[PATCH 01/35] bsps/mips/shared: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Mon Jul 11 22:36:13 UTC 2022
Updates #3053.
bsps/mips/shared/clock/clockdrv.c | 25 ++++++++++++++++++++---
bsps/mips/shared/irq/interruptmask.c | 25 ++++++++++++++++++++---
bsps/mips/shared/irq/interruptmask_TX49.c | 25 ++++++++++++++++++++---
bsps/mips/shared/irq/isr_entries.S | 25 ++++++++++++++++++++---
bsps/mips/shared/irq/vectorexceptions.c | 25 ++++++++++++++++++++---
5 files changed, 110 insertions(+), 15 deletions(-)
diff --git a/bsps/mips/shared/clock/clockdrv.c b/bsps/mips/shared/clock/clockdrv.c
index f1074a652a..ed420fb5eb 100644
--- a/bsps/mips/shared/clock/clockdrv.c
+++ b/bsps/mips/shared/clock/clockdrv.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2013.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <bsp.h>
diff --git a/bsps/mips/shared/irq/interruptmask.c b/bsps/mips/shared/irq/interruptmask.c
index c63421e569..1d4588697b 100644
--- a/bsps/mips/shared/irq/interruptmask.c
+++ b/bsps/mips/shared/irq/interruptmask.c
@@ -1,3 +1,5 @@
* @file
@@ -7,9 +9,26 @@
* COPYRIGHT (c) 1989-2012.
+ * are met:
diff --git a/bsps/mips/shared/irq/interruptmask_TX49.c b/bsps/mips/shared/irq/interruptmask_TX49.c
index 5b1daa57c3..9f9ce2ad6c 100644
--- a/bsps/mips/shared/irq/interruptmask_TX49.c
+++ b/bsps/mips/shared/irq/interruptmask_TX49.c
@@ -1,3 +1,5 @@
* @file
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/bsps/mips/shared/irq/isr_entries.S b/bsps/mips/shared/irq/isr_entries.S
index 2e3791cab2..f3bba8b737 100644
--- a/bsps/mips/shared/irq/isr_entries.S
+++ b/bsps/mips/shared/irq/isr_entries.S
@@ -1,12 +1,31 @@
* This file contains the raw entry points for the exceptions.
* COPYRIGHT (c) 1989-2000.
+ * are met:
#include <rtems/asm.h>
diff --git a/bsps/mips/shared/irq/vectorexceptions.c b/bsps/mips/shared/irq/vectorexceptions.c
index cdfd94c136..f1ce26a6ec 100644
--- a/bsps/mips/shared/irq/vectorexceptions.c
+++ b/bsps/mips/shared/irq/vectorexceptions.c
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
