[PATCH v3 4/5] bsps/stm32f4: Add GPIO implementation for STM32F4
Duc Doan
dtbpkmte at gmail.com
Fri Jul 8 10:54:05 UTC 2022
bsps/arm/stm32f4/gpio/gpio.c | 555 ++++++++++++++++++
bsps/arm/stm32f4/include/bsp.h | 4 -
bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h | 37 ++
bsps/arm/stm32f4/include/bsp/stm32f4_hal.h | 17 +
bsps/arm/stm32f4/start/bspstart.c | 7 +-
bsps/arm/stm32f4/start/bspstarthook.c | 8 +
spec/build/bsps/arm/stm32f4/grp.yml | 6 +-
spec/build/bsps/arm/stm32f4/obj.yml | 1 +
spec/build/bsps/arm/stm32f4/optengpio.yml | 16 +
.../build/bsps/arm/stm32f4/optnumgpioctrl.yml | 16 +
10 files changed, 658 insertions(+), 9 deletions(-)
create mode 100644 bsps/arm/stm32f4/gpio/gpio.c
create mode 100644 bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h
create mode 100644 bsps/arm/stm32f4/include/bsp/stm32f4_hal.h
create mode 100644 spec/build/bsps/arm/stm32f4/optengpio.yml
create mode 100644 spec/build/bsps/arm/stm32f4/optnumgpioctrl.yml
diff --git a/bsps/arm/stm32f4/gpio/gpio.c b/bsps/arm/stm32f4/gpio/gpio.c
new file mode 100644
index 0000000000..d7cac7fd58
--- /dev/null
+++ b/bsps/arm/stm32f4/gpio/gpio.c
@@ -0,0 +1,555 @@
+ * @file
+ * @ingroup rtems_bsp/arm/stm32f4
+ * @brief RTEMS GPIO new API implementation for STM32F4.
+ * @note RTEMS_GPIO_PINMODE_BSP_SPECIFIC is Alternate mode for STM32F4 BSP
+ * Copyright (c) 2022 Duc Doan <dtbpkmte at gmail.com>
+#include <bsp.h>
+#include <rtems.h>
+#include <bsp/stm32f4_gpio.h>
+#include <stdlib.h>
+/*********** Helpers *****************/
+ * @brief Macro to get stm32f4_gpio object from a base rtems_gpio
+ * object.
+ * This is a wrapper of RTEMS_CONTAINER_OF macro
+ * @param base The pointer to a rtems_gpio object
+ * @retval The pointer to the stm32f4_gpio object owning
+ * the specified rtems_gpio object
+#define get_gpio_from_base(base) \
+ RTEMS_CONTAINER_OF(base, stm32f4_gpio, base)
+/*********** GPIO API ***************/
+static rtems_status_code stm32f4_gpio_get(
+ uint32_t interm_pin,
+ rtems_gpio **out
+static rtems_status_code stm32f4_gpio_destroy(
+ rtems_gpio *base
+static rtems_status_code stm32f4_gpio_init(
+ rtems_gpio *base
+static rtems_status_code stm32f4_gpio_deinit(
+ rtems_gpio *base
+static rtems_status_code stm32f4_gpio_set_pin_mode(
+ rtems_gpio *base,
+ rtems_gpio_pin_mode mode
+static rtems_status_code stm32f4_gpio_set_pull(
+ rtems_gpio *base,
+ rtems_gpio_pull pull
