[PATCH 3/4] Use network epoch to protect local IPv4 addresses hash.
Thu Jul 7 12:01:07 UTC 2022
The modification to the hash are already naturally locked by
in_control_sx.  Convert the hash lists to CK lists. Remove the
in_ifaddr_rmlock. Assert the network epoch where necessary.
Most cases when the hash lookup is done the epoch is already entered.
Cover a few cases, that need entering the epoch, which mostly is
initial configuration of tunnel interfaces and multicast addresses.
Reviewed by:		melifaro
Differential revision:	https://reviews.freebsd.org/D32584
 cpukit/include/machine/_kernel_in.h | 4 ++++
 1 file changed, 4 insertions(+)
diff --git a/cpukit/include/machine/_kernel_in.h b/cpukit/include/machine/_kernel_in.h
index 69b189cfe0..c9dcfbd033 100644
--- a/cpukit/include/machine/_kernel_in.h
+++ b/cpukit/include/machine/_kernel_in.h
@@ -50,7 +50,11 @@ int	 in_broadcast(struct in_addr, struct ifnet *);
 int	 in_ifaddr_broadcast(struct in_addr, struct in_ifaddr *);
 int	 in_canforward(struct in_addr);
 int	 in_localaddr(struct in_addr);
+#if __FreeBSD_version >= 1400039
+bool	 in_localip(struct in_addr);
+#else
 int	 in_localip(struct in_addr);
+#endif
 int	 in_ifhasaddr(struct ifnet *, struct in_addr);
 struct in_ifaddr *in_findlocal(uint32_t, bool);
 int	 inet_aton(const char *, struct in_addr *); /* in libkern */
2.35.3
