[newlib] RTEMS: Declare ioctl() also if _KERNEL is defined
Gedare Bloom
gedare at rtems.org
Wed Jul 6 19:14:37 UTC 2022
Why are the includes for stdint and cdefs removed also?
On Wed, Jul 6, 2022 at 8:47 AM Sebastian Huber
> This fixes the following warning in libbsd:
> rtems/blkdev.h:200:10: warning: implicit declaration of function 'ioctl'; did
> you mean 'ifioctl'? [-Wimplicit-function-declaration]
> Remove unnecessary includes.
> newlib/libc/sys/rtems/include/sys/ioccom.h | 7 +------
> 1 file changed, 1 insertion(+), 6 deletions(-)
> diff --git a/newlib/libc/sys/rtems/include/sys/ioccom.h b/newlib/libc/sys/rtems/include/sys/ioccom.h
> index 2a8416c41..1044a27e9 100644
> --- a/newlib/libc/sys/rtems/include/sys/ioccom.h
> +++ b/newlib/libc/sys/rtems/include/sys/ioccom.h
> @@ -36,7 +36,6 @@
> #define _SYS_IOCCOM_H_
> #include <sys/types.h>
> -#include <stdint.h>
> typedef unsigned long ioctl_command_t;
> @@ -80,14 +79,10 @@ typedef unsigned long ioctl_command_t;
> #define IOCPARM_IVAL(x) ((int)(intptr_t)(void *)*(caddr_t *)(void *)(x))
> #endif
> -#else
> -#include <sys/cdefs.h>
> +#endif
> __BEGIN_DECLS
> int ioctl(int, ioctl_command_t, ...);
> __END_DECLS
> -#endif
> #endif /* !_SYS_IOCCOM_H_ */
> 2.35.3
> devel mailing list
> devel at rtems.org
