[newlib 35/65] Add IP(V6)_VLAN_PCP to set 802.1 priority per-flow.
Thu Jul 7 11:58:42 UTC 2022
From: Richard Scheffenegger <rscheff at FreeBSD.org>
This adds a new IP_PROTO / IPV6_PROTO setsockopt (getsockopt)
option IP(V6)_VLAN_PCP, which can be set to -1 (interface
default), or explicitly to any priority between 0 and 7.
Note that for untagged traffic, explicitly adding a
priority will insert a special 801.1Q vlan header with
vlan ID = 0 to carry the priority setting
Reviewed by:	gallatin, rrs
MFC after:	2 weeks
Sponsored by:	NetApp, Inc.
Differential Revision:	https://reviews.freebsd.org/D26409
 newlib/libc/sys/rtems/include/netinet/in.h   | 4 ++++
 newlib/libc/sys/rtems/include/netinet6/in6.h | 4 ++++
 2 files changed, 8 insertions(+)
diff --git a/newlib/libc/sys/rtems/include/netinet/in.h b/newlib/libc/sys/rtems/include/netinet/in.h
index 749e74eda..059f50d9b 100644
--- a/newlib/libc/sys/rtems/include/netinet/in.h
+++ b/newlib/libc/sys/rtems/include/netinet/in.h
@@ -483,6 +483,10 @@ __END_DECLS
 /* The following option is private; do not use it from user applications. */
 #define	IP_MSFILTER			74   /* set/get filter list */
+/* The following option deals with the 802.1Q Ethernet Priority Code Point */
+#define	IP_VLAN_PCP		75   /* int; set/get PCP used for packet, */
+				     /*      -1 use interface default */
 /* Protocol Independent Multicast API [RFC3678] */
 #define	MCAST_JOIN_GROUP		80   /* join an any-source group */
 #define	MCAST_LEAVE_GROUP		81   /* leave all sources for group */
diff --git a/newlib/libc/sys/rtems/include/netinet6/in6.h b/newlib/libc/sys/rtems/include/netinet6/in6.h
index 68d4c3e4e..55be82fed 100644
--- a/newlib/libc/sys/rtems/include/netinet6/in6.h
+++ b/newlib/libc/sys/rtems/include/netinet6/in6.h
@@ -387,6 +387,10 @@ struct route_in6 {
 				    * set/get multicast source filter list.
+#define	IPV6_VLAN_PCP		75  /* int; set/get PCP used for packet, */
 /* to define items, should talk with KAME guys first, for *BSD compatibility */
 #define IPV6_RTHDR_LOOSE     0 /* this hop need not be a neighbor. XXX old spec */
2.35.3
