_48,
+ MDC_DIV_64, MDC_DIV_96, MDC_DIV_128, MDC_DIV_224
+} XEmacPs_MdcDiv;
+#define XEMACPS_RX_BUF_SIZE 1536U /**< Specify the receive buffer size in
+ bytes, 64, 128, ... 10240 */
+#define XEMACPS_RX_BUF_SIZE_JUMBO 10240U
+#define XEMACPS_RX_BUF_UNIT 64U /**< Number of receive buffer bytes as a
+ unit, this is HW setup */
+#define XEMACPS_MAX_RXBD 128U /**< Size of RX buffer descriptor queues */
+#define XEMACPS_MAX_TXBD 128U /**< Size of TX buffer descriptor queues */
+#define XEMACPS_MAX_HASH_BITS 64U /**< Maximum value for hash bits. 2**6 */
+/* Register offset definitions. Unless otherwise noted, register access is
+ * 32 bit. Names are self explained here.
+#define XEMACPS_NWCTRL_OFFSET 0x00000000U /**< Network Control reg */
+#define XEMACPS_NWCFG_OFFSET 0x00000004U /**< Network Config reg */
+#define XEMACPS_NWSR_OFFSET 0x00000008U /**< Network Status reg */
+#define XEMACPS_DMACR_OFFSET 0x00000010U /**< DMA Control reg */
+#define XEMACPS_TXSR_OFFSET 0x00000014U /**< TX Status reg */
+#define XEMACPS_RXQBASE_OFFSET 0x00000018U /**< RX Q Base address reg */
+#define XEMACPS_TXQBASE_OFFSET 0x0000001CU /**< TX Q Base address reg */
+#define XEMACPS_RXSR_OFFSET 0x00000020U /**< RX Status reg */
+#define XEMACPS_ISR_OFFSET 0x00000024U /**< Interrupt Status reg */
+#define XEMACPS_IER_OFFSET 0x00000028U /**< Interrupt Enable reg */
+#define XEMACPS_IDR_OFFSET 0x0000002CU /**< Interrupt Disable reg */
+#define XEMACPS_IMR_OFFSET 0x00000030U /**< Interrupt Mask reg */
+#define XEMACPS_PHYMNTNC_OFFSET 0x00000034U /**< Phy Maintaince reg */
+#define XEMACPS_RXPAUSE_OFFSET 0x00000038U /**< RX Pause Time reg */
+#define XEMACPS_TXPAUSE_OFFSET 0x0000003CU /**< TX Pause Time reg */
+#define XEMACPS_JUMBOMAXLEN_OFFSET 0x00000048U /**< Jumbo max length reg */
+#define XEMACPS_RXWATERMARK_OFFSET 0x0000007CU /**< RX watermark reg */
+#define XEMACPS_HASHL_OFFSET 0x00000080U /**< Hash Low address reg */
+#define XEMACPS_HASHH_OFFSET 0x00000084U /**< Hash High address reg */
+#define XEMACPS_LADDR1L_OFFSET 0x00000088U /**< Specific1 addr low reg */
+#define XEMACPS_LADDR1H_OFFSET 0x0000008CU /**< Specific1 addr high reg */
+#define XEMACPS_LADDR2L_OFFSET 0x00000090U /**< Specific2 addr low reg */
+#define XEMACPS_LADDR2H_OFFSET 0x00000094U /**< Specific2 addr high reg */
+#define XEMACPS_LADDR3L_OFFSET 0x00000098U /**< Specific3 addr low reg */
+#define XEMACPS_LADDR3H_OFFSET 0x0000009CU /**< Specific3 addr high reg */
+#define XEMACPS_LADDR4L_OFFSET 0x000000A0U /**< Specific4 addr low reg */
+#define XEMACPS_LADDR4H_OFFSET 0x000000A4U /**< Specific4 addr high reg */
+#define XEMACPS_MATCH1_OFFSET 0x000000A8U /**< Type ID1 Match reg */
+#define XEMACPS_MATCH2_OFFSET 0x000000ACU /**< Type ID2 Match reg */
+#define XEMACPS_MATCH3_OFFSET 0x000000B0U /**< Type ID3 Match reg */
+#define XEMACPS_MATCH4_OFFSET 0x000000B4U /**< Type ID4 Match reg */
+#define XEMACPS_STRETCH_OFFSET 0x000000BCU /**< IPG Stretch reg */
+#define XEMACPS_OCTTXL_OFFSET 0x00000100U /**< Octects transmitted Low
+ reg */
+#define XEMACPS_OCTTXH_OFFSET 0x00000104U /**< Octects transmitted High
+ reg */
+#define XEMACPS_TXCNT_OFFSET 0x00000108U /**< Error-free Frmaes
+ transmitted counter */
+#define XEMACPS_TXBCCNT_OFFSET 0x0000010CU /**< Error-free Broadcast
+ Frames counter*/
+#define XEMACPS_TXMCCNT_OFFSET 0x00000110U /**< Error-free Multicast
+ Frame counter */
+#define XEMACPS_TXPAUSECNT_OFFSET 0x00000114U /**< Pause Frames Transmitted
+ Counter */
+#define XEMACPS_TX64CNT_OFFSET 0x00000118U /**< Error-free 64 byte Frames
+ Transmitted counter */
+#define XEMACPS_TX65CNT_OFFSET 0x0000011CU /**< Error-free 65-127 byte
+ Frames Transmitted
+ counter */
+#define XEMACPS_TX128CNT_OFFSET 0x00000120U /**< Error-free 128-255 byte
+ counter*/
+#define XEMACPS_TX256CNT_OFFSET 0x00000124U /**< Error-free 256-511 byte
+ Frames transmitted
+ counter */
+#define XEMACPS_TX512CNT_OFFSET 0x00000128U /**< Error-free 512-1023 byte
+ counter */
+#define XEMACPS_TX1024CNT_OFFSET 0x0000012CU /**< Error-free 1024-1518 byte
+ counter */
+#define XEMACPS_TX1519CNT_OFFSET 0x00000130U /**< Error-free larger than
+ 1519 byte Frames
+#define XEMACPS_TXURUNCNT_OFFSET 0x00000134U /**< TX under run error
+ counter */
+#define XEMACPS_SNGLCOLLCNT_OFFSET 0x00000138U /**< Single Collision Frame
+ Counter */
+#define XEMACPS_MULTICOLLCNT_OFFSET 0x0000013CU /**< Multiple Collision Frame
+ Counter */
+#define XEMACPS_EXCESSCOLLCNT_OFFSET 0x00000140U /**< Excessive Collision Frame
+ Counter */
+#define XEMACPS_LATECOLLCNT_OFFSET 0x00000144U /**< Late Collision Frame
+ Counter */
+#define XEMACPS_TXDEFERCNT_OFFSET 0x00000148U /**< Deferred Transmission
+ Frame Counter */
+#define XEMACPS_TXCSENSECNT_OFFSET 0x0000014CU /**< Transmit Carrier Sense
+ Error Counter */
+#define XEMACPS_OCTRXL_OFFSET 0x00000150U /**< Octects Received register
+ Low */
+#define XEMACPS_OCTRXH_OFFSET 0x00000154U /**< Octects Received register
+ High */
+#define XEMACPS_RXCNT_OFFSET 0x00000158U /**< Error-free Frames
+ Received Counter */
+#define XEMACPS_RXBROADCNT_OFFSET 0x0000015CU /**< Error-free Broadcast
+ Frames Received Counter */
+#define XEMACPS_RXMULTICNT_OFFSET 0x00000160U /**< Error-free Multicast
+#define XEMACPS_RXPAUSECNT_OFFSET 0x00000164U /**< Pause Frames
+#define XEMACPS_RX64CNT_OFFSET 0x00000168U /**< Error-free 64 byte Frames
+#define XEMACPS_RX65CNT_OFFSET 0x0000016CU /**< Error-free 65-127 byte
+#define XEMACPS_RX128CNT_OFFSET 0x00000170U /**< Error-free 128-255 byte
+#define XEMACPS_RX256CNT_OFFSET 0x00000174U /**< Error-free 256-512 byte
+#define XEMACPS_RX512CNT_OFFSET 0x00000178U /**< Error-free 512-1023 byte
+#define XEMACPS_RX1024CNT_OFFSET 0x0000017CU /**< Error-free 1024-1518 byte
+#define XEMACPS_RX1519CNT_OFFSET 0x00000180U /**< Error-free 1519-max byte
+#define XEMACPS_RXUNDRCNT_OFFSET 0x00000184U /**< Undersize Frames Received
+ Counter */
+#define XEMACPS_RXOVRCNT_OFFSET 0x00000188U /**< Oversize Frames Received
+ Counter */
+#define XEMACPS_RXJABCNT_OFFSET 0x0000018CU /**< Jabbers Received
+ Counter */
+#define XEMACPS_RXFCSCNT_OFFSET 0x00000190U /**< Frame Check Sequence
+ Error Counter */
+#define XEMACPS_RXLENGTHCNT_OFFSET 0x00000194U /**< Length Field Error
+ Counter */
+#define XEMACPS_RXSYMBCNT_OFFSET 0x00000198U /**< Symbol Error Counter */
+#define XEMACPS_RXALIGNCNT_OFFSET 0x0000019CU /**< Alignment Error Counter */
+#define XEMACPS_RXRESERRCNT_OFFSET 0x000001A0U /**< Receive Resource Error
+ Counter */
+#define XEMACPS_RXORCNT_OFFSET 0x000001A4U /**< Receive Overrun Counter */
+#define XEMACPS_RXIPCCNT_OFFSET 0x000001A8U /**< IP header Checksum Error
+ Counter */
+#define XEMACPS_RXTCPCCNT_OFFSET 0x000001ACU /**< TCP Checksum Error
+ Counter */
+#define XEMACPS_RXUDPCCNT_OFFSET 0x000001B0U /**< UDP Checksum Error
+ Counter */
+#define XEMACPS_LAST_OFFSET 0x000001B4U /**< Last statistic counter
+ offset, for clearing */
+#define XEMACPS_1588_SEC_OFFSET 0x000001D0U /**< 1588 second counter */
+#define XEMACPS_1588_NANOSEC_OFFSET 0x000001D4U /**< 1588 nanosecond counter */
+#define XEMACPS_1588_ADJ_OFFSET 0x000001D8U /**< 1588 nanosecond
+ adjustment counter */
+#define XEMACPS_1588_INC_OFFSET 0x000001DCU /**< 1588 nanosecond
+ increment counter */
+#define XEMACPS_PTP_TXSEC_OFFSET 0x000001E0U /**< 1588 PTP transmit second
+ counter */
+#define XEMACPS_PTP_TXNANOSEC_OFFSET 0x000001E4U /**< 1588 PTP transmit
+ nanosecond counter */
+#define XEMACPS_PTP_RXSEC_OFFSET 0x000001E8U /**< 1588 PTP receive second
+ counter */
+#define XEMACPS_PTP_RXNANOSEC_OFFSET 0x000001ECU /**< 1588 PTP receive
+#define XEMACPS_PTPP_TXSEC_OFFSET 0x000001F0U /**< 1588 PTP peer transmit
+ second counter */
+#define XEMACPS_PTPP_TXNANOSEC_OFFSET 0x000001F4U /**< 1588 PTP peer transmit
+#define XEMACPS_PTPP_RXSEC_OFFSET 0x000001F8U /**< 1588 PTP peer receive
+ second counter */
+#define XEMACPS_PTPP_RXNANOSEC_OFFSET 0x000001FCU /**< 1588 PTP peer receive
+#define XEMACPS_INTQ1_STS_OFFSET 0x00000400U /**< Interrupt Q1 Status
+ reg */
+#define XEMACPS_TXQ1BASE_OFFSET 0x00000440U /**< TX Q1 Base address
+ reg */
+#define XEMACPS_RXQ1BASE_OFFSET 0x00000480U /**< RX Q1 Base address
+ reg */
+#define XEMACPS_MSBBUF_TXQBASE_OFFSET 0x000004C8U /**< MSB Buffer TX Q Base
+ reg */
+#define XEMACPS_MSBBUF_RXQBASE_OFFSET 0x000004D4U /**< MSB Buffer RX Q Base
+ reg */
+#define XEMACPS_INTQ1_IER_OFFSET 0x00000600U /**< Interrupt Q1 Enable
+ reg */
+#define XEMACPS_INTQ1_IDR_OFFSET 0x00000620U /**< Interrupt Q1 Disable
+ reg */
+#define XEMACPS_INTQ1_IMR_OFFSET 0x00000640U /**< Interrupt Q1 Mask
+ reg */
+/* Define some bit positions for registers. */
+/** @name network control register bit definitions
+#define XEMACPS_NWCTRL_FLUSH_DPRAM_MASK 0x00040000U /**< Flush a packet from
+ Rx SRAM */
+#define XEMACPS_NWCTRL_ZEROPAUSETX_MASK 0x00000800U /**< Transmit zero quantum
+ pause frame */
+#define XEMACPS_NWCTRL_PAUSETX_MASK 0x00000800U /**< Transmit pause frame */
+#define XEMACPS_NWCTRL_HALTTX_MASK 0x00000400U /**< Halt transmission
+ after current frame */
+#define XEMACPS_NWCTRL_STARTTX_MASK 0x00000200U /**< Start tx (tx_go) */
+#define XEMACPS_NWCTRL_STATWEN_MASK 0x00000080U /**< Enable writing to
+ stat counters */
+#define XEMACPS_NWCTRL_STATINC_MASK 0x00000040U /**< Increment statistic
+ registers */
+#define XEMACPS_NWCTRL_STATCLR_MASK 0x00000020U /**< Clear statistic
+ registers */
+#define XEMACPS_NWCTRL_MDEN_MASK 0x00000010U /**< Enable MDIO port */
+#define XEMACPS_NWCTRL_TXEN_MASK 0x00000008U /**< Enable transmit */
+#define XEMACPS_NWCTRL_RXEN_MASK 0x00000004U /**< Enable receive */
+#define XEMACPS_NWCTRL_LOOPEN_MASK 0x00000002U /**< local loopback */
+/** @name network configuration register bit definitions
+#define XEMACPS_NWCFG_BADPREAMBEN_MASK 0x20000000U /**< disable rejection of
+ non-standard preamble */
+#define XEMACPS_NWCFG_IPDSTRETCH_MASK 0x10000000U /**< enable transmit IPG */
+#define XEMACPS_NWCFG_SGMIIEN_MASK 0x08000000U /**< SGMII Enable */
+#define XEMACPS_NWCFG_FCSIGNORE_MASK 0x04000000U /**< disable rejection of
+ FCS error */
+#define XEMACPS_NWCFG_HDRXEN_MASK 0x02000000U /**< RX half duplex */
+#define XEMACPS_NWCFG_RXCHKSUMEN_MASK 0x01000000U /**< enable RX checksum
+ offload */
+#define XEMACPS_NWCFG_PAUSECOPYDI_MASK 0x00800000U /**< Do not copy pause
+ Frames to memory */
+#define XEMACPS_NWCFG_DWIDTH_64_MASK 0x00200000U /**< 64 bit Data bus width */
+#define XEMACPS_NWCFG_MDC_SHIFT_MASK 18U /**< shift bits for MDC */
+#define XEMACPS_NWCFG_MDCCLKDIV_MASK 0x001C0000U /**< MDC Mask PCLK divisor */
+#define XEMACPS_NWCFG_FCSREM_MASK 0x00020000U /**< Discard FCS from
+ received frames */
+#define XEMACPS_NWCFG_LENERRDSCRD_MASK 0x00010000U
+/**< RX length error discard */
+#define XEMACPS_NWCFG_RXOFFS_MASK 0x0000C000U /**< RX buffer offset */
+#define XEMACPS_NWCFG_PAUSEEN_MASK 0x00002000U /**< Enable pause RX */
+#define XEMACPS_NWCFG_RETRYTESTEN_MASK 0x00001000U /**< Retry test */
+#define XEMACPS_NWCFG_XTADDMACHEN_MASK 0x00000200U
+/**< External address match enable */
+#define XEMACPS_NWCFG_PCSSEL_MASK 0x00000800U /**< PCS Select */
+#define XEMACPS_NWCFG_1000_MASK 0x00000400U /**< 1000 Mbps */
+#define XEMACPS_NWCFG_1536RXEN_MASK 0x00000100U /**< Enable 1536 byte
+ frames reception */
+#define XEMACPS_NWCFG_UCASTHASHEN_MASK 0x00000080U /**< Receive unicast hash
+ frames */
+#define XEMACPS_NWCFG_MCASTHASHEN_MASK 0x00000040U /**< Receive multicast hash
+ frames */
+#define XEMACPS_NWCFG_BCASTDI_MASK 0x00000020U /**< Do not receive
+ broadcast frames */
+#define XEMACPS_NWCFG_COPYALLEN_MASK 0x00000010U /**< Copy all frames */
+#define XEMACPS_NWCFG_JUMBO_MASK 0x00000008U /**< Jumbo frames */
+#define XEMACPS_NWCFG_NVLANDISC_MASK 0x00000004U /**< Receive only VLAN
+ frames */
+#define XEMACPS_NWCFG_FDEN_MASK 0x00000002U/**< full duplex */
+#define XEMACPS_NWCFG_100_MASK 0x00000001U /**< 100 Mbps */
+#define XEMACPS_NWCFG_RESET_MASK 0x00080000U/**< reset value */
+/** @name network status register bit definitaions
+#define XEMACPS_NWSR_MDIOIDLE_MASK 0x00000004U /**< PHY management idle */
+#define XEMACPS_NWSR_MDIO_MASK 0x00000002U /**< Status of mdio_in */
+/** @name MAC address register word 1 mask
+#define XEMACPS_LADDR_MACH_MASK 0x0000FFFFU /**< Address bits[47:32]
+ bit[31:0] are in BOTTOM */
+/** @name DMA control register bit definitions
+#define XEMACPS_DMACR_ADDR_WIDTH_64 0x40000000U /**< 64 bit address bus */
+#define XEMACPS_DMACR_TXEXTEND_MASK 0x20000000U /**< Tx Extended desc mode */
+#define XEMACPS_DMACR_RXEXTEND_MASK 0x10000000U /**< Rx Extended desc mode */