+static rtems_status_code stm32f4_gpio_configure_interrupt(
+ rtems_gpio *base,
+ rtems_gpio_isr isr,
+ void *arg,
+ rtems_gpio_interrupt_trig trig,
+static rtems_status_code stm32f4_gpio_remove_interrupt(
+ rtems_gpio *base
+static rtems_status_code stm32f4_gpio_enable_interrupt(
+ rtems_gpio *base
+static rtems_status_code stm32f4_gpio_disable_interrupt(
+ rtems_gpio *base
+static rtems_status_code stm32f4_gpio_read(
+ rtems_gpio *base,
+ rtems_gpio_pin_state *value
+static rtems_status_code stm32f4_gpio_write(
+ rtems_gpio *base,
+ rtems_gpio_pin_state value
+static rtems_status_code stm32f4_gpio_toggle(
+ rtems_gpio *base
+ * @brief STM32F4 GPIO handlers
+static const rtems_gpio_handlers stm32f4_gpio_handlers = {
+ .init = stm32f4_gpio_init,
+ .deinit = stm32f4_gpio_deinit,
+ .set_pin_mode = stm32f4_gpio_set_pin_mode,
+ .set_pull = stm32f4_gpio_set_pull,
+ .configure_interrupt = stm32f4_gpio_configure_interrupt,
+ .remove_interrupt = stm32f4_gpio_remove_interrupt,
+ .enable_interrupt = stm32f4_gpio_enable_interrupt,
+ .disable_interrupt = stm32f4_gpio_disable_interrupt,
+ .read = stm32f4_gpio_read,
+ .write = stm32f4_gpio_write,
+ .toggle = stm32f4_gpio_toggle
+static GPIO_TypeDef * const GPIOx[] = {
+ GPIOA, GPIOB, GPIOC, GPIOD, GPIOE,
+ GPIOF, GPIOG, GPIOH, GPIOI,
+#ifdef STM32F429X
+ GPIOJ, GPIOK
+#endif /* STM32F429X */
+static unsigned int const EXTIx_IRQn[] = {
+ EXTI0_IRQn,
+ EXTI1_IRQn,
+ EXTI2_IRQn,
+ EXTI3_IRQn,
+ EXTI4_IRQn,
+ EXTI9_5_IRQn,
+ EXTI9_5_IRQn,
+ EXTI9_5_IRQn,
+ EXTI9_5_IRQn,
+ EXTI9_5_IRQn,
+ EXTI15_10_IRQn,
+ EXTI15_10_IRQn,
+ EXTI15_10_IRQn,
+ EXTI15_10_IRQn,
+ EXTI15_10_IRQn,
+ EXTI15_10_IRQn
+ * @brief Converts intermediate pin number to port pointer.
+ * Intermediate pin number is a way of numerically labeling
+ * pins. Pins are labeled incrementally across all ports.
+ * Pins 0-15 from port A are 0-15. Pins 0-15 from port B are
+ * 16-31. And so on.
+ * @param interm_pin is the intermediate pin number
+#define STM32F4_GET_PORT(interm_pin) (GPIOx[ ( interm_pin ) / 16 ])
+ * @brief Converts intermediate pin number to 0-15.
+#define STM32F4_GET_PIN_0_15(interm_pin) (( interm_pin ) % 16)
+ * @brief Converts pin number from 0-15 to HAL pin mask.
+ * @param pin is the pin number from 0-15
+#define STM32F4_GET_HAL_GPIO_PIN(pin) ((uint16_t) (1 << ( pin )))
+ * @brief Get EXTI Line from pin number 0-15
