[newlib 29/65] Support for userspace non-transparent superpages (largepages).
Thu Jul 7 11:58:36 UTC 2022
Created with shm_open2(SHM_LARGEPAGE) and then configured with
FIOSSHMLPGCNF ioctl, largepages posix shared memory objects guarantee
that all userspace mappings of it are served by superpage non-managed
mappings.
Only amd64 for now, both 2M and 1G superpages can be requested, the
later requires CPU feature.
Reviewed by:	markj
Tested by:	pho
Sponsored by:	The FreeBSD Foundation
MFC after:	1 week
Differential revision:	https://reviews.freebsd.org/D24652
 newlib/libc/sys/rtems/include/sys/filio.h |  3 +++
 newlib/libc/sys/rtems/include/sys/mman.h  | 13 ++++++++++++-
 2 files changed, 15 insertions(+), 1 deletion(-)
diff --git a/newlib/libc/sys/rtems/include/sys/filio.h b/newlib/libc/sys/rtems/include/sys/filio.h
index c5cf3d443..3eea7a7ac 100644
--- a/newlib/libc/sys/rtems/include/sys/filio.h
+++ b/newlib/libc/sys/rtems/include/sys/filio.h
@@ -70,6 +70,9 @@ struct fiobmap2_arg {
 /* Get the file's bmap info for the logical block bn. */
 #define	FIOBMAP2	_IOWR('f', 99, struct fiobmap2_arg)
+/* POSIX shm largepage set/get config */
+#define	FIOSSHMLPGCNF	_IOW('f', 100, struct shm_largepage_conf)
+#define	FIOGSHMLPGCNF	_IOR('f', 101, struct shm_largepage_conf)
 #ifdef _KERNEL
 #ifdef COMPAT_FREEBSD32
diff --git a/newlib/libc/sys/rtems/include/sys/mman.h b/newlib/libc/sys/rtems/include/sys/mman.h
index 6d861422d..d726a80d6 100644
--- a/newlib/libc/sys/rtems/include/sys/mman.h
+++ b/newlib/libc/sys/rtems/include/sys/mman.h
@@ -192,6 +192,17 @@
 #define	SHM_ALLOW_SEALING		0x00000001
 #define	SHM_GROW_ON_WRITE		0x00000002
+#define	SHM_LARGEPAGE			0x00000004
+#define	SHM_LARGEPAGE_ALLOC_DEFAULT	0
+#define	SHM_LARGEPAGE_ALLOC_NOWAIT	1
+#define	SHM_LARGEPAGE_ALLOC_HARD	2
+struct shm_largepage_conf {
+	int psind;
+	int alloc_policy;
+	int pad[10];
  * Flags for memfd_create().
@@ -199,7 +210,6 @@
 #define	MFD_CLOEXEC			0x00000001
 #define	MFD_ALLOW_SEALING		0x00000002
-/* UNSUPPORTED */
 #define	MFD_HUGETLB			0x00000004
 #define	MFD_HUGE_MASK			0xFC000000
@@ -279,6 +289,7 @@ int	shm_unlink(const char *);
 #endif
 #if __BSD_VISIBLE
 int	memfd_create(const char *, unsigned int);
+int	shm_create_largepage(const char *, int, int, int, mode_t);
 int	shm_rename(const char *, const char *, int);
 #endif
 __END_DECLS
2.35.3