+#define XEMACPS_DMACR_RXBUF_MASK 0x00FF0000U /**< Mask bit for RX buffer
+ size */
+#define XEMACPS_DMACR_RXBUF_SHIFT 16U /**< Shift bit for RX buffer
+ size */
+#define XEMACPS_DMACR_TCPCKSUM_MASK 0x00000800U /**< enable/disable TX
+ checksum offload */
+#define XEMACPS_DMACR_TXSIZE_MASK 0x00000400U /**< TX buffer memory size */
+#define XEMACPS_DMACR_RXSIZE_MASK 0x00000300U /**< RX buffer memory size */
+#define XEMACPS_DMACR_ENDIAN_MASK 0x00000080U /**< endian configuration */
+#define XEMACPS_DMACR_BLENGTH_MASK 0x0000001FU /**< buffer burst length */
+#define XEMACPS_DMACR_SINGLE_AHB_BURST 0x00000001U /**< single AHB bursts */
+#define XEMACPS_DMACR_INCR4_AHB_BURST 0x00000004U /**< 4 bytes AHB bursts */
+#define XEMACPS_DMACR_INCR8_AHB_BURST 0x00000008U /**< 8 bytes AHB bursts */
+#define XEMACPS_DMACR_INCR16_AHB_BURST 0x00000010U /**< 16 bytes AHB bursts */
+/** @name transmit status register bit definitions
+#define XEMACPS_TXSR_HRESPNOK_MASK 0x00000100U /**< Transmit hresp not OK */
+#define XEMACPS_TXSR_URUN_MASK 0x00000040U /**< Transmit underrun */
+#define XEMACPS_TXSR_TXCOMPL_MASK 0x00000020U /**< Transmit completed OK */
+#define XEMACPS_TXSR_BUFEXH_MASK 0x00000010U /**< Transmit buffs exhausted
+ mid frame */
+#define XEMACPS_TXSR_TXGO_MASK 0x00000008U /**< Status of go flag */
+#define XEMACPS_TXSR_RXOVR_MASK 0x00000004U /**< Retry limit exceeded */
+#define XEMACPS_TXSR_FRAMERX_MASK 0x00000002U /**< Collision tx frame */
+#define XEMACPS_TXSR_USEDREAD_MASK 0x00000001U /**< TX buffer used bit set */
+#define XEMACPS_TXSR_ERROR_MASK ((u32)XEMACPS_TXSR_HRESPNOK_MASK | \
+ (u32)XEMACPS_TXSR_URUN_MASK | \
+ (u32)XEMACPS_TXSR_BUFEXH_MASK | \
+ (u32)XEMACPS_TXSR_RXOVR_MASK | \
+ (u32)XEMACPS_TXSR_FRAMERX_MASK | \
+ (u32)XEMACPS_TXSR_USEDREAD_MASK)
+ * @name receive status register bit definitions
+#define XEMACPS_RXSR_HRESPNOK_MASK 0x00000008U /**< Receive hresp not OK */
+#define XEMACPS_RXSR_RXOVR_MASK 0x00000004U /**< Receive overrun */
+#define XEMACPS_RXSR_FRAMERX_MASK 0x00000002U /**< Frame received OK */
+#define XEMACPS_RXSR_BUFFNA_MASK 0x00000001U /**< RX buffer used bit set */
+#define XEMACPS_RXSR_ERROR_MASK ((u32)XEMACPS_RXSR_HRESPNOK_MASK | \
+ (u32)XEMACPS_RXSR_RXOVR_MASK | \
+ (u32)XEMACPS_RXSR_BUFFNA_MASK)
+#define XEMACPS_SR_ALL_MASK 0xFFFFFFFFU /**< Mask for full register */
+ * @name Interrupt Q1 status register bit definitions
+#define XEMACPS_INTQ1SR_TXCOMPL_MASK 0x00000080U /**< Transmit completed OK */
+#define XEMACPS_INTQ1SR_TXERR_MASK 0x00000040U /**< Transmit AMBA Error */
+#define XEMACPS_INTQ1_IXR_ALL_MASK ((u32)XEMACPS_INTQ1SR_TXCOMPL_MASK | \
+ (u32)XEMACPS_INTQ1SR_TXERR_MASK)
+ * @name interrupts bit definitions
+ * Bits definitions are same in XEMACPS_ISR_OFFSET,
+ * XEMACPS_IER_OFFSET, XEMACPS_IDR_OFFSET, and XEMACPS_IMR_OFFSET
+#define XEMACPS_IXR_PTPPSTX_MASK 0x02000000U /**< PTP Pdelay_resp TXed */
+#define XEMACPS_IXR_PTPPDRTX_MASK 0x01000000U /**< PTP Pdelay_req TXed */
+#define XEMACPS_IXR_PTPPSRX_MASK 0x00800000U /**< PTP Pdelay_resp RXed */
+#define XEMACPS_IXR_PTPPDRRX_MASK 0x00400000U /**< PTP Pdelay_req RXed */
+#define XEMACPS_IXR_PTPSTX_MASK 0x00200000U /**< PTP Sync TXed */
+#define XEMACPS_IXR_PTPDRTX_MASK 0x00100000U /**< PTP Delay_req TXed */
+#define XEMACPS_IXR_PTPSRX_MASK 0x00080000U /**< PTP Sync RXed */
+#define XEMACPS_IXR_PTPDRRX_MASK 0x00040000U /**< PTP Delay_req RXed */
+#define XEMACPS_IXR_PAUSETX_MASK 0x00004000U /**< Pause frame transmitted */
+#define XEMACPS_IXR_PAUSEZERO_MASK 0x00002000U /**< Pause time has reached
+ zero */
+#define XEMACPS_IXR_PAUSENZERO_MASK 0x00001000U /**< Pause frame received */
+#define XEMACPS_IXR_HRESPNOK_MASK 0x00000800U /**< hresp not ok */
+#define XEMACPS_IXR_RXOVR_MASK 0x00000400U /**< Receive overrun occurred */
+#define XEMACPS_IXR_TXCOMPL_MASK 0x00000080U /**< Frame transmitted ok */
+#define XEMACPS_IXR_TXEXH_MASK 0x00000040U /**< Transmit err occurred or
+ no buffers*/
+#define XEMACPS_IXR_RETRY_MASK 0x00000020U /**< Retry limit exceeded */
+#define XEMACPS_IXR_URUN_MASK 0x00000010U /**< Transmit underrun */
+#define XEMACPS_IXR_TXUSED_MASK 0x00000008U /**< Tx buffer used bit read */
+#define XEMACPS_IXR_RXUSED_MASK 0x00000004U /**< Rx buffer used bit read */
+#define XEMACPS_IXR_FRAMERX_MASK 0x00000002U /**< Frame received ok */
+#define XEMACPS_IXR_MGMNT_MASK 0x00000001U /**< PHY management complete */
+#define XEMACPS_IXR_ALL_MASK 0x00007FFFU /**< Everything! */
+#define XEMACPS_IXR_TX_ERR_MASK ((u32)XEMACPS_IXR_TXEXH_MASK | \
+ (u32)XEMACPS_IXR_RETRY_MASK | \
+ (u32)XEMACPS_IXR_URUN_MASK)
+#define XEMACPS_IXR_RX_ERR_MASK ((u32)XEMACPS_IXR_HRESPNOK_MASK | \
+ (u32)XEMACPS_IXR_RXUSED_MASK | \
+ (u32)XEMACPS_IXR_RXOVR_MASK)
+/** @name PHY Maintenance bit definitions
+#define XEMACPS_PHYMNTNC_OP_MASK 0x40020000U /**< operation mask bits */
+#define XEMACPS_PHYMNTNC_OP_R_MASK 0x20000000U /**< read operation */
+#define XEMACPS_PHYMNTNC_OP_W_MASK 0x10000000U /**< write operation */
+#define XEMACPS_PHYMNTNC_ADDR_MASK 0x0F800000U /**< Address bits */
+#define XEMACPS_PHYMNTNC_REG_MASK 0x007C0000U /**< register bits */
+#define XEMACPS_PHYMNTNC_DATA_MASK 0x00000FFFU /**< data bits */
+#define XEMACPS_PHYMNTNC_PHAD_SHFT_MSK 23U /**< Shift bits for PHYAD */
+#define XEMACPS_PHYMNTNC_PREG_SHFT_MSK 18U /**< Shift bits for PHREG */
+/** @name RX watermark bit definitions
+#define XEMACPS_RXWM_HIGH_MASK 0x0000FFFFU /**< RXWM high mask */
+#define XEMACPS_RXWM_LOW_MASK 0xFFFF0000U /**< RXWM low mask */
+#define XEMACPS_RXWM_LOW_SHFT_MSK 16U /**< Shift for RXWM low */
+/* Transmit buffer descriptor status words offset
+#define XEMACPS_BD_ADDR_OFFSET 0x00000000U /**< word 0/addr of BDs */
+#define XEMACPS_BD_STAT_OFFSET 0x00000004U /**< word 1/status of BDs */
+#define XEMACPS_BD_ADDR_HI_OFFSET 0x00000008U /**< word 2/addr of BDs */
+/* Transmit buffer descriptor status words bit positions.
+ * Transmit buffer descriptor consists of two 32-bit registers,
+ * the first - word0 contains a 32-bit address pointing to the location of
+ * the transmit data.
+ * The following register - word1, consists of various information to control
+ * the XEmacPs transmit process. After transmit, this is updated with status
+ * information, whether the frame was transmitted OK or why it had failed.
+#define XEMACPS_TXBUF_USED_MASK 0x80000000U /**< Used bit. */
+#define XEMACPS_TXBUF_WRAP_MASK 0x40000000U /**< Wrap bit, last descriptor */
+#define XEMACPS_TXBUF_RETRY_MASK 0x20000000U /**< Retry limit exceeded */
+#define XEMACPS_TXBUF_URUN_MASK 0x10000000U /**< Transmit underrun occurred */
+#define XEMACPS_TXBUF_EXH_MASK 0x08000000U /**< Buffers exhausted */
+#define XEMACPS_TXBUF_TCP_MASK 0x04000000U /**< Late collision. */
+#define XEMACPS_TXBUF_NOCRC_MASK 0x00010000U /**< No CRC */
+#define XEMACPS_TXBUF_LAST_MASK 0x00008000U /**< Last buffer */
+#define XEMACPS_TXBUF_LEN_MASK 0x00003FFFU /**< Mask for length field */
+/* Receive buffer descriptor status words bit positions.
+ * Receive buffer descriptor consists of two 32-bit registers,
+ * the first - word0 contains a 32-bit word aligned address pointing to the
+ * address of the buffer. The lower two bits make up the wrap bit indicating
+ * the last descriptor and the ownership bit to indicate it has been used by
+ * the XEmacPs.
+ * The following register - word1, contains status information regarding why
+ * the frame was received (the filter match condition) as well as other
+ * useful info.
+#define XEMACPS_RXBUF_BCAST_MASK 0x80000000U /**< Broadcast frame */
+#define XEMACPS_RXBUF_MULTIHASH_MASK 0x40000000U /**< Multicast hashed frame */
+#define XEMACPS_RXBUF_UNIHASH_MASK 0x20000000U /**< Unicast hashed frame */
+#define XEMACPS_RXBUF_EXH_MASK 0x08000000U /**< buffer exhausted */
+#define XEMACPS_RXBUF_AMATCH_MASK 0x06000000U /**< Specific address
+ matched */
+#define XEMACPS_RXBUF_IDFOUND_MASK 0x01000000U /**< Type ID matched */
+#define XEMACPS_RXBUF_IDMATCH_MASK 0x00C00000U /**< ID matched mask */
+#define XEMACPS_RXBUF_VLAN_MASK 0x00200000U /**< VLAN tagged */
+#define XEMACPS_RXBUF_PRI_MASK 0x00100000U /**< Priority tagged */
+#define XEMACPS_RXBUF_VPRI_MASK 0x000E0000U /**< Vlan priority */
+#define XEMACPS_RXBUF_CFI_MASK 0x00010000U /**< CFI frame */
+#define XEMACPS_RXBUF_EOF_MASK 0x00008000U /**< End of frame. */
+#define XEMACPS_RXBUF_SOF_MASK 0x00004000U /**< Start of frame. */
+#define XEMACPS_RXBUF_LEN_MASK 0x00001FFFU /**< Mask for length field */
+#define XEMACPS_RXBUF_LEN_JUMBO_MASK 0x00003FFFU /**< Mask for jumbo length */
+#define XEMACPS_RXBUF_WRAP_MASK 0x00000002U /**< Wrap bit, last BD */
+#define XEMACPS_RXBUF_NEW_MASK 0x00000001U /**< Used bit.. */
+#define XEMACPS_RXBUF_ADD_MASK 0xFFFFFFFCU /**< Mask for address */
+ * Define appropriate I/O access method to memory mapped I/O or other
+ * interface if necessary.
+#define XEmacPs_In32 Xil_In32
+#define XEmacPs_Out32 Xil_Out32
+* Read the given register.
+* @param BaseAddress is the base address of the device
+* @param RegOffset is the register offset to be read
+* @return The 32-bit value of the register
+* @note
+* C-style signature:
+* u32 XEmacPs_ReadReg(u32 BaseAddress, u32 RegOffset)
+#define XEmacPs_ReadReg(BaseAddress, RegOffset) \
+ XEmacPs_In32((BaseAddress) + (u32)(RegOffset))
+* Write the given register.
+* @param RegOffset is the register offset to be written
+* @param Data is the 32-bit value to write to the register
+* @return None.
+* @note
+* void XEmacPs_WriteReg(u32 BaseAddress, u32 RegOffset,
+* u32 Data)
+#define XEmacPs_WriteReg(BaseAddress, RegOffset, Data) \
+ XEmacPs_Out32((BaseAddress) + (u32)(RegOffset), (u32)(Data))
+/************************** Function Prototypes *****************************/
+ * Perform reset operation to the emacps interface
+void XEmacPs_ResetHw(u32 BaseAddr);
+#ifdef __cplusplus
+#endif
+#endif /* end of protection macro */
diff --git a/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_intr.c b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_intr.c
index 0000000..2dbdb0b
--- /dev/null
+++ b/embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_intr.c
@@ -0,0 +1,242 @@
+* @file xemacps_intr.c
+* Functions in this file implement general purpose interrupt processing related
+* functionality. See xemacps.h for a detailed description of the driver.
+* <pre>
+* 1.03a asa 01/24/13 Fix for CR #692702 which updates error handling for
+* Rx errors. Under heavy Rx traffic, there will be a large
+* number of errors related to receive buffer not available.
+* Because of a HW bug (SI #692601), under such heavy errors,
+* the Rx data path can become unresponsive. To reduce the
+* probabilities for hitting this HW bug, the SW writes to
+* bit 18 to flush a packet from Rx DPRAM immediately. The
+* changes for it are done in the function
+* XEmacPs_IntrHandler.
+* and 64-bit changes.
+* 3.0 kvn 02/13/15 Modified code for MISRA-C:2012 compliance.
+* 3.1 hk 07/27/15 Do not call error handler with '0' error code when
+* there is no error. CR# 869403
+* </pre>
+ * Install an asynchronous handler function for the given HandlerType:
+ * @param HandlerType indicates what interrupt handler type is.
+ * XEMACPS_HANDLER_DMASEND, XEMACPS_HANDLER_DMARECV and
+ * XEMACPS_HANDLER_ERROR.
+ * @param FuncPointer is the pointer to the callback function
+ * @param CallBackRef is the upper layer callback reference passed back when
+ * when the callback function is invoked.
+ * @return
+ * None.
+ * @note
+ * There is no assert on the CallBackRef since the driver doesn't know what
+ * it is.
+LONG XEmacPs_SetHandler(XEmacPs *InstancePtr, u32 HandlerType,
+ void *FuncPointer, void *CallBackRef)
+ LONG Status;
+ Xil_AssertNonvoid(FuncPointer != NULL);
+ switch (HandlerType) {
+ case XEMACPS_HANDLER_DMASEND:
+ Status = (LONG)(XST_SUCCESS);
+ InstancePtr->SendHandler = ((XEmacPs_Handler)(void *)FuncPointer);
+ InstancePtr->SendRef = CallBackRef;
+ break;
+ case XEMACPS_HANDLER_DMARECV:
+ InstancePtr->RecvHandler = ((XEmacPs_Handler)(void *)FuncPointer);
+ InstancePtr->RecvRef = CallBackRef;
+ break;
+ case XEMACPS_HANDLER_ERROR:
+ InstancePtr->ErrorHandler = ((XEmacPs_ErrHandler)(void *)FuncPointer);
+ InstancePtr->ErrorRef = CallBackRef;
+ break;
+ default:
+ break;
+ return Status;
+* Master interrupt handler for EMAC driver. This routine will query the
+* status of the device, bump statistics, and invoke user callbacks.
+* This routine must be connected to an interrupt controller using OS/BSP
+* specific methods.
