[newlib 18/65] Introduce nexthop objects and new routing KPI.
Sebastian Huber
Thu Jul 7 11:58:25 UTC 2022
From: "Alexander V. Chernikov" <melifaro at FreeBSD.org>
This is the foundational change for the routing subsytem rearchitecture.
More details and goals are available in https://reviews.freebsd.org/D24141 .
This patch introduces concept of nexthop objects and new nexthop-based
routing KPI.
Nexthops are objects, containing all necessary information for performing
the packet output decision. Output interface, mtu, flags, gw address goes
there. For most of the cases, these objects will serve the same role as
the struct rtentry is currently serving.
Typically there will be low tens of such objects for the router even with
multiple BGP full-views, as these objects will be shared between routing
entries. This allows to store more information in the nexthop.
New KPI:
struct nhop_object *fib4_lookup(uint32_t fibnum, struct in_addr dst,
uint32_t scopeid, uint32_t flags, uint32_t flowid);
struct nhop_object *fib6_lookup(uint32_t fibnum, const struct in6_addr *dst6,
These 2 function are intended to replace all all flavours of
<in_|in6_>rtalloc[1]<_ign><_fib>, mpath functions and the previous
fib[46]-generation functions.
Upon successful lookup, they return nexthop object which is guaranteed to
exist within current NET_EPOCH. If longer lifetime is desired, one can
specify NHR_REF as a flag and get a referenced version of the nexthop.
Reference semantic closely resembles rtentry one, allowing sed-style conversion.
Additionally, another 2 functions are introduced to support uRPF functionality
inside variety of our firewalls. Their primary goal is to hide the multipath
implementation details inside the routing subsystem, greatly simplifying
firewalls implementation:
int fib4_lookup_urpf(uint32_t fibnum, struct in_addr dst, uint32_t scopeid,
uint32_t flags, const struct ifnet *src_if);
int fib6_lookup_urpf(uint32_t fibnum, const struct in6_addr *dst6, uint32_t scopeid,
All functions have a separate scopeid argument, paving way to eliminating IPv6 scope
embedding and allowing to support IPv4 link-locals in the future.
Structure changes:
* rtentry gets new 'rt_nhop' pointer, slightly growing the overall size.
* rib_head gets new 'rnh_preadd' callback pointer, slightly growing overall sz.
Old KPI:
During the transition state old and new KPI will coexists. As there are another 4-5
decent-sized conversion patches, it will probably take a couple of weeks.
To support both KPIs, fields not required by the new KPI (most of rtentry) has to be
kept, resulting in the temporary size increase.
Once conversion is finished, rtentry will notably shrink.
More details:
* architectural overview: https://reviews.freebsd.org/D24141
* list of the next changes: https://reviews.freebsd.org/D24232
Reviewed by: ae,glebius(initial version)
Differential Revision: https://reviews.freebsd.org/D24232
newlib/libc/sys/rtems/include/sys/socket.h | 1 +
1 file changed, 1 insertion(+)
diff --git a/newlib/libc/sys/rtems/include/sys/socket.h b/newlib/libc/sys/rtems/include/sys/socket.h
index 30c606389..3431947cf 100644
--- a/newlib/libc/sys/rtems/include/sys/socket.h
+++ b/newlib/libc/sys/rtems/include/sys/socket.h
@@ -408,6 +408,7 @@ struct sockproto {
#define NET_RT_IFMALIST 4 /* return multicast address list */
#define NET_RT_IFLISTL 5 /* Survey interface list, using 'l'en
* versions of msghdr structs. */
+#define NET_RT_NHOP 6 /* dump routing nexthops */
#endif /* __BSD_VISIBLE */
2.35.3
