[newlib 52/65] This brings into sync FreeBSD with the netflix
Sebastian Huber
Thu Jul 7 11:58:59 UTC 2022
versions of rack and bbr. This fixes several breakages (panics) since the
tcp_lro code was committed that have been reported. Quite a few new features
are now in rack (prefecting of DGP -- Dynamic Goodput Pacing among the
largest). There is also support for ack-war prevention. Documents comming soon
on rack..
Sponsored by: Netflix
Reviewed by: rscheff, mtuexen
Differential Revision: https://reviews.freebsd.org/D30036
newlib/libc/sys/rtems/include/netinet/tcp.h | 24 ++++++++++++++++++++-
1 file changed, 23 insertions(+), 1 deletion(-)
diff --git a/newlib/libc/sys/rtems/include/netinet/tcp.h b/newlib/libc/sys/rtems/include/netinet/tcp.h
index d2bf1f843..50f0811a6 100644
--- a/newlib/libc/sys/rtems/include/netinet/tcp.h
+++ b/newlib/libc/sys/rtems/include/netinet/tcp.h
@@ -181,13 +181,24 @@ struct tcphdr {
#define TCP_TXTLS_MODE 40 /* Transmit TLS mode */
#define TCP_RXTLS_ENABLE 41 /* TLS framing and encryption for receive */
#define TCP_RXTLS_MODE 42 /* Receive TLS mode */
+#define TCP_IWND_NB 43 /* Override initial window (units: bytes) */
+#define TCP_IWND_NSEG 44 /* Override initial window (units: MSS segs) */
+#define TCP_LOGID_CNT 46 /* get number of connections with the same ID */
+#define TCP_LOG_TAG 47 /* configure tag for grouping logs */
+#define TCP_USER_LOG 48 /* userspace log event */
#define TCP_CONGESTION 64 /* get/set congestion control algorithm */
#define TCP_CCALGOOPT 65 /* get/set cc algorithm specific options */
+#define TCP_MAXUNACKTIME 68 /* maximum time without making progress (sec) */
+#define TCP_MAXPEAKRATE 69 /* maximum peak rate allowed (kbps) */
+#define TCP_IDLE_REDUCE 70 /* Reduce cwnd on idle input */
#define TCP_REMOTE_UDP_ENCAPS_PORT 71 /* Enable TCP over UDP tunneling via the specified port */
#define TCP_DELACK 72 /* socket option for delayed ack */
#define TCP_FIN_IS_RST 73 /* A fin from the peer is treated has a RST */
#define TCP_LOG_LIMIT 74 /* Limit to number of records in tcp-log */
#define TCP_SHARED_CWND_ALLOWED 75 /* Use of a shared cwnd is allowed */
+#define TCP_PROC_ACCOUNTING 76 /* Do accounting on tcp cpu usage and counts */
+#define TCP_USE_CMP_ACKS 77 /* The transport can handle the Compressed mbuf acks */
+#define TCP_PERF_INFO 78 /* retrieve accounting counters */
#define TCP_KEEPINIT 128 /* N, time to establish connection */
#define TCP_KEEPIDLE 256 /* L,N,X start keeplives after this period */
#define TCP_KEEPINTVL 512 /* L,N interval between keepalives */
@@ -201,7 +212,7 @@ struct tcphdr {
#define TCP_RACK_MBUF_QUEUE 1050 /* Do we allow mbuf queuing if supported */
#define TCP_RACK_PROP 1051 /* RACK proportional rate reduction (bool) */
#define TCP_RACK_TLP_REDUCE 1052 /* RACK TLP cwnd reduction (bool) */
-#define TCP_RACK_PACE_REDUCE 1053 /* RACK Pacing reduction factor (divisor) */
+#define TCP_RACK_PACE_REDUCE 1053 /* RACK Pacingv reduction factor (divisor) */
#define TCP_RACK_PACE_MAX_SEG 1054 /* Max TSO size we will send */
#define TCP_RACK_PACE_ALWAYS 1055 /* Use the always pace method */
#define TCP_RACK_PROP_RATE 1056 /* The proportional reduction rate */
@@ -284,6 +295,16 @@ struct tcphdr {
#define TCP_RACK_PACE_TO_FILL 1127 /* If we are not in recovery, always pace to fill the cwnd in 1 RTT */
#define TCP_SHARED_CWND_TIME_LIMIT 1128 /* we should limit to low time values the scwnd life */
#define TCP_RACK_PROFILE 1129 /* Select a profile that sets multiple options */
+#define TCP_HDWR_RATE_CAP 1130 /* Allow hardware rates to cap pacing rate */
+#define TCP_PACING_RATE_CAP 1131 /* Highest rate allowed in pacing in bytes per second (uint64_t) */
+#define TCP_HDWR_UP_ONLY 1132 /* Allow the pacing rate to climb but not descend (with the exception of fill-cw */
+#define TCP_RACK_ABC_VAL 1133 /* Set a local ABC value different then the system default */
+#define TCP_REC_ABC_VAL 1134 /* Do we use the ABC value for recovery or the override one from sysctl */
+#define TCP_RACK_MEASURE_CNT 1135 /* How many measurements are required in GP pacing */
+#define TCP_DEFER_OPTIONS 1136 /* Defer options until the proper number of measurements occur, does not defer TCP_RACK_MEASURE_CNT */
+#define TCP_FAST_RSM_HACK 1137 /* Do we do the broken thing where we don't twiddle the TLP bits properly in fast_rsm_output? */
+#define TCP_RACK_PACING_BETA 1138 /* Changing the beta for pacing */
+#define TCP_RACK_PACING_BETA_ECN 1139 /* Changing the beta for ecn with pacing */
/* Start of reserved space for third-party user-settable options. */
#define TCP_VENDOR SO_VENDOR
@@ -295,6 +316,7 @@ struct tcphdr {
#define TCPI_OPT_WSCALE 0x04
#define TCPI_OPT_ECN 0x08
#define TCPI_OPT_TOE 0x10
+#define TCPI_OPT_TFO 0x20
/* Maximum length of log ID. */
#define TCP_LOG_ID_LEN 64
2.35.3
