[PATCH] bsps/microblaze: Fix build option definition order
Fri Jul 8 02:06:12 UTC 2022
On Thu, Jul 7, 2022, 7:42 PM Chris Johns <chrisj at rtems.org> wrote:
> On 8/7/2022 5:26 am, Joel Sherrill wrote:
> > I'm ok with this but since you said Sebastian committed something which
> broke
> > this, it would be good for him to ack as well.
> > Are there other BSPs which might have this issue?
> I am also wondering this. There is another patch Duc posted for ARM and
> compiler
> flags that I have not seen.
> Would your builder catch any issues?
Your builder? :)
There was an RTEMS bsp builder run from a few days ago with odd failures. I
don't remember if I poked Alex or not but the Microblaze was failing.
https://lists.rtems.org/pipermail/build/2022-July/034727.html
There are a few others but I don't think there are related to this.
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220707/e9edd700/attachment.htm>