+* @param XEmacPsPtr is a pointer to the XEMACPS instance that has caused the
+* interrupt.
+void XEmacPs_IntrHandler(void *XEmacPsPtr)
+ u32 RegISR;
+ u32 RegSR;
+ u32 RegCtrl;
+ u32 RegQ1ISR = 0U;
+ XEmacPs *InstancePtr = (XEmacPs *) XEmacPsPtr;
+ /* This ISR will try to handle as many interrupts as it can in a single
+ * call. However, in most of the places where the user's error handler
+ * is called, this ISR exits because it is expected that the user will
+ * reset the device in nearly all instances.
+ RegISR = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_ISR_OFFSET);
+ /* Read Transmit Q1 ISR */
+ if (InstancePtr->Version > 2)
+ RegQ1ISR = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_INTQ1_STS_OFFSET);
+ /* Clear the interrupt status register */
+ XEmacPs_WriteReg(InstancePtr->Config.BaseAddress, XEMACPS_ISR_OFFSET,
+ RegISR);
+ /* Receive complete interrupt */
+ if ((RegISR & XEMACPS_IXR_FRAMERX_MASK) != 0x00000000U) {
+ /* Clear RX status register RX complete indication but preserve
+ * error bits if there is any */
+ XEMACPS_RXSR_OFFSET,
+ ((u32)XEMACPS_RXSR_FRAMERX_MASK |
+ (u32)XEMACPS_RXSR_BUFFNA_MASK));
+ InstancePtr->RecvHandler(InstancePtr->RecvRef);
+ /* Transmit Q1 complete interrupt */
+ if ((InstancePtr->Version > 2) &&
+ ((RegQ1ISR & XEMACPS_INTQ1SR_TXCOMPL_MASK) != 0x00000000U)) {
+ /* Clear TX status register TX complete indication but preserve
+ XEMACPS_INTQ1_STS_OFFSET,
+ XEMACPS_INTQ1SR_TXCOMPL_MASK);
+ XEMACPS_TXSR_OFFSET,
+ ((u32)XEMACPS_TXSR_TXCOMPL_MASK |
+ (u32)XEMACPS_TXSR_USEDREAD_MASK));
+ InstancePtr->SendHandler(InstancePtr->SendRef);
+ /* Transmit complete interrupt */
+ if ((RegISR & XEMACPS_IXR_TXCOMPL_MASK) != 0x00000000U) {
+ /* Receive error conditions interrupt */
+ if ((RegISR & XEMACPS_IXR_RX_ERR_MASK) != 0x00000000U) {
+ /* Clear RX status register */
+ RegSR = XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ XEMACPS_RXSR_OFFSET);
+ XEMACPS_RXSR_OFFSET, RegSR);
+ /* Fix for CR # 692702. Write to bit 18 of net_ctrl
+ * register to flush a packet out of Rx SRAM upon
+ * an error for receive buffer not available. */
+ if ((RegISR & XEMACPS_IXR_RXUSED_MASK) != 0x00000000U) {
+ RegCtrl =
+ XEmacPs_ReadReg(InstancePtr->Config.BaseAddress,
+ RegCtrl |= (u32)XEMACPS_NWCTRL_FLUSH_DPRAM_MASK;
+ XEMACPS_NWCTRL_OFFSET, RegCtrl);
+ if(RegSR != 0) {
+ InstancePtr->ErrorHandler(InstancePtr->ErrorRef,
+ XEMACPS_RECV, RegSR);
+ /* When XEMACPS_IXR_TXCOMPL_MASK is flagged, XEMACPS_IXR_TXUSED_MASK
+ * will be asserted the same time.
+ * Have to distinguish this bit to handle the real error condition.
+ /* Transmit Q1 error conditions interrupt */
+ ((RegQ1ISR & XEMACPS_INTQ1SR_TXERR_MASK) != 0x00000000U) &&
+ /* Clear Interrupt Q1 status register */
+ XEMACPS_INTQ1_STS_OFFSET, RegQ1ISR);
+ InstancePtr->ErrorHandler(InstancePtr->ErrorRef, XEMACPS_SEND,
+ RegQ1ISR);
+ /* Transmit error conditions interrupt */
+ if (((RegISR & XEMACPS_IXR_TX_ERR_MASK) != 0x00000000U) &&
+ (!(RegISR & XEMACPS_IXR_TXCOMPL_MASK) != 0x00000000U)) {
+ /* Clear TX status register */
+ XEMACPS_TXSR_OFFSET);
+ XEMACPS_TXSR_OFFSET, RegSR);
+ RegSR);
diff --git a/embeddedsw/XilinxProcessorIPLib/drivers/scugic/src/xscugic.h b/embeddedsw/XilinxProcessorIPLib/drivers/scugic/src/xscugic.h
index 0000000..28043f6
--- /dev/null
+++ b/embeddedsw/XilinxProcessorIPLib/drivers/scugic/src/xscugic.h
@@ -0,0 +1,601 @@
+* Copyright (C) 2010 - 2021 Xilinx, Inc. All rights reserved.
+* @file xscugic.h
+* @addtogroup scugic_v4_7
+* @details
+* The generic interrupt controller driver component.
+* The interrupt controller driver uses the idea of priority for the various
+* handlers. Priority is an integer within the range of 1 and 31 inclusive with
+* default of 1 being the highest priority interrupt source. The priorities
+* of the various sources can be dynamically altered as needed through
+* hardware configuration.
+* The generic interrupt controller supports the following
+* features:
+* - specific individual interrupt enabling/disabling
+* - specific individual interrupt acknowledging
+* - attaching specific callback function to handle interrupt source
+* - assigning desired priority to interrupt source if default is not
+* acceptable.
+* Details about connecting the interrupt handler of the driver are contained
+* in the source file specific to interrupt processing, xscugic_intr.c.
+* This driver is intended to be RTOS and processor independent. It works with
+* physical addresses only. Any needs for dynamic memory management, threads
+* or thread mutual exclusion, virtual memory, or cache control must be
+* satisfied by the layer above this driver.
+* <b>Interrupt Vector Tables</b>
+* The device ID of the interrupt controller device is used by the driver as a
+* direct index into the configuration data table. The user should populate the
+* vector table with handlers and callbacks at run-time using the
+* XScuGic_Connect() and XScuGic_Disconnect() functions.
+* Each vector table entry corresponds to a device that can generate an
+* interrupt. Each entry contains an interrupt handler function and an
+* argument to be passed to the handler when an interrupt occurs. The
+* user must use XScuGic_Connect() when the interrupt handler takes an
+* argument other than the base address.
+* <b>Nested Interrupts Processing</b>
+* Nested interrupts are not supported by this driver.
+* NOTE:
+* The generic interrupt controller is not a part of the snoop control unit
+* as indicated by the prefix "scu" in the name of the driver.
+* It is an independent module in APU.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver Who Date Changes
+* 1.00a drg 01/19/00 First release
+* 1.01a sdm 11/09/11 The XScuGic and XScuGic_Config structures have changed.
+* The HandlerTable (of type XScuGic_VectorTableEntry) is
+* moved to XScuGic_Config structure from XScuGic structure.
+* The "Config" entry in XScuGic structure is made as
+* pointer for better efficiency.
+* A new file named as xscugic_hw.c is now added. It is
+* to implement low level driver routines without using
+* any xscugic instance pointer. They are useful when the
+* user wants to use xscugic through device id or
+* base address. The driver routines provided are explained
+* below.
+* XScuGic_DeviceInitialize that takes device id as
+* argument and initializes the device (without calling
+* XScuGic_CfgInitialize).
+* XScuGic_DeviceInterruptHandler that takes device id
+* as argument and calls appropriate handlers from the
+* HandlerTable.
+* XScuGic_RegisterHandler that registers a new handler
+* by taking xscugic hardware base address as argument.
+* LookupConfigByBaseAddress is used to return the
+* corresponding config structure from XScuGic_ConfigTable
+* based on the scugic base address passed.
+* 1.02a sdm 12/20/11 Removed AckBeforeService from the XScuGic_Config
+* structure.
+* 1.03a srt 02/27/13 Moved Offset calculation macros from *.c and *_hw.c to
+* *_hw.h
+* Added APIs
+* - XScuGic_SetPriTrigTypeByDistAddr()
+* - XScuGic_GetPriTrigTypeByDistAddr()
+* (CR 702687)
+* Added support to direct interrupts to the appropriate CPU. Earlier
+* interrupts were directed to CPU1 (hard coded). Now depending
+* upon the CPU selected by the user (xparameters.h), interrupts
+* will be directed to the relevant CPU. This fixes CR 699688.
+* 1.04a hk 05/04/13 Assigned EffectiveAddr to CpuBaseAddress in
+* XScuGic_CfgInitialize. Fix for CR#704400 to remove warnings.
+* Moved functions XScuGic_SetPriTrigTypeByDistAddr and
+* XScuGic_GetPriTrigTypeByDistAddr to xscugic_hw.c.
+* This is fix for CR#705621.
+* 1.05a hk 06/26/13 Modified tcl to export external interrupts correctly to
+* xparameters.h. Fix for CR's 690505, 708928 & 719359.
+* 2.0 adk 12/10/13 Updated as per the New Tcl API's
+* 2.1 adk 25/04/14 Fixed the CR:789373 changes are made in the driver tcl file.
+* 3.00 kvn 02/13/15 Modified code for MISRA-C:2012 compliance.
+* 3.2 asa 02/29/16 Modified DistributorInit function for Zynq AMP case. The
+* distributor is left uninitialized for Zynq AMP. It is assumed
+* that the distributor will be initialized by Linux master. However
+* for CortexR5 case, the earlier code is left unchanged where the
+* the interrupt processor target registers in the distributor is
+* initialized with the corresponding CPU ID on which the application
+* built over the scugic driver runs.
+* These changes fix CR#937243.
+* 3.4 asa 04/07/16 Created a new static function DoDistributorInit to simplify
+* the flow and avoid code duplication. Changes are made for
+* USE_AMP use case for R5. In a scenario (in R5 split mode) when
+* one R5 is operating with A53 in open amp config and other
+* R5 running baremetal app, the existing code
+* had the potential to stop the whole AMP solution to work (if
+* for some reason the R5 running the baremetal app tasked to
+* initialize the Distributor hangs or crashes before initializing).
+* Changes are made so that the R5 under AMP first checks if
+* the distributor is enabled or not and if not, it does the
+* standard Distributor initialization.
+* This fixes the CR#952962.
+* 3.6 ms 01/23/17 Modified xil_printf statement in main function for all
+* examples to ensure that "Successfully ran" and "Failed"
+* strings are available in all examples. This is a fix
+* for CR-965028.
+* kvn 02/17/17 Add support for changing GIC CPU master at run time.
+* kvn 02/28/17 Make the CpuId as static variable and Added new
+* XScugiC_GetCpuId to access CpuId.
+* ms 03/17/17 Added readme.txt file in examples folder for doxygen
+* generation.
+* 3.7 ms 04/11/17 Modified tcl file to add suffix U for all macro
+* definitions of scugic in xparameters.h
+* 3.8 mus 07/05/17 Updated scugic.tcl to add support for interrupts connected
+* through util_reduced_vector IP(OR gate)
+* mus 07/05/17 Updated xdefine_zynq_canonical_xpars proc to initialize
+* the HandlerTable in XScuGic_ConfigTable to 0, it removes
+* the compilation warning in xscugic_g.c. Fix for CR#978736.
+* mus 07/25/17 Updated xdefine_gic_params proc to export correct canonical
+* definitions for pl to ps interrupts.Fix for CR#980534
+* 3.9 mus 02/21/18 Added new API's XScuGic_UnmapAllInterruptsFromCpu and
+* XScuGic_InterruptUnmapFromCpu, These API's can be used
+* by applications to unmap specific/all interrupts from
+* target CPU.
+* 3.10 aru 08/23/18 Resolved MISRA-C:2012 compliance mandatory violations
+* 4.0 mus 11/22/18 Fixed bugs in software interrupt generation through
+* XScuGic_SoftwareIntr API
+* 4.1 asa 03/30/19 Made changes not to direct each interrupt to all
+* available CPUs by default. This was breaking AMP
+* behavior. Instead every time an interrupt enable
+* request is received, the interrupt was mapped to
+* the respective CPU. There were several other changes
+* made to implement this. This set of changes was to
+* fix CR-1024716.
+* 4.1 mus 06/19/19 Added API's XScuGic_MarkCoreAsleep and
+* XScuGic_MarkCoreAwake to mark processor core as
+* asleep or awake. Fix for CR#1027220.
+* 4.5 asa 03/07/21 Included a header file xil_spinlock.h to ensure that
+* GIC driver can use newly introduced spinlock
+* functionality.
+* 4.6 sk 08/05/21 Fix scugic misrac violations.
+* 4.7 dp 11/22/21 Added new API XScuGic_IsInitialized() to check and return
+* the GIC initialization status.
+* </pre>
+#ifndef XSCUGIC_H /* prevent circular inclusions */
+#define XSCUGIC_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+/***************************** Include Files *********************************/
+#include "xstatus.h"
+#include "xscugic_hw.h"
+#include "xil_exception.h"
+#include "xil_spinlock.h"
+/************************** Constant Definitions *****************************/
+#define EFUSE_STATUS_OFFSET 0x10
+#define EFUSE_STATUS_CPU_MASK 0x80
+#if !defined (ARMR5) && !defined (__aarch64__) && !defined (ARMA53_32)
+#define ARMA9
+#endif
+#define XSCUGIC500_DCTLR_ARE_NS_ENABLE 0x20
+#define XSCUGIC500_DCTLR_ARE_S_ENABLE 0x10
+/**************************** Type Definitions *******************************/
+/* The following data type defines each entry in an interrupt vector table.
+ * The callback reference is the base address of the interrupting device
+ * for the low level driver and an instance pointer for the high level driver.
+typedef struct
+ Xil_InterruptHandler Handler;
+ void *CallBackRef;
+} XScuGic_VectorTableEntry;
+ * This typedef contains configuration information for the device.
+typedef struct
+ u16 DeviceId; /**< Unique ID of device */
+ u32 CpuBaseAddress; /**< CPU Interface Register base address */
+ u32 DistBaseAddress; /**< Distributor Register base address */
+ XScuGic_VectorTableEntry HandlerTable[XSCUGIC_MAX_NUM_INTR_INPUTS];/**<
+ Vector table of interrupt handlers */
+} XScuGic_Config;
+ * The XScuGic driver instance data. The user is required to allocate a
+ * variable of this type for every intc device in the system. A pointer
+ * to a variable of this type is then passed to the driver API functions.
+typedef struct
+ XScuGic_Config *Config; /**< Configuration table entry */
+ u32 IsReady; /**< Device is initialized and ready */
+ u32 UnhandledInterrupts; /**< Intc Statistics */
+} XScuGic;
+/************************** Variable Definitions *****************************/
+extern XScuGic_Config XScuGic_ConfigTable[]; /**< Config table */
+/***************** Macros (Inline Functions) Definitions *********************/
+* Write the given CPU Interface register
+* @param InstancePtr is a pointer to the instance to be worked on.
+* @return None.
+* @note
+* void XScuGic_CPUWriteReg(XScuGic *InstancePtr, u32 RegOffset, u32 Data)
+#define XScuGic_CPUWriteReg(InstancePtr, RegOffset, Data) \
+(XScuGic_WriteReg(((InstancePtr)->Config->CpuBaseAddress), (RegOffset), \
+ ((u32)(Data))))
+* Read the given CPU Interface register
+* @note
+* u32 XScuGic_CPUReadReg(XScuGic *InstancePtr, u32 RegOffset)
+#define XScuGic_CPUReadReg(InstancePtr, RegOffset) \
+ (XScuGic_ReadReg(((InstancePtr)->Config->CpuBaseAddress), (RegOffset)))
+* Write the given Distributor Interface register
+* @return None.
+* @note
+* void XScuGic_DistWriteReg(XScuGic *InstancePtr, u32 RegOffset, u32 Data)
+#define XScuGic_DistWriteReg(InstancePtr, RegOffset, Data) \
+(XScuGic_WriteReg(((InstancePtr)->Config->DistBaseAddress), (RegOffset), \
+ ((u32)(Data))))
+* Read the given Distributor Interface register
+* @note
+* u32 XScuGic_DistReadReg(XScuGic *InstancePtr, u32 RegOffset)
+#define XScuGic_DistReadReg(InstancePtr, RegOffset) \
+(XScuGic_ReadReg(((InstancePtr)->Config->DistBaseAddress), (RegOffset)))
+* Write the given ReDistributor Interface register
+* @return None.
+* @note
+#define XScuGic_ReDistWriteReg(InstancePtr, RegOffset, Data) \
+(XScuGic_WriteReg(((InstancePtr)->Config->DistBaseAddress)+ \
+ XSCUGIC_RDIST_OFFSET, (RegOffset), ((u32)(Data))))
+* Read the given ReDistributor Interface register
+* @note
+#define XScuGic_ReDistReadReg(InstancePtr, RegOffset) \
+(XScuGic_ReadReg((((InstancePtr)->Config->DistBaseAddress)+ \
+XSCUGIC_RDIST_OFFSET), (RegOffset)))
+* Write the given ReDistributor SGI PPI Interface register
+* @return None.