+#define STM32F4_GET_LL_EXTI_LINE(pin) (0x1UL << ( pin ))
+ * @brief Get EXTI IRQ number from pin 0-15
+#define STM32F4_GET_EXTI_IRQn(pin) (EXTIx_IRQn[( pin )])
+/************** Interrupt manager *****************/
+typedef struct {
+ void *arg;
+ stm32f4_gpio *gpio;
+} stm32f4_interrupt_arg;
+typedef struct {
+ stm32f4_interrupt_arg arg;
+ rtems_gpio_isr isr;
+} stm32f4_interrupt;
+static stm32f4_interrupt isr_table[16];
+void exti_handler(void *arg);
+/********** STM32F4 GPIO API functions ************/
+rtems_status_code bsp_gpio_register_controllers(
+ void
+ return rtems_gpio_register(
+ stm32f4_gpio_get,
+ stm32f4_gpio_destroy,
+ sizeof(GPIOx)/sizeof(GPIOx[0])*16
+rtems_status_code stm32f4_gpio_get(
+ rtems_gpio **out
+ stm32f4_gpio *tmp = malloc(sizeof(stm32f4_gpio));
+ if (tmp == NULL) {
+ return RTEMS_NO_MEMORY;
+ tmp->base = (rtems_gpio) { .handlers = &stm32f4_gpio_handlers };
+ tmp->pin = STM32F4_GET_PIN_0_15(interm_pin);
+ tmp->port = STM32F4_GET_PORT(interm_pin);
+ *out = (rtems_gpio *) tmp;
+ return RTEMS_SUCCESSFUL;
+rtems_status_code stm32f4_gpio_destroy(
+ rtems_gpio *base
+ stm32f4_gpio *gpio = get_gpio_from_base(base);
+ free(gpio);
+rtems_status_code stm32f4_gpio_init(rtems_gpio *base) {
+ switch ((uintptr_t) gpio->port) {
+ case (uintptr_t) GPIOA:
+ __HAL_RCC_GPIOA_CLK_ENABLE();
+ break;
+ case (uintptr_t) GPIOB:
+ __HAL_RCC_GPIOB_CLK_ENABLE();
+ break;
+ case (uintptr_t) GPIOC:
+ __HAL_RCC_GPIOC_CLK_ENABLE();
+ break;
+ case (uintptr_t) GPIOD:
+ __HAL_RCC_GPIOD_CLK_ENABLE();
+ break;
+ case (uintptr_t) GPIOE:
+ __HAL_RCC_GPIOE_CLK_ENABLE();
+ break;
+ case (uintptr_t) GPIOF:
+ __HAL_RCC_GPIOF_CLK_ENABLE();
+ break;
+ case (uintptr_t) GPIOG:
+ __HAL_RCC_GPIOG_CLK_ENABLE();
+ break;
+ case (uintptr_t) GPIOH:
+ __HAL_RCC_GPIOH_CLK_ENABLE();
+ break;
+ case (uintptr_t) GPIOI:
+ __HAL_RCC_GPIOI_CLK_ENABLE();
+ break;
+#ifdef STM32F429X
+ case (uintptr_t) GPIOJ:
+ __HAL_RCC_GPIOJ_CLK_ENABLE();
+ break;
+ case (uintptr_t) GPIOK:
+ __HAL_RCC_GPIOK_CLK_ENABLE();
+ break;
+ default:
+ return RTEMS_UNSATISFIED;
+rtems_status_code stm32f4_gpio_deinit(rtems_gpio *base) {
+ __HAL_RCC_GPIOA_CLK_DISABLE();
+ break;
+ __HAL_RCC_GPIOB_CLK_DISABLE();
+ break;
+ __HAL_RCC_GPIOC_CLK_DISABLE();
+ break;
+ __HAL_RCC_GPIOD_CLK_DISABLE();
+ break;
+ __HAL_RCC_GPIOE_CLK_DISABLE();
+ break;
+ __HAL_RCC_GPIOF_CLK_DISABLE();
+ break;
+ __HAL_RCC_GPIOG_CLK_DISABLE();
+ break;
