[newlib 32/65] add SIOCGIFDATA ioctl
Sebastian Huber
Thu Jul 7 11:58:39 UTC 2022
For interfaces that do not support SIOCGIFMEDIA (for which there are
quite a few) the only fallback is to query the interface for
if_data->ifi_link_state. While it's possible to get at if_data for an
interface via getifaddrs(3) or sysctl, both are heavy weight mechanisms.
SIOCGIFDATA is a simple ioctl to retrieve this fast with very little
resource use in comparison. This implementation mirrors that of other
similar ioctls in FreeBSD.
Submitted by: Roy Marples <roy at marples.name>
Reviewed by: markj
MFC after: 1 month
Differential Revision: https://reviews.freebsd.org/D26538
newlib/libc/sys/rtems/include/sys/sockio.h | 1 +
1 file changed, 1 insertion(+)
diff --git a/newlib/libc/sys/rtems/include/sys/sockio.h b/newlib/libc/sys/rtems/include/sys/sockio.h
index 447e2c884..03502d770 100644
--- a/newlib/libc/sys/rtems/include/sys/sockio.h
+++ b/newlib/libc/sys/rtems/include/sys/sockio.h
@@ -83,6 +83,7 @@
#define SIOCSIFDESCR _IOW('i', 41, struct ifreq) /* set ifnet descr */
#define SIOCGIFDESCR _IOWR('i', 42, struct ifreq) /* get ifnet descr */
#define SIOCAIFADDR _IOW('i', 43, struct ifaliasreq)/* add/chg IF alias */
+#define SIOCGIFDATA _IOW('i', 44, struct ifreq) /* get if_data */
#define SIOCADDMULTI _IOW('i', 49, struct ifreq) /* add m'cast addr */
#define SIOCDELMULTI _IOW('i', 50, struct ifreq) /* del m'cast addr */
2.35.3