+* @note
+#define XScuGic_ReDistSGIPPIWriteReg(InstancePtr, RegOffset, Data) \
+ XSCUGIC_RDIST_SGI_PPI_OFFSET, (RegOffset), ((u32)(Data))))
+* Read the given ReDistributor SGI PPI Interface register
+* @note
+#define XScuGic_ReDistSGIPPIReadReg(InstancePtr, RegOffset) \
+ XSCUGIC_RDIST_SGI_PPI_OFFSET), (RegOffset)))
+* This function enables system register interface for GIC CPU Interface
+* @param value to be written
+* @return None.
+* @note None.
+#define XScuGic_Enable_SystemReg_CPU_Interface_EL3() mtcp(S3_6_C12_C12_5, 0xF);
+#define XScuGic_Enable_SystemReg_CPU_Interface_EL1() mtcp(S3_0_C12_C12_5, 0xF);
+* This function enables Grou0 interrupts
+* @param None.
+* @return None.
+* @note None.
+#define XScuGic_Enable_Group0_Interrupts() mtcp(S3_0_C12_C12_6,0x1);
+* This function enables Group1 interrupts
+* @param None.
+* @return None.
+* @note None.
+#if defined (__aarch64__)
+#if EL1_NONSECURE
+#define XScuGic_Enable_Group1_Interrupts() \
+ mtcp (S3_0_C12_C12_7, 0x1 | mfcp(S3_0_C12_C12_7) );
+#else
+ mtcp (S3_6_C12_C12_7, 0x1 | mfcp(S3_6_C12_C12_7) );
+#endif
+#endif
+* This function writes to ICC_SGI0R_EL1
+* @return None.
+* @note None.
+#define XScuGic_WriteICC_SGI0R_EL1(val) mtcp(S3_0_C12_C11_7,val)
+* This function writes to ICC_SGI1R_EL1
+* @return None.
+* @note None.
+#define XScuGic_WriteICC_SGI1R_EL1(val) mtcp(S3_0_C12_C11_5,val)
+* This function reads ICC_SGI1R_EL1 register
+* @param None
+* @return Value of ICC_SGI1R_EL1 register
+* @note None.
+#define XScuGic_ReadICC_SGI1R_EL1() mfcp(S3_0_C12_C11_5)
+* This function sets interrupt priority filter
+* @param None.
+* @return None.
+* @note None.
+#define XScuGic_set_priority_filter(val) __asm__ __volatile__("msr S3_0_C4_C6_0,%0" : : "r" (val))
+* This function returns interrupt id of highest priority pending interrupt
+* @param None.
+* @return None.
+* @note None.
+#if EL3
+#define XScuGic_get_IntID() mfcp(S3_0_C12_C8_0)
+#else
+#define XScuGic_get_IntID() mfcp(S3_0_C12_C12_0)
+#endif
+#endif
+* This function acks the interrupt
+* @param None.
+* @return None.
+* @note None.
+#if EL3
+#define XScuGic_ack_Int(val) mtcp(S3_0_C12_C8_1,val)
+#else
+#define XScuGic_ack_Int(val) mtcp(S3_0_C12_C12_1,val)
+#endif
+#endif
+* This macro returns bit position for the specific interrupt's trigger type
+* configuration within GICR_ICFGR0/GICR_ICFGR1 register
+* @param None.
+* @return None.
+* @note None.
+#define XScuGic_Get_Rdist_Int_Trigger_Index(IntrId) (((Int_Id%16) & 0x1f) << 2) +1
+/************************** Function Prototypes ******************************/
+ * Required functions in xscugic.c
+s32 XScuGic_Connect(XScuGic *InstancePtr, u32 Int_Id,
+ Xil_InterruptHandler Handler, void *CallBackRef);
+void XScuGic_Disconnect(XScuGic *InstancePtr, u32 Int_Id);
+void XScuGic_Enable(XScuGic *InstancePtr, u32 Int_Id);
+void XScuGic_Disable(XScuGic *InstancePtr, u32 Int_Id);
+s32 XScuGic_CfgInitialize(XScuGic *InstancePtr, XScuGic_Config *ConfigPtr,
+ u32 EffectiveAddr);
+s32 XScuGic_SoftwareIntr(XScuGic *InstancePtr, u32 Int_Id, u32 Cpu_Identifier);
+void XScuGic_GetPriorityTriggerType(XScuGic *InstancePtr, u32 Int_Id,
+ u8 *Priority, u8 *Trigger);
+void XScuGic_SetPriorityTriggerType(XScuGic *InstancePtr, u32 Int_Id,
+ u8 Priority, u8 Trigger);
+void XScuGic_InterruptMaptoCpu(XScuGic *InstancePtr, u8 Cpu_Identifier, u32 Int_Id);
+void XScuGic_InterruptUnmapFromCpu(XScuGic *InstancePtr, u8 Cpu_Identifier, u32 Int_Id);
+void XScuGic_UnmapAllInterruptsFromCpu(XScuGic *InstancePtr, u8 Cpu_Identifier);
+void XScuGic_Stop(XScuGic *InstancePtr);
+void XScuGic_SetCpuID(u32 CpuCoreId);
+u32 XScuGic_GetCpuID(void);
+u8 XScuGic_IsInitialized(u32 DeviceId);
+ * Initialization functions in xscugic_sinit.c
+XScuGic_Config *XScuGic_LookupConfig(u16 DeviceId);
+XScuGic_Config *XScuGic_LookupConfigBaseAddr(UINTPTR BaseAddress);
+ * Interrupt functions in xscugic_intr.c
+void XScuGic_InterruptHandler(XScuGic *InstancePtr);
+ * Self-test functions in xscugic_selftest.c
+s32 XScuGic_SelfTest(XScuGic *InstancePtr);
+#if defined (GICv3)
+void XScuGic_MarkCoreAsleep(XScuGic *InstancePtr);
+void XScuGic_MarkCoreAwake(XScuGic *InstancePtr);
+#endif
+#ifdef __cplusplus
+#endif
diff --git a/embeddedsw/XilinxProcessorIPLib/drivers/scugic/src/xscugic_hw.h b/embeddedsw/XilinxProcessorIPLib/drivers/scugic/src/xscugic_hw.h
index 0000000..57b388b
--- /dev/null
+++ b/embeddedsw/XilinxProcessorIPLib/drivers/scugic/src/xscugic_hw.h
@@ -0,0 +1,697 @@
+* Copyright (C) 2010 - 2022 Xilinx, Inc. All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xscugic_hw.h
+* This header file contains identifiers and HW access functions (or
+* macros) that can be used to access the device. The user should refer to the
+* hardware device specification for more details of the device operation.
+* The driver functions/APIs are defined in xscugic.h.
+* This GIC device has two parts, a distributor and CPU interface(s). Each part
+* has separate register definition sections.
+* <pre>
+* 1.00a drg 01/19/10 First release
+* 1.01a sdm 11/09/11 "xil_exception.h" added as include.
+* Macros XScuGic_EnableIntr and XScuGic_DisableIntr are
+* added to enable or disable interrupts based on
+* Distributor Register base address. Normally users use
+* XScuGic instance and call XScuGic_Enable or
+* XScuGic_Disable to enable/disable interrupts. These
+* new macros are provided when user does not want to
+* use an instance pointer but still wants to enable or
+* disable interrupts.
+* Function prototypes for functions (present in newly
+* added file xscugic_hw.c) are added.
+* 1.03a srt 02/27/13 Moved Offset calculation macros from *_hw.c (CR
+* 702687).
+* 1.04a hk 05/04/13 Fix for CR#705621. Moved function prototypes
+* XScuGic_SetPriTrigTypeByDistAddr and
+* XScuGic_GetPriTrigTypeByDistAddr here from xscugic.h
+* 3.0 pkp 12/09/14 changed XSCUGIC_MAX_NUM_INTR_INPUTS for
+* Zynq Ultrascale Mp
+* 3.0 kvn 02/13/14 Modified code for MISRA-C:2012 compliance.
+* 3.2 pkp 11/09/15 Corrected the interrupt processsor target mask value
+* for CPU interface 2 i.e. XSCUGIC_SPI_CPU2_MASK
+* 3.9 mus 02/21/18 Added new API's XScuGic_InterruptUnmapFromCpuByDistAddr
+* and XScuGic_UnmapAllInterruptsFromCpuByDistAddr, These
+* API's can be used by applications to unmap specific/all
+* interrupts from target CPU. It fixes CR#992490.
+* 4.1 asa 03/30/19 Removed macros for XScuGic_EnableIntr, and
+* XScuGic_DisableIntr. These are now C functions. This
+* change was to fix CR-1024716.
+* 4.1 mus 06/12/19 Updated XSCUGIC_MAX_NUM_INTR_INPUTS for Versal.
+* 4.6 sk 06/07/21 Delete the commented macro code to fix the MISRA-C warning.
+* 4.6 sk 08/05/21 Fix Scugic Misrac violations.
+* 4.7 sk 12/10/21 Update XSCUGIC_SPI_INT_ID_START macro from signed to unsigned
+* to fix misrac violation.
+* 4.7 mus 03/17/22 GICv3 coupled with A72 has different redistributor for
+* each core, and each redistributor has different address,
+* Updated #define for re-distributor address to have correct
+* value based on the cpu number. It fixes CR#1126156.
+* </pre>
+#ifndef XSCUGIC_HW_H /* prevent circular inclusions */
+#define XSCUGIC_HW_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "bspconfig.h"
+#if defined (versal) && !defined(ARMR5)
+#define GICv3
+#endif
+ * The maximum number of interrupts supported by the hardware.
+#ifdef PLATFORM_ZYNQ
+#define XSCUGIC_MAX_NUM_INTR_INPUTS 95U /* Maximum number of interrupt defined by Zynq */
+#elif defined (versal)
+#define XSCUGIC_MAX_NUM_INTR_INPUTS 192U
+#else
+#define XSCUGIC_MAX_NUM_INTR_INPUTS 195U /* Maximum number of interrupt defined by Zynq Ultrascale Mp */
+#endif
+ * First Interrupt Id for SPI interrupts.
+#define XSCUGIC_SPI_INT_ID_START 0x20U
+ * The maximum priority value that can be used in the GIC.
+#define XSCUGIC_MAX_INTR_PRIO_VAL 248U
+#define XSCUGIC_INTR_PRIO_MASK 0x000000F8U
+/** @name Distributor Interface Register Map
+ * Define the offsets from the base address for all Distributor registers of
+ * the interrupt controller, some registers may be reserved in the hardware
+ * device.
+#define XSCUGIC_DIST_EN_OFFSET 0x00000000U /**< Distributor Enable
+ Register */
+#define XSCUGIC_IC_TYPE_OFFSET 0x00000004U /**< Interrupt Controller
+ Type Register */
+#define XSCUGIC_DIST_IDENT_OFFSET 0x00000008U /**< Implementor ID
+ Register */
+#define XSCUGIC_SECURITY_OFFSET 0x00000080U /**< Interrupt Security
+ Register */
+#define XSCUGIC_ENABLE_SET_OFFSET 0x00000100U /**< Enable Set
+ Register */
+#define XSCUGIC_DISABLE_OFFSET 0x00000180U /**< Enable Clear Register */
+#define XSCUGIC_PENDING_SET_OFFSET 0x00000200U /**< Pending Set
+ Register */
+#define XSCUGIC_PENDING_CLR_OFFSET 0x00000280U /**< Pending Clear
+ Register */
+#define XSCUGIC_ACTIVE_OFFSET 0x00000300U /**< Active Status Register */
+#define XSCUGIC_PRIORITY_OFFSET 0x00000400U /**< Priority Level Register */
+#define XSCUGIC_SPI_TARGET_OFFSET 0x00000800U /**< SPI Target
+ Register 0x800-0x8FB */
+#define XSCUGIC_INT_CFG_OFFSET 0x00000C00U /**< Interrupt Configuration
+ Register 0xC00-0xCFC */
+#define XSCUGIC_PPI_STAT_OFFSET 0x00000D00U /**< PPI Status Register */
+#define XSCUGIC_SPI_STAT_OFFSET 0x00000D04U /**< SPI Status Register
+ 0xd04-0xd7C */
+#define XSCUGIC_AHB_CONFIG_OFFSET 0x00000D80U /**< AHB Configuration
+ Register */
+#define XSCUGIC_SFI_TRIG_OFFSET 0x00000F00U /**< Software Triggered
+ Interrupt Register */
+#define XSCUGIC_PERPHID_OFFSET 0x00000FD0U /**< Peripheral ID Reg */
+#define XSCUGIC_PCELLID_OFFSET 0x0000FFF0U /**< Pcell ID Register */
+#else
+#define XSCUGIC_PCELLID_OFFSET 0x00000FF0U /**< Pcell ID Register */
+#endif
+/** @name Distributor Enable Register
+ * Controls if the distributor response to external interrupt inputs.
+#define XSCUGIC_EN_INT_MASK 0x00000003U /**< Interrupt In Enable */
+#else
+#define XSCUGIC_EN_INT_MASK 0x00000001U /**< Interrupt In Enable */
+#endif
+/** @name Interrupt Controller Type Register
+#define XSCUGIC_LSPI_MASK 0x0000F800U /**< Number of Lockable
+ Shared Peripheral
+ Interrupts*/
+#define XSCUGIC_DOMAIN_MASK 0x00000400U /**< Number os Security domains*/
+#define XSCUGIC_CPU_NUM_MASK 0x000000E0U /**< Number of CPU Interfaces */
+#define XSCUGIC_NUM_INT_MASK 0x0000001FU /**< Number of Interrupt IDs */
+/** @name Implementor ID Register
+ * Implementor and revision information.
+#define XSCUGIC_REV_MASK 0x00FFF000U /**< Revision Number */
+#define XSCUGIC_IMPL_MASK 0x00000FFFU /**< Implementor */
+/** @name Interrupt Security Registers
+ * Each bit controls the security level of an interrupt, either secure or non
+ * secure. These registers can only be accessed using secure read and write.
+ * There are registers for each of the CPU interfaces at offset 0x080. A
+ * register set for the SPI interrupts is available to all CPU interfaces.
+ * There are up to 32 of these registers staring at location 0x084.
+#define XSCUGIC_INT_NS_MASK 0x00000001U /**< Each bit corresponds to an
+ INT_ID */
+/** @name Enable Set Register
+ * Each bit controls the enabling of an interrupt, a 0 is disabled, a 1 is
+ * enabled. Writing a 0 has no effect. Use the ENABLE_CLR register to set a
+ * bit to 0.
+ * There are registers for each of the CPU interfaces at offset 0x100. With up
+ * to 8 registers aliased to the same address. A register set for the SPI
+ * interrupts is available to all CPU interfaces.
+ * There are up to 32 of these registers staring at location 0x104.
+#define XSCUGIC_INT_EN_MASK 0x00000001U /**< Each bit corresponds to an
+ INT_ID */
+/** @name Enable Clear Register
+ * Each bit controls the disabling of an interrupt, a 0 is disabled, a 1 is
+ * enabled. Writing a 0 has no effect. Writing a 1 disables an interrupt and
+ * sets the corresponding bit to 0.
+ * There are registers for each of the CPU interfaces at offset 0x180. With up
+ * A register set for the SPI interrupts is available to all CPU interfaces.
+ * There are up to 32 of these registers staring at location 0x184.
+#define XSCUGIC_INT_CLR_MASK 0x00000001U /**< Each bit corresponds to an
+ INT_ID */
+/** @name Pending Set Register
+ * Each bit controls the Pending or Active and Pending state of an interrupt, a
+ * 0 is not pending, a 1 is pending. Writing a 0 has no effect. Writing a 1 sets
+ * an interrupt to the pending state.
+ * There are registers for each of the CPU interfaces at offset 0x200. With up
+ * There are up to 32 of these registers staring at location 0x204.
+#define XSCUGIC_PEND_SET_MASK 0x00000001U /**< Each bit corresponds to an
+ INT_ID */
+/** @name Pending Clear Register
+ * Each bit can clear the Pending or Active and Pending state of an interrupt, a
+ * clears the pending state of an interrupt.
+ * There are registers for each of the CPU interfaces at offset 0x280. With up
+ * There are up to 32 of these registers staring at location 0x284.
+#define XSCUGIC_PEND_CLR_MASK 0x00000001U /**< Each bit corresponds to an
+ INT_ID */
+/** @name Active Status Register
+ * Each bit provides the Active status of an interrupt, a
+ * 0 is not Active, a 1 is Active. This is a read only register.
+ * There are registers for each of the CPU interfaces at offset 0x300. With up
+ * to 8 registers aliased to each address.
+ * There are up to 32 of these registers staring at location 0x380.
+#define XSCUGIC_ACTIVE_MASK 0x00000001U /**< Each bit corresponds to an
+ INT_ID */
+/** @name Priority Level Register
+ * Each byte in a Priority Level Register sets the priority level of an
+ * interrupt. Reading the register provides the priority level of an interrupt.
+ * There are registers for each of the CPU interfaces at offset 0x400 through
+ * 0x41C. With up to 8 registers aliased to each address.
+ * 0 is highest priority, 0xFF is lowest.
+ * There are up to 255 of these registers staring at location 0x420.
+#define XSCUGIC_PRIORITY_MASK 0x000000FFU /**< Each Byte corresponds to an
+ INT_ID */
+#define XSCUGIC_PRIORITY_MAX 0x000000FFU /**< Highest value of a priority
+ actually the lowest priority*/
+/** @name SPI Target Register 0x800-0x8FB
+ * Each byte references a separate SPI and programs which of the up to 8 CPU
+ * interfaces are sent a Pending interrupt.
+ * There are registers for each of the CPU interfaces at offset 0x800 through
+ * 0x81C. With up to 8 registers aliased to each address.
+ * There are up to 255 of these registers staring at location 0x820.