+ __HAL_RCC_GPIOH_CLK_DISABLE();
+ break;
+ __HAL_RCC_GPIOI_CLK_DISABLE();
+ break;
+#ifdef STM32F429X
+ __HAL_RCC_GPIOJ_CLK_DISABLE();
+ break;
+ __HAL_RCC_GPIOK_CLK_DISABLE();
+ break;
+#endif
+ default:
+ return RTEMS_NOT_IMPLEMENTED;
+rtems_status_code stm32f4_gpio_set_pin_mode(
+ rtems_gpio *base,
+ uint32_t pin_mask = STM32F4_GET_HAL_GPIO_PIN(gpio->pin);
+ uint32_t stm32f4_mode, stm32f4_output_type;
+ switch (mode) {
+ case RTEMS_GPIO_PINMODE_OUTPUT_PP:
+ stm32f4_mode = LL_GPIO_MODE_OUTPUT;
+ stm32f4_output_type = LL_GPIO_OUTPUT_PUSHPULL;
+ break;
+ case RTEMS_GPIO_PINMODE_OUTPUT_OD:
+ stm32f4_output_type = LL_GPIO_OUTPUT_OPENDRAIN;
+ break;
+ case RTEMS_GPIO_PINMODE_INPUT:
+ stm32f4_mode = LL_GPIO_MODE_INPUT;
+ break;
+ case RTEMS_GPIO_PINMODE_ANALOG:
+ stm32f4_mode = LL_GPIO_MODE_ANALOG;
+ break;
+ case RTEMS_GPIO_PINMODE_BSP_SPECIFIC:
+ stm32f4_mode = LL_GPIO_MODE_ALTERNATE;
+ break;
+ default:
+ /* illegal argument */
+ LL_GPIO_SetPinMode(gpio->port, pin_mask, stm32f4_mode);
+ if (stm32f4_mode == LL_GPIO_MODE_OUTPUT) {
+ LL_GPIO_SetPinOutputType(gpio->port, pin_mask, stm32f4_output_type);
+rtems_status_code stm32f4_gpio_set_pull(
+ rtems_gpio *base,
+ uint32_t stm32f4_pull;
+ switch (pull) {
+ case RTEMS_GPIO_NOPULL:
+ stm32f4_pull = LL_GPIO_PULL_NO;
+ break;
+ case RTEMS_GPIO_PULLUP:
+ stm32f4_pull = LL_GPIO_PULL_UP;
+ break;
+ case RTEMS_GPIO_PULLDOWN:
+ stm32f4_pull = LL_GPIO_PULL_DOWN;
+ break;
+ default:
+ /* Illegal argument */
+ LL_GPIO_SetPinPull(gpio->port, pin_mask, stm32f4_pull);
+rtems_status_code stm32f4_gpio_configure_interrupt(
+ rtems_gpio *base,
+ void *arg,
+ // configure pin
+ GPIO_InitTypeDef hal_conf;
+ switch (trig) {
+ case RTEMS_GPIO_INT_TRIG_NONE:
+ case RTEMS_GPIO_INT_TRIG_FALLING:
+ hal_conf.Mode = GPIO_MODE_IT_FALLING;
+ break;
+ case RTEMS_GPIO_INT_TRIG_RISING:
+ hal_conf.Mode = GPIO_MODE_IT_RISING;
+ break;
+ case RTEMS_GPIO_INT_TRIG_BOTH_EDGES:
+ hal_conf.Mode = GPIO_MODE_IT_RISING_FALLING;
+ break;
+ default:
+ /* Invalid argument */
+ switch (pull) {
+ hal_conf.Pull = GPIO_NOPULL;
+ break;
+ hal_conf.Pull = GPIO_PULLUP;
+ break;
+ hal_conf.Pull = GPIO_PULLDOWN;
+ break;
+ default:
+ hal_conf.Pin = pin_mask;
+ HAL_GPIO_Init(gpio->port, &hal_conf);
+ // RTEMS interrupt config
+ isr_table[gpio->pin] = (stm32f4_interrupt){
+ .arg = {
+ .arg = arg,
+ .gpio = gpio
+ .isr = isr
+ rtems_option opt = gpio->pin < 5 ?
