[PATCH v2] irq/arm-gicv3.h: Customize ICC_IGRPEN0/1 init
Fri Jul 8 08:15:06 UTC 2022
On 08.07.22 09:55, Chris Johns wrote:
> I have finally managed to test this patch and it does not work on a
> secure/non-secure Versal. I did a `distclean configure` and rebuild so it would
> pick up the option changes.
> The `BSP_ARM_GIC_ICC_IGRPEN0 write is still in the build and it is a secure access:
>    /* Initialize the group 0 and 1 interrupt enable */
> #ifdef BSP_ARM_GIC_ICC_IGRPEN0
>    WRITE_SR(ICC_IGRPEN0, BSP_ARM_GIC_ICC_IGRPEN0);
>      103e7e5c:   52800020        mov     w0, #0x1                        // #1
>      103e7e60:   d518ccc0        msr     icc_igrpen0_el1, x0
> #endif
Sorry, the variants pattern was wrong. It should be:
diff --git a/spec/build/bsps/optarmgic-icc-igrpen0.yml
b/spec/build/bsps/optarmgic-icc-igrpen0.yml
index 5acd37617d..29a4d7ad51 100644
--- a/spec/build/bsps/optarmgic-icc-igrpen0.yml
+++ b/spec/build/bsps/optarmgic-icc-igrpen0.yml
@@ -9,7 +9,7 @@ default: 1
  default-by-variant:
  - value: null
    variants:
-  - aarch64
+  - aarch64/.*
  description: |
    Optionally, defines the initial value of the ICC_IGRPEN0 register of
the ARM
    GIC CPU Interface.
I will fix this in v3.
> I tested this piece of code and it is OK:
> #ifdef BSP_ARM_GIC_ICC_IGRPEN1
>    WRITE_SR(ICC_IGRPEN1, BSP_ARM_GIC_ICC_IGRPEN1);
>      103e7e64:   d518cce0        msr     icc_igrpen1_el1, x0
> #endif
> Why is this register conditional because I think it is always needed?
I don't know.
> I think the default for BSP_ARM_GIC_ICC_IGRPEN0 should be disabled.
Yes, for aarch64.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