+ * This driver does not support multiple CPU interfaces. These are included
+ * for complete documentation.
+#define XSCUGIC_SPI_CPU7_MASK 0x00000080U /**< CPU 7 Mask*/
+#define XSCUGIC_SPI_CPU6_MASK 0x00000040U /**< CPU 6 Mask*/
+#define XSCUGIC_SPI_CPU5_MASK 0x00000020U /**< CPU 5 Mask*/
+#define XSCUGIC_SPI_CPU4_MASK 0x00000010U /**< CPU 4 Mask*/
+#define XSCUGIC_SPI_CPU3_MASK 0x00000008U /**< CPU 3 Mask*/
+#define XSCUGIC_SPI_CPU2_MASK 0x00000004U /**< CPU 2 Mask*/
+#define XSCUGIC_SPI_CPU1_MASK 0x00000002U /**< CPU 1 Mask*/
+#define XSCUGIC_SPI_CPU0_MASK 0x00000001U /**< CPU 0 Mask*/
+/** @name Interrupt Configuration Register 0xC00-0xCFC
+ * The interrupt configuration registers program an SFI to be active HIGH level
+ * sensitive or rising edge sensitive.
+ * Each bit pair describes the configuration for an INT_ID.
+ * SFI Read Only b10 always
+ * PPI Read Only depending on how the PPIs are configured.
+ * b01 Active HIGH level sensitive
+ * b11 Rising edge sensitive
+ * SPI LSB is read only.
+ * b11 Rising edge sensitive/
+ * There are registers for each of the CPU interfaces at offset 0xC00 through
+ * 0xC04. With up to 8 registers aliased to each address.
+ * There are up to 255 of these registers staring at location 0xC08.
+#define XSCUGIC_INT_CFG_MASK 0x00000003U /**< */
+/** @name PPI Status Register
+ * Enables an external AMBA master to access the status of the PPI inputs.
+ * A CPU can only read the status of its local PPI signals and cannot read the
+ * status for other CPUs.
+ * This register is aliased for each CPU interface.
+#define XSCUGIC_PPI_C15_MASK 0x00008000U /**< PPI Status */
+#define XSCUGIC_PPI_C14_MASK 0x00004000U /**< PPI Status */
+#define XSCUGIC_PPI_C13_MASK 0x00002000U /**< PPI Status */
+#define XSCUGIC_PPI_C12_MASK 0x00001000U /**< PPI Status */
+#define XSCUGIC_PPI_C11_MASK 0x00000800U /**< PPI Status */
+#define XSCUGIC_PPI_C10_MASK 0x00000400U /**< PPI Status */
+#define XSCUGIC_PPI_C09_MASK 0x00000200U /**< PPI Status */
+#define XSCUGIC_PPI_C08_MASK 0x00000100U /**< PPI Status */
+#define XSCUGIC_PPI_C07_MASK 0x00000080U /**< PPI Status */
+#define XSCUGIC_PPI_C06_MASK 0x00000040U /**< PPI Status */
+#define XSCUGIC_PPI_C05_MASK 0x00000020U /**< PPI Status */
+#define XSCUGIC_PPI_C04_MASK 0x00000010U /**< PPI Status */
+#define XSCUGIC_PPI_C03_MASK 0x00000008U /**< PPI Status */
+#define XSCUGIC_PPI_C02_MASK 0x00000004U /**< PPI Status */
+#define XSCUGIC_PPI_C01_MASK 0x00000002U /**< PPI Status */
+#define XSCUGIC_PPI_C00_MASK 0x00000001U /**< PPI Status */
+/** @name SPI Status Register 0xd04-0xd7C
+ * Enables an external AMBA master to access the status of the SPI inputs.
+ * There are up to 63 registers if the maximum number of SPI inputs are
+ * configured.
+#define XSCUGIC_SPI_N_MASK 0x00000001U /**< Each bit corresponds to an SPI
+ input */
+/** @name AHB Configuration Register
+ * Provides the status of the CFGBIGEND input signal and allows the endianness
+ * of the GIC to be set.
+#define XSCUGIC_AHB_END_MASK 0x00000004U /**< 0-GIC uses little Endian,
+ 1-GIC uses Big Endian */
+#define XSCUGIC_AHB_ENDOVR_MASK 0x00000002U /**< 0-Uses CFGBIGEND control,
+ 1-use the AHB_END bit */
+#define XSCUGIC_AHB_TIE_OFF_MASK 0x00000001U /**< State of CFGBIGEND */
+/** @name Software Triggered Interrupt Register
+ * Controls issuing of software interrupts.
+#define XSCUGIC_SFI_SELFTRIG_MASK 0x02010000U
+#define XSCUGIC_SFI_TRIG_TRGFILT_MASK 0x03000000U /**< Target List filter
+ b00-Use the target List
+ b01-All CPUs except requester
+ b10-To Requester
+ b11-reserved */
+#define XSCUGIC_SFI_TRIG_CPU_MASK 0x00FF0000U /**< CPU Target list */
+#define XSCUGIC_SFI_TRIG_SATT_MASK 0x00008000U /**< 0= Use a secure interrupt */
+#define XSCUGIC_SFI_TRIG_INTID_MASK 0x0000000FU /**< Set to the INTID
+ signaled to the CPU*/
+/** @name CPU Interface Register Map
+ * Define the offsets from the base address for all CPU registers of the
+ * interrupt controller, some registers may be reserved in the hardware device.
+#define XSCUGIC_CONTROL_OFFSET 0x00000000U /**< CPU Interface Control
+ Register */
+#define XSCUGIC_CPU_PRIOR_OFFSET 0x00000004U /**< Priority Mask Reg */
+#define XSCUGIC_BIN_PT_OFFSET 0x00000008U /**< Binary Point Register */
+#define XSCUGIC_INT_ACK_OFFSET 0x0000000CU /**< Interrupt ACK Reg */
+#define XSCUGIC_EOI_OFFSET 0x00000010U /**< End of Interrupt Reg */
+#define XSCUGIC_RUN_PRIOR_OFFSET 0x00000014U /**< Running Priority Reg */
+#define XSCUGIC_HI_PEND_OFFSET 0x00000018U /**< Highest Pending Interrupt
+ Register */
+#define XSCUGIC_ALIAS_BIN_PT_OFFSET 0x0000001CU /**< Aliased non-Secure
+ Binary Point Register */
+/**< 0x00000020 to 0x00000FBC are reserved and should not be read or written
+ * to. */
+/** @name Control Register
+ * CPU Interface Control register definitions
+ * All bits are defined here although some are not available in the non-secure
+ * mode.
+#define XSCUGIC_CNTR_SBPR_MASK 0x00000010U /**< Secure Binary Pointer,
+ 0=separate registers,
+ 1=both use bin_pt_s */
+#define XSCUGIC_CNTR_FIQEN_MASK 0x00000008U /**< Use nFIQ_C for secure
+ interrupts,
+ 0= use IRQ for both,
+ 1=Use FIQ for secure, IRQ for non*/
+#define XSCUGIC_CNTR_ACKCTL_MASK 0x00000004U /**< Ack control for secure or non secure */
+#define XSCUGIC_CNTR_EN_NS_MASK 0x00000002U /**< Non Secure enable */
+#define XSCUGIC_CNTR_EN_S_MASK 0x00000001U /**< Secure enable, 0=Disabled, 1=Enabled */
+/** @name Binary Point Register
+ * Binary Point register definitions
+#define XSCUGIC_BIN_PT_MASK 0x00000007U /**< Binary point mask value
+ Value Secure Non-secure
+ b000 0xFE 0xFF
+ b001 0xFC 0xFE
+ b010 0xF8 0xFC
+ b011 0xF0 0xF8
+ b100 0xE0 0xF0
+ b101 0xC0 0xE0
+ b110 0x80 0xC0
+ b111 0x00 0x80
+/** @name Interrupt Acknowledge Register
+ * Interrupt Acknowledge register definitions
+ * Identifies the current Pending interrupt, and the CPU ID for software
+ * interrupts.
+#define XSCUGIC_ACK_INTID_MASK 0x000003FFU /**< Interrupt ID */
+#define XSCUGIC_CPUID_MASK 0x00000C00U /**< CPU ID */
+/** @name End of Interrupt Register
+ * End of Interrupt register definitions
+ * Allows the CPU to signal the GIC when it completes an interrupt service
+ * routine.
+#define XSCUGIC_EOI_INTID_MASK 0x000003FFU /**< Interrupt ID */
+/** @name Running Priority Register
+ * Running Priority register definitions
+ * Identifies the interrupt priority level of the highest priority active
+ * interrupt.
+#define XSCUGIC_RUN_PRIORITY_MASK 0x000000FFU /**< Interrupt Priority */
+#define XSCUGIC_IROUTER_BASE_OFFSET 0x6000U
+#endif
+ * Highest Pending Interrupt register definitions
+ * Identifies the interrupt priority of the highest priority pending interrupt
+#define XSCUGIC_PEND_INTID_MASK 0x000003FFU /**< Pending Interrupt ID */
+/** @name ReDistributor Interface Register Map
+#define XSCUGIC_RDIST_OFFSET (0x80000U + (XPAR_CPU_ID * 0x20000))
+#define XSCUGIC_RDIST_BASE_ADDRESS (XPAR_SCUGIC_0_DIST_BASEADDR + XSCUGIC_RDIST_OFFSET)
+#define XSCUGIC_RDIST_SGI_PPI_OFFSET (0x90000U + (XPAR_CPU_ID * 0x20000))
+#define XSCUGIC_RDIST_SGI_PPI_BASE_ADDRESS (XPAR_SCUGIC_0_DIST_BASEADDR + XSCUGIC_RDIST_SGI_PPI_OFFSET)
+#define XSCUGIC_RDIST_ISENABLE_OFFSET 0x100U
+#define XSCUGIC_RDIST_IPRIORITYR_OFFSET 0x400U
+#define XSCUGIC_RDIST_IGROUPR_OFFSET 0x80U
+#define XSCUGIC_RDIST_GRPMODR_OFFSET 0xD00U
+#define XSCUGIC_RDIST_INT_CONFIG_OFFSET 0xC00U
+#define XSCUGIC_RDIST_WAKER_OFFSET 0x14U
+#define XSCUGIC_SGIR_EL1_INITID_SHIFT 24U
+ * GICR_IGROUPR register definitions
+#if EL3
+#define XSCUGIC_DEFAULT_SECURITY 0x0U
+#else
+#define XSCUGIC_DEFAULT_SECURITY 0xFFFFFFFFU
+#endif
+ * GICR_WAKER register definitions
+#define XSCUGIC_RDIST_WAKER_LOW_POWER_STATE_MASK 0x7
+#endif
+* Read the Interrupt Configuration Register offset for an interrupt id.
+* @param InterruptID is the interrupt number.
+* @return The 32-bit value of the offset
+* @note
+#define XSCUGIC_INT_CFG_OFFSET_CALC(InterruptID) \
+ ((u32)XSCUGIC_INT_CFG_OFFSET + (((InterruptID)/16U) * 4U))
+* Read the Interrupt Priority Register offset for an interrupt id.
+* @note
+#define XSCUGIC_PRIORITY_OFFSET_CALC(InterruptID) \
+ ((u32)XSCUGIC_PRIORITY_OFFSET + (((InterruptID)/4U) * 4U))
+* Read the Interrupt Routing Register offset for an interrupt id.
+* @note
+#define XSCUGIC_IROUTER_OFFSET_CALC(InterruptID) \
+ ((u32)XSCUGIC_IROUTER_BASE_OFFSET + (InterruptID * 8))
+* Read the SPI Target Register offset for an interrupt id.
+* @note
+#define XSCUGIC_SPI_TARGET_OFFSET_CALC(InterruptID) \
+ ((u32)XSCUGIC_SPI_TARGET_OFFSET + (((InterruptID)/4U) * 4U))
+* @note
+#define XSCUGIC_SECURITY_TARGET_OFFSET_CALC(InterruptID) \
+ ((u32)XSCUGIC_SECURITY_OFFSET + (((InterruptID)/32U)*4U))
+* Read the Re-distributor Interrupt configuration register offset
+* @note
+#define XSCUGIC_RDIST_INT_CONFIG_OFFSET_CALC(InterruptID) \
+ ((u32)XSCUGIC_RDIST_INT_CONFIG_OFFSET + ((InterruptID /16)*4))
+* Read the Re-distributor Interrupt Priority register offset
+* @note
+#define XSCUGIC_RDIST_INT_PRIORITY_OFFSET_CALC(InterruptID) \
+ ((u32)XSCUGIC_RDIST_IPRIORITYR_OFFSET + (InterruptID * 4))
+* Read the Interrupt Clear-Enable Register offset for an interrupt ID
+* @param Register is the register offset for the clear/enable bank.
+* @note
+#define XSCUGIC_EN_DIS_OFFSET_CALC(Register, InterruptID) \
+ ((Register) + (((InterruptID)/32U) * 4U))
+* Read the given Intc register.
+* @param BaseAddress is the base address of the device.
+* @note
+* u32 XScuGic_ReadReg(u32 BaseAddress, u32 RegOffset)
+#define XScuGic_ReadReg(BaseAddress, RegOffset) \
+ (Xil_In32((BaseAddress) + (RegOffset)))
+* Write the given Intc register.
+* @return None.
+* @note
+* void XScuGic_WriteReg(u32 BaseAddress, u32 RegOffset, u32 Data)
+#define XScuGic_WriteReg(BaseAddress, RegOffset, Data) \
+ (Xil_Out32(((BaseAddress) + (RegOffset)), ((u32)(Data))))
+void XScuGic_DeviceInterruptHandler(void *DeviceId);
+s32 XScuGic_DeviceInitialize(u32 DeviceId);
+void XScuGic_RegisterHandler(u32 BaseAddress, s32 InterruptID,
+ Xil_InterruptHandler IntrHandler, void *CallBackRef);
+void XScuGic_SetPriTrigTypeByDistAddr(u32 DistBaseAddress, u32 Int_Id,
+void XScuGic_GetPriTrigTypeByDistAddr(u32 DistBaseAddress, u32 Int_Id,
+void XScuGic_InterruptMapFromCpuByDistAddr(u32 DistBaseAddress,
+ u8 Cpu_Id, u32 Int_Id);
+void XScuGic_InterruptUnmapFromCpuByDistAddr(u32 DistBaseAddress,
+void XScuGic_UnmapAllInterruptsFromCpuByDistAddr(u32 DistBaseAddress,
+ u8 Cpu_Id);
+void XScuGic_EnableIntr (u32 DistBaseAddress, u32 Int_Id);
+void XScuGic_DisableIntr (u32 DistBaseAddress, u32 Int_Id);
+#ifdef __cplusplus
+#endif
diff --git a/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h b/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h
new file mode 100644
index 0000000..b878d05
--- /dev/null
+++ b/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h
@@ -0,0 +1,75 @@
+* Copyright (c) 2014 - 2021 Xilinx, Inc. All rights reserved.
+* @file xil_cache.h
+* @addtogroup a53_64_cache_apis Cortex A53 64bit Processor Cache Functions
+* Cache functions provide access to cache related operations such as flush
+* and invalidate for instruction and data caches. It gives option to perform
+* the cache operations on a single cacheline, a range of memory and an entire
+* cache.
+* <pre>
+* 5.00 pkp 05/29/14 First release
+* </pre>
+#ifndef XIL_CACHE_H
+#define XIL_CACHE_H
+#include "xil_types.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *@cond nocomments
+#define L1_DATA_PREFETCH_CONTROL_MASK 0xE000
+#define L1_DATA_PREFETCH_CONTROL_SHIFT 13
+ *@endcond
+#define Xil_DCacheFlushRange Xil_DCacheInvalidateRange
+void Xil_DCacheEnable(void);
+void Xil_DCacheDisable(void);
+void Xil_DCacheInvalidate(void);
+void Xil_DCacheInvalidateRange(INTPTR adr, INTPTR len);
+void Xil_DCacheInvalidateLine(INTPTR adr);
+void Xil_DCacheFlush(void);
+void Xil_DCacheFlushLine(INTPTR adr);
+void Xil_ICacheEnable(void);
+void Xil_ICacheDisable(void);
+void Xil_ICacheInvalidate(void);
+void Xil_ICacheInvalidateRange(INTPTR adr, INTPTR len);
+void Xil_ICacheInvalidateLine(INTPTR adr);
+void Xil_ConfigureL1Prefetch(u8 num);
+#ifdef __cplusplus
+#endif
+#endif
+* @} End of "addtogroup a53_64_cache_apis".
diff --git a/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_mmu.h b/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_mmu.h
index 0000000..396a0ab
--- /dev/null
+++ b/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_mmu.h
@@ -0,0 +1,94 @@
+* @file xil_mmu.h
+* @addtogroup a53_64_mmu_apis Cortex A53 64bit Processor MMU Handling
+* MMU function equip users to modify default memory attributes of MMU table as
+* per the need.
+* <pre>
+* </pre>
+* @note
+* None.