+ RTEMS_INTERRUPT_UNIQUE :
+ RTEMS_INTERRUPT_SHARED;
+ rtems_status_code sc = rtems_interrupt_handler_install(
+ STM32F4_GET_EXTI_IRQn(gpio->pin),
+ NULL,
+ opt,
+ exti_handler,
+ &isr_table[gpio->pin].arg
+ return sc;
+rtems_status_code stm32f4_gpio_remove_interrupt(
+ rtems_gpio *base
+ rtems_status_code sc = rtems_interrupt_handler_remove(
+ exti_handler,
+ if (sc == RTEMS_SUCCESSFUL) {
+ isr_table[gpio->pin] = (stm32f4_interrupt){0};
+ return sc;
+rtems_status_code stm32f4_gpio_enable_interrupt(
+ rtems_gpio *base
+ LL_EXTI_EnableIT_0_31(STM32F4_GET_LL_EXTI_LINE(gpio->pin));
+rtems_status_code stm32f4_gpio_disable_interrupt(
+ rtems_gpio *base
+ LL_EXTI_DisableIT_0_31(STM32F4_GET_LL_EXTI_LINE(gpio->pin));
+rtems_status_code stm32f4_gpio_write(
+ rtems_gpio *base,
+ if (value)
+ LL_GPIO_SetOutputPin(gpio->port, STM32F4_GET_HAL_GPIO_PIN(gpio->pin));
+ else
+ LL_GPIO_ResetOutputPin(gpio->port, STM32F4_GET_HAL_GPIO_PIN(gpio->pin));
+rtems_status_code stm32f4_gpio_read(
+ rtems_gpio *base,
+ *value = LL_GPIO_IsInputPinSet(
+ gpio->port,
+ STM32F4_GET_HAL_GPIO_PIN(gpio->pin)
+rtems_status_code stm32f4_gpio_toggle(
+ rtems_gpio *base
+ LL_GPIO_TogglePin(
+ gpio->port,
+void exti_handler(void *arg) {
+ stm32f4_interrupt_arg *stm32_arg = (stm32f4_interrupt_arg *) arg;
+ uint32_t pin_mask = STM32F4_GET_HAL_GPIO_PIN(stm32_arg->gpio->pin);
+ if(__HAL_GPIO_EXTI_GET_IT(pin_mask) != RESET)
+ __HAL_GPIO_EXTI_CLEAR_IT(pin_mask);
+ (*isr_table[stm32_arg->gpio->pin].isr)(stm32_arg->arg);
diff --git a/bsps/arm/stm32f4/include/bsp.h b/bsps/arm/stm32f4/include/bsp.h
index 42a74e109d..968545cd5a 100644
--- a/bsps/arm/stm32f4/include/bsp.h
+++ b/bsps/arm/stm32f4/include/bsp.h
@@ -42,10 +42,6 @@ extern "C" {
#define BSP_ARMV7M_SYSTICK_FREQUENCY STM32F4_HCLK
-#ifdef __rtems__
-void Error_Handler(void);
-#endif /* __rtems__ */
#ifdef __cplusplus
#endif /* __cplusplus */
diff --git a/bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h b/bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h
index 0000000000..8f21539709
--- /dev/null
+++ b/bsps/arm/stm32f4/include/bsp/stm32f4_gpio.h
@@ -0,0 +1,37 @@
+#ifndef LIBBSP_ARM_STM32F4_BSP_GPIO
+#define LIBBSP_ARM_STM32F4_BSP_GPIO
+#include <stdbool.h>
+#include <stm32f4xx.h>
+#include <stm32f4xx_ll_gpio.h>
+#include <stm32f4xx_ll_exti.h>
+#include <bsp/gpio2.h>
+ * @brief STM32F4 BSP GPIO structure
+typedef struct {
+ * @brief This member is a rtems_gpio object.
+ rtems_gpio base;
+ *@brief This member is the pin number from 0 to 15.
+ uint32_t pin;
+ * @brief This member is HAL GPIOx pointer.
+ GPIO_TypeDef *port;
+} stm32f4_gpio;
+#endif /* LIBBSP_ARM_STM32F4_BSP_GPIO */
diff --git a/bsps/arm/stm32f4/include/bsp/stm32f4_hal.h b/bsps/arm/stm32f4/include/bsp/stm32f4_hal.h
index 0000000000..9e88b39067
--- /dev/null
+++ b/bsps/arm/stm32f4/include/bsp/stm32f4_hal.h
@@ -0,0 +1,17 @@
+#ifndef LIBBSP_ARM_STM32F4_BSP_STM32F4HAL_H
+#define LIBBSP_ARM_STM32F4_BSP_STM32F4HAL_H
+#include <stm32f4xx_hal.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+void stm32f4_clk_enable();
+void stm32f4_clk_disable();
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/arm/stm32f4/start/bspstart.c b/bsps/arm/stm32f4/start/bspstart.c
index 8589c6486c..84e8ee7c94 100644
--- a/bsps/arm/stm32f4/start/bspstart.c
+++ b/bsps/arm/stm32f4/start/bspstart.c
@@ -19,6 +19,7 @@
#ifdef __rtems__
#ifdef STM32F4_FAMILY_F4XXXX
@@ -46,7 +47,7 @@ uint32_t HAL_GetTick(void)
* @brief This function is executed in case of error occurrence.
