[PATCH] tester: Make the SIS time limit user configurable
    Sebastian Huber
    Thu Jul  7 06:41:59 UTC 2022
On 06/07/2022 23:55, Chris Johns wrote:
> On 6/7/2022 6:00 pm, Sebastian Huber wrote:
>> Yes, if tests go wrong the tester can kill a test execution after the specified
>> timeout.
> Killing should be taken as a sign something in the test equipment is broken.
A simulator which kills itself after an arbitrary amount of time is a
broken test equipment.
>> Why do we need this arbitrary SIS -tlim of 400 s?
> There was a few values and I select this one based on those. If you have a
> better value please say.
I started this discussion by the best value from my point of view: no
time limit for the simulator.
> I do not recommend removing the time limit option from testing.
Why don't you recommend removing the time limit option?
> If you want to
> operate that way create a user config with:
> [erc32-sis]
> sis_time_limit = >
>> Which problem does this solve?
> Repeatable test results across wide ranging hosts and host operating systems.
I don't see how an arbitrary simulator timeout helps here. Killing the
SIS is very reliably. I have never seen a zombie SIS process after an
rtems-test exit.
>> Why can't we let the tests run in SIS without a limit just like we do it for
>> Qemu?
> Qemu is painful to make work in a consistent and reliable way.
>> Normally, if a test is done, it terminates the SIS execution.
> The time outs are for the cases that end abnormally.
Yes, this timeout should be defined by the --timeout command line
option. The timeout depends on the tests you run. This is also selected
through the command line. Test executions stopped by the tester due to a
timeout are reported as a timed out test, however, test executions
stopped by the simulator due to a simulator internal timeout are
reported as "failed".
>> The new performance tests can be used to catch performance regressions.
> We need to consider the existing benchmarks.
>> In the
>> long run I think we need a more modular approach. For example, one component
>> which runs tests and reports the test output. Another component which analyses
>> the test output. The test outputs can be archived.
> The rtems-test command is required to report regressions and as simply as
> possible. A user wants to build, test then know what they have matches what we
> released.
Yes, the rtems-test command should do this, however, the machinery it
uses could be more modular. If you want to catch performance regressions
you need history data.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