+#ifndef XIL_MMU_H
+#define XIL_MMU_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ *@cond nocomments
+/* Memory type */
+#define NORM_NONCACHE 0x401UL /* Normal Non-cacheable*/
+#define STRONG_ORDERED 0x409UL /* Strongly ordered (Device-nGnRnE)*/
+#define DEVICE_MEMORY 0x40DUL /* Device memory (Device-nGnRE)*/
+#define RESERVED 0x0UL /* reserved memory*/
+/* Normal write-through cacheable inner shareable*/
+#define NORM_WT_CACHE 0x711UL
+/* Normal write back cacheable inner-shareable */
+#define NORM_WB_CACHE 0x705UL
+ * shareability attribute only applicable to
+ * normal cacheable memory
+#define INNER_SHAREABLE (0x3 << 8)
+#define OUTER_SHAREABLE (0x2 << 8)
+#define NON_SHAREABLE (~(0x3 << 8))
+/* Execution type */
+#define EXECUTE_NEVER ((0x1 << 53) | (0x1 << 54))
+/* Security type */
+#define NON_SECURE (0x1 << 5)
+ *@endcond
+void Xil_SetTlbAttributes(UINTPTR Addr, u64 attrib);
+#ifdef __cplusplus
+#endif /* XIL_MMU_H */
+* @} End of "addtogroup a53_64_mmu_apis".
diff --git a/embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h b/embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h
index 0000000..144d842
--- /dev/null
+++ b/embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h
@@ -0,0 +1,408 @@
+* Copyright (c) 2015 - 2022 Xilinx, Inc. All rights reserved.
+* @file xil_exception.h
+* This header file contains ARM Cortex A53,A9,R5 specific exception related APIs.
+* For exception related functions that can be used across all Xilinx supported
+* processors, please use xil_exception.h.
+* @addtogroup arm_exception_apis ARM Processor Exception Handling
+* ARM processors specific exception related APIs for cortex A53,A9 and R5 can
+* utilized for enabling/disabling IRQ, registering/removing handler for
+* exceptions or initializing exception vector table with null handler.
+* <pre>
+* 5.2 pkp 28/05/15 First release
+* 6.0 mus 27/07/16 Consolidated file for a53,a9 and r5 processors
+* 6.7 mna 26/04/18 Add API Xil_GetExceptionRegisterHandler.
+* 6.7 asa 18/05/18 Update signature of API Xil_GetExceptionRegisterHandler.
+* 7.0 mus 01/03/19 Tweak Xil_ExceptionEnableMask and
+* Xil_ExceptionDisableMask macros to support legacy
+* examples for Cortexa72 EL3 exception level.
+* 7.3 mus 04/15/20 Added Xil_EnableNestedInterrupts and
+* Xil_DisableNestedInterrupts macros for ARMv8.
+* For Cortexa72, these macro's would not be supported
+* at EL3, as Cortexa72 is using GIC-500(GICv3), which
+* triggeres only FIQ at EL3. Fix for CR#1062506
+* 7.6 mus 09/17/21 Updated flag checking to fix warning reported with
+* -Wundef compiler option CR#1110261
+* 7.7 mus 01/31/22 Few of the #defines in xil_exception.h in are treated
+* in different way based on "versal" flag. In existing
+* flow, this flag is defined only in xparameters.h and
+* BSP compiler flags, it is not defined in application
+* compiler flags. So, including xil_exception.h in
+* application source file, without including
+* xparameters.h results in incorrect behavior.
+* Including xparameters.h in xil_exception.h to avoid
+* such issues. It fixes CR#1120498.
+* 7.7 sk 03/02/22 Define XExc_VectorTableEntry structure to fix
+* misra_c_2012_rule_5_6 violation.
+* 7.7 sk 03/02/22 Add XExc_VectorTable as extern to fix misra_c_2012_
+* rule_8_4 violation.
+* </pre>
+ *@cond nocomments
+#ifndef XIL_EXCEPTION_H /* prevent circular inclusions */
+#define XIL_EXCEPTION_H /* by using protection macros */
+/***************************** Include Files ********************************/
+#include "xpseudo_asm.h"
+#include "xparameters.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+/************************** Constant Definitions ****************************/
+#define XIL_EXCEPTION_FIQ XREG_CPSR_FIQ_ENABLE
+#define XIL_EXCEPTION_IRQ XREG_CPSR_IRQ_ENABLE
+#define XIL_EXCEPTION_ALL (XREG_CPSR_FIQ_ENABLE | XREG_CPSR_IRQ_ENABLE)
+#define XIL_EXCEPTION_ID_FIRST 0U
+#define XIL_EXCEPTION_ID_SYNC_INT 1U
+#define XIL_EXCEPTION_ID_IRQ_INT 2U
+#define XIL_EXCEPTION_ID_FIQ_INT 3U
+#define XIL_EXCEPTION_ID_SERROR_ABORT_INT 4U
+#define XIL_EXCEPTION_ID_LAST 5U
+#else
+#define XIL_EXCEPTION_ID_RESET 0U
+#define XIL_EXCEPTION_ID_UNDEFINED_INT 1U
+#define XIL_EXCEPTION_ID_SWI_INT 2U
+#define XIL_EXCEPTION_ID_PREFETCH_ABORT_INT 3U
+#define XIL_EXCEPTION_ID_DATA_ABORT_INT 4U
+#define XIL_EXCEPTION_ID_IRQ_INT 5U
+#define XIL_EXCEPTION_ID_FIQ_INT 6U
+#define XIL_EXCEPTION_ID_LAST 6U
+#endif
+ * XIL_EXCEPTION_ID_INT is defined for all Xilinx processors.
+#if defined (versal) && !defined(ARMR5) && EL3
+#define XIL_EXCEPTION_ID_INT XIL_EXCEPTION_ID_FIQ_INT
+#else
+#define XIL_EXCEPTION_ID_INT XIL_EXCEPTION_ID_IRQ_INT
+#endif
+/**************************** Type Definitions ******************************/
+ * This typedef is the exception handler function.
+typedef void (*Xil_ExceptionHandler)(void *data);
+typedef void (*Xil_InterruptHandler)(void *data);
+typedef struct {
+ Xil_ExceptionHandler Handler;
+ void *Data;
+} XExc_VectorTableEntry;
+extern XExc_VectorTableEntry XExc_VectorTable[];
+*@endcond
+/***************** Macros (Inline Functions) Definitions ********************/
+* @brief Enable Exceptions.
+* @param Mask: Value for enabling the exceptions.
+* @return None.
+* @note If bit is 0, exception is enabled.
+* C-Style signature: void Xil_ExceptionEnableMask(Mask)
+ * Cortexa72 processor in versal is coupled with GIC-500, and GIC-500 supports
+ * only FIQ at EL3. Hence, tweaking this macro to always enable FIQ
+ * ignoring argument passed by user.
+#define Xil_ExceptionEnableMask(Mask) \
+ mtcpsr(mfcpsr() & ~ ((XIL_EXCEPTION_FIQ) & XIL_EXCEPTION_ALL))
+#elif defined (__GNUC__) || defined (__ICCARM__)
+ mtcpsr(mfcpsr() & ~ ((Mask) & XIL_EXCEPTION_ALL))
+#else
+ register u32 Reg __asm("cpsr"); \
+ mtcpsr((Reg) & (~((Mask) & XIL_EXCEPTION_ALL))); \
+#endif
+* @brief Enable the IRQ exception.
+* @return None.
+* @note None.
+#define Xil_ExceptionEnable() \
+ Xil_ExceptionEnableMask(XIL_EXCEPTION_FIQ)
+#else
+ Xil_ExceptionEnableMask(XIL_EXCEPTION_IRQ)
+#endif
+* @brief Disable Exceptions.
+* @param Mask: Value for disabling the exceptions.
+* @return None.
+* @note If bit is 1, exception is disabled.
+* C-Style signature: Xil_ExceptionDisableMask(Mask)
+ * only FIQ at EL3. Hence, tweaking this macro to always disable FIQ
+#define Xil_ExceptionDisableMask(Mask) \
+ mtcpsr(mfcpsr() | ((XIL_EXCEPTION_FIQ) & XIL_EXCEPTION_ALL))
+ mtcpsr(mfcpsr() | ((Mask) & XIL_EXCEPTION_ALL))
+#else
+ mtcpsr((Reg) | ((Mask) & XIL_EXCEPTION_ALL)); \
+#endif
+* Disable the IRQ exception.
+* @return None.
+* @note None.
+#define Xil_ExceptionDisable() \
+ Xil_ExceptionDisableMask(XIL_EXCEPTION_IRQ)
+#if ( defined (PLATFORM_ZYNQMP) && defined (EL3) && (EL3==1) )
+* @brief Enable nested interrupts by clearing the I bit in DAIF.This
+* macro is defined for Cortex-A53 64 bit mode BSP configured to run
+* at EL3.. However,it is not defined for Versal Cortex-A72 BSP
+* configured to run at EL3. Reason is, Cortex-A72 is coupled
+* with GIC-500(GICv3 specifications) and it triggers only FIQ at EL3.
+* @return None.
+* @note This macro is supposed to be used from interrupt handlers. In the
+* interrupt handler the interrupts are disabled by default (I bit
+* is set as 1). To allow nesting of interrupts, this macro should be
+* used. It clears the I bit. Once that bit is cleared and provided the
+* preemption of interrupt conditions are met in the GIC, nesting of
+* interrupts will start happening.
+* Caution: This macro must be used with caution. Before calling this
+* macro, the user must ensure that the source of the current IRQ
+* is appropriately cleared. Otherwise, as soon as we clear the I
+* bit, there can be an infinite loop of interrupts with an
+* eventual crash (all the stack space getting consumed).
+#define Xil_EnableNestedInterrupts() \
+ __asm__ __volatile__ ("mrs X1, ELR_EL3"); \
+ __asm__ __volatile__ ("mrs X2, SPSR_EL3"); \
+ __asm__ __volatile__ ("stp X1,X2, [sp,#-0x10]!"); \
+ __asm__ __volatile__ ("mrs X1, DAIF"); \
+ __asm__ __volatile__ ("bic X1,X1,#(0x1<<7)"); \
+ __asm__ __volatile__ ("msr DAIF, X1"); \
+* @brief Disable the nested interrupts by setting the I bit in DAIF. This
+* at EL3.
+* @return None.
+* @note This macro is meant to be called in the interrupt service routines.
+* This macro cannot be used independently. It can only be used when
+* nesting of interrupts have been enabled by using the macro
+* Xil_EnableNestedInterrupts(). In a typical flow, the user first
+* calls the Xil_EnableNestedInterrupts in the ISR at the appropriate
+* point. The user then must call this macro before exiting the interrupt
+* service routine. This macro puts the ARM back in IRQ mode and
+* hence sets back the I bit.
+#define Xil_DisableNestedInterrupts() \
+ __asm__ __volatile__ ("ldp X1,X2, [sp,#0x10]!"); \
+ __asm__ __volatile__ ("msr ELR_EL3, X1"); \
+ __asm__ __volatile__ ("msr SPSR_EL3, X2"); \
+ __asm__ __volatile__ ("orr X1, X1, #(0x1<<7)"); \
+#elif (defined (EL1_NONSECURE) && (EL1_NONSECURE==1))
+* macro is defined for Cortex-A53 64 bit mode and Cortex-A72 64 bit
+* BSP configured to run at EL1 NON SECURE
+* @return None.
+ __asm__ __volatile__ ("mrs X1, ELR_EL1"); \
+ __asm__ __volatile__ ("mrs X2, SPSR_EL1"); \
+* @return None.
+ __asm__ __volatile__ ("msr ELR_EL1, X1"); \
+ __asm__ __volatile__ ("msr SPSR_EL1, X2"); \
+#elif (!defined (__aarch64__) && !defined (ARMA53_32))
+* @brief Enable nested interrupts by clearing the I and F bits in CPSR. This
+* API is defined for cortex-a9 and cortex-r5.
+* @return None.
+* interrupt handler the interrupts are disabled by default (I and F
+* are 1). To allow nesting of interrupts, this macro should be
+* used. It clears the I and F bits by changing the ARM mode to
+* system mode. Once these bits are cleared and provided the
+* is appropriately cleared. Otherwise, as soon as we clear the I and
+* F bits, there can be an infinite loop of interrupts with an
+ __asm__ __volatile__ ("stmfd sp!, {lr}"); \
+ __asm__ __volatile__ ("mrs lr, spsr"); \
+ __asm__ __volatile__ ("msr cpsr_c, #0x1F"); \
+* @brief Disable the nested interrupts by setting the I and F bits. This API
+* is defined for cortex-a9 and cortex-r5.
+* @return None.
+* service routine. This macro puts the ARM back in IRQ/FIQ mode and
+* hence sets back the I and F bits.
+ __asm__ __volatile__ ("ldmfd sp!, {lr}"); \
+ __asm__ __volatile__ ("msr cpsr_c, #0x92"); \
+ __asm__ __volatile__ ("msr spsr_cxsf, lr"); \
+#endif
+/************************** Variable Definitions ****************************/
+extern void Xil_ExceptionRegisterHandler(u32 Exception_id,
+ Xil_ExceptionHandler Handler,
+ void *Data);
+extern void Xil_ExceptionRemoveHandler(u32 Exception_id);
+extern void Xil_GetExceptionRegisterHandler(u32 Exception_id,
+ Xil_ExceptionHandler *Handler, void **Data);
+extern void Xil_ExceptionInit(void);
+void Xil_SyncAbortHandler(void *CallBackRef);
+void Xil_SErrorAbortHandler(void *CallBackRef);
+#else
+extern void Xil_DataAbortHandler(void *CallBackRef);
+extern void Xil_PrefetchAbortHandler(void *CallBackRef);
+extern void Xil_UndefinedExceptionHandler(void *CallBackRef);
+#endif
+#ifdef __cplusplus
+#endif /* XIL_EXCEPTION_H */
+* @} End of "addtogroup arm_exception_apis".
diff --git a/embeddedsw/lib/bsp/standalone/src/common/xil_assert.c b/embeddedsw/lib/bsp/standalone/src/common/xil_assert.c
index 0000000..b3dd7e9
--- /dev/null
+++ b/embeddedsw/lib/bsp/standalone/src/common/xil_assert.c
@@ -0,0 +1,126 @@
+* Copyright (c) 2009 - 2021 Xilinx, Inc. All rights reserved.
+* @file xil_assert.c
+* @addtogroup common_assert_apis Assert APIs and Macros
+* This file contains basic assert related functions for Xilinx software IP.
+* <pre>
+* 1.00a hbm 07/14/09 Initial release
+* 6.0 kvn 05/31/16 Make Xil_AsserWait a global variable
+* </pre>
+#include "xil_assert.h"
+ * @brief This variable allows testing to be done easier with asserts. An assert
+ * sets this variable such that a driver can evaluate this variable
+ * to determine if an assert occurred.
+u32 Xil_AssertStatus;
+ * @brief This variable allows the assert functionality to be changed for testing
+ * such that it does not wait infinitely. Use the debugger to disable the
+ * waiting during testing of asserts.
+s32 Xil_AssertWait = 1;
+/* The callback function to be invoked when an assert is taken */
+static Xil_AssertCallback Xil_AssertCallbackRoutine = NULL;
+* @brief Implement assert. Currently, it calls a user-defined callback
+* function if one has been set. Then, it potentially enters an
+* infinite loop depending on the value of the Xil_AssertWait
+* variable.
+* @param File: filename of the source
+* @param Line: linenumber within File
+* @return None.
+* @note None.
+void Xil_Assert(const char8 *File, s32 Line)
+ /* if the callback has been set then invoke it */
+ if (Xil_AssertCallbackRoutine != 0) {
+ (*Xil_AssertCallbackRoutine)(File, Line);
+ /* if specified, wait indefinitely such that the assert will show up
+ * in testing
+ while (Xil_AssertWait != 0) {
+* @brief Set up a callback function to be invoked when an assert occurs.
+* If a callback is already installed, then it will be replaced.
+* @param Routine: callback to be invoked when an assert is taken
+* @return None.
+* @note This function has no effect if NDEBUG is set
+void Xil_AssertSetCallback(Xil_AssertCallback Routine)
+ Xil_AssertCallbackRoutine = Routine;
+* @brief Null handler function. This follows the XInterruptHandler
+* signature for interrupt handlers. It can be used to assign a null
+* handler (a stub) to an interrupt controller vector table.
+* @param NullParameter: arbitrary void pointer and not used.
+* @return None.
+* @note None.
+void XNullHandler(void *NullParameter)
+ (void) NullParameter;
+* @} End of "addtogroup common_assert_apis".
diff --git a/embeddedsw/lib/bsp/standalone/src/common/xil_assert.h b/embeddedsw/lib/bsp/standalone/src/common/xil_assert.h
index 0000000..e8b87b5
--- /dev/null
+++ b/embeddedsw/lib/bsp/standalone/src/common/xil_assert.h
@@ -0,0 +1,176 @@
+* @file xil_assert.h
+* The xil_assert.h file contains assert related functions and macros.
+* Assert APIs/Macros specifies that a application program satisfies certain
+* conditions at particular points in its execution. These function can be
+* used by application programs to ensure that, application code is satisfying
+* certain conditions.
+* <pre>
+* 1.00a hbm 07/14/09 First release
+* </pre>
+ *@cond nocomments
+#ifndef XIL_ASSERT_H /* prevent circular inclusions */
+#define XIL_ASSERT_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define XIL_ASSERT_NONE 0U
+#define XIL_ASSERT_OCCURRED 1U
+#define XNULL NULL
+extern u32 Xil_AssertStatus;
+extern s32 Xil_AssertWait;
+extern void Xil_Assert(const char8 *File, s32 Line);
+ *@endcond
+void XNullHandler(void *NullParameter);
+ * This data type defines a callback to be invoked when an
+ * assert occurs. The callback is invoked only when asserts are enabled
+typedef void (*Xil_AssertCallback) (const char8 *File, s32 Line);
+#ifndef NDEBUG
+* @brief This assert macro is to be used for void functions. This in
+* conjunction with the Xil_AssertWait boolean can be used to
+* accommodate tests so that asserts which fail allow execution to
+* continue.