* @retval None
+static void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
@@ -166,7 +167,6 @@ static rtems_status_code SystemClock_Config(void)
HAL_StatusTypeDef status = HAL_RCC_OscConfig(&RCC_OscInitStruct);
if (status != HAL_OK)
-// Error_Handler();
@@ -181,7 +181,6 @@ static rtems_status_code SystemClock_Config(void)
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, flash_latency) != HAL_OK)
@@ -465,7 +464,7 @@ void bsp_start( void )
init_main_osc();
-#ifdef __rtems__
+#ifndef __rtems__
stm32f4_gpio_set_config_array( &stm32f4_start_config_gpio[ 0 ] );
diff --git a/bsps/arm/stm32f4/start/bspstarthook.c b/bsps/arm/stm32f4/start/bspstarthook.c
index bbfaed615e..7f5f85c67a 100644
--- a/bsps/arm/stm32f4/start/bspstarthook.c
+++ b/bsps/arm/stm32f4/start/bspstarthook.c
@@ -20,4 +20,12 @@ void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
bsp_start_clear_bss();
/* At this point we can use objects outside the .start section */
+#ifdef __rtems__
+#if STM32F4_ENABLE_GENERIC_GPIO == 1
+ bsp_gpio_register_controllers();
+#endif /* STM32F4_ENABLE_GENERIC_GPIO */
+#endif /* __rtems__ */
diff --git a/spec/build/bsps/arm/stm32f4/grp.yml b/spec/build/bsps/arm/stm32f4/grp.yml
index 99a78e1890..99b3a10527 100644
--- a/spec/build/bsps/arm/stm32f4/grp.yml
+++ b/spec/build/bsps/arm/stm32f4/grp.yml
@@ -17,9 +17,11 @@ links:
- role: build-dependency
uid: abi
- uid: obj
+ uid: optnumgpioctrl
uid: optenhal
+- role: build-dependency
+ uid: optengpio
uid: optvariant
@@ -66,6 +68,8 @@ links:
uid: ../../objirq
uid: ../../objmem
+ uid: obj
uid: ../../bspopts
type: build
diff --git a/spec/build/bsps/arm/stm32f4/obj.yml b/spec/build/bsps/arm/stm32f4/obj.yml
index 7afe000024..172643b700 100644
--- a/spec/build/bsps/arm/stm32f4/obj.yml
+++ b/spec/build/bsps/arm/stm32f4/obj.yml
@@ -261,6 +261,7 @@ source:
- bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c
- bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c
- bsps/arm/stm32f4/hal/system_stm32f4xx.c
+- bsps/arm/stm32f4/gpio/gpio.c
- bsps/arm/shared/irq/irq-armv7m.c
- bsps/arm/shared/irq/irq-dispatch-armv7m.c
- bsps/arm/shared/start/bsp-start-memcpy.S
diff --git a/spec/build/bsps/arm/stm32f4/optengpio.yml b/spec/build/bsps/arm/stm32f4/optengpio.yml
index 0000000000..8b15bce9a9
--- /dev/null
+++ b/spec/build/bsps/arm/stm32f4/optengpio.yml
@@ -0,0 +1,16 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2022 Duc Doan (dtbpkmte at gmail.com)
+default: true
+default-by-variant: []
+description: |
+ This option enables the BSP to use RTEMS GPIO API.
+enabled-by: true
+format: '{}'
+links: []
+name: STM32F4_ENABLE_GENERIC_GPIO
+type: build
diff --git a/spec/build/bsps/arm/stm32f4/optnumgpioctrl.yml b/spec/build/bsps/arm/stm32f4/optnumgpioctrl.yml
index 0000000000..da21d9c62c
--- /dev/null
+++ b/spec/build/bsps/arm/stm32f4/optnumgpioctrl.yml
@@ -0,0 +1,16 @@
+actions:
+- get-integer: null
+- define: null
+build-type: option
+copyrights:
+default: 1
+description: |
+ Number of GPIO controllers of this BSP.
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_GPIO_NUM_CONTROLLERS
+type: build
2.36.1
