[newlib 26/65] net: clean up empty lines in .c and .h files
Sebastian Huber
Thu Jul 7 11:58:33 UTC 2022
newlib/libc/sys/rtems/include/net/if.h | 1 -
newlib/libc/sys/rtems/include/netinet/tcp.h | 2 --
2 files changed, 3 deletions(-)
diff --git a/newlib/libc/sys/rtems/include/net/if.h b/newlib/libc/sys/rtems/include/net/if.h
index 78b1654dc..1a3a0e564 100644
--- a/newlib/libc/sys/rtems/include/net/if.h
+++ b/newlib/libc/sys/rtems/include/net/if.h
@@ -164,7 +164,6 @@ struct if_data {
#define IFF_RENAMING 0x400000 /* (n) interface is being renamed */
#define IFF_NOGROUP 0x800000 /* (n) interface is not part of any groups */
* Old names for driver flags so that user space tools can continue to use
* the old (portable) names.
diff --git a/newlib/libc/sys/rtems/include/netinet/tcp.h b/newlib/libc/sys/rtems/include/netinet/tcp.h
index 5dc13eca2..0a5226836 100644
--- a/newlib/libc/sys/rtems/include/netinet/tcp.h
+++ b/newlib/libc/sys/rtems/include/netinet/tcp.h
@@ -107,7 +107,6 @@ struct tcphdr {
#define MAX_SACK_BLKS 6 /* Max # SACK blocks stored at receiver side */
#define TCP_MAX_SACK 4 /* MAX # SACKs sent in any segment */
* The default maximum segment size (MSS) to be used for new TCP connections
* when path MTU discovery is not enabled.
@@ -282,7 +281,6 @@ struct tcphdr {
#define TCP_SHARED_CWND_TIME_LIMIT 1128 /* we should limit to low time values the scwnd life */
#define TCP_RACK_PROFILE 1129 /* Select a profile that sets multiple options */
/* Start of reserved space for third-party user-settable options. */
#define TCP_VENDOR SO_VENDOR
2.35.3