+* @param Expression: expression to be evaluated. If it evaluates to
+* false, the assert occurs.
+* @return Returns void unless the Xil_AssertWait variable is true, in which
+* case no return is made and an infinite loop is entered.
+#define Xil_AssertVoid(Expression) \
+ if (Expression) { \
+ Xil_AssertStatus = XIL_ASSERT_NONE; \
+ } else { \
+ Xil_Assert(__FILE__, __LINE__); \
+ Xil_AssertStatus = XIL_ASSERT_OCCURRED; \
+ return; \
+* @brief This assert macro is to be used for functions that do return a
+* value. This in conjunction with the Xil_AssertWait boolean can be
+* used to accommodate tests so that asserts which fail allow execution
+* to continue.
+* @param Expression: expression to be evaluated. If it evaluates to false,
+* the assert occurs.
+* @return Returns 0 unless the Xil_AssertWait variable is true, in which
+#define Xil_AssertNonvoid(Expression) \
+ } else { \
+ return 0; \
+* @brief Always assert. This assert macro is to be used for void functions.
+* Use for instances where an assert should always occur.
+#define Xil_AssertVoidAlways() \
+ return; \
+* @brief Always assert. This assert macro is to be used for functions that
+* do return a value. Use for instances where an assert should always
+* occur.
+#define Xil_AssertNonvoidAlways() \
+ return 0; \
+#else
+#endif
+void Xil_AssertSetCallback(Xil_AssertCallback Routine);
+#ifdef __cplusplus
+#endif
+#endif /* end of protection macro */
diff --git a/embeddedsw/lib/bsp/standalone/src/common/xil_io.h b/embeddedsw/lib/bsp/standalone/src/common/xil_io.h
index 0000000..853ef6b
--- /dev/null
+++ b/embeddedsw/lib/bsp/standalone/src/common/xil_io.h
@@ -0,0 +1,412 @@
+* @file xil_io.h
+* @addtogroup common_io_interfacing_apis Register IO interfacing APIs
+* The xil_io.h file contains the interface for the general I/O component, which
+* encapsulates the Input/Output functions for the processors that do not
+* require any special I/O handling.
+* <pre>
+* 6.00 mus 08/19/16 Remove checking of __LITTLE_ENDIAN__ flag for
+* ARM processors
+* 7.20 har 01/03/20 Added Xil_SecureOut32 for avoiding blindwrite for
+* CR-1049218
+* 7.30 kpt 09/21/20 Moved Xil_EndianSwap16 and Xil_EndianSwap32 to
+* xil_io.h and made them as static inline
+* am 10/13/20 Changed the return type of Xil_SecureOut32 function
+* from u32 to int
+* 7.50 dp 02/12/21 Fix compilation error in Xil_EndianSwap32() that occur
+* when -Werror=conversion compiler flag is enabled
+* 7.5 mus 05/17/21 Update the functions with comments. It fixes CR#1067739.
+* </pre>
+#ifndef XIL_IO_H /* prevent circular inclusions */
+#define XIL_IO_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "xil_printf.h"
+#if defined (__MICROBLAZE__)
+#include "mb_interface.h"
+#else
+#endif
+#ifdef ENABLE_SAFETY
+extern u32 XStl_RegUpdate(u32 RegAddr, u32 RegVal);
+#endif
+#if defined __GNUC__
+# define INST_SYNC mbar(0)
+# define DATA_SYNC mbar(1)
+# else
+# define SYNCHRONIZE_IO dmb()
+# define INST_SYNC isb()
+# define DATA_SYNC dsb()
+# endif
+#else
+# define INST_SYNC
+# define DATA_SYNC
+# define INST_SYNC
+# define DATA_SYNC
+#endif
+#if defined (__GNUC__) || defined (__ICCARM__) || defined (__MICROBLAZE__)
+#define INLINE inline
+#else
+#define INLINE __inline
+#endif
+* @brief Performs an input operation for a memory location by reading
+* from the specified address and returning the 8 bit Value read from
+* that address.
+* @param Addr: contains the address to perform the input operation
+* @return The 8 bit Value read from the specified input address.
+static INLINE u8 Xil_In8(UINTPTR Addr)
+ return *(volatile u8 *) Addr;
+* @brief Performs an input operation for a memory location by reading from
+* the specified address and returning the 16 bit Value read from that
+* address.
+* @return The 16 bit Value read from the specified input address.
+static INLINE u16 Xil_In16(UINTPTR Addr)
+ return *(volatile u16 *) Addr;
+* reading from the specified address and returning the 32 bit Value
+* read from that address.
+* @return The 32 bit Value read from the specified input address.
+static INLINE u32 Xil_In32(UINTPTR Addr)
+ return *(volatile u32 *) Addr;
+* @brief Performs an input operation for a memory location by reading the
+* 64 bit Value read from that address.
+* @return The 64 bit Value read from the specified input address.
+static INLINE u64 Xil_In64(UINTPTR Addr)
+ return *(volatile u64 *) Addr;
+* @brief Performs an output operation for an memory location by
+* writing the 8 bit Value to the the specified address.
+* @param Addr: contains the address to perform the output operation
+* @param Value: contains the 8 bit Value to be written at the specified
+* address.
+* @return None.
+static INLINE void Xil_Out8(UINTPTR Addr, u8 Value)
+ /* write 8 bit value to specified address */
+ volatile u8 *LocalAddr = (volatile u8 *)Addr;
+ *LocalAddr = Value;
+* @brief Performs an output operation for a memory location by writing the
+* 16 bit Value to the the specified address.
+* @param Addr contains the address to perform the output operation
+* @param Value contains the Value to be written at the specified address.
+* @return None.
+static INLINE void Xil_Out16(UINTPTR Addr, u16 Value)
+ /* write 16 bit value to specified address */
+ volatile u16 *LocalAddr = (volatile u16 *)Addr;
+* 32 bit Value to the the specified address.
+* @param Value contains the 32 bit Value to be written at the specified
+* address.
+* @return None.
+static INLINE void Xil_Out32(UINTPTR Addr, u32 Value)
+ /* write 32 bit value to specified address */
+#ifndef ENABLE_SAFETY
+ volatile u32 *LocalAddr = (volatile u32 *)Addr;
+#else
+ XStl_RegUpdate(Addr, Value);
+#endif
+* 64 bit Value to the the specified address.
+* @param Value contains 64 bit Value to be written at the specified address.
+* @return None.
+static INLINE void Xil_Out64(UINTPTR Addr, u64 Value)
+ /* write 64 bit value to specified address */
+ volatile u64 *LocalAddr = (volatile u64 *)Addr;
+ * @brief Performs an output operation for a memory location by writing the
+ * 32 bit Value to the the specified address and then reading it
+ * back to verify the value written in the register.
+ * @param Addr contains the address to perform the output operation
+ * @param Value contains 32 bit Value to be written at the specified address
+ * @return Returns Status
+ * - XST_SUCCESS on success
+ * - XST_FAILURE on failure
+static INLINE int Xil_SecureOut32(UINTPTR Addr, u32 Value)
+ int Status = XST_FAILURE;
+ u32 ReadReg;
+ u32 ReadRegTemp;
+ /* writing 32 bit value to specified address */
+ Xil_Out32(Addr, Value);
+ /* verify value written to specified address with multiple reads */
+ ReadReg = Xil_In32(Addr);
+ ReadRegTemp = Xil_In32(Addr);
+ if( (ReadReg == Value) && (ReadRegTemp == Value) ) {
+ Status = XST_SUCCESS;
+ return Status;
+* @brief Perform a 16-bit endian conversion.
+* @param Data: 16 bit value to be converted
+* @return 16 bit Data with converted endianness
+static INLINE __attribute__((always_inline)) u16 Xil_EndianSwap16(u16 Data)
+ return (u16) (((Data & 0xFF00U) >> 8U) | ((Data & 0x00FFU) << 8U));
+* @brief Perform a 32-bit endian conversion.
+* @param Data: 32 bit value to be converted
+* @return 32 bit data with converted endianness
+static INLINE __attribute__((always_inline)) u32 Xil_EndianSwap32(u32 Data)
+ u16 LoWord;
+ u16 HiWord;
+ /* get each of the half words from the 32 bit word */
+ LoWord = (u16) (Data & 0x0000FFFFU);
+ HiWord = (u16) ((Data & 0xFFFF0000U) >> 16U);
+ /* byte swap each of the 16 bit half words */
+ LoWord = (u16)(((LoWord & 0xFF00U) >> 8U) | ((LoWord & 0x00FFU) << 8U));
+ HiWord = (u16)(((HiWord & 0xFF00U) >> 8U) | ((HiWord & 0x00FFU) << 8U));
+ /* swap the half words before returning the value */
+ return ((((u32)LoWord) << (u32)16U) | (u32)HiWord);
+#ifdef __LITTLE_ENDIAN__
+# define Xil_In16LE Xil_In16
+# define Xil_In32LE Xil_In32
+# define Xil_Out16LE Xil_Out16
+# define Xil_Out32LE Xil_Out32
+# define Xil_Htons Xil_EndianSwap16
+# define Xil_Htonl Xil_EndianSwap32
+# define Xil_Ntohs Xil_EndianSwap16
+# define Xil_Ntohl Xil_EndianSwap32
+# else
+# define Xil_In16BE Xil_In16
+# define Xil_In32BE Xil_In32
+# define Xil_Out16BE Xil_Out16
+# define Xil_Out32BE Xil_Out32
+# define Xil_Htons(Data) (Data)
+# define Xil_Htonl(Data) (Data)
+# define Xil_Ntohs(Data) (Data)
+# define Xil_Ntohl(Data) (Data)
+#endif
+#else
+#endif
+static INLINE u16 Xil_In16BE(UINTPTR Addr)
+#else
+static INLINE u16 Xil_In16LE(UINTPTR Addr)
+#endif
+#else
+#endif
+ u16 value = Xil_In16(Addr);
+ return Xil_EndianSwap16(value);
+static INLINE u32 Xil_In32BE(UINTPTR Addr)
+#else
+static INLINE u32 Xil_In32LE(UINTPTR Addr)
+#endif
+#else
+#endif
+ u32 value = Xil_In32(Addr);
+ return Xil_EndianSwap32(value);
+static INLINE void Xil_Out16BE(UINTPTR Addr, u16 Value)
+#else
+static INLINE void Xil_Out16LE(UINTPTR Addr, u16 Value)
+#endif
+#else
+#endif
+ Value = Xil_EndianSwap16(Value);
+ Xil_Out16(Addr, Value);
+static INLINE void Xil_Out32BE(UINTPTR Addr, u32 Value)
+#else
+static INLINE void Xil_Out32LE(UINTPTR Addr, u32 Value)
+#endif
+#else
+#endif
+ Value = Xil_EndianSwap32(Value);
+#ifdef __cplusplus
+#endif
+* @} End of "addtogroup common_io_interfacing_apis".
diff --git a/embeddedsw/lib/bsp/standalone/src/common/xil_types.h b/embeddedsw/lib/bsp/standalone/src/common/xil_types.h
index 0000000..1d18bfb
--- /dev/null
+++ b/embeddedsw/lib/bsp/standalone/src/common/xil_types.h
@@ -0,0 +1,203 @@
+* Copyright (c) 2010 - 2021 Xilinx, Inc. All rights reserved.
+* @file xil_types.h
+* @addtogroup common_types Basic Data types for Xilinx® Software IP
+* The xil_types.h file contains basic types for Xilinx software IP. These data types
+* are applicable for all processors supported by Xilinx.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver Who Date Changes
+* 3.03a sdm 05/30/11 Added Xuint64 typedef and XUINT64_MSW/XUINT64_LSW macros
+* 5.00 pkp 05/29/14 Made changes for 64 bit architecture
+* srt 07/14/14 Use standard definitions from stdint.h and stddef.h
+* Define LONG and ULONG datatypes and mask values
+* 7.00 mus 01/07/19 Add cpp extern macro
+* 7.1 aru 08/19/19 Shift the value in UPPER_32_BITS only if it
+* is 64-bit processor
+* </pre>
+ *@cond nocomments
+#ifndef XIL_TYPES_H /* prevent circular inclusions */
+#define XIL_TYPES_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <stdint.h>
+#include <stddef.h>
+#ifndef TRUE
+# define TRUE 1U
+#endif
+#ifndef FALSE
+# define FALSE 0U
+#endif
+#ifndef NULL
+#define NULL 0U
+#endif
+#define XIL_COMPONENT_IS_READY 0x11111111U /**< In device drivers, This macro will be
+ assigend to "IsReady" member of driver
+ instance to indicate that driver
+ instance is initialized and ready to use. */
+#define XIL_COMPONENT_IS_STARTED 0x22222222U /**< In device drivers, This macro will be assigend to
+ "IsStarted" member of driver instance
+ to indicate that driver instance is
+ started and it can be enabled. */
+/* @name New types
+ * New simple types.
+#ifndef __KERNEL__
+#ifndef XBASIC_TYPES_H
+ * guarded against xbasic_types.h.
+typedef uint8_t u8;
+typedef uint16_t u16;
+typedef uint32_t u32;
+#define __XUINT64__
+typedef struct
+ u32 Upper;
+ u32 Lower;
+} Xuint64;
+* @brief Return the most significant half of the 64 bit data type.
+* @param x is the 64 bit word.
+* @return The upper 32 bits of the 64 bit word.
+#define XUINT64_MSW(x) ((x).Upper)
+* @brief Return the least significant half of the 64 bit data type.
+* @return The lower 32 bits of the 64 bit word.
+#define XUINT64_LSW(x) ((x).Lower)
+#endif /* XBASIC_TYPES_H */
+ * xbasic_types.h does not typedef s* or u64
+typedef char char8;
+typedef int8_t s8;
+typedef int16_t s16;
+typedef int32_t s32;
+typedef int64_t s64;
+typedef uint64_t u64;
+typedef int sint32;
+typedef intptr_t INTPTR;
+typedef uintptr_t UINTPTR;
+typedef ptrdiff_t PTRDIFF;
+#if !defined(LONG) || !defined(ULONG)
+typedef long LONG;
+typedef unsigned long ULONG;
+#endif
+#define ULONG64_HI_MASK 0xFFFFFFFF00000000U
+#define ULONG64_LO_MASK ~ULONG64_HI_MASK
+#else
+#include <linux/types.h>
+#endif
+ * This data type defines an interrupt handler for a device.
+ * The argument points to the instance of the component
+typedef void (*XInterruptHandler) (void *InstancePtr);
+ * This data type defines an exception handler for a processor.
+typedef void (*XExceptionHandler) (void *InstancePtr);
+ * @brief Returns 32-63 bits of a number.
+ * @param n : Number being accessed.
+ * @return Bits 32-63 of number.
+ * @note A basic shift-right of a 64- or 32-bit quantity.
+ * Use this to suppress the "right shift count >= width of type"
+ * warning when that quantity is 32-bits.
+#if defined (__aarch64__) || defined (__arch64__)
+#define UPPER_32_BITS(n) ((u32)(((n) >> 16) >> 16))
+#else
+#define UPPER_32_BITS(n) 0U
+#endif
+ * @brief Returns 0-31 bits of a number
+ * @return Bits 0-31 of number
+#define LOWER_32_BITS(n) ((u32)(n))
+#ifndef TRUE
+#define TRUE 1U
+#endif
+#ifndef FALSE
+#define FALSE 0U
+#endif
+#ifndef NULL
+#define NULL 0U
+#endif
+#ifdef __cplusplus
+#endif
+ *@endcond
+* @} End of "addtogroup common_types".
diff --git a/embeddedsw/lib/bsp/standalone/src/common/xstatus.h b/embeddedsw/lib/bsp/standalone/src/common/xstatus.h
index 0000000..1e9e6fb
--- /dev/null
+++ b/embeddedsw/lib/bsp/standalone/src/common/xstatus.h
@@ -0,0 +1,522 @@
+* Copyright (c) 2002 - 2021 Xilinx, Inc. All rights reserved.
+* @file xstatus.h
+* @addtogroup common_status_codes Xilinx software status codes
+* The xstatus.h file contains the Xilinx software status codes.These codes are
+* used throughout the Xilinx device drivers.
+ *@cond nocomments
+#ifndef XSTATUS_H /* prevent circular inclusions */
+#define XSTATUS_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+/*********************** Common statuses 0 - 500 *****************************/
+ at name Common Status Codes for All Device Drivers
+#define XST_SUCCESS 0L
+#define XST_FAILURE 1L
+#define XST_DEVICE_NOT_FOUND 2L
+#define XST_DEVICE_BLOCK_NOT_FOUND 3L
+#define XST_INVALID_VERSION 4L
+#define XST_DEVICE_IS_STARTED 5L
+#define XST_DEVICE_IS_STOPPED 6L
+#define XST_FIFO_ERROR 7L /*!< An error occurred during an
+ operation with a FIFO such as
+ an underrun or overrun, this
+ error requires the device to
+ be reset */
+#define XST_RESET_ERROR 8L /*!< An error occurred which requires
+ the device to be reset */
+#define XST_DMA_ERROR 9L /*!< A DMA error occurred, this error
+ typically requires the device
+ using the DMA to be reset */
+#define XST_NOT_POLLED 10L /*!< The device is not configured for
+ polled mode operation */
+#define XST_FIFO_NO_ROOM 11L /*!< A FIFO did not have room to put
+ the specified data into */
+#define XST_BUFFER_TOO_SMALL 12L /*!< The buffer is not large enough
+ to hold the expected data */
+#define XST_NO_DATA 13L /*!< There was no data available */
+#define XST_REGISTER_ERROR 14L /*!< A register did not contain the
+ expected value */
+#define XST_INVALID_PARAM 15L /*!< An invalid parameter was passed
+ into the function */
+#define XST_NOT_SGDMA 16L /*!< The device is not configured for
+ scatter-gather DMA operation */
+#define XST_LOOPBACK_ERROR 17L /*!< A loopback test failed */
+#define XST_NO_CALLBACK 18L /*!< A callback has not yet been
+ registered */
+#define XST_NO_FEATURE 19L /*!< Device is not configured with
+ the requested feature */
+#define XST_NOT_INTERRUPT 20L /*!< Device is not configured for
+ interrupt mode operation */
+#define XST_DEVICE_BUSY 21L /*!< Device is busy */
+#define XST_ERROR_COUNT_MAX 22L /*!< The error counters of a device
+ have maxed out */
+#define XST_IS_STARTED 23L /*!< Used when part of device is
+ already started i.e.
