[PATCH 23/23] bsps/m68k/uC5282: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Jul 8 14:02:50 UTC 2022
Updates #3053.
bsps/m68k/uC5282/start/bspreset.c | 25 ++++++++++++++++++++++---
bsps/m68k/uC5282/start/start.S | 25 ++++++++++++++++++++++---
2 files changed, 44 insertions(+), 6 deletions(-)
diff --git a/bsps/m68k/uC5282/start/bspreset.c b/bsps/m68k/uC5282/start/bspreset.c
index b93fbb409f..eedfb9bb0c 100644
--- a/bsps/m68k/uC5282/start/bspreset.c
+++ b/bsps/m68k/uC5282/start/bspreset.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2008.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
diff --git a/bsps/m68k/uC5282/start/start.S b/bsps/m68k/uC5282/start/start.S
index 63ac62e15d..4149159d78 100644
--- a/bsps/m68k/uC5282/start/start.S
+++ b/bsps/m68k/uC5282/start/start.S
@@ -1,3 +1,5 @@
* uC5282 startup code
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-1998.
+ * are met:
#include <rtems/asm.h>
2.24.4