+ sub channel */
+#define XST_IS_STOPPED 24L /*!< Used when part of device is
+ already stopped i.e.
+ sub channel */
+#define XST_DATA_LOST 26L /*!< Driver defined error */
+#define XST_RECV_ERROR 27L /*!< Generic receive error */
+#define XST_SEND_ERROR 28L /*!< Generic transmit error */
+#define XST_NOT_ENABLED 29L /*!< A requested service is not
+ available because it has not
+ been enabled */
+#define XST_NO_ACCESS 30L /* Generic access error */
+#define XST_TIMEOUT 31L /*!< Event timeout occurred */
+/***************** Utility Component statuses 401 - 500 *********************/
+ at name Utility Component Status Codes 401 - 500
+#define XST_MEMTEST_FAILED 401L /*!< Memory test failed */
+/***************** Common Components statuses 501 - 1000 *********************/
+ at name Packet Fifo Status Codes 501 - 510
+/********************* Packet Fifo statuses 501 - 510 ************************/
+#define XST_PFIFO_LACK_OF_DATA 501L /*!< Not enough data in FIFO */
+#define XST_PFIFO_NO_ROOM 502L /*!< Not enough room in FIFO */
+#define XST_PFIFO_BAD_REG_VALUE 503L /*!< Self test, a register value
+ was invalid after reset */
+#define XST_PFIFO_ERROR 504L /*!< Generic packet FIFO error */
+#define XST_PFIFO_DEADLOCK 505L /*!< Packet FIFO is reporting
+ * empty and full simultaneously
+ at name DMA Status Codes 511 - 530
+/************************** DMA statuses 511 - 530 ***************************/
+#define XST_DMA_TRANSFER_ERROR 511L /*!< Self test, DMA transfer
+ failed */
+#define XST_DMA_RESET_REGISTER_ERROR 512L /*!< Self test, a register value
+#define XST_DMA_SG_LIST_EMPTY 513L /*!< Scatter gather list contains
+ no buffer descriptors ready
+ to be processed */
+#define XST_DMA_SG_IS_STARTED 514L /*!< Scatter gather not stopped */
+#define XST_DMA_SG_IS_STOPPED 515L /*!< Scatter gather not running */
+#define XST_DMA_SG_LIST_FULL 517L /*!< All the buffer descriptors of
+ the scatter gather list are
+ being used */
+#define XST_DMA_SG_BD_LOCKED 518L /*!< The scatter gather buffer
+ descriptor which is to be
+ copied over in the scatter
+ list is locked */
+#define XST_DMA_SG_NOTHING_TO_COMMIT 519L /*!< No buffer descriptors have been
+ put into the scatter gather
+ list to be committed */
+#define XST_DMA_SG_COUNT_EXCEEDED 521L /*!< The packet count threshold
+ specified was larger than the
+ total # of buffer descriptors
+ in the scatter gather list */
+#define XST_DMA_SG_LIST_EXISTS 522L /*!< The scatter gather list has
+ already been created */
+#define XST_DMA_SG_NO_LIST 523L /*!< No scatter gather list has
+ been created */
+#define XST_DMA_SG_BD_NOT_COMMITTED 524L /*!< The buffer descriptor which was
+ being started was not committed
+ to the list */
+#define XST_DMA_SG_NO_DATA 525L /*!< The buffer descriptor to start
+ has already been used by the
+ hardware so it can't be reused
+#define XST_DMA_SG_LIST_ERROR 526L /*!< General purpose list access
+ error */
+#define XST_DMA_BD_ERROR 527L /*!< General buffer descriptor
+ error */
+ at name IPIF Status Codes Codes 531 - 550
+/************************** IPIF statuses 531 - 550 ***************************/
+#define XST_IPIF_REG_WIDTH_ERROR 531L /*!< An invalid register width
+ was passed into the function */
+#define XST_IPIF_RESET_REGISTER_ERROR 532L /*!< The value of a register at
+ reset was not valid */
+#define XST_IPIF_DEVICE_STATUS_ERROR 533L /*!< A write to the device interrupt
+ status register did not read
+ back correctly */
+#define XST_IPIF_DEVICE_ACK_ERROR 534L /*!< The device interrupt status
+ register did not reset when
+ acked */
+#define XST_IPIF_DEVICE_ENABLE_ERROR 535L /*!< The device interrupt enable
+ register was not updated when
+ other registers changed */
+#define XST_IPIF_IP_STATUS_ERROR 536L /*!< A write to the IP interrupt
+ back correctly */
+#define XST_IPIF_IP_ACK_ERROR 537L /*!< The IP interrupt status register
+ did not reset when acked */
+#define XST_IPIF_IP_ENABLE_ERROR 538L /*!< IP interrupt enable register was
+ not updated correctly when other
+ registers changed */
+#define XST_IPIF_DEVICE_PENDING_ERROR 539L /*!< The device interrupt pending
+ register did not indicate the
+ expected value */
+#define XST_IPIF_DEVICE_ID_ERROR 540L /*!< The device interrupt ID register
+ did not indicate the expected
+ value */
+#define XST_IPIF_ERROR 541L /*!< Generic ipif error */
+/****************** Device specific statuses 1001 - 4095 *********************/
+ at name Ethernet Status Codes 1001 - 1050
+/********************* Ethernet statuses 1001 - 1050 *************************/
+#define XST_EMAC_MEMORY_SIZE_ERROR 1001L /*!< Memory space is not big enough
+ * to hold the minimum number of
+ * buffers or descriptors */
+#define XST_EMAC_MEMORY_ALLOC_ERROR 1002L /*!< Memory allocation failed */
+#define XST_EMAC_MII_READ_ERROR 1003L /*!< MII read error */
+#define XST_EMAC_MII_BUSY 1004L /*!< An MII operation is in progress */
+#define XST_EMAC_OUT_OF_BUFFERS 1005L /*!< Driver is out of buffers */
+#define XST_EMAC_PARSE_ERROR 1006L /*!< Invalid driver init string */
+#define XST_EMAC_COLLISION_ERROR 1007L /*!< Excess deferral or late
+ * collision on polled send */
+ at name UART Status Codes 1051 - 1075
+/*********************** UART statuses 1051 - 1075 ***************************/
+#define XST_UART
+#define XST_UART_INIT_ERROR 1051L
+#define XST_UART_START_ERROR 1052L
+#define XST_UART_CONFIG_ERROR 1053L
+#define XST_UART_TEST_FAIL 1054L
+#define XST_UART_BAUD_ERROR 1055L
+#define XST_UART_BAUD_RANGE 1056L
+ at name IIC Status Codes 1076 - 1100
+/************************ IIC statuses 1076 - 1100 ***************************/
+#define XST_IIC_SELFTEST_FAILED 1076 /*!< self test failed */
+#define XST_IIC_BUS_BUSY 1077 /*!< bus found busy */
+#define XST_IIC_GENERAL_CALL_ADDRESS 1078 /*!< mastersend attempted with */
+ /* general call address */
+#define XST_IIC_STAND_REG_RESET_ERROR 1079 /*!< A non parameterizable reg */
+ /* value after reset not valid */
+#define XST_IIC_TX_FIFO_REG_RESET_ERROR 1080 /*!< Tx fifo included in design */
+#define XST_IIC_RX_FIFO_REG_RESET_ERROR 1081 /*!< Rx fifo included in design */
+#define XST_IIC_TBA_REG_RESET_ERROR 1082 /*!< 10 bit addr incl in design */
+#define XST_IIC_CR_READBACK_ERROR 1083 /*!< Read of the control register */
+ /* didn't return value written */
+#define XST_IIC_DTR_READBACK_ERROR 1084 /*!< Read of the data Tx reg */
+#define XST_IIC_DRR_READBACK_ERROR 1085 /*!< Read of the data Receive reg */
+#define XST_IIC_ADR_READBACK_ERROR 1086 /*!< Read of the data Tx reg */
+#define XST_IIC_TBA_READBACK_ERROR 1087 /*!< Read of the 10 bit addr reg */
+ /* didn't return written value */
+#define XST_IIC_NOT_SLAVE 1088 /*!< The device isn't a slave */
+#define XST_IIC_ARB_LOST 1089 /*!< Arbitration lost for master */
+ at name ATMC Status Codes 1101 - 1125
+/*********************** ATMC statuses 1101 - 1125 ***************************/
+#define XST_ATMC_ERROR_COUNT_MAX 1101L /*!< the error counters in the ATM
+ controller hit the max value
+ which requires the statistics
+ to be cleared */
+ at name Flash Status Codes 1126 - 1150
+/*********************** Flash statuses 1126 - 1150 **************************/
+#define XST_FLASH_BUSY 1126L /*!< Flash is erasing or programming
+#define XST_FLASH_READY 1127L /*!< Flash is ready for commands */
+#define XST_FLASH_ERROR 1128L /*!< Flash had detected an internal
+ error. Use XFlash_DeviceControl
+ to retrieve device specific codes
+#define XST_FLASH_ERASE_SUSPENDED 1129L /*!< Flash is in suspended erase state
+#define XST_FLASH_WRITE_SUSPENDED 1130L /*!< Flash is in suspended write state
+#define XST_FLASH_PART_NOT_SUPPORTED 1131L /*!< Flash type not supported by
+ driver */
+#define XST_FLASH_NOT_SUPPORTED 1132L /*!< Operation not supported */
+#define XST_FLASH_TOO_MANY_REGIONS 1133L /*!< Too many erase regions */
+#define XST_FLASH_TIMEOUT_ERROR 1134L /*!< Programming or erase operation
+ aborted due to a timeout */
+#define XST_FLASH_ADDRESS_ERROR 1135L /*!< Accessed flash outside its
+ addressible range */
+#define XST_FLASH_ALIGNMENT_ERROR 1136L /*!< Write alignment error */
+#define XST_FLASH_BLOCKING_CALL_ERROR 1137L /*!< Couldn't return immediately from
+ write/erase function with
+ XFL_NON_BLOCKING_WRITE/ERASE
+ option cleared */
+#define XST_FLASH_CFI_QUERY_ERROR 1138L /*!< Failed to query the device */
+ at name SPI Status Codes 1151 - 1175
+/*********************** SPI statuses 1151 - 1175 ****************************/
+#define XST_SPI_MODE_FAULT 1151 /*!< master was selected as slave */
+#define XST_SPI_TRANSFER_DONE 1152 /*!< data transfer is complete */
+#define XST_SPI_TRANSMIT_UNDERRUN 1153 /*!< slave underruns transmit register */
+#define XST_SPI_RECEIVE_OVERRUN 1154 /*!< device overruns receive register */
+#define XST_SPI_NO_SLAVE 1155 /*!< no slave has been selected yet */
+#define XST_SPI_TOO_MANY_SLAVES 1156 /*!< more than one slave is being
+ * selected */
+#define XST_SPI_NOT_MASTER 1157 /*!< operation is valid only as master */
+#define XST_SPI_SLAVE_ONLY 1158 /*!< device is configured as slave-only
+#define XST_SPI_SLAVE_MODE_FAULT 1159 /*!< slave was selected while disabled */
+#define XST_SPI_SLAVE_MODE 1160 /*!< device has been addressed as slave */
+#define XST_SPI_RECEIVE_NOT_EMPTY 1161 /*!< device received data in slave mode */
+#define XST_SPI_COMMAND_ERROR 1162 /*!< unrecognised command - qspi only */
+#define XST_SPI_POLL_DONE 1163 /*!< controller completed polling the
+ device for status */
+ at name OPB Arbiter Status Codes 1176 - 1200
+/********************** OPB Arbiter statuses 1176 - 1200 *********************/
+#define XST_OPBARB_INVALID_PRIORITY 1176 /*!< the priority registers have either
+ * one master assigned to two or more
+ * priorities, or one master not
+ * assigned to any priority
+#define XST_OPBARB_NOT_SUSPENDED 1177 /*!< an attempt was made to modify the
+ * priority levels without first
+ * suspending the use of priority
+ * levels
+#define XST_OPBARB_PARK_NOT_ENABLED 1178 /*!< bus parking by id was enabled but
+ * bus parking was not enabled
+#define XST_OPBARB_NOT_FIXED_PRIORITY 1179 /*!< the arbiter must be in fixed
+ * priority mode to allow the
+ * priorities to be changed
+ at name INTC Status Codes 1201 - 1225
+/************************ Intc statuses 1201 - 1225 **************************/
+#define XST_INTC_FAIL_SELFTEST 1201 /*!< self test failed */
+#define XST_INTC_CONNECT_ERROR 1202 /*!< interrupt already in use */
+ at name TmrCtr Status Codes 1226 - 1250
+/********************** TmrCtr statuses 1226 - 1250 **************************/
+#define XST_TMRCTR_TIMER_FAILED 1226 /*!< self test failed */
+ at name WdtTb Status Codes 1251 - 1275
+/********************** WdtTb statuses 1251 - 1275 ***************************/
+#define XST_WDTTB_TIMER_FAILED 1251L
+ at name PlbArb status Codes 1276 - 1300
+/********************** PlbArb statuses 1276 - 1300 **************************/
+#define XST_PLBARB_FAIL_SELFTEST 1276L
+ at name Plb2Opb Status Codes 1301 - 1325
+/********************** Plb2Opb statuses 1301 - 1325 *************************/
+#define XST_PLB2OPB_FAIL_SELFTEST 1301L
+ at name Opb2Plb Status 1326 - 1350
+/********************** Opb2Plb statuses 1326 - 1350 *************************/
+#define XST_OPB2PLB_FAIL_SELFTEST 1326L
+ at name SysAce Status Codes 1351 - 1360
+/********************** SysAce statuses 1351 - 1360 **************************/
+#define XST_SYSACE_NO_LOCK 1351L /*!< No MPU lock has been granted */
+ at name PCI Bridge Status Codes 1361 - 1375
+/********************** PCI Bridge statuses 1361 - 1375 **********************/
+#define XST_PCI_INVALID_ADDRESS 1361L
+ at name FlexRay Constants 1400 - 1409
+/********************** FlexRay constants 1400 - 1409 *************************/
+#define XST_FR_TX_ERROR 1400
+#define XST_FR_TX_BUSY 1401
+#define XST_FR_BUF_LOCKED 1402
+#define XST_FR_NO_BUF 1403
+ at name USB constants 1410 - 1420
+/****************** USB constants 1410 - 1420 *******************************/
+#define XST_USB_ALREADY_CONFIGURED 1410
+#define XST_USB_BUF_ALIGN_ERROR 1411
+#define XST_USB_NO_DESC_AVAILABLE 1412
+#define XST_USB_BUF_TOO_BIG 1413
+#define XST_USB_NO_BUF 1414
+ at name HWICAP constants 1421 - 1429
+/****************** HWICAP constants 1421 - 1429 *****************************/
+#define XST_HWICAP_WRITE_DONE 1421
+ at name AXI VDMA constants 1430 - 1440
+/****************** AXI VDMA constants 1430 - 1440 *****************************/
+#define XST_VDMA_MISMATCH_ERROR 1430
+ at name NAND Flash Status Codes 1441 - 1459
+/*********************** NAND Flash statuses 1441 - 1459 *********************/
+#define XST_NAND_BUSY 1441L /*!< Flash is erasing or
+ * programming
+#define XST_NAND_READY 1442L /*!< Flash is ready for commands
+#define XST_NAND_ERROR 1443L /*!< Flash had detected an
+ * internal error.
+#define XST_NAND_PART_NOT_SUPPORTED 1444L /*!< Flash type not supported by
+ * driver
+#define XST_NAND_OPT_NOT_SUPPORTED 1445L /*!< Operation not supported
+#define XST_NAND_TIMEOUT_ERROR 1446L /*!< Programming or erase
+ * operation aborted due to a
+ * timeout
+#define XST_NAND_ADDRESS_ERROR 1447L /*!< Accessed flash outside its
+ * addressible range
+#define XST_NAND_ALIGNMENT_ERROR 1448L /*!< Write alignment error
+#define XST_NAND_PARAM_PAGE_ERROR 1449L /*!< Failed to read parameter
+ * page of the device
+#define XST_NAND_CACHE_ERROR 1450L /*!< Flash page buffer error
+#define XST_NAND_WRITE_PROTECTED 1451L /*!< Flash is write protected
+/**************************** Type Definitions *******************************/
+typedef s32 XStatus;
+/***************** Macros (Inline Functions) Definitions *********************/
+/************************** Function Prototypes ******************************/
+#ifdef __cplusplus
+#endif
+ *@endcond
+* @} End of "addtogroup common_status_codes".
2.30.2
